path: root/arch
2019-02-07Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- SPI-NOR support
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2019-02-07sh: bitops: add hweight*() macrosVignesh R
Add hweight*() macros required for moving to new SF layer Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2019-02-06arm: dts: am33xx: introduce 'am33xx-u-boot.dtsi'Hannes Schmelzer
commit fdce9d35dc36 ("arm: dts: am33xx: Sync dts with Linux 4.20.0") did remove the "u-boot,dm-spl" flag from the 'ocp' bus which was introduced with commit 19aa4ac09db9 ("dts: am33xx: add u-boot, dm-spl to ocp bus") Due to this all boards having CONFIG_SPL_OF_CONTROL enabled are broken because they cannot bind/probe the boot-media interface during SPL stage. This commit introduces the 'am33xx-u-boot.dtsi' which is included with the auto include mechanism. The am33xx-u-boot-dtsi adds the important "u-boot,dm-pre-reloc" to the 'ocp bus' (the root bus of almost all peripherals, at least the bootable ones). The peripherials (mmc, spi, ...) needed during SPL stage need to be equipped with the 'u-boot,dm-pre-reloc' in their responsible dts file. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2019-02-05arm: mvebu: theadorable: Enable video / LCD support with the new DM driverStefan Roese
With the new DM_VIDEO support in the Armada XP LCD driver, this patch adds the needed DT node for the LCD controller to the theadorable dts file. This DT property is not added to the Armada XP dtsi files, as this LCD feature is pretty unusual for this SoC and I personally know of no other board that uses this controller. This patch also enables CONFIG_BMP_16BPP/24BPP/32BPP, as the "old" bmp command supported these BMP files. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2019-02-05video: Armada XP: Move driver to DM_VIDEOStefan Roese
This patch moves the Armada XP video / LCD driver to DM_VIDEO. With this move, the legacy interface board_video_init() is removed from the theadorable board code (only user of this video driver). The support via DT will be added in a separate patch. This patch also enables DM_VIDEO for the theadorable board, as this is needed to not break git bisect'ability. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Anatolij Gustschin <agust@denx.de> Acked-by: Anatolij Gustschin <agust@denx.de>
2019-02-05arm64: mvebu: Add basic support for uDPU boardVladimir Vid
This adds initial support for micro-DPU (uDPU) board which is based on Armada-3720 SoC. micro-DPU is the single-port FTTdp "distribution point unit" made by Methode Electronics which offers complete modularity with replaceable SFP modules both for uplink and downlink (G.hn over twisted-pair, G.hn over coax, 1G and 2.5G Ethernet over Cat-5e cable). On-board features: - 512 MiB DDR3 - 2 x 2.5G SFP via HSGMII SERDES interface to the A3720 SoC - USB 2.0 Type-C connector - 4GB eMMC - ETSI TS 101548 reverse powering via twisted pair (RJ45) or coax (F Type) Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Luis Torres <luis.torres@methode.com> Cc: Scott Roberts <scott.roberts@telus.com> Cc: Paul Arola <paul.arola@telus.com> Signed-off-by: Vladimir Vid <vladimir.vid@sartura.hr> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-02-05arm: mvebu: armada-xp-theadorable.dts: Enable PCIe DT nodesStefan Roese
Now that the PCIe driver supports DM and DT parsing, enable the PCIe DT nodes that are used by this board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com>
2019-02-05arm: mvebu: armada-xp/37x.dtsi: Sync PCIe DT nodes with Linux v4.20Stefan Roese
This patch sync's the PCIe DT nodes with the recent Linux v4.20 version. This change makes it easier to reference specific PCIe nodes in the board dts files to e.g. enable a PCIe port as this is now necessary with the new DM PCI driver for these platforms. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Mario Six <mario.six@gdsys.cc> Cc: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Phil Sutter <phil@nwl.cc> Cc: Marek BehĂșn <marek.behun@nic.cz> Cc: VlaoMao <vlaomao@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2019-02-02Merge tag 'for-master-20190201' of git://git.denx.de/u-boot-rockchipTom Rini
u-boot-rockchip changes for 2019.04-rc1: * support for Chromebook Bob * full pinctrl driver using DTS properties * documentation improvements * I2S support for some Rockchip SoCs
2019-02-02Merge tag 'mips-pull-2019-02-01' of git://git.denx.de/u-boot-mipsTom Rini
- MIPS: mscc: jr2: small fixes - MIPS: mscc: luton: add ethernet and switch driver - MIPS: mt76xx: fix timer frequency
2019-02-02Kconfig: Migrate CONFIG_BUILD_TARGETJagan Teki
Migrate CONFIG_BUILD_TARGET into Kconfig. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-02-01rockchip: rk3399: spl: ensure that debug_uart_init is calledPhilipp Tomsich
With the latest changes to add support for the Chromebook Bob, initialisation through debug_uart_init() did no longer get called for other targets. Fix this, by moving debug_uart_init() out of the Bob-specific Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Add support for chromebook_bobSimon Glass
Bob is a 10-inch chromebook produced by Asus. It has two USB 3.0 type-C ports, 4GB of SDRAM, WiFi and a 1280x800 display. It uses its USB ports for both power and external display. It includes a Chrome OS EC (Cortex-M3) to provide access to the keyboard and battery functions. Support so far includes only: - UART - SDRAM - MMC, SD card - Cros EC (but not keyboard) Not included: - Keyboard - Display - Sound - USB - TPM Bob is quite similar to Kevin, the Samsung Chromebook Plus, but support for this is not provided in this series. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: gru: Add extra device-tree settingsSimon Glass
Add some U-Boot-specific settings. These should really go in the *u-boot.dtsi file, but it seems that rk3399 does not use that yet. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Implement spl_gpio in the GPIO driverSimon Glass
Allow rockchip boards to use GPIOs before driver model is ready. This is really only useful for setting GPIOs to enable the early debug console, if needed on some platforms. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Move pull-up/down enum into a common fileSimon Glass
At present this enum is only available to rk3288. Move it so that other rockchip SoCs can access it. It is needed for the SPL GPIO driver for rk3999 in a later patch. Also adjust the enum name to lower case. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Tidy up board include-file orderingSimon Glass
These board files have inconsistent #include ordering. Fix them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Add settings for Samsung LPDDR3 4GB SDRAM 1866MHzSimon Glass
This memory is used on Bob. Add settings for this, taken from coreboot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Allow booting from SPISimon Glass
The u-boot,spl-boot-device property only allows MMC at present. Add SPI as well for boards that boot from SPI flash. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Adjust rk3399 device tree to be closer to linuxSimon Glass
This file has changed upstream, with some additions and changes. Move the U-Boot version towards this. Some USB changes seem to be incompatible with how the bindings work on rockchip in U-Boot. Testing is needed to make sure that USB still works correct, and adjust the code (not device tree) if not. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Bring in device tree files for rk3399-gruSimon Glass
Bring in these files from Linux v4.20. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01ARM: dts: rk322x: Correct the uart2 default pin configurationDavid Wu
To match the iomux setting of uart2 at SPL, correct the uart2 default pin configuration, if not changed, the evb-rk3229 can't output the log message. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01ARM: rockchip: Remove the pinctrl request at rk3288-board-splDavid Wu
If we use the new pinctrl driver, the pinctrl setup will be done by device probe. Remove the pinctrl setup at rk3288-board-spl. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01ARM: rockchip: Kconfig: Remove the SPL_PINCTRL for rk3188David Wu
It seems that pinctrl is not requested for rk3188 SPL, remove it so that can save more space for SPL image size. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01ARM: rockchip: rk3188: Remove the pinctrl setup and enable uart at SPLDavid Wu
When the boot ROM sets up MMC we don't need to do it again. Remove the MMC setup code entirely, but we also need to enable uart for debug message. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: add support for veyron-speedy (ASUS Chromebook C201)Marty E. Plummer
This adds support for the ASUS C201, a RK3288-based clamshell device. The device tree comes from linus's linux tree at 3f16503b7d2274ac8cbab11163047ac0b4c66cfe. The SDRAM parameters are for 4GB Samsung LPDDR3, decoded from coreboot's src/mainboard/google/veyron/sdram_inf/sdram-lpddr3-samsung-4GB.inc Signed-off-by: Marty E. Plummer <hanetzer@startmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: dts: rk3399-firely: add 'same-as-spl'Mark Kettenis
Like on rk3399-puma we want to continue booting the fill U-Boot from the same device as the SPL stage. Signed-off-by: Mark Kettenis <kettenis@openbsd.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: Drop call to rockchip_dnl_mode_check() for nowSimon Glass
This function causes a 5-second delay and stops the display working on minnie. This code should be in a driver and should only be enabled by a device-tree property, so that it does not affect devices which do not have this feature. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01sound: rockchip: Add sound support for jerrySimon Glass
Jerry uses a max98090 audio codec and the internal SoC I2S peripheral. Enable sound support and add the required device-tree pieces. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01rockchip: rk3288: Add i2s pinctrl and clock supportSimon Glass
Add support for setting pinctrl and clock for I2S on rk3288. This allows the sound driver to operate. These settings were created by rkmux.py Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-02-01ARM: DTS: am43xx: Enable the DTS entries for USB port #2 in SPLJean-Jacques Hiblot
This is required to enable the USB port #2 in SPL when DM_USB is used. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-02-01ARM: DTS: am43xx: Add aliases for the USB portsJean-Jacques Hiblot
Although not required, it doesn't hurt to explicitly map the USB ports to a USB controller. Without this, the port number will be derived from the binding order of the peripheral devices. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-02-01ARM: DTS: Resync am3517-evm.dts with Linux 5.0-rc3Adam Ford
The chosen node was added in the kernel. This may come in handy in the future, so resync with 5.0-rc3 Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-01ARM: dts: da850-evm: Re-sync with Kernel 5.0Adam Ford
Resync with Kernel 5.0-rc3 Signed-off-by: Adam Ford <aford173@gmail.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01ARM: DTS: am335x-evm: Use USB0 in peripheral modeJean-Jacques Hiblot
This USB port is mainly used for RNDIS and DFU. To be able to use it with DM_USB and DM_USB_GADGET, we need to provide a dr_mode value in the DTS. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01ARM: dts: am335x-shc: add u-boot specific dtsiHeiko Schocher
add u-boot specific am335x-shc-u-boot.dtsi file, in which we add u-boot specific adaptions. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01arm: dts: add am335x-shc.dts for shc boardHeiko Schocher
add DTS from linux tree commit "47bfa6d9dc8c060bf56554a465c9031e286d2f80" change for U-Boot: switch to SPDX-license identifier. Signed-off-by: Heiko Schocher <hs@denx.de>
2019-02-01mips: mscc: luton: Add ethernet nodes for Luton.Horatiu Vultur
Add nodes for pcb090 and pcb091. There is currently no support in Linux for this SoC. Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
2019-01-31Merge tag 'video-updates-for-2019.04-rc1' of git://git.denx.de/u-boot-videoTom Rini
- ihs and imx driver fixes - relax EDID validation checks for 0 hsync/vsync pulse width (support some quirky displays)
2019-01-31arm: meson: board-gx: Setup VPU in fdtMaxime Jourdan
If VIDEO_MESON is enabled, we need to setup the fdt for the framebuffer. Call meson_vpu_rsv_fb() which reserves the framebuffer memory region for EFI, and sets up simple-framebuffer nodes if simplefb support is enabled. Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-01-31arm64: dts: meson-gx: add hhi reg entry to hdmi_txMaxime Jourdan
There's no reliable way to reuse the hhi entry from the vpu as is done in the linux kernel, so we duplicate it here. We will be able to sync against kernel DTS in the future when the VPU gets based on the clock framework rather than the HHI reg. Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-01-31arm64: dts: meson-gx: Add hdmi_5v regulator as hdmi tx supplyNeil Armstrong
The hdmi_5v regulator must be enabled to provide power to the physical HDMI PHY and enables the HDMI 5V presence loopback for the monitor. Fixes: b409f625a6d5 ("ARM64: dts: meson-gx: Add HDMI_5V regulator on selected boards") Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Kevin Hilman <khilman@baylibre.com> [backport of linux commit e1f2163deac059ad39f07aba9e314ebe605d5a7a]
2019-01-31arm64: dts: meson-gx: vpu should be probed before relocationMaxime Jourdan
Flag the appropriate nodes with u-boot,dm-pre-reloc Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-01-31video: Add Meson Video Processing Unit DriverNeil Armstrong
This adds video output support for Amlogic GXBB/GXL/GXM chips. The supported ports are CVBS and HDMI (based on DW_HDMI). When using HDMI, only DMT modes are supported. There is support for simple-framebuffer (CONFIG_VIDEO_DT_SIMPLEFB) Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Jorge Ramire-Ortiz <jramirez@baylibre.com> Signed-off-by: Maxime Jourdan <mjourdan@baylibre.com> [narmstrong: fixed defines alignment in meson_canvas.c] Reviewed-by: Anatolij Gustschin <agust@denx.de>
2019-01-30Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
- Enable DM_MMC support
2019-01-30arm: sunxi: Enable DM_MMCJagan Teki
Enable DM_MMC for all Allwinner SoCs, this will eventually enable BLK. Also removed DM_MMC enablement in few parts of sunxi configurations. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2019-01-30sunxi: A64: pinebook-u-boot: Include sunxi-u-boot.dtsiJagan Teki
Like other Allwinner A64 boards, pinebook also need altering auto-numbering of mmc2 to mmc1 which is available in common sunxi dsti file, sunxi-u-boot.dtsi Pinebook has a separate sun50i-a64-pinebook-u-boot.dtsi which takes more precedence for u-boot.dtsi inclusion and it eventually failed to include the sunxi-u-boot.dtsi. So, this patch add support to include the sunxi-u-boot.dtsi in the sun50i-a64-pinebook-u-boot.dtsi Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Vasily Khoruzhick <anarsoul@gmail.com> # Pinebook
