path: root/arch
2014-03-04m68k: merge compile flags -ffixed-d7 -sep-dataMasahiro Yamada
All arch/m68k/cpu/*/config.mk define the same flags PLAGFORM_REFLFLAGS += -ffixed-d7 -msep-data Move it to arch/m68k/config.mk Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2014-03-04sh: merge compiler flag -ffixed-r13Masahiro Yamada
-ffixed-r13 is defined commonly for sh2, sh3, sh4. Move it to arch/sh/config.mk Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-03-04sh: Do not define -ffreestanding twiceMasahiro Yamada
-ffreestanding is defined at the top Makefile for all architectures. Do not define it twice for SH2A. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-03-04x86: Delete redundant compiler flagsMasahiro Yamada
-Wstrict-prototypes, -ffreestanding, -fno-stack-protector are defined at the top Makefile for all architectures. Do not define them twice for x86. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-04mmc: zynq: Add OF initialization supportMichal Simek
Enable initialize sdhci from DTB. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-03mtd: nand: omap: optimize chip->ecc.hwctl() for H/W ECC schemespekon gupta
chip->ecc.hwctl() is used for preparing the H/W controller before read/write NAND accesses (like assigning data-buf, enabling ECC scheme configs, etc.) Though all ECC schemes in OMAP NAND driver use GPMC controller for generating ECC syndrome (for both Read/Write accesses). But but in current code HAM1_ECC and BCHx_ECC schemes implement individual function to achieve this. This patch (1) removes omap_hwecc_init() and omap_hwecc_init_bch() as chip->ecc.hwctl will re-initializeGPMC before every read/write call. omap_hwecc_init_bch() -> omap_enable_ecc_bch() (2) merges the GPMC configuration code for all ECC schemes into single omap_enable_hwecc(), thus adding scalability for future ECC schemes. omap_enable_hwecc() + omap_enable_ecc_bch() -> omap_enable_hwecc() Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
With this, fixup a trivial build error of get_effective_memsize needing to be updated in the new board/freescale/p1010rdb/spl.c Signed-off-by: Tom Rini <trini@ti.com>
2014-02-25arm: omap: delete unincluded omap-common/config.mkMasahiro Yamada
arch/arm/cpu/armv7/omap-common/config.mk is never included because "omap-common" is not SoC name. If we want to add OMAP-specific compiler flags, they must be added to omap3/config.mk, omap4/config.mk, omap5/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2014-02-25kbuild: refactor more IMX image rulesMasahiro Yamada
This commit avoids generating ./SPL twice. - Fist time descending to spl/ - Second time as a prerequisite of u-boot-with-spl.imx, u-boot-with-nand-spl.imx. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-25kbuild: use shorten logs for IMX imagesMasahiro Yamada
2014-02-25kbuild: use shorten logs for misc targetsMasahiro Yamada
2014-02-25kbuild: use shorten log for linking u-bootMasahiro Yamada
Move sandbox-specific link rule to arch/sandbox/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-25kbuild: use shorten logs for mkimage rulesMasahiro Yamada
2014-02-25kbuild: rename OBJCFLAGS to OBJCOPYFLAGSMasahiro Yamada
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use "cmd_objcopy" in scripts/Makefile.lib in an upcoming commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-24powerpc/t208x: some update to support t2081Shengzhou Liu
- fix serdes definition for t2081. - fix clock speed for t2081. - update ids, as CONFIG_FSL_SATA_V2 is needed only for t2080, T2081 has no SATA. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-24arm: delete unused macro CONFIG_ARCH_DEVICE_TREEMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Rajeshwari Birje <rajeshwari.s@samsung.com> Cc: Inderpal Singh <inderpal.singh@linaro.org>
2014-02-24Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-22arch: bcm281xx: Initial commit of bcm281xx architecture codeDarwin Rambo
Add bcm281xx architecture support code including a clock framework and chip reset. Define register block base addresses for the bcm281xx architecture and create an empty gpio header file required when CONFIG_CMD_GPIO is set. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Tim Kryger <tkryger@linaro.org>
2014-02-22arch: kona: Initial commit of kona-common architecture codeDarwin Rambo
The Kona architecture is present on a number of Broadcom mobile SoCs including the bcm281xx family of chips. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Tim Kryger <tkryger@linaro.org>
2014-02-21ti814x: Fix illegal use of FP ops in clock_ti814x.cMåns Rullgård
The function pll_sigma_delta_val uses "float" data which is not correct. The exact "why" of this mangling is lost to history, but this changes us to equivalent non-FP math to get the same results. Reported-by: Wolfgang Denk <wd@denx.de> Acked-by: Matt Porter <mporter@linaro.org>
2014-02-21DRA7: fix ABB efuse offset for OPP_NOMNishanth Menon
commit 194dd74ad919e57026f385aaab7f89acf7ea79ef (DRA7: add ABB setup for MPU voltage domain) Made an offset typo error by using 0x4A003B24 as the efuse offset for OPP_NOM. As per TI documentation, 0x4A003B24 is for OPP_OD, and 0x4A003B20 is for OPP_NOM. Fix the same. Reported-by: Praveen Rao <prao@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2014-02-21ARM: OMAP4: fix DDR timings for OMAP4430 ES2.0Janne Grunau
DDR timings were broken since 47abc3df701d8bc26f311350aa523fc1d0f8ad4e for PandaBoard EA1. Signed-off-by: Janne Grunau <j@jannau.net>
2014-02-21ARM: AM43xx: GP-EVM: Correct GPIO used for VTT regulator controlDave Gerlach
Schematic indicates GPIO5_7 is to be used for VTT regulator control rather than GPIO0_21 so modify enable_vtt_regulator to reflect this. Without this some boards will experience DDR3 corruption and fail to boot. Signed-off-by: Dave Gerlach <d-gerlach@ti.com> [trini: Rework patch against mainline] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21Add support for B&R KWB MotherboardHannes Petermaier
Adds support for Bernecker & Rainer Industrieelektronik GmbH KWB Motherboard, using TI's AM3352 SoC. Most of code is derived from TI's AM335x_EVM Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at> Cc: trini@ti.com
2014-02-21am335x: Initial support for Silica Pengwyn boardLothar Felten
This patch add support for the Silica Pengwyn board [1] The board is based on a TI AM3354 CPU [2] All jumpers removed it will boot from the SDcard, the console is on UART1 accessible via the FDTI -> USB. The on board NAND flash is supported and can act as boot medium, depending on jumper settings. USB Host, USB Device and Ethernet are also provided but untested. [1] http://www.silica.com/product/silica-pengwyn-board.html [2] http://www.ti.com/product/am3354 Signed-off-by: Lothar Felten <lothar.felten@gmail.com> [trini: Move CONFIG_BOARD_LATE_INIT into am335x_evm.h, drop unused spi0_pin_mux from Pengwyn support] Signed-off-by: Tom Rini <trini@ti.com>
2014-02-21common: Add get_effective_memsize() to memsize.cYork Sun
This function has been around for powerpc. It is used for systems with memory more than CONFIG_MAX_MEM_MAPPED. In case of non-contiguous memory, this feature can limit U-boot to one block without going over the limit. Signed-off-by: York Sun <yorksun@freescale.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-21Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2014-02-21arc: fix relocation for big-endian targetAlexey Brodkin
In case of little-endian ARC700 instructions (which may include target address) are encoded as middle-endian. That's why it's required to swap bytes after read and ten right before write back. But in case of big-endian ARC700 instructions are encoded as a plain big-endian. Thus no need for byte swapping. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Tom Rini <trini@ti.com> cc: Noam Camus <noamc@ezchip.com>
2014-02-20Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-02-20blackfin: Add <asm/clock.h> to numerous driversTom Rini
With d6a320d we moved some clock externs out of blackfin_local.h and into clock.h but now need to include <asm/clock.h> in more drivers to avoid warnings. Cc: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-20venice2: move device tree to fix build errorMasahiro Yamada
Commit 5ab502cb gathered all device tree sources to arch/$(ARCH)/dts/. So tegra124-venice2.dts also must go to arch/arm/dts directory to build venice2 board. (Commit 5ab502cb had been posted before venice2 board support was merged. So an unvisible conflict happened.) Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2014-02-20Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: Makefile drivers/net/npe/Makefile These two conflicts arise from commit 0b2d3f20 ("ARM: NET: Remove the IXP NPE ethernet driver") and are resolved by deleting the drivers/net/npe/Makefile file and removing the CONFIG_IXP4XX_NPE line from Makefile.
2014-02-20arc: remove "hardware.h"Alexey Brodkin
This file was only required for compilation of designware_i2c driver. Since explicit inclusion of "hardware.h" is now removed from the driver we may safely remove this empty header as well. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Armando Visconti <armando.visconti@st.com>
2014-02-20spear: move CONFIG_SYS_I2C_BASE from arch-spear/hardware to board configsAlexey Brodkin
Having CONFIG_SYS_I2C_BASE requires DW I2C driver to explicitly include <arch/hardware.h> which other platforms may not have at all. It's always good to have a driver platform-independent. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Vipin Kumar <vipin.kumar@st.com> Cc: Armando Visconti <armando.visconti@st.com>
2014-02-20blackfin: rename bfin-twi_i2c driver to adi_i2cSonic Zhang
The ADI twi peripheral is not binding to Blackfin processor only. Change to a generic name. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-02-20blackfin: add spi and i2c specific get clock functionsSonic Zhang
2014-02-19kbuild,tegra124: add dummy obj- for KbuildMasahiro Yamada
In Kbuild, every makefile must have non-empty obj- or obj-y. Otherwise, built-in.o will not be created and the link stage will fail. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Move CONFIG_DISPLAY_CPUINFO to MakefileMasahiro Yamada
If the whole code is surrounded by #ifdef(CONFIG_ ) .. #endif, it should be moved to Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: generate multiple device tree blobsMasahiro Yamada
It is convenient to have all device trees on the same SoC compiled. It allows for later easy repackaging without the need to re-run the make file. - Build device trees with the same SoC under arch/$(ARCH)/dts - Copy the one specified by CONFIG_DEFAULT_DEVICE_TREE or DEVICE_TREE=... to dts/dt.dtb Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use scripts/Makefile.cleanMasahiro Yamada
This commit refactors cleaning targets such as clean, clobber, mrpropper, distclean with scripts/Makefile.clean. By using scripts/Makefile.clean, we can recursively descend into subdirectories and delete generated files there. We do not need add a big list of generated files to the "clean" target. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
