Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards
pretty much do the same thing. The only variations are in how many
controllers or DIMMs per controller exist. To make this work we
standardize on the names of the SPD_EEPROM_ADDRESS defines based on the
use case of the board.
We allow boards to override get_spd to either do board specific fixups
to the SPD data or deal with any unique behavior of how the SPD eeproms
are wired up.
Every 85xx board implements fsl_ddr_get_mem_data_rate via get_ddr_freq()
and every 86xx board uses get_bus_freq(). If implement get_ddr_freq()
as a static inline to call get_bus_freq() we can remove
fsl_ddr_get_mem_data_rate altogether and just call get_ddr_freq()
directly.
We've been utilizing board_lmb_reserve to reserve the boot page for MP
systems. We can just move this into arch_lmb_reserve for 85xx & 86xx
systems rather than duplicating in each board port.
Specify the number of DDR controllers, number of frame managers, number
of 1g and 10g ports.
In a manner similar to passing ethernet stashing parameters into device
tree for "gianfar", extend the support to the "fsl,etsec2" as well.
Signed-off-by: Pankaj Chauhan <pankaj.chauhan@freescale.com>
Signed-off-by: Sandeep Gopalpet <sandeep.kumar@freescale.com>
Remove declerations of fsl_ddr_set_memctl_regs in board files with and
place it into a common header.
Based on patch from Poonam Aggrwal.
The Integrated Flash Controller (IFC) is used to access the external
NAND Flash, NOR Flash, EPROM, SRAM and Generic ASIC memories.Four chip
selects are provided in IFC so that maximum of four Flash devices can be
hooked, but only one can be accessed at a given time.
Features supported by IFC are,
- Functional muxing of pins between NAND, NOR and GPCM
- Support memory banks of size 64KByte to 4 GBytes
- Write protection capability (only for NAND and NOR)
- Provision of Software Reset
- Flexible Timing programmability for every chip select
- NAND Machine
- x8/ x16 NAND Flash Interface
- SLC and MLC NAND Flash devices support with
configurable
page sizes of upto 4KB
- Internal SRAM of 9KB which is directly mapped and
availble at
boot time for NAND Boot
- Configurable block size
- Boot chip select (CS0) available at system reset
- NOR Machine
- Data bus width of 8/16/32
- Compatible with asynchronous NOR Flash
- Directly memory mapped
- Supports address data multiplexed (ADM) NOR device
- GPCM Machine (NORMAL GPCM Mode)
- Support for x8/16/32 bit device
- Compatible with general purpose addressable device
e.g. SRAM, ROM
- External clock is supported with programmable division
ratio
- GPCM Machine (Generic ASIC Mode)
- Address and Data are shared on I/O bus
- Following Address and Data sequences can be supported
on I/O bus
- 32 bit I/O: AD
- 16 bit I/O: AADD
- 8 bit I/O : AAAADDDD
- Configurable Even/Odd Parity on Address/Data bus
supported
Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Add the ability to determine if a given IP block connected on SERDES is
configured. This is useful for things like PCIe and SRIO since they are only
ever connected on SERDES.
Updated MPC85xx_PORDEVSR_IO_SEL & MPC85xx_PORDEVSR_IO_SEL_SHIFT
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
The P1011, P1012, P1015, P1016, P1020, P1021, P1024, & P1025 SoCs require
that we initialize the SERDES registers if the lanes are configured for
PCIe. Additionally these devices PCIe controller do not support ASPM
and we have to explicitly disable it.
Enable workaround for errata ELBC A001, ESDHC 111 & SATA A001 on
P1022/P1013 SoCs.
Also updated P1022DS config to properly enable CONFIG_FSL_SATA_V2.
Signed-off-by: Jiang Yutang <b14898@freescale.com>
The MMC registers are accessed through struct s5p_mmc member
variables. MMC controller "control4" register offset is set
to 0x8C as per data sheet. The size of struct s5p_mmc is also
corrected.
Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Use the global data instead of bss variable, replace as follow.
count_value -> removed
timestamp -> tbl
lastdec -> lastinc
Acked-by: Albert ARIBAUD <albert.aribaud@free.fr>
Use pwm functions for timer that is PWM timer 4.
This is common pwm driver of S5P.
Signed-off-by: Donghwa Lee <dh09.lee@samsung.com>
Since nand boot have some limit for the first 4KB, We only
disable the LED function to reduce the code space. At the
same time, Fix the compile error for LED function undefined
in the compile time of nand_spl.
Signed-off-by: Zhong Hongbo <bocui107@gmail.com>
Monitor protection region in FLASH did not cover .rel.dyn
and .dynsym sections, because it uses __bss_start to compute
monitor_flash_len. Use _end instead.
Add _end to linker scripts for end of u-boot image
Add _end_ofs to all the start.S.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
The fix for errata workaround is to avoid covering physical address
0xff000000 to 0xffffffff during the implementation.
Signed-off-by: York Sun <yorksun@freescale.com>
rcw_en bit is only available for DDR3 controllers. It is a reserved bit on
DDR1 and DDR2 controllers.
To recognize DIMMs with ECC capability by testing ECC bit only. Not to be
confused by Address Parity bit.
commit 8aba9dceebb14144e07d19593111ee3a999c37fc
Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS
breaks the usage of --gc-section to build nand_spl. We still need linker option
--gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes
the --gc-sections to each uboot image.
To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace
PLATFORM_LDFLAGS in the Makefile of each nand_spl board.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The start.o section is changed by --gc-section option of ld.
Of this using KEEP order, therefore, evade this problem.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Some board of SH does not have flash memoy.
This revises it to initialize Flash when CONFIG_SYS_NO_FLASH is not
defined.
There is a small ordering issue in the master core in that we need to
make sure the disabling of the timebase in the SoC is visible before we
set the value to 0. We can simply just read back the value to
synchronizatize the write, before we set TB to 0.
Reported-by: Dan Hettena
Tested-by: Dan Hettena
The POST word is stored in a spare register in the PIC on MPC8[5/6]xx
processors. When interrupt_init() is called, this register gets reset
which resulted in all POST_RAM POSTs not being ran due to the corrupted
POST word. To resolve this, store off POST word before the PIC is
reset, and restore it after the PIC has been initialized.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
Copying directly from ECM/PQ3 is not correct for how CoreNet based
platforms handle boot page translation.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
The write recovery time of both registers should match. Since mode register
doesn't support cycles of 9,11,13,15, we should use next higher number for
both registers.
This commit updates the mach-types based on the latest
in linus's head
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
get_sp() was incorrectly excluded if none of
CONFIG_SETUP_MEMORY_TAGS
CONFIG_CMDLINE_TAG
CONFIG_INITRD_TAG
CONFIG_SERIAL_TAG
CONFIG_REVISION_TAG
were defined.
This patch adds the Multiple Function Pin configuration support for
Marvell PANTHEON SoCs
Signed-off-by: Lei Wen <leiwen@marvell.com>
Pantheon Family processors are highly integrated SoCs
based on Sheeva_88SV331x-v5 PJ1 cpu core.
Ref:
http://www.marvell.com/products/processors/communications/marvell_pantheon_910_920_pb.pdf
SoC versions Supported:
1) PANTHEON920 (TD)
2) PANTHEON910 (TTC)
Since there are lots of difference between kirkwood and armada series,
it is better to seperate them but still keep the most common file
shared by all marvell platform in the mv-common configure file.
This patch move the kirkwood only driver definitoin in mv-common to
the <soc_name>/config.h.
This patch is tested with compilation for armada100 and guruplug.
Commit 3c0659b "ARM: Avoid compiler optimization for readb, writeb
and friends." introduced I/O accessors with memory barriers.
Unfortunately the new write*() accessors introduced a bug:
The problem is that the argument "v" gets evaluated twice. This
breaks code like used here (from "drivers/net/dnet.c"):
for (i = 0; i < wrsz; i++)
writel(*bufp++, &dnet->regs->TX_DATA_FIFO);
Use auxiliary variables to avoid such problems.
Cc: Albert Aribaud <albert.aribaud@free.fr>
Cc: Alexander Holler <holler@ahsoftware.de>
Cc: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Alexander Stein <alexander.stein@informatik.tu-chemnitz.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Fix ancient code which worked with MSR in a bad way.
Use rtid instruction which enable IRQs and jump.
u-boot BSP generates XILINX_USE_MSR_INSTR macro
even for system with MSR=0. That's why explicitly
check that MSR=1.
x86 has always used relocation offset in the opposite sense to the ELF
standard - Fix this
