path: root/arch
2015-01-14Add support for Seagate BlackArmor NAS220Evgeni Dobrev
Add support for Seagate BlackArmor NAS220 Signed-off-by: Evgeni Dobrev <evgeni@studio-punkt.com>
2015-01-14sunxi: usbc: Add support for usb-vbus0 controller by axp drivebus pinHans de Goede
The axp221 / axp223's N_VBUSEN pin can be configured as an output rather then an input, and this is used on some boards to control usb-vbus0, add support for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: usbc: Add support for usb0 to the common usbc codeHans de Goede
2015-01-14sunxi: Move usb-controller init code out of ehci-sunxi.c for reuse for otgHans de Goede
Most of the usb-controller init code found in ehci-sunxi.c also is necessary to init the otg usb controller, so move it to a common place. While at it also update various #ifdefs / defines for sun8i support. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun7i: Move psci_arch_init close to text_endJan Kiszka
"adr rX, text_end" only works if the label is close. Adding further code to the other functions will prevent this. So move the containing function close to label. No functional change. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun7i: Add support for taking CPUs offline via PSCIJan Kiszka
Based on the original version by Marc Zyngier. It adds a psci_cpu_off implementation for the A20 SoC. The mechanism works by first preparing the calling CPU to go offline (disable and flush cache, disable SMP), then requesting CPU 0 to pull the plug. The request is sent as FIQ on SGI15. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: video: Add lvds supportHans de Goede
Add support for lvds lcd panels Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-01-14sunxi: video: Add VGA output supportHans de Goede
Add support for VGA directly from the sunxi SoC / display engine. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: video: Add lcd output supportHans de Goede
Add lcd output support, see the new Kconfig entries and doc/README.video for how to enable / configure this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: video: Modify sunxi_lcdc_pll_set to work with both tcon0 and tcon1Hans de Goede
Modify sunxi_lcdc_pll_set to work with both tcon0 and tcon1, this is a preparation patch for adding lcd support. While at it also swap the divider search order, searching from low to high, as the comment above the code says we should do. In cases where there are multiple solutions this will result in picking a lower pll clock and divider, which is more stable and saves power. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: gpio: Add support for gpio pins on the AXP209 pmicHans de Goede
Some boards use GPIO-s on the pmic, one example of this is the A13-OLinuXino board, which uses gpio0 of the axp209 for the lcd-power signal. This commit adds support for gpio pins on the AXP209 pmic, the sunxi_gpio.c changes are universal, adding gpio support for the other AXP pmics (when necessary) should be a matter of adding the necessary axp_gpio_foo functions to their resp. drivers, and add "#define AXP_GPIO" to their header file. Note this commit only adds support for the non device-model version of the gpio code, patches for adding support to the device-model version are very welcome. The string representation for these gpio-s is AXP0-#, the 0 in the AXP0 prefix is there in case we need to support gpio-s on more then 1 pmic in the future. At least A80 boards have 2 pmics, and we may end up needing to support gpio-s on both. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: gpio: Properly sort mux defines by port numberHans de Goede
Move a few mux defines around so that all the mux defines are properly sorted by port number. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: video: Set input sync enableHans de Goede
Add a write to the "unknown" (*) register to enable auto input sync, when initially adding sunxi hdmi output support this magic write from the android kernel code was missed, causing lcdc -> hdmi encoder sync problems. With this write added, we can drop the modesetting retries and the extra delays added to work around these sync problems. With the retries dropped there also is no need to 0 all the enable flags at the beginning of the modeset, as they are initialized to 0 already by engines_init. *) "unknown" is the actual name of this register in the android kernel sources Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-01-14sunxi: video: Add hdmi supportHans de Goede
So far we've been programming the hdmi-encoder to send out dvi data over the hdmi connector. This works well for most devices, including hdmi devices, but not all devices accept dvi data on a hdmi input. Add support for sending proper hdmi data over the hdmi output found on most sunxi boards. This can be turned on by adding monitor=hdmi as option to the video-mode env. variable. A follow up patch will determine whether to send dvi or hdmi automatically when EDID is used. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-01-14sunxi: video: Add DDC & EDID supportHans de Goede
Add DDC & EDID support and use it to automatically select the native mode of the attached monitor. This can be disabled by adding edid=0 as option to the video-mode env. variable. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Anatolij Gustschin <agust@denx.de>
2015-01-14sunxi: Fix PLL1 running at half speed on sun8iHans de Goede
PLL1 on sun6i / sun8i also has a p factor which divides the clock by 2^p (to the power p). On sun6i the p factor is ignored, but on sun8i it is used and we were setting it to 1, resulting in the CPU running at 504 MHz instead of 1008 MHz, this commit fixes this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Fix buggy sun6i/sun8i DRAM size detection logicSiarhei Siamashka
After reboot, reset or even short power off, DRAM typically retains the old stale data for some period of time (for this type of memory, the bits of data are stored in slowly discharging capacitors). The current sun6i/sun8i DRAM size detection logic, which is inherited from the Allwinner code, relies on using a large magic signature with the hope that it is unique enough and unlikely to ever accidentally match this leftover garbage data in RAM. But this approach is inherently unsafe, as can be demonstrated using the following test program: /***** A testcase for reproducing the problem ******/ void main(int argc, char *argv[]) { size_t size, i; uint32_t *buf; /* Allocate the buffer */ if (argc < 2 || !(size = (size_t)atoi(argv[1]) * 1048576) || !(buf = malloc(size))) { printf("Need buffer size in MiB as a cmdline argument\n"); exit(1); } /* Fill it with the Allwinner DRAM "magic" values */ for (i = 0; i < size / 4; i++) buf[i] = 0xaa55aa55 + ((uintptr_t)&buf[i] / 4) % 64; /* Try to reboot */ system("reboot"); /* And wait */ for (;;) {} } /***************************************************/ If this test program is run on the device (giving it a large chunk of memory), then the DRAM size detection logic in u-boot gets confused after reboot and fails to initialize DRAM properly. A better approach is not to rely on luck and abstain from making any assumptions about the properties of the leftover garbage data in RAM. Instead just use a more reliable code for testing whether two different addresses refer to the same memory location. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-14sun8i: Add dram initialization supportHans de Goede
Based on the register / dram_para headers from the Allwinner u-boot / linux sources + the init sequences from boot0. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Use memcmp for mctl_mem_matchesHans de Goede
Use memcmp for mctl_mem_matches instead of DIY. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Fill memory before comparing it when doing dram init on sun6iHans de Goede
The sun8i boot0 code fills the DRAM with a "random" pattern before comparing it at different offsets to do columns, etc. detection. The sun6i boot0 code does not do it, instead relying on the memory contents being random enough to begin with for the memcmp to properly detect the wrap-around address, iow it is working purely by chance. Since our sun6i dram code was modelled after the boot0 code it contained the same issue. This commit fixes this by filling the memory with a unique, distinct pattern. The new mctl_mem_fill function this introduces is added as an inline helper in dram.h, so that it can be shared with the sun8i dram code. While at it move mctl_mem_matches to dram.h for re-use in sun8i too. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Move await_completion dram helper to dram.hHans de Goede
The await_completion helper is already copy pasted between the sun4i and sun6i dram code, and we need it for sun8i too, so lets make it an inline helper in dram.h, rather then adding yet another copy. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: clock_set_pll5: Calculate k and m rather then hardcoding themHans de Goede
Our old hardcoded k and m values are based on PLL5 being configured in steps of 48 MHz, which is correct for sun6i where the DRAM PLL runs at twice the DRAM CLK, which is usually configured in 24 MHz step. But on the A23 (sun8i) the PLL5 runs at half the DRAM CLK, so we require 12 MHz steps. This commit adjusts clock_set_pll5 to automatically select the best k and m depending on the requested clk rate. Suggested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add a sigma_delta_enable paramter to clock_set_pll5()Hans de Goede
The sun8i dram code sometimes wants to enable sigma delta mode, add a parameter to allow this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: axp221: Add axp223 supportHans de Goede
The axp223 appears to be the same as the axp221, except that it uses the rsb to communicate rather then the p2wi. At least all the registers we use are 100% the same. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Add support for the rsb (Reduced Serial Bus)Hans de Goede
sun8i (A23) introduces a new bus for communicating with the pmic, the rsb, the rsb is also used to communicate with the pmic on the A80, and is documented in the A80 user manual. This commit adds support for this based on the rsb driver from the allwinner u-boot sources. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: s/SUNXI_*P2WI*/SUN6I_*P2WI*/Hans de Goede
The p2wi interface is only available on sun6i, adjust the gpio pinmux and base address defines for it to reflect this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Align PSCI stack calculation to commentJan Kiszka
0x400 is true 1K. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Add sunxi_get_sid helper functionHans de Goede
On sun6i the SID is stored in the pmic, rather then in the SoC itself, add a helper function to abstract this away. This makes our MAC address generation code also work on sun6i. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: mmc: Properly setup mod-clk and clock sampling phasesHans de Goede
The sunxi mmc controller has both an internal clock divider, as well as the divider in the mod0-clk for the mmc controller. The internal divider cannot be used, as it conflicts with the setting of clock sampling phases which is done in the mod0-clk, so it must be set to 0 (divide by 1). For some reason while the kernel has had this correct from day one, the u-boot sunxi mmc code has been using a fixed mod0-clk and setting its internal divider depending on the desired speed. This is something which we've inherited from the original Allwinner u-boot sources, but while this has been fixed in Allwinner's own u-boot code at least for the A23 and later upstream u-boot was still doing this wrong. This commit fixes this, thereby also fixing mmc support not working reliable on the A23 (which seems more sensitive to this) and possible also fixes some other sunxi mmc issues. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: dram: Do not try to initialize a second dram chan on A31sHans de Goede
The A31s only has one dram channel, so do not bother with trying to initialize a second channel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add sunxi_get_ss_bonding_id() functionHans de Goede
Add a sunxi_get_ss_bonding_id() function, and use it to differentiate between the A31s and the A31. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Make dram clk and zq value Kconfig optionsHans de Goede
It turns out that there is a too large spread between boards to handle this with a default value, turn this into Kconfig options, and set the values the factory images are using for the Colombus and Mele_M9 boards. Note this changes the ZQ default when not overriden through defconfig from 120 to 123, as that is what most boards seem to actually use. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-13Merge git://git.denx.de/u-boot-x86Tom Rini
2015-01-13x86: coreboot: Configure pci memory regionsBin Meng
Configure coreboot pci memory regions so that pci device drivers could work correctly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Make chromebook_link the default board for corebootBin Meng
Change SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE to chromebook_link which is currently the only real board officially supported to run U-Boot loaded by coreboot. Note the symbolic link file chromebook_link.dts is deleted and link.dts is renamed to chromebook_link.dts. To avoid multiple definition of video_hw_init, the CONFIG_VIDEO_X86 define needs to be moved to arch/x86/cpu/ivybridge/Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Move coreboot-specific defines from coreboot.h to KconfigBin Meng
There are many places in the U-Boot source tree which refer to CONFIG_SYS_COREBOOT, CONFIG_CBMEM_CONSOLE and CONFIG_VIDEO_COREBOOT that is currently defined in coreboot.h. Move them to arch/x86/cpu/coreboot/Kconfig so that we can switch to board configuration file to build U-Boot later. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Hide ROM chip size when CONFIG_X86_RESET_VECTOR is not selectedBin Meng
When CONFIG_X86_RESET_VECTOR is not selected, specifying the ROM chip size is meaningless, hence hide it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Move CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to KconfigBin Meng
Convert CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to Kconfig options so that we can remove them from board configuration file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Allow a hardcoded TSC frequency provided by KconfigBin Meng
By default U-Boot automatically calibrates TSC running frequency via MSR and PIT. The calibration may not work on every x86 processor, so a new Kconfig option CONFIG_TSC_CALIBRATION_BYPASS is introduced to allow bypassing the calibration and assign a hardcoded TSC frequency CONFIG_TSC_FREQ_IN_MHZ. Normally the bypass should be turned on in a simulation environment like qemu. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: coreboot: Set up timer base correctlyBin Meng
If coreboot is built with CONFIG_COLLECT_TIMESTAMPS, use the value of base_time in coreboot's timestamp table as our timer base, otherwise TSC counter value will be used. Sometimes even coreboot is built with CONFIG_COLLECT_TIMESTAMPS, the value of base_time in the timestamp table is still zero, so we must exclude this case too (this is currently seen on booting coreboot in qemu). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: fsp: Drop get_hob_type() and get_hob_length()Bin Meng
These two are not worth having separate inline functions as they are really simple, so drop them. Also changed 'type' parameter of fsp_get_next_hob() from u16 to uint. Suggested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Add an 'mtrr' command to list and adjust MTRRsSimon Glass
It is useful to be able to see the MTRR setup in U-Boot. Add a command to list the state of the variable MTRR registers and allow them to be changed. Update the documentation to list some of the available commands. This does not support fixed MTRRs as yet. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-13x86: ivybridge: Update microcode early in bootSimon Glass
At present the normal update (which happens much later) does not work. This seems to have something to do with the 'no eviction' mode in the CAR, or at least moving the microcode update after that causes it not to work. For now, do an update early on so that it definitely works. Also refuse to continue unless the microcode update check (later in boot) is successful. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Disable CAR before relocation on platforms that need itSimon Glass
For platforms with CAR we should disable it before relocation. Check if this function is available and call it if so. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: ivybridge: Add a way to turn off the CARSimon Glass
Cache-as-RAM should be turned off when we relocate since we want to run from RAM. Add a function to perform this task. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Commit the current MTRRs before relocationSimon Glass
Once we stop running from ROM we should set up the MTTRs to speed up execution. This is only needed for platforms that don't have an FSP. Also in the Coreboot case, the MTRRs are set up for us. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: ivybridge: Request MTRRs for DRAM regionsSimon Glass
We should use MTRRs to speed up execution. Add a list of MTRR requests which will dealt with when we relocate and run from RAM. We set RAM as cacheable (with write-back) and registers as non-cacheable. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: ivybridge: Set up an MTRR for the video frame bufferSimon Glass
Set the frame buffer to write-combining. This makes it faster, although for scrolling write-through is even faster for U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: Add support for MTRRsSimon Glass
Memory Type Range Registers are used to tell the CPU whether memory is cacheable and if so the cache write mode to use. Clean up the existing header file to follow style, and remove the unneeded code. These can speed up booting so should be supported. Add these to global_data so they can be requested while booting. We will apply the changes during relocation (in a later commit). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-13x86: ivybridge: Drop support for ROM cachingSimon Glass
This is set up along with CAR (Cache-as-RAM) anyway. When we relocate we don't really need ROM caching (we read the VGA BIOS from ROM but that is about it) Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
