With sandbox it is tricky to add an FDT to the image at build time (or
later) since we build an ELF file, not a plain binary, and the address
space of the whole U-Boot is not accessible in the emulated memory map
of sandbox.
Sandbox can read files directly from the host, though, so add an option
to read an FDT from a host file on start-up.
Add generic board support for sandbox. and remove the old board init code.
Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported.
Reviewed-by: Tom Rini <trini@ti.com>
In many cases, pointers to memory are passed around, and these pointers
refer to U-Boot memory, not host memory. This in itself is not a
problem.
However, in a few places, we cast that pointer back to a ulong (being
a U-Boot memory address). It is possible to convert many of these cases
to avoid this. However there are data structures (e.g. struct
bootm_headers) which use pointers. We could with a lot of effort adjust
the structs and all code that uses them to use ulong instead of pointers.
This seems like an unacceptable cost, since our objective with sandbox
is to minimise the impact on U-Boot code while maximising the features
available to sandbox.
Therefore, create a map_to_sysmem() function which converts from a
pointer to a U-Boot address. This can be used sparingly when needed.
Watchdog can be used on Microblaze, PPC and Zynq hw designs.
This patch adds SPL booting support (NOR flash) for the
PPC4xx platforms.
This SPL booting (Falcon mode) will be used by the upcoming
lcd4_lwmon5 board port (lwmon5 variant).
Quick manual fixup to merge the USB boot related defines and TPM related
defines.
include/configs/exynos5250-dt.h
The current code is causing errors like this on my toolchains:
/usr/x86_64-pc-linux-gnu/armv7a-cros-linux-gnueabi/binutils-bin/2.22/
ld.bfd.real: failed to merge target specific data of file /usr/lib/gcc/
armv7a-cros-linux-gnueabi/4.7.x-google/libgcc.a(_divdi3.o)
Use do_div() to avoid this.
The intention of the memory init code is that it should work the same with
CONFIG_SYS_GENERIC_BOARD and without. This is tricky because dram_init()
is called prior to relocation with generic board (matching other archs)
and after relocation without generic board.
Adjust the init sequence so that dram_init() is not called in the generic
board case, which seems like the easiest fix for now. Also ensure that
relocation addresses are still calculated.
As suggested by Stephen Warren, use tegra_get_chip() to return
the pure CHIPID for a Tegra SoC (i.e. 0x20 for Tegra20, 0x30 for
Tegra30, etc.) and rename tegra_get_chip_type() to reflect its true
function, i.e. tegra_get_chip_sku(), which returns an ID like
TEGRA_SOC_T25, TEGRA_SOC_T33, etc.
Signed-off-by: Tom Warren <twarren@nvidia.com>
A comparison of registers between our internal NV U-Boot and
u-boot-tegra/next showed some discrepancies in the MSELECT
clock divisor programming. T20 doesn't have a MSELECT clk src reg.
T114 needs the SYSCTR0 counter initialized so the TSC can be
read by the kernel. Do it in the bootloader since it's a write-once
deal (secure/non-secure mode dependent).
Without this change, kernel fails at calling function cache_clean_flush
during kernel early boot.
Aprocryphally, intended for T114 only, so I check for a T114 SoC.
Works (i.e. dalmore 3.8 kernel now starts printing to console).
A start vector fix was added by AneeshV for OMAP4 (commit 0d479b53),
and caused the old monilithic Tegra builds to hang due to an undefined
instruction trap. Previously, the code needed to run on both the
AVP (ARM7TDI) and A9, and the AVP doesn't have a CP15 register.
I corrected this in commit 6d6c0bae w/#ifndef CONFIG_TEGRA, but
now that we use SPL, and boot the AVP w/o any ARMv7 code, I can
revert my change, and make Aneesh's change apply to Tegra.
Make U-Boot aware of the T33 SKU of Tegra30, and treat it identically
to any other Tegra30.
An alternative would be to simply remove the SKU checking from
tegra_get_chip_type(); most use of the value most likely simply wants
to know the current chip, not the specific SKU. Or, the function could
be split into separate tegra_get_chip() and tegra_get_sku() for the
cases where differentiation really is required.
I wonder whether tegra_get_chip_type() should printf() whenever any
unkown chip/SKU is found, although perhaps the function is called so
early that the printf() wouldn't actually make it to the UART anyway.
The KVM and Xen hypervisors for the Cortex-A15 virtualization
implementation need to be entered in HYP mode. Should the primary
board firmware already enter HYP mode (Calxeda firmware does that),
we should not deliberately drop back to SVC mode.
Since U-boot does not use the MMU, running in HYP mode is just fine.
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Remove SPL-related ASSERT() in arch/arm/cpu/u-boot.lds
as this file is never used for SPL builds.
Rewrite the ASSERT() in arch/arm/cpu/u-boot-spl.lds
to separately test image (text,data,rodata...) size,
BSS size, and full footprint each against its own max,
and make Tegra boards check full footprint.
Also, output section mmutable is not used in SPL builds.
Remove it.
Finally, update README regarding the (now homogeneous)
semantics of CONFIG_SPL_[BSS_]MAX_SIZE and add the new
CONFIG_SPL_MAX_FOOTPRINT macro.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Commit 3ebd1cbc introduced compiler-generated __bss_start
and __bss_end__ and commit c23561e7 rewrote all __bss_end__
as __bss_end. Their merge caused silent and harmless but
potentially bug-inducing clashes between compiler- and linker-
generated __bss_end symbols.
Make __bss_end and __bss_start compiler-only, and create
__bss_base and __bss_limit for linker-only use.
The glitch in the SPI clock line, which commit 3cea335c34 (spi: mxc_spi: Fix spi
clock glitch durant reset) solved, is back now and itwas re-introduced by
commit d36b39bf0d (spi: mxc_spi: Fix ECSPI reset handling).
Actually the glitch is happening due to always toggling between slave mode
and master mode by configuring the CHANNEL_MODE bits in this reset function.
Since the spi driver only supports master mode, set the mode for all channels
always to master mode in order to have a stable, "glitch-free" SPI clock line.
When swi instruction is executed, it is expected to get message
"software interrupt" in console and dump registers and reboot, as
do_software_interrupt() in arch/arm/lib/interrupts.c.
But, actually it causes data abort accessing wrong address in get_bad_stack_swi
macro in arch/arm/cpu/v7/start.S.
This patch fixes this problem.
The same mistake in arch/arm/cpu/{arm1136,arm1176,pxa}/start.S.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
drivers/video/exynos_fb.c
The processor is hopefully running with M(ega)Hz and not with m(illi)Hz.
Signed-off-by: Manfred Huber <man.huber@arcor.de>
The previous timings were done on the internal-only A1 board which has
different DDR part than all later revs. The timings need a slight
adjustment to be correct in all cases with later revs.
Let all ARM linker scripts handle properly -ffunction-sections
and -fdata-sections. This will be useful for future changes in order to create
symbol-specific sections in common .S files.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Following the removal of the smdk6400 board, the MMU setup code in
arm1176/start.S becomes unused, so remove it. It will still be possible to
restore it later from the Git history if necessary, in which case it should be
moved out of the relocate_code() function.
Following the removal of the smdk6400 board, the s3c64xx SoC becomes unused, so
remove associated code. It will still be possible to restore it later from the
Git history if necessary.
The migration of boards from Makefile to boards.cfg was due for v2012.03, but
smdk6400 did not follow, and it does not build, so move it to scrapyard. It will
still be possible to restore it from the Git history before fixing it.
This image combines the SPL with the i.MX header, the FCB and U-Boot.
For i.MX25/35/51, the FCB is ignored by the boot ROM, so this image is just
useful because it can be programmed on a NAND Flash page boundary.
For i.MX53, the FCB is required by the boot ROM.
This does not support i.MX6 so far because its FCB is more complicated.
This image combines the SPL with the i.MX header and U-Boot. This is a
convenient way of having a single image to program on some boot devices.
The i.MX header has to be added to the SPL before appending U-Boot, so that the
boot ROM loads only the SPL.
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of
ARM's relocate_code() useless since it moved the code handling them to crt0.S.
So, drop these parameters.
This also fixes support for mx31pdk and tx25, which had been broken by commit
e05e5de7fae5bec79617e113916dac6631251156.
Acked-by: Scott Wood <scottwood@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Automatically build the 'u-boot.imx' (i.e. imx header + u-boot.bin) and 'SPL'
(i.e. imx header + u-boot-spl.bin) make targets for all imx processors
supporting this header, so for arm926ejs, arm1136 and armv7. Some combinations
were missing.
At the same time, fix the build of SPL targets not supporting the imx header on
arm1136. For arm1136, the 'SPL' make target was forced to build in all cases if
CONFIG_SPL_BUILD was defined, even for non-imx platforms or imx setups without
an imx header.
The purpose of .globl is to export symbols for ld, not to declare external
symbols.
By the way, use the ENTRY() and ENDPROC() macros to define functions rather than
using .global directly.
Use __image_copy_end instead of __bss_start for the end of the image to
relocate. This is the same as commit 033ca72, but applied to all ARM start.S.
This is a more appropriate symbol naming for an image copy & relocate feature,
and this also saves a useless copy of data put between __image_copy_end and
__bss_start in linker scripts (e.g. relocation information, or MMU
initialization tables used only before jumping to the relocated image).
Commit e05e5de7fae5bec79617e113916dac6631251156 made ARM's relocate_code()
return to its caller, but it did not update its declaration accordingly.
Fixing this function declaration fixes dropped C code following calls to
relocate_code().
_TEXT_BASE must be set to CONFIG_SPL_TEXT_BASE for generic SPL, and to
CONFIG_SYS_TEXT_BASE for non-SPL builds.
Don't use several instructions to build constant values.
The function get_timer() should return time in ms and CONFIG_SYS_HZ
should be set to 1000 by default. Fix both of these items.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
The omap4460_volts struct was incorrectly referencing tps62361
instead of twl6030 as PMIC for the core and mm voltages (the
tps is used for mpu supply only). This shall lead to bad OPP
settings while booting kernel. Fixing it.
Fix some comments as well.
Signed-off-by: Lubomir Popov <lpopov@mm-sol.com>
If watchdog is enabled, the arch/powerpc/lib/ticks.S::wait_ticks() function
calls the function specified by the WATCHDOG_RESET macro.
The wait_ticks function depends on the registers r0, r6 and r7 being
preserved however that is not guaranteed, e.g. if the reset function is a
C function this will probably overwrite r0 and cause an endless loop.
The following patch changes to using r14+r15 instead of r6+r7 (to resemble
what would have been generated by a C compiler) and saves all necessary
registers on the stack.
The patch has been tested on a custom MPC5125 based machine using the 512x
powerpc architecture.
Signed-off-by: Mats Karrman <mats.karrman@tritech.se>
Acked-by: Joakim Tjernlund <joakim.tjernlund@transmode.se>
Tested-by: Stefan Roese <sr@denx.de>
After further testing we can run DDR at 400MHz so update the timings
again.
Tested-by: Koen Kooi <koen@dominion.thruhere.net>
