path: root/arch
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-29Merge branch 'for-v2013.04'Anatolij Gustschin
Conflicts: drivers/video/Makefile Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-28Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/spi/tegra20_sflash.c include/fdtdec.h lib/fdtdec.c
2013-03-28armv7: do not relocate _start twiceVincent Stehlé
The _start symbol is already relocated, so do not add the relocation the second time in c_runtime_cpu_setup. This fixes e.g. the abort exception handling path, which ended in double fault due to bad address in VBAR. Signed-off-by: Vincent Stehlé <v-stehle@ti.com> Reported-by: Lubomir Popov <lpopov@mm-sol.com>
2013-03-28ARM: mmu: Set domain permissions to client accessR Sricharan
The 'XN' execute never bit is set in the pagetables. This will prevent speculative prefetches to non executable regions. But the domain permissions are set as master in the DACR register. So the pagetable attribute for 'XN' is not effective. Change the permissions to client. This fixes lot of speculative prefetch aborts seen on OMAP5 secure devices. Signed-off-by: R Sricharan <r.sricharan@ti.com> Tested-by: Vincent Stehle <v-stehle@ti.com> Cc: Vincent Stehle <v-stehle@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-28ARM: mmu: Introduce weak dram_bank_setup functionR Sricharan
Introduce a weak version of dram_bank_setup function to allow a platform specific function. This is used in the subsequent patch to setup dram region without 'XN' attribute in order to enable the region under client permissions. Signed-off-by: R Sricharan <r.sricharan@ti.com> Cc: Vincent Stehle <v-stehle@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-28ARM: cache: declare set_section_dcacheVincent Stehlé
We declare the set_section_dcache function globally in the cache header, for later use by e.g. machine specific code. Signed-off-by: Vincent Stehlé <v-stehle <at> ti.com> Cc: Tom Rini <trini <at> ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-26Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-26Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-25Tegra114: Dalmore: Add SDIO3 pad config to pinctrl_config tableTom Warren
SDIO1 (the SD-card slot on Dalmore) needs to have its pads setup before the MMC driver is added. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25Tegra114: fdt: Add SDMMC (sdhci) nodes for T114 boards (Dalmore for now)Tom Warren
Took these values directly from the kernel dts files. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra114: add SPI driverAllen Martin
Add driver for tegra114 SPI controller. This controller is not compatible with either the tegra20 or tegra30 controllers, so it requires a new driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra114: fdt: add SPI blocksAllen Martin
Add nodes for t114 SPI controller hardware Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra114: fdt: add apbdma blockAllen Martin
Add node for apbdma controller hardware. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25spi: add common fdt SPI driver interfaceAllen Martin
Add a common interface to fdt based SPI drivers. Each driver is represented by a table entry in fdt_spi_drivers[]. If there are multiple SPI drivers in the table, the first driver to return success from spi_init() will be registered as the SPI driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: spi: pull register structs out of headersAllen Martin
Move register structs from headers into .c files and use common name. This is in preparation of making common fdt front end for SPI drivers. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: spi: rename tegra SPI driversAllen Martin
Rename tegra SPI drivers to tegra20_flash and tegra20_slink in preparation for commonization and addition of tegra114_spi. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-25tegra: remove support for UART SPI switchAllen Martin
This feature was only used for tegra20 seaboard that had a pinmux conflict on the SPI pins. These boards were never manufactured, so remove this support to clean up SPI driver. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-24Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-24arm: Correct CONFIG_STANDALONE_LOAD_ADDR for AM33XX/OMAP* platformsTom Rini
All of these platforms have memory starting at 0x80000000, so this is the correct CONFIG_STANDALONE_LOAD_ADDR for all of them. Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am335x_evm: Add better timings for the new BeagleBoard DDR3 partTom Rini
Tested-by: Rao Bodapati <rao@circuitco.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24ti814x_evm: add ti814x evm board supportMatt Porter
Add TI814X EVM board directory, config file, and MAINTAINERS entry. Enable build. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com> [trini: Adapt to recent omap_hsmmc requirements, Matt re-tested] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: support ti814x mmc reference clockMatt Porter
TI814x has a 192MHz hsmmc reference clock. Select that clock rate when building for TI814x. Signed-off-by: Matt Porter <mporter@ti.com>
2013-03-24am33xx: add dmm support to emif4 libraryMatt Porter
Adds a config_dmm() routine to support TI814X DMM configuration. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: add ti814x specific register definitionsMatt Porter
Support the ti814x specific register definitions within arch-am33xx. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: refactor am33xx mux support and add ti814x supportMatt Porter
AM33XX and TI814X have a similar mux though the pinmux register layout and address space differ. Add a separate ti814x mux include to support the TI814X-specific differences. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-03-24am33xx: refactor am33xx clocks and add ti814x supportMatt Porter
Split clock.c for am335x and ti814x and add ti814x specific clock support. Signed-off-by: Matt Porter <mporter@ti.com>
2013-03-24am33xx: refactor emif4/ddr to support multiple EMIF instancesMatt Porter
The AM33xx emif4/ddr support closely matches what is need to support TI814x except that TI814x has two EMIF instances. Refactor all the emif4 helper calls and the config_ddr() init function to use an additional instance number argument. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: convert defines from am33xx-specific to generic namesMatt Porter
Eliminate AM33xx specific names to prepare for TI814x support within AM33xx-land. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: Add required includes to some omap/am33xx codeTom Rini
- In arch/arm/cpu/armv7/omap-common/timer.c, drivers/mtd/nand/omap_gpmc.c and drivers/net/cpsw.c add #include files that the driver needs but had been relying on <config.h> to bring in. - In arch/arm/cpu/armv7/omap-common/lowlevel_init.S add <config.h> - In am335x_evm.h and pcm051.h don't globally include <asm/arch/hardware.h> and <asm/arch/cpu.h> but just <asm/arch/omap.h> as that is the only include which defines things the config uses. Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24ARM: AM33XX: Fix typo that causes an AM duplication in CPU name.Enric Balletbo i Serra
Just fix a typo displaying the CPU info. With CONFIG_DISPLAY_INFO we see something like AMAM335X-GP rev 0 instead of AM335X-GP rev 0. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
2013-03-24am335x: Enable DDR PHY dynamic power down bit for DDR3 boardsVaibhav Hiremath
Enable DDR PHY dynamic power down bit, which enables powering down the IO receiver when not performing read. This also helps in reducing overall power consumption in low power states (suspend/standby). Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Satyanarayana, Sandhya <sandhya.satyanarayana@ti.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-22ARM: implement erratum 716044 workaroundStephen Warren
Add common code to enable the workaround for ARM erratum 716044. This will be enabled for Tegra. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-03-22am33xx:ddr:Fix config_sdram to work for all DDRSteve Kipisz
The original write to sdram_config is correct for DDR3 but incorrect for DDR2 so SPL was hanging. For DDR2, the write to sdram_config should be after the writes to ref_ctrl. This was working for DDR3 because there was a write of 0x2800 to ref_ctrl before a write to sdram_config. Tested on: GP EVM 1.1A (DDR2), GP EVM 1.5A (DDR3), Beaglebone A6 (DDR2), Beagleone Blacd A4A (DDR3) Signed-off-by: Steve Kipisz <s-kipisz2@ti.com>
2013-03-22Initialise correct GPMC WAITx irq for AM33xxMark Jackson
Currently WAIT0 irq is reset and then WAIT1 irq is enabled. Fix it such that WAIT0 irq is enabled instead. Signed-off-by: Mark Jackson <mpfj@newflow.co.uk> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-03-22Allow AM335x MPU core clock speed to be specified in the board config fileMark Jackson
Allow AM335x MPU core clock speed to be specified in the board config file. To use, add the following to the board's config file:- #define CONFIG_SYS_MPUCLK <desired clock freq in MHz> Signed-off-by: Mark Jackson <mpfj@newflow.co.uk> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-03-21lcd, pxafb: move the pxafb to drivers/videoJeroen Hofstee
Since the lcd code was compiled unconditionally for pxa also add CONFIG_PXA_LCD to the boards using this framebuffer. Since driver/video contains video and lcd drivers, add lcd to the name to make clear it belongs to common/lcd.c. cc: Anatolij Gustschin <agust@denx.de> cc: Cliff Brake <cliff.brake@gmail.com> cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21lcd, mpc8xx: move the mpc8xx driver to drivers/videoJeroen Hofstee
Since the lcd code was compiled unconditionally in arch also add CONFIG_MPC8XX_LCD to the boards using this driver. cc: Anatolij Gustschin <agust@denx.de> cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-03-21common/lcd.c: cleanup use of global variablesWolfgang Denk
lcd_color_fg and lcd_color_bg had to be declared in board specific code, but were not actually used there; in addition, we have getter / setter functions for these, which were not used either. Get rid of the global variables, and use the getter function where needed (so far no setter calls are needed). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Alessandro Rubini <rubini@unipv.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Bo Shen <voice.shen@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Simon Glass <sjg@chromium.org> Cc: Stelian Pop <stelian@popies.net> Cc: Tom Warren <twarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl> [agust: also fixed cm_t35 board while rebasing] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-03-20ARM: rpi_b: enable SD controller, add related env/cmdsStephen Warren
Enable the SD controller driver for the Raspberry Pi. Enable a number of useful MMC, partition, and filesystem-related commands. Set up the environment to provide standard locations for loading a kernel, DTB, etc. Provide a boot command that loads and executes boot.scr.uimg from the SD card; this is written considering future extensibilty to USB storage. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-03-20mmc: add bcm2835 driverStephen Warren
This adds a simple driver for the BCM2835's SD controller. Workarounds are implemented for: * Register writes can't be too close to each-other in time, or they will be lost. * Register accesses must all be 32-bit, so implement custom accessors. This code was extracted from: git://github.com/gonzoua/u-boot-pi.git master which was created by Oleksandr Tymoshenko. Portions of the code there were obviously based on the Linux kernel at: git://github.com/raspberrypi/linux.git rpi-3.6.y commit f5b930b "Main bcm2708 linux port" signed-off-by Dom Cobley. swarren changed the following for upstream: * Removed hack udelay()s in bcm2835_sdhci_raw_writel(); setting SDHCI_QUIRK_WAIT_SEND_CMD appears to solve the issues. * Remove register logging from read*/write* functions. * Sort out confusion with min/max_freq values passed to add_sdhci(). * Use more descriptive variable names and calculations in IO accessors. * Simplified and commented twoticks_delay calculation. * checkpatch fixes. Cc: Andy Fleming <afleming@gmail.com> Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Andy Fleming <afleming@gmail.com>
2013-03-20ARM: bcm2835: add mailbox driverStephen Warren
The BCM2835 SoC contains (at least) two CPUs; the VideoCore (a/k/a "GPU") and the ARM CPU. The ARM CPU is often thought of as the main CPU. However, the VideoCore actually controls the initial SoC boot, and hides much of the hardware behind a protocol. This protocol is transported using the SoC's mailbox hardware module. Here, we add a very simplistic driver for the mailbox module, and define a few structures for the property messages. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-03-19x86: Move PCI init before SPI initSimon Glass
It is possible that our PCI bus will provide the SPI controller, so change the init order to make this work. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15sparc: Fix build warnings in serial.cSimon Glass
These macros are already defined in io.h so should not be declared in serial.c. serial.c:38:0: warning: "READ_BYTE" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:36:0: note: this is the location of the previous definition serial.c:39:0: warning: "READ_HWORD" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:37:0: note: this is the location of the previous definition serial.c:40:0: warning: "READ_WORD" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:38:0: note: this is the location of the previous definition serial.c:41:0: warning: "READ_DWORD" redefined /home/sjg/c/src/third_party/u-boot/files/include/asm/io.h:39:0: note: this is the location of the previous definition Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15sparc: Fix out-of-tree buildingSimon Glass
It isn't clear why the sparc cpu Makefile has its own compile line, but it does not work correctly with an out-of-tree build. Removing it fixes this problem. Perhaps it does not introduce others. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15avr32: Fix cast warning in board.cSimon Glass
The frame buffer pointer in global_data is not a pointer, so we should remove these casts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-15blackfin: Remove noreturn attribute from cpu_init_f()Simon Glass
Now that board_init_f() is not marked as noreturn, we need to do the same to blackfin's cpu_init_f() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15blackfin: Fix up board_type global dataSimon Glass
This should be in arch_global_data but was dropped in the change-over. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15x86: Enable generic boardSimon Glass
This will be used exclusively on x86, so enable it for the whole architecture. Signed-off-by: Simon Glass <sjg@chromium.org>
