path: root/arch
2013-02-15Merge branch 'fixes' of git://git.denx.de/u-boot-mipsTom Rini
2013-02-15MIPS: board.c: remove manual relocation of env_name_specDaniel Schwierzeck
Remove the manual relocation of env_name_spec. This has been missed in the previous patch series for introducing dynamic relocation on MIPS. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-14x86: Remove unused real mode codeSimon Glass
This code is pretty old and we want to support only 32-bit systems now. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2013-02-14x86: Rename CONFIG_NO_X86_RESET_VECTOR to CONFIG_X86_RESET_VECTORSimon Glass
Invert the polarity of this option to simplify the Makefile logic. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Gabe Black <gabeblack@chromium.org>
2013-02-14x86: Remove sc520 cpuSimon Glass
This x86 CPU variant is no longer required as the boards that use it have been removed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2013-02-12Merge branch 'next' of git://git.denx.de/u-boot-mipsTom Rini
2013-02-12MIPS: add dynamic relocation supportGabor Juhos
The code handles relocation entries with the following relocation types only: mips32: R_MIPS_REL32 mips64: R_MIPS_REL+R_MIPS_64 xburst: R_MIPS_REL32 Other relocation entries are skipped without processing. The code must be extended if other relocation types must be supported. Add -pie to LDFLAGS_FINAL to generate the .rel.dyn fixup table, which will be applied to the relocated image before transferring control to it. The CONFIG_NEEDS_MANUAL_RELOC is not needed after the patch, so remove that as well. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: u-boot.lds: add relocation specific sectionsGabor Juhos
This section contain the table needed for dynamic relocation. Also provide symbols for the relocation code to access the table. Discard all sections which are not needed in the final ELF binary and U-Boot image. Section .dynsym cannot be discarded or GNU ld crashes otherwise. This section will be stripped by GNU objcpy in a later patch. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: start.S: use symbol __image_copy_end for U-Boot image relocationDaniel Schwierzeck
Use the newly introduced symbol __image_copy_end as end address for relocation of U-Boot image. This is needed for dynamic relocation added in later patches. This patch obsoletes the symbols uboot_end and uboot_end_data which are removed. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: start.S: optimize BSS initializationDaniel Schwierzeck
Get the start and end address for clearing BSS from the newly introduced symbols __bss_start and __bss_end. After GOT is relocated, those symbols are already pointing to the correct addresses. Also optimize the loop by moving the address incrementation to the delay slot to avoid the initial sub instruction. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: board.c: switch to new symbols __bss_end and __image_copy_endDaniel Schwierzeck
Use the newly introduced symbols __image_copy_end and __bss_end for setting up the memory area for the relocated U-Boot. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: u-boot.lds: introduce symbol __image_copy_endDaniel Schwierzeck
This symbol is used in later patches as end address for relocation of the U-Boot image into RAM. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: u-boot.lds: merge all BSS sections and introduce symbols __bss_[start|end]Daniel Schwierzeck
These symbols are used in later patches for as addresses for clearing the BSS area in the relocated U-Boot image. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: compute num_got_entries from .got section's sizeGabor Juhos
The '__got_start' and '__got_end' symbols are used only in the linker script to compute the value of the 'num_got_entries' symbol. Remove the symbols and use the SIZEOF(.got) command to get the size of the .got section. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-02-12MIPS: start.S: unify and simplify reset vector handlingDaniel Schwierzeck
Adopt reset vector handling from Yamon. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-02-12MIPS: start.S: remove obsolete 64 bit handling in setup_c0_statusDaniel Schwierzeck
2013-02-12MIPS: xburst: fix broken access to global_dataDaniel Schwierzeck
Fix access to global_data which is broken since commits: commit 035cbe99cd2fd4adf9d7fd95aeebb5f814e37eb9 Author: Simon Glass <sjg@chromium.org> Date: Thu Dec 13 20:49:08 2012 +0000 mips: Move per_clk and dev_clk to arch_global_data Move these field into arch_global_data and tidy up. The other CONFIG_JZSOC fields are used by various architectures, so just remove the #ifdef bracketing for these. Signed-off-by: Simon Glass <sjg@chromium.org> commit 582601da2f90b1850aa19f7820b1623c79b3dac6 Author: Simon Glass <sjg@chromium.org> Date: Thu Dec 13 20:48:35 2012 +0000 arm: Move lastinc to arch_global_data Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> commit 66ee69234795c0596f84b25f06b7fbc2e8ed214c Author: Simon Glass <sjg@chromium.org> Date: Thu Dec 13 20:48:34 2012 +0000 arm: Move tbl to arch_global_data Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Xiangfu Liu <xiangfu@openmobilefree.net>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-11arm: fix CONFIG_DELAY_ENVIRONMENT to act like it claims in the READMELucas Stach
No one expects to end up in a delayed environment if CONFIG_DELAY_ENVIRONMENT isn't defined. Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Allen Martin <amartin@nvidia.com>
2013-02-11Tegra114: Dalmore: Add DT filesTom Warren
These are stripped down for bringup, They'll be filled out later to match-up with the kernel DT contents, and/or as devices are brought up (mmc, usb, spi, etc.). Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra114: Add common CPU (shared) filesTom Warren
These files are used by both SPL and main U-Boot. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra114: Add CPU (armv7) filesTom Warren
These files are for code that runs on the CPU (A15) on T114 boards. At this time, there is no A15-specific code here. As T114-specific run-time code is added, it'll go here. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra114: Add AVP (arm720t) filesTom Warren
This provides SPL support for T114 boards - AVP early init, plus CPU (A15) init/jump to main U-Boot. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra114: Add arch-tegra114 include filesTom Warren
Common Tegra files are in arch-tegra, shared between T20/T30/T114. Tegra114-specific headers are in arch-tegra114. Note that some of these will be filled in as more T114 support is added (drivers, WB/LP0 support, etc.). Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-02-11tegra: add SPI SLINK driverAllen Martin
Add driver for tegra SPI "SLINK" style driver. This controller is similar to the tegra20 SPI "SFLASH" controller. The difference is that the SLINK controller is a genernal purpose SPI controller and the SFLASH controller is special purpose and can only talk to FLASH devices. In addition there are potentially many instances of an SLINK controller on tegra and only a single instance of SFLASH. Tegra20 is currently ths only version of tegra that instantiates an SFLASH controller. This driver supports basic PIO mode of operation and is configurable (CONFIG_OF_CONTROL) to be driven off devicetree bindings. Up to 4 devices per controller may be attached, although typically only a single chip select line is exposed from tegra per controller so in reality this is usually limited to 1. To enable this driver, use CONFIG_TEGRA_SLINK Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: add addresses of SPI SLINK controllersAllen Martin
Add I/O addresses of SPI SLINK controllers 1-6 Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra30: fdt: add SPI SLINK nodesAllen Martin
Add tegra30 SPI SLINK nodes to fdt. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra30: add SBC1 to periph id mapping tableAllen Martin
SBC1 is SPI controller 1 on tegra30 Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra20: fdt: add SPI SFLASH nodeAllen Martin
Add node for tegra20 SPI SFLASH controller to fdt. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: rename FUNCMUX_UART2_UARTBStephen Warren
FUNCMUX_ defines should be named after the pin groups they affect, not after the module they're muxing onto those pin groups. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra: Move common clock code to arch/arm/cpu/tegra-common/clock.cTom Warren
This 'commonizes' much of the clock/pll code. SoC-dependent code and tables are left in arch/cpu/tegraXXX-common/clock.c Some T30 tables needed whitespace fixes due to checkpatch complaints. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra: T20: Remove unused 'SLOW' SoC ID and PLLX table entryTom Warren
2013-02-08Clean up libfdt.h includesGerald Van Baren
The libfdt.h file is the definition file for libfdt. It is unnecessary to include other fdt header files (the necessary ones are pulled in by libfdt.h). Signed-off-by: Gerald Van Baren <gvb@unssw.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2013-02-07common/fdt_support.c: sparse fixesKim Phillips
trivial: fdt_support.c:89:64: warning: Using plain integer as NULL pointer fdt_support.c:325:65: warning: Using plain integer as NULL pointer fdt_support.c:352:65: warning: Using plain integer as NULL pointer For the following bad constant expression, We hardcode the max. number of memory banks to four for the foreseeable future, and add an error with instructions on what to do once it's exceeded: fdt_support.c:397:22: error: bad constant expression For the rest below, sparse found a couple of wrong endian conversions in of_bus_default_translate() and fdt_get_base_address(), but otherwise the rest is mostly annotation fixes: fdt_support.c:64:24: warning: cast to restricted __be32 fdt_support.c:192:21: warning: incorrect type in assignment (different base types) fdt_support.c:192:21: expected unsigned int [unsigned] [usertype] tmp fdt_support.c:192:21: got restricted __be32 [usertype] <noident> fdt_support.c:201:21: warning: incorrect type in assignment (different base types) fdt_support.c:201:21: expected unsigned int [unsigned] [addressable] [usertype] tmp fdt_support.c:201:21: got restricted __be32 [usertype] <noident> fdt_support.c:304:13: warning: incorrect type in assignment (different base types) fdt_support.c:304:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:304:13: got restricted __be32 [usertype] <noident> fdt_support.c:333:13: warning: incorrect type in assignment (different base types) fdt_support.c:333:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:333:13: got restricted __be32 [usertype] <noident> fdt_support.c:359:13: warning: incorrect type in assignment (different base types) fdt_support.c:359:13: expected unsigned int [unsigned] [usertype] val fdt_support.c:359:13: got restricted __be32 [usertype] <noident> fdt_support.c:373:21: warning: cast to restricted __be32 fdt_support.c:963:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:963:48: expected restricted __be32 const [usertype] *p fdt_support.c:963:48: got unsigned int [usertype] *<noident> fdt_support.c:971:48: warning: incorrect type in argument 1 (different base types) fdt_support.c:971:48: expected restricted __be32 const [usertype] *p fdt_support.c:971:48: got unsigned int [usertype] *<noident> fdt_support.c:984:29: warning: incorrect type in argument 1 (different base types) fdt_support.c:984:29: expected restricted __be32 const [usertype] *cell fdt_support.c:984:29: got unsigned int [usertype] *addr fdt_support.c:996:32: warning: incorrect type in argument 1 (different base types) fdt_support.c:996:32: expected restricted __be32 const [usertype] *cell fdt_support.c:996:32: got unsigned int [usertype] *addr fdt_support.c:1041:41: warning: incorrect type in argument 1 (different base types) fdt_support.c:1041:41: expected restricted __be32 const [usertype] *cell fdt_support.c:1041:41: got unsigned int [usertype] *addr fdt_support.c:1053:41: warning: incorrect type in argument 2 (different base types) fdt_support.c:1053:41: expected restricted __be32 const [usertype] *range fdt_support.c:1053:41: got unsigned int const [usertype] *[assigned] ranges fdt_support.c:1064:53: warning: incorrect type in argument 2 (different base types) fdt_support.c:1064:53: expected restricted __be32 const [usertype] *addr fdt_support.c:1064:53: got unsigned int [usertype] *addr fdt_support.c:1110:50: warning: incorrect type in argument 2 (different base types) fdt_support.c:1110:50: expected restricted __be32 const [usertype] *addr fdt_support.c:1110:50: got unsigned int *<noident> fdt_support.c:1121:49: warning: incorrect type in argument 1 (different base types) fdt_support.c:1121:49: expected restricted __be32 const [usertype] *cell fdt_support.c:1121:49: got unsigned int *<noident> fdt_support.c:1147:60: warning: incorrect type in argument 2 (different base types) fdt_support.c:1147:60: expected restricted __be32 const [usertype] *addr fdt_support.c:1147:60: got unsigned int *<noident> fdt_support.c:1081:5: warning: symbol '__of_translate_address' was not declared. Should it be static? fdt_support.c:1154:5: error: symbol 'fdt_translate_address' redeclared with different type (originally declared at include/fdt_support.h:95) - incompatible argument 3 (different base types) fdt_support.c: In function 'fdt_node_offset_by_compat_reg': fdt_support.c:1173:17: warning: initialization discards 'const' qualifier from pointer target type [enabled by default] See also linux kernel commit 0131d897 "of/address: use proper endianess in get_flags". Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07treewide: include libfdt_env.h before fdt.hKim Phillips
and, if including libfdt.h which includes libfdt_env.h in the correct order, don't include fdt.h before libfdt.h. this is needed to get the fdt type definitions set from the project environment before fdt.h uses them. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Jerry Van Baren <gvb.uboot@gmail.com>
2013-02-07Add DDR3 support for AM335x-EVM (Version 1.5A)Jeff Lance
AM335x EVM 1.5A uses Micron MT41J512M8RH-125 SDRAM 4Gb (512Mx8) as the DDR3 chip. [Hebbar Gururaja <gururaja.hebbar@ti.com>] - Resolve merge conflict while rebasing. File structure is changed in the mainline. So re-arrange the code accordingly. - Update commit message to reflect the DDR3 part number Signed-off-by: Jeff Lance <j-lance1@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07am33xx: add a pulldown macro to pinmux configLars Poeschel
2013-02-04Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2013-02-04x86: Use generic global_dataSimon Glass
Move x86 over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04sparc: Use generic global_dataSimon Glass
Move sparc over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04sh: Use generic global_dataSimon Glass
Move sh over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04sandbox: Use generic global_dataSimon Glass
Move sandbox over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04powerpc: Use generic global_dataSimon Glass
Move powerpc over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04openrisc: Use generic global_dataSimon Glass
Move openrisc over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04nios2: Use generic global_dataSimon Glass
Move nios2 over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Thomas Chou <thomas@wytron.com.tw>
2013-02-04nds32: Use generic global_dataSimon Glass
Move nds32 over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04mips: Use generic global_dataSimon Glass
Move mips over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04microblaze: Use generic global_dataSimon Glass
Move microblaze over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Michal Simek <monstr@monstr.eu>
2013-02-04m68k: Use generic global_dataSimon Glass
Move m68k over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
