Without resizing the SDL window showed by
./u-boot -D -l
is not legible on a high resolution screen.
Allow resizing the window
- Bug fixes and updates on vid, ls1088a lx2160a and other layerscape
platforms.
- Add optee_rpmb support for LX2 & Kontron sl28 support
Provide tests to check the behavior of the multiplexer framework.
Two sets of tests are added. One is using an emulated multiplexer driver
that can be used to test basic functionality like select, deselect, etc.
The other is using the mmio mux which adds tests specific to it.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
Signed-off-by: Pratyush Yadav <p.yadav@ti.com>
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Reviewed-by: Bin Meng <bin.meng@windriver.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Half of this driver is a DM-based timer driver, and half is RISC-V-specific
IPI code. Move the timer portions in with the other timer drivers. The
KConfig is not moved, since it also enables IPIs. It could also be split
into two configs, but no boards use the timer but not the IPI atm, so I
haven't split it.
Signed-off-by: Sean Anderson <seanga2@gmail.com>
This matches the naming scheme of other timer drivers.
This is a regular timer driver, and should live with the other timer
drivers.
Although the max DMA size supported by the hardware register is 22 bits (or
4M), the Linux driver for this device only supports transfers of up to 2M.
On a device with 8M total memory, I don't think it will make too much of a
difference.
Reported-by: Damien Le Moal <Damien.LeMoal@wdc.com>
It is unsafe to enable OF_BOARD_FIXUP only based on OF_SEPARATE.
OF_SEPARATE may indicate that the user wishes U-Boot to use a different
device tree than one obtained via OF_PRIOR_STAGE. However, OF_SEPARATE may
also indicate that the device tree which would be obtained via
OF_PRIOR_STAGE is invalid, nonexistant, or otherwise unusable. In this
latter case, enabling OF_BOARD_FIXUP will result in corruption of the
device tree. To remedy this, only enable OF_BOARD_FIXUP if U-Boot is
configured for S-Mode.
Fixes: 1c17e55594a394ced7de88d91be294eaf8c564c1
Reviewed-by: Leo Liang <ycliang@andestech.com>
This reverts commit 3a51b2a2c3cedc0d2a9ce981b8e00ab8cefcb6b7.
On all newer Layerscape SoCs, only the export-controlled ciphers of the
crypto module are disabled on non-E parts. Thus it doesn't make sense to
completely remove the node. Linux will figure out what is there and what
is not.
Just remove it for older SoCs, where the module is indeed completely
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Horia Geanta <horia.geanta@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Add basic support for the Kontron SMARC-sAL28 board. This includes just
the bare minimum to be able to bring up the board and boot linux.
For now, the Single and Dual PHY variant is supported. Other variants
will fall back to the basic variant.
In particular, there is no watchdog support for now. This means that you
have to disable the default watchdog, otherwise you'll end up in the
recovery bootloader. See the board README for details.
Tested-by: Heiko Thiery <heiko.thiery@gmail.com>
As per hardware documentation, ECx_PMUX has precedence
over SerDes protocol.
For LX2160/LX2162 if DPMACs 17 and 18 are enabled as SGMII
through SerDes protocol but ECx_PMUX configured them as RGMII,
then the ports will be configured as RGMII and not SGMII.
Signed-off-by: Razvan Ionut Cirjan <razvanionut.cirjan@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
In the current implementation, u-boot creates iommu mappings only
for PCI devices enumarated at boot time thus does not take into
account more dynamic scenarios such as SR-IOV or PCI hot-plug.
Add an u-boot env var and a device tree property (to be used for
example in more static scenarios such as hardwired PCI endpoints
that get initialized later in the system setup) that would allow
two things:
- for a SRIOV capable PCI EP identified by its B.D.F specify
the maximum number of VFs that will ever be created for it
- for hot-plug case, specify the B.D.F with which the device
will show up on the PCI bus
More details can be found in the included documentation:
arch/arm/cpu/armv8/fsl-layerscape/doc/README.pci_iommu_extra
Signed-off-by: Laurentiu Tudor <laurentiu.tudor@nxp.com>
- sun8i emac changes (Andre)
- SCP firmware (Samuel)
This new function, xen_debug_putc(), is intended to be used to
enable CONFIG_DEBUG_UART on xen guest.
Please note that the underlying functionality in Xen is available
only when Xen is configured with !NDEBUG but is much simpler than
a generic HYPERVISOR_console_io().
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
The System Control Unit (SCU) controller of Aspeed
SoCs provides the reset control for each peripheral.
This patch refactors the reset method to leverage
the SCU reset control. Thus the driver dependency
on watchdog including dedicated WDT API and reset
flag encoding can be eliminated.
The Kconfig description is also updated accordingly.
Signed-off-by: Chia-Wei, Wang <chiawei_wang@aspeedtech.com>
Reviewed-by: Ryan Chen <ryan_chen@aspeedtech.com>
Since we now have the driver for Qualcomm PRNG HW, lets use it and add the necessary clocks and nodes.
Signed-off-by: Robert Marko <robert.marko@sartura.hr>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Lets add the necessary DTS node and pinctrl properties for newly added MDIO driver.
Since we have SPI driver for IPQ40xx QUP SPI controller, lets add the necessary nodes, pinctrl and clocks.
As the ownership is now Hitachi Power Grids, change the license string
and adapt the compatible string in DTS files. For kmeter1.dts we
change it to "keymile,KMETER1" for now, as this is then compliant with
what is submitted to the linux kernel. All other boards don't have
a upstreamed version in linux mainline.
Signed-off-by: Holger Brunck <holger.brunck@hitachi-powergrids.com>
CC: Valentin Longchamp <valentin.longchamp@hitachi-powergrids.com>
CC: Heiko Schocher <hs@denx.de>
CC: Marek Vasut <marex@denx.de>
CC: Tom Rini <trini@konsulko.com>
No timer drivers return an error from get_count. Instead of possibly
returning an error, just return the count directly.
Reviewed-by: Claudiu Beznea <claudiu.beznea@microchip.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Activate CMD_EXPORTENV/CMD_IMPORTENV/CMD_ELF for STM32MP15 defconfig
- Fix stm32prog command: parsing of FlashLayout without partition
- Update MAINTAINERS for ARM STM STM32MP
- Manage eth1addr on dh board with KS8851
- Limit size of cacheable DDR in pre-reloc stage in stm32mp1
- Use mmc_of_parse() to read host capabilities in mmc:sdmmc2 driver
- fix Gen5 enable of EMAC via FPGA
Allwinner sun50i SoCs contain an OpenRISC 1000 CPU that functions as a
System Control Processor, or SCP. ARM Trusted Firmware (ATF)
communicates with the SCP over SCPI to implement the PSCI system
suspend, shutdown and reset functionality. Currently, SCP firmware is
optional; the system will boot and run without it, but system suspend
will be unavailable.
Since all communication with the SCP is mediated by ATF, the only thing
U-Boot needs to do is load the firmware into SRAM. The SCP firmware
occupies the last 16KiB of SRAM A2, immediately following ATF.
Signed-off-by: Samuel Holland <samuel@sholland.org>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Since commit d879616e9e64 ("spl: fit: simplify logic for FDT loading for
non-OS boots"), the SPL looks at the "os" properties of FIT images to
determine where to append the FDT.
The "os" property of the "firmware" image also determines how to execute
the next stage of the boot process, as in 1d3790905d9c ("spl: atf:
introduce spl_invoke_atf and make bl31_entry private"). For this reason,
the next stage must be specified in "firmware", not in "loadables".
To support this additional functionality, and to properly model the boot
process, where ATF runs before U-Boot, add the "os" properties and swap
the firmware/loadable images in the FIT image.
Since this description was copied as an example in commit 70248d6a2916
("binman: Support generating FITs with multiple dtbs"), update those
examples as well for correctness and consistency.
Acked-by: Patrick Wildt <patrick@blueri.se>
This consolidates the SoC-specific part at the top of the file to avoid
cluttering it up with preprocessor conditions.
Prior to commit 7f7f8aca8257 ("sunxi: Convert 64-bit boards to use
binman"), if the BL31 environment variable was not defined, the firmware
would be loaded from a file "bl31.bin" in the current directory. Restore
that behavior by providing that as the default filename in case no entry
arg is provided, which will be the case if the environment variable is
unset.
Nodes should have a blank line separating them from sibling nodes and
properties. Add the necessary lines.
Previously, because we have no source code about the DRAM initialization
of V3s and missing some configurations (delays and MBUS QoS info), our
V3s DRAM initialization sequence is hacked from the H3 one.
As the SDK shipped with PineCube contains source code for V3s libdram,
we can retrieve these information from it and tweak some other magic
bits.
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
When partitions are not available on a device the command stm32prog raises
an error but a device can have no partition to check in init_device()
and the command need to continue to the next part_id.
This patch correct an issue for ram0 target, when block_dev and mtd
are NULL.
For example with the simple flashlayout file:
Opt Part Name Type Device Offset Binary
- 0x01 fsbl Binary none 0x0 tf-a-serialboot.stm32
- 0x03 ssbl Binary none 0x0 u-boot.stm32
P 0x10 kernel System ram0 0xC2000000 uImage.bin
P 0x11 dtb FileSytem ram0 0xC4000000 stm32mp157f-ev1.dtb
Fixes: ffc405e63b94 ("stm32mp: stm32prog: add upport of partial update")
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Cosmetic update of gpio.h:
- remove enumerate: stm32_gpio_port, stm32_gpio_pin
because STM32_GPIO_XXX values are unused
- move STM32_GPIOS_PER_BANK in stm32_gpio.c
as its value is IP dependent and not arch dependent
No functional change as number of banks and number of gpio by banks
is managed by device tree since since DM migration and
commit 8f651ca60ba1 ("pinctrl: stm32: Add get_pins_count() ops").
In pre-reloc stage, U-Boot marks cacheable the DDR limited by
the new config CONFIG_DDR_CACHEABLE_SIZE.
This patch allows to avoid any speculative access to DDR protected by
firewall and used by OP-TEE; the "no-map" reserved memory
node in DT are assumed after this limit:
STM32_DDR_BASE + DDR_CACHEABLE_SIZE.
Without security, in basic boot, the value is equal to STM32_DDR_SIZE.
An earlier conversion from struct to defines introduced two errors, both
related to setup of EMAC routed via the FPGA. One of the offsets was
incorrect, and the EMAC0/EMAC1 were swapped.
The effect of this was rather odd: both ports could operate at gigabit,
but one of them would fail to transmit when operating at 100Mbit.
Fixes: db5741f7a85ec3ee79b64496172afaa7dc2cb225 ("arm: socfpga: Convert system manager from struct to defines")
Signed-off-by: Ralph Siemsen <ralph.siemsen@linaro.org>
Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com>
- Assorted R-Car Gen3 updates
Import RZ/G2E (R8A774C0) clock tables from Linux 5.9 commit
bbf5c979011a ("Linux 5.9").
Signed-off-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
Reviewed-by: Biju Das <biju.das.jz@bp.renesas.com>
This sync's the RZ/G2H clock tables with mainline linux 5.9 commit
Signed-off-by: Biju Das <biju.das.jz@bp.renesas.com>
Reviewed-by: Lad Prabhakar <prabhakar.mahadev-lad.rj@bp.renesas.com>
This sync's the RZ/G2N clock tables with mainline linux 5.9 commit
Import R8A774C0 (RZ/G2E) SoC DTSI and headers from Linux 5.9
commit bbf5c979011a ("Linux 5.9").
Add config support for RZ/G2E (a.k.a R8A774C0) SoC.
Add config support for RZ/G2H(a.k.a R8A774E1) SoC.
Add config support for RZ/G2N(a.k.a R8A774B1) SoC.
Also fixed the alignment issue on R8A774A1 config.
Add usb, usb phy, and fixed regulators nodes
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Acked-by: Bin Meng <bmeng.cn@gmail.com>
SAM9X60 SiP (System in Package) are added for SoC identification.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Use alphabetical order for entries in sam9x60ek-u-boot.dtsi
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Use CCF compatible for PMC. With this, the board/SoC will be
able to boot.
Use slow clock CCF compatible DT bindings. This will not break
the above functionality as the SoC is not booting with current
PMC bindings.
Use u-boot,dm-pre-reloc for slow xtal and main xtal.
Slow Xtal and Main Xtal are board specific. Add their proper
frequency to board file.
- Fix Octeon SPI driver for Octeon TX2
- Fix and enhance Octeon watchdog driver
- Misc minor enhancements to Octeon TX/TX2
