path: root/arch
2015-09-11arm: spear: Add command to switch between 1-bit HW ECC and SW BCH4Stefan Roese
This patch adds the "nandecc" command to switch between the SPEAr600 internal 1-bit HW ECC and the 4-bit SW BCH4 ECC. This can be needed to support NAND chips with a stronger ECC than 1-bit, as on the x600. And to dynamically switch between both ECC schemes for backwards compatibility. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2015-09-11arm: Remove tx25 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove palmtreo680 boardSimon Glass
2015-09-11arm: Remove xaeniax boardSimon Glass
2015-09-11arm: Remove vpac270_nor_128 boardSimon Glass
2015-09-11arm: Remove vl_ma2sc boardSimon Glass
2015-09-11arm: Remove vision2 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stefano Babic <sbabic@denx.de>
2015-09-11arm: Remove versatileab boardSimon Glass
2015-09-11arm: Remove tt01 boardSimon Glass
2015-09-11arm: Remove tk71 boardSimon Glass
2015-09-11arm: Remove scb9328 boardSimon Glass
2015-09-11arm: Remove rd6281a boardSimon Glass
2015-09-11arm: Remove qong boardSimon Glass
2015-09-11arm: Remove pxa255_idp, zipitz2 boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove portuxg20, stamp9g20 boardsSimon Glass
2015-09-11arm: Remove polaris and trizepsiv boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stefano Babic <sbabic@denx.de>
2015-09-11arm: Remove palmtc boardSimon Glass
2015-09-11arm: Remove palmld boardSimon Glass
2015-09-11arm: Remove otc570 boardSimon Glass
2015-09-11arm: Remove openrd boardsSimon Glass
2015-09-11arm: Remove omap3_sdp3430 boardSimon Glass
2015-09-11arm: Remove omap3_mvblx boardSimon Glass
2015-09-11arm: Remove nhk8815 boards and nomadik archSimon Glass
2015-09-11arm: Remove mx51_efikamx, mx51_efikasb boardsSimon Glass
2015-09-11arm: Remove mv88f6281gtw_ge boardSimon Glass
2015-09-11arm: Remove lp8x4x boardSimon Glass
2015-09-11arm: Remove jornada boardSimon Glass
2015-09-11arm: Remove mx31_litekit boardSimon Glass
2015-09-11arm: Remove imx27lite, imx27_litekit and magnesium boardsSimon Glass
2015-09-11arm: Remove ima3-mx53 boardSimon Glass
2015-09-11arm: Remove enbw_cmc boardSimon Glass
2015-09-11arm: Remove eb_cpu9k2 and eb_cpu9k2_ram boardsSimon Glass
These board have not been converted to generic board by the deadline. Remove them. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove dig297 boardSimon Glass
2015-09-11arm: Remove unmaintained davinci boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove dm355evm, dm355leopard, dm365evm, dm6467evm, dvevm, ea20, schmoogie, sffsdr, sonata. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove snowball and u8500_href boardsSimon Glass
2015-09-11arm: Remove eukrea boardsSimon Glass
These boards have not been converted to generic board by the deadline. Remove all cpu9260 and cpuat91 boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove balloon3 boardSimon Glass
2015-09-11ARM: DRA7: emif: Fix disabling/enabling of refreshesLokesh Vutla
clrsetbits_le32/clrbits_le32 takes mask of the bits as input that are needed to be set/clear. But emif driver passes the shift of the bits. Fixing it here. Reported-by: Mark Mckeown <m-mckeown@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-09-11lpc32xx: remove duplicated DMA_CLK_ENABLE bit definitionVladimir Zapolskiy
Because there is an originally defined CLK_DMA_ENABLE macro in clk.h, no reason to add another DMA_CLK_ENABLE macro with the same value. Remove DMA_CLK_ENABLE, since it does not follow naming convention from the code, this implies renaming of DMA_CLK_ENABLE to CLK_DMA_ENABLE in lpc32xx/devices.c file. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Tested-by: Sylvain Lemieux <slemieux@tycoint.com>
2015-09-11Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-09-10sun5i: Add A10s-Wobo-i5 defconfig and dtsJelle van der Waa
The Wobo i5 top set box is a somewhat curious A10s based top set box, it uses an AXP209 rather then the AXP152 usually used in combination with the A10s. It has an ethernet phy connected to PORTD rather then PORTA, and its built-in usb wifi is connected via the otg controller. The dts file changes are identical to the changes submitted to the upstream kernel. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-09-10sun5i: Add q8_a13_tablet defconfig and dtsHans de Goede
This commits adds a generic support for q8 formfactor a13 based tablets. These tablets ship in many variants, with the difference mainly being the touchscreen controller / accelerometer / wifi chip used. The wifi is USB based, and thus not listed in devicetree. ATM the kernel does not support the touchscreen / accelerometer on these devices. In the future we may need multiple configs with different CONFIG_DEFAULT_DEVICE_TREE settings, this depends on how we solve the hw differences on the kernel side. For now this will suffice. The dts files are identical to the dts files submitted to the upstream kernel for these tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-10sun4i: Add dts and defconfig for iNet-1 based tabletsHans de Goede
The iNet-tek iNet-1 PCB is a PCB found in various generic 10.1" 1024x600 A10 based tablets such as the Point of View Protab2 XXL and the Cherry M1007. This patch has been tested on both rev2 and rev5 of this board / these tablets. These tablets feature the usual connectors: headphone, mini hdmi, power-barrel, mini-usb and a micro-sd slot. The dts is identical to the dts submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-10sun4i: Add defconfig and dts for inet9f-rev03 based tabletsHans de Goede
The inet9f-rev03 pcb is specially designed for gaming tablets, such as the qware tb-g100 tablet. These 7" tablets feature a dpad, firebuttons and 2 joysticks on the sides of the screen. Besides this they have the usual connectors: power-barrel, mini usb, mini hdmi, headphone and micro-sd slot. The dts is identical to the dts submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-10sun4i: Add defconfig and dts for the pov protab2-ips9 tabletHans de Goede
The Point of View protab2-ips9 is a tablet with a 9" ips 1024x768 lcd screen, microsd slot, headphones, mini hdmi, mini usb b and power barrel connectors. The dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-09-09x86: quark: Add USB PHY initialization supportBin Meng
USB PHY needs to be properly initialized per Quark firmware writer guide, otherwise the EHCI controller on Quark SoC won't work. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: Convert to use driver model pci on quark/galileoBin Meng
Move to driver model pci for Intel quark/galileo. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: Enable PCIe controller on quark/galileoBin Meng
Quark SoC holds the PCIe controller in reset following a power on. U-Boot needs to release the PCIe controller from reset. The PCIe controller (D23:F0/F1) will not be visible in PCI configuration space and any access to its PCI configuration registers will cause system hang while it is held in reset. Enable PCIe controller per Quark firmware writer guide. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: quark: Avoid chicken and egg problemBin Meng
If we convert to use driver model pci on quark, we will encounter some chicken and egg problems like below: - To enable PCIe root ports, we need program some registers on the message bus via pci bus. With driver model, the first time to access pci bus, the pci enumeration process will be triggered. But without first enabling PCIe root ports, pci enumeration just hangs when scanning PCIe root ports. - Similar situation happens when trying to access GPIO from the PCIe enabling codes, as GPIO requires its block base address to be assigned via a pci configuration register in the bridge. To avoid such dilemma, replace all pci calls in the quark codes to use the local version which does not go through driver model. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-09-09x86: quark: Optimize MRC execution timeBin Meng
Intel Quark SoC has a low end x86 processor with only 400MHz frequency. Currently it takes about 15 seconds for U-Boot to boot to shell and the most time consuming part is with MRC, which is about 12 seconds. MRC programs lots of registers on the SoC internal message bus indirectly accessed via pci bus. To speed up the boot, create an optimized version of pci config read/write dword routines which directly operate on PCI I/O ports. These two routines are inlined to provide better performance too. Now it only takes about 3 seconds to finish MRC, which is really fast (4 times faster than before). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
