Add the required node describing how to find the EC on link.
GDT limit should be one less than an integral multiple of eight.
When building U-Boot with CONFIG_X86_RESET_VECTOR, the linking
process misses the resetvec.o and start16.o so it cannot generate
the rom version of U-Boot. The arch/x86/cpu/Makefile is updated to
pull them into the final linking process.
If we are passing this using the device tree then we may not want to
set this up here.
The x86 bootm code is quite special, and geared to zimage. Adjust it
to support device tree and make it more like the ARM code, with
separate bootm stages and functions for each stage.
Create a function announce_and_cleanup() to handle printing the
"Starting kernel ..." message and put it in bootm so it is in one
place and can be used by any loading code. Also move the
board_final_cleanup() function into bootm.
These options are used by the image code. To allow us to use the generic
code more easily, define these for x86.
By default, PAMU's (IOMMU) are enabled in case of secure boot.
Disable/bypass them once the control reaches the bootloader.
For non-secure boot, PAMU's are already bypassed in the default
SoC configuration.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Hardware accelerated support for SHA-1 and SHA-256 has been added.
Hash command enabled along with hardware accelerated support for
SHA-1 and SHA-256 for platforms which have CAAM block.
SHA-256 and SHA-1 accelerated using SEC hardware in Freescale SoC's
The driver for SEC (CAAM) IP is based on linux drivers/crypto/caam.
The platforms needto add the MACRO CONFIG_FSL_CAAM inorder to
enable initialization of this hardware IP.
SEC registers can be of type Little Endian or big Endian depending upon
Freescale SoC. Here SoC defines the register type of SEC IP.
So update acessor functions with common SEC acessor functions to take care
both type of endianness.
Freescale SEC controller has been used for mpc8xxx. It will be used
for ARM-based SoC as well. This patch moves the CCSR defintion of
SEC to common include
These boards have been orphaned for more than 6 months.
This board has been orphaned for more than 6 months.
It is the last board defining CONFIG_APM821XX.
The code inside #ifdef CONFIG_APM821XX should be removed too.
The definitions for div ratio supposed to be in hex and were added
in dec by mistake.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
scsi_scan() must be called as part of scsi_init() and not
as part of sata_init().
Signed-off-by: Roger Quadros <rogerq@ti.com>
On OMAP platforms, SATA controller provides the SCSI subsystem
so implement scsi_init().
Get rid of the unnecessary sata_init() call from dra7xx-evm
and omap5-uevm board files.
rmobile/lowlevel_init_ca15.S are common in r8a7790, r8a7791 and r8a7794 of
rmobile SoCs. The initialize L2 cache in lowlevel_init_ca15.S only needed
for Cortex-A15. The r8a7794 is Cortex-A7, not Cortex-A15.
This adds Skip to initialize L2 cache when r8a7794.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
rmobile/lowlevel_init_ca15.S are common in r8a7790 and r8a7791 of
rmobile SoC. But L2 cache of r8a7791 does not use L2CTLR[5].
This adds fix to set L2CTLR [5] only when the r8a7790.
This removes duplicate initialization of l2ctlr.
The single file conflict below is actually trivial.
board/boundary/nitrogen6x/nitrogen6x.c
Move cache handling code to C file, and add enable_caches() and
disable_caches() functions.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Change this board to add a device tree.
This also adds a pinmux header file although it is not used as yet.
Most of the smdkv310 features are common with other exynos4 boards. To
permit easier addition of driver model support, use the common file and
add a device tree file.
Add a keyboard definition so that the keyboard can be used on pit.
The device seems to hang in SPL if the full speed is used when booting from
USB, perhaps because the PMIC has not been set to the maximum ARM core
voltage yet. Slow it down to a reliable speed.
Removed settings in unsupported register fields. They didn’t
do anything, and in most cases, were not documented in the
reference manual.
Changed register settings to comply with JEDEC required values.
Changed timing parameters because they included full clock
periods that were doing nothing.
Signed-off-by: Anthony Felice <tony.felice@timesys.com>
[rebased on v2014.10-rc2]
Signed-off-by: Stefan Agner <stefan@agner.ch>
Add command to enable and disable the bridges between HPS and FPGA.
This patch does have a checkpatch issue with the assembler portion,
checkpatch correctly complains that there should be no whitespace
before quoted newline. I do not agree that fixing this specific
checkpatch issue will improve the readability, thus this one is not
addressed.
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Move icache_enable() and dcache_enable() function calls from
board code into the CPU code and into the enable_caches()
function. This is how the cache enabling code was designed
to work.
Acked-by: Pavel Machek <pavel@denx.de>
Add code which configures the AMBA NIC-301 and the SCU on the SoCFPGA .
The code sets the access permissions for the CPU to the AMBA slaves such
that the CPU can access them in both secure and non-secure mode.
Cc: Chin Liang See <clsee@altera.com>
Configure the PL310 address filter to make sure DRAM is mapped to 0x0.
This code also configures the "remap" register of NIC-301 and sets the
required 'mpuzero' bit.
Add register definition for the NIC-301 used on SoCFPGA.
Add the Snoop Control Unit register definition file.
Add missing system manager bits from Altera U-Boot to make the code
comparable. These are the bits which depend on the FPGA manager.
Add function to enable and disable FPGA bridges. This code is used
by the FPGA manager to disable the bridges before programming the
FPGA and will later be also used by the initialization code for the
chip to put the chip into well defined state during startup.
Add code necessary to program the FPGA part of SoCFPGA from U-Boot
with an RBF blob. This patch also integrates the code into the
FPGA driver framework in U-Boot so it can be used via the 'fpga'
command.
Signed-off-by: Pavel Machek <pavel@denx.de>
V2: Move the not-CPU specific stuff into drivers/fpga/ and base
this on the cleaned up altera FPGA support.
Cosmetic change to the print_cpuinfo() function output. Align the
output with the rest of initial output produced by U-Boot.
Add CPU function to register and initialize the dw_mmc SD controller.
This allows us to use the HPS SDMMC block.
Add function to initialize the EMAC blocks upon board startup.
The preprocessor guards against building on SoCFPGA-VT and against
SPL build are not needed as those are handled implicitly via both
SPL framework and the socfpga_cyclone5.h config file, which will
not define CONFIG_DESIGNWARE_ETH if building for SoCFPGA-VT.
We cannot handle two EMAC ethernet blocks yet, therefore the ifdefs.
Once there is hardware using both EMAC blocks, this ifdef will have
to go.
Add functions to reset the EMAC ethernet blocks. We cannot handle
two EMAC ethernet blocks yet, therefore the ifdefs. Once there is
hardware using both EMAC blocks, this ifdef will have to go.
The timer reload value is a property of the timer hardware and there
is no reason for this to be configurable. Place this into the timer
driver just like on the other hardware.
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add the missing pieces from the reference clock code from Altera. This
puts the code on par with the Altera U-Boot fork for all but the SDRAM
self-refresh bits, which are not part of this patch.
Clean up the clock code definitions so they are aligned with mainline
standards. There are no functional changes in this patch.
Pull out functions to read frequency of Main clock VCO and
PLL clock VCO as the code is duplicated multiple times.
