The commit 132e5b68986d ("ARM: dts: stm32: Split AV96 into DHCOR SoM
and AV96 board") was not applied correctly and in full, and omitted
an important split of the SoM into 3V3 and 1V8 options. The Avenger96
board is based on the 1V8 IO option of the DHCOR SoM, however this is
an optional modification of the 3V3 IO DHCOR SoM with extra on-SoM
regulator to cater for the 96boards 1V8 IO requirements.
Reinstate the split between the 1V8 and 3V3 IO variants.
Fixes: 132e5b68986d ("ARM: dts: stm32: Split AV96 into DHCOR SoM and AV96 board")
Cc: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Cc: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
Use the DDR3 dtsi files generated by STM32CubeMX 5.6.0
Speed Bin Grade = using DDR3-1066G / 8-8-8 and all others
parameters at default value.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Force boot-led ON and no more rely on default-state.
This patch avoid device-tree modification for U-Boot.
Call hang when an error is detected for probe of any driver
needed for console or DDR init: clk, reset and pincontrol
NB: previous behavior with a return in board_init_f() was not correct;
DDR is not initialized and SPL execution can't continue
This command is not more depending on fuse command, but have
direct access to BSEC misc driver, so the dependency with
can be removed CMD_FUSE
Add support of RAM target in flashlayout to load kernel image
("system") and device tree ("filesystem") in DDR with DFU and
start these images.
The flashlayout.tsv is:
- 0x01 fsbl Binary none 0x00000000 tf-a.stm32
- 0x03 ssbl Binary none 0x00000000 u-boot.stm32
P 0x10 kernel System ram0 0xC2000000 uImage.bin
P 0x11 dtb FileSystem ram0 0xC4000000 dtb.bin
Support an U-Boot script included in uimage instead of flashlayout file
(text file in tsv format).
This feature is used to execute this script directly when U-Boot is
loaded in DDR (for update without STM32CubeProgrammer for example).
A simple example with dfu-util only is:
$> echo "dfu 0" > script.cmd
$> mkimage -C none -A arm -T script -d script.cmd script.uimg
$> mkimage -T stm32image -a 0xC0000000 -e 0xC0000000 -d script.uimg \
script.stm32
$> dfu-util -d 0483:df11 -a 1 -D tf-a.stm32
$> dfu-util -d 0483:df11 -a 0 -D script.stm32
$> dfu-util -d 0483:df11 -a 0 -D u-boot.stm32
$> dfu-util -d 0483:df11 -a 0 -e
Then you can used dfu-utils to update your device
To increase speed, you can also switch to fastboot protocol with:
echo "fastboot 0" > script.cmd
Enable the videoconsole during the stm32prog command execution
to have information without UART.
Add a support of UART, using the same protocol than MCU STM32.
See "AN5275: USB DFU/USART protocols used in STM32MP1 Series
bootloaders" for details.
Add a virtual partition to update the pmic non volatile memory.
(on ST board, STPMIC1).
Add a virtual partition to update the STM32MP15x OTP based
on SMC service provided by TF-A.
Add support for delete option 'D' in flashlayout for
full device or for partitions
For reliability of boot from NAND/SPI-NAND (with read-disturb issue)
the SSBL can be present several time, when it is indicated in the
flashlayout with "Binary(X)".
The received binary is copied X times by U-Boot on the target.
Dynamically adapt the MTD partitions in NOR/NAND/SPI-NAND when stm32prog
command detects in the parsed flash layout files:
- a fsbl partition in NOR.
- a tee partition in NOR/NAND/SPI-NAND
Add support of MTD device (DFU_MTD backend) for
NOR, NAND or SPI-NAND target.
Add support of partial update, update only some partitions,
and check the coherence of the layout with the existing GPT
partitions (offset and size).
Add support of eMMC device boot partition with
part_id = -1 for offset="boot1"
or = -2 for offset="boot2"
The stm32prog command configures the MMC DFU backend with "mmcpart"
and configure the eMMC (command "mmc bootbus" and "mmc partconf")
when the update is done.
Add support of MMC device (based on DFU_MMC backend)
for SD card and eMMC update.
Create a GPT partitioning on the device.
Build the list of device and of partition with
a tab separated value file with a stm32 header: the FlashLayout.tsv
(https://wiki.st.com/stm32mpu/wiki/STM32CubeProgrammer_flashlayout)
Add a specific command stm32prog for STM32MP soc family
witch allows to program the boot devices with the tool
STM32CubeProgrammer (http://www.st.com/STM32CubeProg).
This command uses the same UART STM32 protocol than MCU
STM32 with or USB with DFU protocol v1.1 (ithe MCU ST
extension are no supported).
The executed actions are based on a tab separated value file
with a stm32 header, the FlashLayout file
(https://wiki.st.com/stm32mpu/wiki/STM32CubeProgrammer_flashlayout).
This file is parsed by the U-Boot command to:
- initialize the devices
- create the partition table on each device
- initialize the DFU backend to access to not volatile memory
(NOR/NAND/SD/eMMC) or to virtual device (OTP/PMIC)
Up to STM32PROG_MAX_DEV (5) devices can be updated with a FlashLayout.
The communication between U-Boot and STM32CubeProgrammer is done with
the specific alternate configuration (see "AN5275: USB DFU/USART protocols
used in STM32MP1 Series bootloaders" for details).
The command stm32prog is executed when a boot from USB is detected
(selected with bootpins) and we can program the boot devices with
a simple command (on Windows or Linux):
PC $> STM32_Programmer_CLI -c port=usb1 -w flaslayout.tsv
1/ the ROM code loads TF-A in embedded RAM (DFU or uart)
2/ TF-A loads flashlayout file and U-Boot in DDR (DFU or uart)
3/ U-Boot executes the stm32prog command (DFU or uart)
Add a function get_cpu_dev to get the DEV_ID present
in DBGMCU_IDC register.
Manage BOOT_FLASH_SPINAND, with boot_device="spi-nand"
and treat this value in bootcmd_stm32mp.
Save and use the FDT address provided by TF-A in r2 at boot time
(it is NT_FW_CONFIG = Non Trusted Firmware configuration file)
Address is saved in save_boot_params(), called by start.S
and the used DTB is gd->fdt_blob = board_fdt_blob_setup().
If dtb is not provided or invalid, U-Boot use as fallback
the builtin DTB.
Activate OP-TEE driver for trusted and optee defconfig.
This driver allows detection of TEE presence for boot from flash;
CONFIG_STM32MP1_OPTEE is also removed.
Add reserve memory for OP-TEE in U-Boot and in kernel device tree:
- no more reduce the DDR size in "memory" node:
CONFIG_SYS_MEM_TOP_HIDE is no more used
- U-Boot device-tree defines the needed "reserved-memory" for OP-TEE
and U-Boot should not use this reserved memory: board_get_usable_ram_top
use lmb lib to found the first free region, the not reserved
memory, enough to relocate U-Boot: the needed size of U-Boot
is estimated with gd->mon_len + CONFIG_SYS_MALLOC_LEN.
- the optee node ("optee@...": firmware with compatible "linaro,optee-tz")
and the associated "reserved-memory" are deactivated in kernel device
tree when OP-TEE is not detected by U-Boot to prevent kernel issue
(memory is reserved but not used, optee driver probe failed).
The DHCOR board does exist in multiple variants with different DDR3
DRAM sizes. To cater for all of them, implement DDR3 code handling.
There are two GPIOs which code the DRAM size populated on the SoM,
read them out and use the value to pick the correct DDR3 config.
Adjust the DDR configuration dtsi such that they only generate the
DRAM configuration node, the DDR controller node is moved into the
stm32mp157-u-boot.dtsi itself. This permits including multiple DDR
configuration dtsi files in board DT.
The AV96 board does exist in multiple variants. To cater for all of
them, implement board code handling. There are two GPIOs which code
the type of the board, read them out and use the value to pick the
correct device tree from an fitImage.
Change-Id: Iddb330b9a66500495885457cbe17edc0eacaaf43
Add weak implementation of board_early_init_f() hook into the
STM32MP1 SPL. This can be used to read out e.g. configuration
straps before initializing the DRAM.
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- Enable USB Host for Odroid-C2 board
- Add Open-Drain/Open-Source emulation in GPIO uclass
https://gitlab.denx.de/u-boot/custodians/u-boot-ti
- Fix boot issues on Nokia RX-51
- Configure AM6 CPSW for 10Mbps in rgmii mode.
- Minor changes for J721e
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
i.MX for 2020.07
- i.MX NAND and nandbxb for i.MX8M
- imx8MM : new beacon devkit
- imx8MQ : new pico-imx8MQ
- imx8QXP : extend to enable M4, fixes
- add thermal support
- caches in SPL (missing board)
- Fixes
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/685391011
Add tests for testing open-drain/open-source emulation in gpio-uclass.
It also adds two test3-gpios configured as GPIO_ACTIVE_LOW.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Enable the second USB controller, which is connected to a hub with 4
ports. The first controller is for the OTG port and is currently not
supported.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
[narmstrong: removed useless DWC2_UTMI_WIDTH in meson64.h]
The memory allocated to store the FIT image containing SYSFW and board
configuration data is statically defined to the largest size expected.
Some additions to the board configuration data has pushed us slightly
over the current defined size on some HS devices, expand to 278000.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Clients that are requesting some of uclass API's
without a device (with ofnode) usually have _nodev
naming convention.
- clk_get_by_index_nodev
- clk_get_by_name_nodev
- reset_get_by_index_nodev
- gpio_request_by_name_nodev
So, update the same naming convention PHY framework.
This doesn't change the existing functionality.
Cc: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
When we create software partition, we still need let parent
partition to configure sid, so move the check after sid failed.
Acked-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Add code to check m4 partition booted or not, we will use this
to runtime set device tree file that passed to Linux Kernel.
For fspi build, we will enable both SPL NOR support and SPL SPI
support. SPL will dynamically check the resource owner then
select corresponding boot device.
Signed-off-by: Ye Li <ye.li@nxp.com>
When doing partition reboot, the boot image won't be reloaded by ROM,
it is just CPU reset to boot entry. The SW has to keep the boot image
inside the RAM unchanged. It includes both the TEXT section and DATA
section.
For SPL, the problem is DATA section will be updated at runtime, so in
next partition reboot the data is not same as the initial value from
cold boot. If any code depends on the initial value, then it will have
problem.
This patch introduces a mechanism to recover the data section
for partition reboot. It adds a new section in image for saving
data section. When from cold boot, the data section will be saved
to that new section at SPL early phase. When from partition reboot,
the data section will be restored from the new section.
Make sure that all devices that are powered up by SPL are powered down
before entering into the u-boot. Otherwise the subsystem/device will
never be powered down by SCFW, due to SPL and u-boot are in different
partitions.
Benefiting from power domain driver, this patch implements the function
"imx8_power_off_pd_devices" to power off all active devices.
Add get_board_serial support, the info could be got from fuse.
When Trusty OS allocates the mem region from 0xfe0000000-0xffffffff,
the get_effective_memsize does not return correct memory size.
There is a check in get_effective_memsize to find the memreg where
the u-boot is running, and return the size of that memreg as the result
of get_effective_memsize. When using aligned start, the value is
0x80200000 since it is 2MB aligned. Thus the finding of memreg will
fail and return the PHYS_SDRAM_1_SIZE because u-boot text base is
0x80020000. This cause u-boot is relocated to the high memory where has
been occupied by Trusty OS.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
The DDR memory from 0x88000000 to 0x8FFFFFFF is assigned to M4 on
QM and QXP. The M4 can allocate this memory by two ways,
in SCD or u-boot.
In this patch, u-boot addes the memory reserve node to DTB to pass
the info to kernel, no matter the M4 memory is reserved in SCD
or u-boot. So kernel won't access M4 reserved memory.
add support for imx8qxp to read boot search count from fuse in nandbcb
Signed-off-by: Han Xu <han.xu@nxp.com>
The original nandbcb tool was designed for imx6 only, when trying to
leverage it to replace the kobs-ng tool, we found the design is not
friendly for supporting all platforms. To support all iMX6/7/8 platforms
and for easy further maintain, I reconstruct the structure of the tool.
The main changes including:
1. Use platform_data to determine the logic branches rather than simply
use SOC name.
2. More data structures as parameter for functions.
3. Global variables to define the FCB/DBBT/FW locations.
4. Implement the kobs-ng default 4 FCB/4 DBBT/2 FW layout.
5. Support Hamming coding/ 40bit BCH/ 62bit BCH coding FCB.
6. Dump and compare all written FCB/DBBT to verify data integrity.
The tool has been verified on iMX6Q/DL, 6SX, 7D, 6ULL, iMX8QX, iMX8MM.
Verify/dump boot structures.
Signed-off-by: Alice Guo <alice.guo@nxp.com>
Verify/dump boot structures written to NAND Flash chip.
Tested on i.MX8MM EVK, imx8mm evk uses BCH
encoding and randomizer
modify macro and print size_t with %zx
use CONFIG_IMX8M because it should apply to imx8mq/mm/mn
bchtype in FCB should be associated to the gf_13/14 settings in BCH, fix
the issue and test on Micron 29F64G08CBABB, it can boot after the
change.
