originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with
the 5235 processor. The registers in struct fbcs are different sizes from
those in the 5235. Also, the defines are a little different.
This is what I have so far. Comments?
Reformat the patch manually by Jason Jin
Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
This patch adds a driver for Freescale Colfire Queued SPI bus.
Coded to work with 8 bits per transfer to use with SPI flash.
CPOL, CPHA, and CS_ACTIVE_HIGH can be configured.
Tested with MCF5270 which have 4 chip selects.
Activate by #define CONFIG_CF_QSPI in board config.
Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
This patch uses the general ffs definition to replace the
platform ffs definition.
This patch also fixes the build error by adding hweightN
definition for m5329evb and m5373evb.
This board is the only board that still sticks to OneNAND IPL.
Remove this board, since we have SPL around for a while and
OneNAND is well supported in the SPL framework. The board can
be revived if necessary.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: u-boot-dm@lists.denx.de
Constants set with binary value (0b...) are not compiled
from old toolchain when used by the clrsetbits_le32 macro.
Replaces them with the corresponding hex value.
The error reported (for example with the mx6qsabrelite board)
is something like:
mx6qsabrelite.c:369:1: error: invalid suffix "b101" on integer constant
mx6qsabrelite.c:369:1: error: invalid suffix "b10010" on integer constant
mx6qsabrelite.c:369:1: error: invalid suffix "b0000" on integer constant
mx6qsabrelite.c:369:1: error: invalid suffix "b10001" on integer constant
Prepare for device-tree driven configuration.
Acked-by: Stephan Linz <linz@li-pro.net>
Move board specific function to board_init function in board/ folder
Remove externs from generic board.c
Use board_init_f function in board.c file.
Fix CONFIG_SYS_HZ usage in board config.
Do not use hardcoded value. Use CONFIG_SYS_HZ instead.
Separate static configuration to single block.
Just coding style cleanup.
Remove unneeded externs.
Return value to find out if un/registration was succesful.
Variable is used when CONFIG_SYS_FLASH_CHECKSUM is used.
Warning log:
board.c: In function 'board_init':
board.c:101: warning: unused variable 's'
This is minimum code required to be able to use device-tree
for u-boot initialization.
Currently only for device driver initialization.
Linker script change ensures DTB to be aligned
for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE.
CC: Simon Glass <sjg@chromium.org>
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate.
Convert tegra20_ source file and function names to tegra_, also.
Upcoming Tegra30 port will use common code/defines/names where possible.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This allows for two things:
- VBus GPIO may be used on other ports than the OTG one
- VBus GPIO may be low active if specified by DT
Signed-off-by: Lucas Stach <dev@lynxeye.de>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Tom Warren <TWarren@nvidia.com>
Up now only MX5 and MX6 can share code, because they have
a common source directory in cpu/armv7. Other not armv7
i.MX can profit of the same shared code. Move these files
into a directory accessible for all, similar to plat-mxc
in linux.
A device tree is used to configure the NAND, including memory
timings and block/pages sizes.
If this node is not present or is disabled, then NAND will not
be initialized.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Add a NAND controller along with a bindings file for review.
Add selection of NAND flash pins to the funcmux.
Define default SoC input clock frequencies for i.MX31 in order to get rid of
duplicated definitions.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Helmut Raiger <helmut.raiger@hale.at>
The MFN bit-field of the PLL registers represents a signed value. See the
reference manual.
Switch the mx35 timer driver to the 32-kHz clock source to avoid calling
mxc_get_clock() again and again, and to be consistent with the timer drivers of
other i.MX SoCs.
Define default SoC input clock frequencies for i.MX35 in order to get rid of
Define default SoC input clock frequencies for i.MX25 in order to get rid of
Cc: Matthias Weisser <weisserm@arcor.de>
The clock dividers that were used do not match at all the reference manual. They
were either completely broken, or came from an early silicon revision
incompatible with the current one.
reference manual.
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
Useless code is removed, and get buswidth value.
buswidth value will be used to choice the 4bit or 8bit.
(Now used 4bit mode in sdhci.c by default)
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Kyungmin Park <kyungin.park@samsung.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
We have the timer code in arch/arm/cpu/armv7/omap-common/timer.c that
has been configuring and enabling the timer, so remove our code that
does the same thing by different methods.
Tested on EVM GP, SK-EVM and Beaglebone.
Add a common macros to set the registers for horizontal
and vertical timing.
AM/DM37x SoCs add the CTRL_WKUP_CTRL register. It contains the
GPIO_IO_PWRDNZ bit, which is required to be set to enable the I/O pads
of gpio_126, gpio_127 and gpio_129.
Signed-off-by: Arnout Vandecappelle (Essensium/Mind) <arnout@mind.be>
The board_postclk_init() function can be used to perform operations
that requires a working timer early within the U-Boot init_sequence.
Signed-off-by: Markus Hubig <mhubig@imko.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Use proper struct-based access for this register in the SPL code.
Cc: Fabio Estevam <festevam@freescale.com>
* 'master' of git://git.denx.de/u-boot-avr32:
net:macb: add line break
avr32:portmux: fix setup for macb1
avr32: Remove redundant LDSCRIPT definition
Use portd_mask instead of portc_mask to setup the pins for port D.
