path: root/arch
2013-07-24nds32: introduce macros for bit manipulationGabor Juhos
U-Boot does not compile for the adp-ag101 boards since commit f6c3b34697bf8bf05cb4e81c2fd3cadb9a98daea (mmc: update Faraday FTSDC010 for rw performance) The driver assumes that the bit manipulation macros are provided by all architectures. This is not the case for nds32 and it causes a build error like this: ftsdc010_mci.c: In function 'ftsdc010_clkset': ftsdc010_mci.c:118: warning: implicit declaration of function 'setbits_le32' ftsdc010_mci.c:123: warning: implicit declaration of function 'clrbits_le32' drivers/mmc/libmmc.o: In function `ftsdc010_request': /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:234: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:243: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:234: undefined reference to `clrbits_le32' drivers/mmc/libmmc.o: In function `ftsdc010_clkset': /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:118: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:118: undefined reference to `clrbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:121: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:123: undefined reference to `setbits_le32' /devel/u-boot.git/drivers/mmc/ftsdc010_mci.c:123: undefined reference to `setbits_le32' The patch adds bit manipulation macros for the nds32 architecture to avoid the errors. The macros are copied from the ARM implementation. Compile tested only. Cc: Kuo-Jung Su <dantesu@faraday-tech.com> Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-07-16powerpc/mpc85xx:Disable Debug TLB entry for non-minimal SPLPrabhakar Kushwaha
CONFIG_SPL_BUILD creates debug TLB entry, so disable it before init_tlbs. CONFIG_SPL_INIT_MINIMAL never creates any debug TLB entry, so no need of disable_tlb(). Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16arm:exynos:fix: Fix clock calculation for Exynos4210 based targets.Łukasz Majewski
Provide proper setting for the APLL fout frequency calculation for Exynos4 based targets (especially Exynos4210 - Trats board). Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12blackfin: x86: bootm: Handle PREP stage of bootmSimon Glass
The OS function is now always called with the PREP stage. Adjust the remaining bootm OS functions to deal with this correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-11ARM: Tegra: USB: EHCI: Add support for Tegra30/Tegra114Jim Lin
Tegra30 and Tegra114 are compatible except PLL parameters. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: Tegra: FDT: Add USB EHCI function for T30/T114Jim Lin
Add DT node for USB EHCI function. Add support for T30-Cardhu, T30-Beaver, T114-Dalmore boards. Signed-off-by: Jim Lin <jilin@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-10Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-10bootm: Clean up bootz_setup() functionSimon Glass
This function has no prototype in the headers and passes void * around, thus requiring several casts. Tidy this up. - Add new patch to clean up bootz_setup() function Signed-off-by: Simon Glass <sjg@chromium.org>
2013-07-09arm: exynos: fix clock calculationMinkyu Kang
There are differnce with clock calcuation by cpu variations. This patch will fix it according to user manual. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Add API for power reset and exit wakeupRajeshwari Shinde
This patch adds APIs to get power reset status and exit the wakeup condition for both exynos5 and exynos4 Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-02ARM: OMAP: GPIO: Fix valid range and enable usage of all GPIOs on OMAP5Axel Lin
The omap_gpio driver is used by AM33XX, OMAP3/4, OMAP54XX and DRA7XX SoCs. These SoCs have different gpio count but currently omap_gpio driver uses hard coded 192 which is wrong. This patch fixes this issue by: 1. Move define of OMAP_MAX_GPIO to all arch/arm/include/asm/arch-omap*/gpio.h. 2. Update gpio bank settings and enable GPIO modules 7 & 8 clocks for OMAP5. Thanks for Lubomir Popov to provide valuable comments to fix this issue. Signed-off-by: Axel Lin <axel.lin@ingics.com> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-07-02ARM: OMAP4+: Fix MA detection during SDRAM_AUTO_DETECTIONLokesh Vutla
During SDRAM_AUTO_DETECTION MA is not configured. For Soc's > OMAP4460 MA is present. So populating MA for the same. Tested on OMAP4430 PANDA, OMAP4460 PANDA. Reported-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2013-07-02am33xx: fix the ddr_cmdtctrl structureIlya Ledvich
Fix the wrong mapping between the DDR I/O control registers on AM33XX SoCs and the software representation in the SPL code. The most recent public TRM defines the following DDR I/O control registers offsets: * ddr_cmd0_ioctrl : offset 0x44E11404 * ddr_cmd1_ioctrl : offset 0x44E11408 * ddr_cmd2_ioctrl : offset 0x44E1140C * ddr_data0_ioctrl: offset 0x44E11440 * ddr_data1_ioctrl: offset 0x44E11444 While the struct ddr_cmdtctrl has also some reserved bits in the beginning. The struct is mapped to the address 0x44E11404. As a result "cm0ioctl" points to the ddr_cmd1_ioctrl register, "cm1ioctl" to the ddr_cmd2_ioctrl and etc. Registers ddr_cmd0_ioctrl and ddr_data0_ioctrl are never configured because of this mapping mismatch. Signed-off-by: Ilya Ledvich <ilya@compulab.co.il> Reviewed-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-28Fix bootm to work on powerpc again (compressed uImage)Stefan Roese
Patch 35fc84fa1 [Refactor the bootm command to reduce code duplication] breaks booting Linux (compressed uImage with fdt) on powerpc. boot_jump_linux() mustn't be called before boot_prep_linux() and boot_body_linux() have been called. So remove the superfluous call to boot_jump_linux() in arch/powerpc/lib/bootm.c as its called later on in this function. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com>
2013-06-28Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-06-28SMDK5250: Remove reduntant codeRajeshwari Shinde
enum boot_mode is defined twice once in spl.h and also in spl_boot.c, hence removing the same from spl_boot.c and including the header file. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-27ColdFire: Update the arch_global_date changes for mcf5441xJason Jin
Update inp_clk, vco_clk and flb_clk for mcf5441x as those items were moved to arch_global_data. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2013-06-27Fix MCF5235 SDRAM base address macroSteve deRosier
SDRAMC_DARCn_BA() macro worked fine when the BA is 0x00000000 even though the macro is incorrect. It causes the BA to be set incorrctly for other base addresses. This patch fixes the macro so that base addresses other than zero can be used with the MCF5235. Signed-off-by: Steve deRosier <derosier@gmail.com>
2013-06-27m68k: fix debug call befor serial initJens Scharsig (BuS Elektronik)
There is a debug call in board.c befor serial interface was initialized. This moves the debug code behind serial_initialize call. Signed-off-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
2013-06-26mx27: add i2c clocktrem
Signed-off-by: Eric Jarrige <eric.jarrige@armadeus.org> Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-06-26mx27: add function enable_cachestrem
2013-06-26imx: Complete the pin definitions for the i.MX6DL / i.MX6SoloPierre Aubert
Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de>
2013-06-26imx6: fix GPR2 wrong definitionPierre Aubert
Signed-off-by: Pierre Aubert <p.aubert@staubli.com> CC: Stefano Babic <sbabic@denx.de> Acked-by: Dirk Behme <dirk.behme@gmail.com>
2013-06-26x86: Support tracing functionSimon Glass
Some changes are needed to x86 timer functions to support tracing. Add these so that the feature works correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26exynos: Avoid function instrumentation for microsecond timerSimon Glass
For tracing to work it has to be able to access the microsecond timer without causing a recursive call to the function entry/exit handlers. Add attributes to the relevant functions to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26arm: Implement the 'fake' go commandSimon Glass
Implement this feature on ARM for tracing. It would be nice to have generic bootm support so that it is easily implemented on any arch. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-06-26Clarify bootm OS argumentsSimon Glass
At present the arguments to bootm are processed in a somewhat confusing way. Sub-functions must know how many arguments their calling functions have processed, and the OS boot function must also have this information. Also it isn't obvious that 'bootm' and 'bootm start' provide arguments in the same way. Adjust the code so that arguments are removed from the list before calling a sub-function. This means that all functions can know that argv[0] is the first argument of which they need to take notice. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26sandbox: Support trace featureSimon Glass
Support tracing on sandbox by adding suitable CONFIG options. To enable it, compile U-Boot with FTRACE=1. The timer functions are marked to skip tracing, since these are called from the tracing code itself, and we want to avoid an infinite loop. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26x86: Correct missing local variable in bootmSimon Glass
Enabling FIT produces a compile error. Fix this. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26cros: exynos: add cros-ec device nodes to exynos5250-snow.dtsHung-ying Tyan
This patch adds cros-ec related device nodes to exynos5250-snow.dts. It also adds a gpio node to exynos5250.dtsi. Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-24EXYNOS5: FDT: Add serial device node valuesRajeshwari Shinde
This patch adds the device node required for serial driver Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com> Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-22pxa: fix memory coherency problem after relocationMike Dunn
On the xscale, the icache must be invalidated and the write buffers drained after writing code over the data bus, even if the caches are disabled. Tested on the pxa270. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-22pxa: use -mcpu=xscale compiler optionMike Dunn
Pass '-mcpu=xscale' to the compiler instead of march and mtune. This will cause gcc to define the __XSCALE__ macro. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-22pxa: turn icache off in cpu_init_crit()Mike Dunn
The comment in the low-level initialization function cpu_init_crit() says that the caches are being disabled, but (oddly) the icache is actually turned on. This is probably not a good idea prior to relocating code, so this patch turns it off. Tested on the pxa270. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-06-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-06-21arm: optimize relocate_code routineAlbert ARIBAUD
Use section symbols directly Drop support for R_ARM_ABS32 record types Eliminate unneeded intermediate registers Optimize relocation table iteration Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: make __rel_dyn_{start, end} compiler-generatedAlbert ARIBAUD
This change is only done where needed: some linker scripts may contain relocation symbols yet remain unchanged. __rel_dyn_start and __rel_dyn_end each requires its own output section; putting them in relocation sections changes their flags and breaks relocation. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: make __image_copy_{start, end} compiler-generatedAlbert ARIBAUD
This change is only done where needed: some linker scripts may contain __image_copy_{start,end} yet remain unchanged. Also, __image_copy_end needs its own section; putting it in relocation sections changes their flags and makes relocation break. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: generalize lib/bss.c into lib/sections.cAlbert ARIBAUD
File arch/arm/lib/bss.c was initially defined for BSS only, but is now going to also contain definitions for other section-boundary-related symbols, so rename it for better accuracy. Also, remove useless 'used' attributes. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21remove all references to .dynsymAlbert ARIBAUD
Discard all .dynsym sections from linker scripts Remove all __dynsym_start definitions from linker scripts Remove all __dynsym_start references from the codebase Note: this touches include/asm-generic/sections.h, which is not ARM-specific, but actual uses of __dynsym_start are only in ARM, so this patch can safely go through the ARM repository. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-21arm: ensure u-boot only uses relative relocationsAlbert ARIBAUD
Add a Makefile target ('checkarmreloc') which fails if the ELF binary contains relocation records of types other than R_ARM_RELATIVE. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-06-20powerpc/85xx: Add P1023RDB board supportChunhe Lan
P1023RDB Specification: ----------------------- Memory subsystem: 512MB DDR3 (Fixed DDR on board) 64MB NOR flash 128MB NAND flash Ethernet: eTSEC1: Connected to Atheros AR8035 GETH PHY eTSEC2: Connected to Atheros AR8035 GETH PHY PCIe: Three mini-PCIe slots USB: Two USB2.0 Type A ports I2C: AT24C08 8K Board EEPROM (8 bit address) Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx:Disable Debug TLB entry before init_tlbsPrabhakar Kushwaha
init_tlbs() initialize all the TLB entries required for the system. So disable DEBUG TLB entry before TLB entries initialization. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc: mpc85xx/mpc86xx: Fix off-by-one boundary checking with ARRAY_SIZEAxel Lin
If a variable is used as array subscript, it's valid value range is 0 ... ARRAY_SIZE -1. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: modify the functionality clear_bss and aligning the end ↵Ying Zhang
address of the BSS There will clear the BSS in the function clear_bss(), the reset address of the BSS started from the __bss_start, and increased by four-byte increments, finally stoped depending on the address is equal to the _bss_end. If the end address __bss_end is not alignment to 4byte, it will be an infinite loop. 1. The reset action stoped depending on the reset address is greater than or equal the end address of the BSS. 2. The end address of the BSS should be 4byte aligned. Because the reset unit is 4 Bytes. This patch is on top of the patch "powerpc/mpc85xx: support application without resetvec segment in the linker script". Signed-off-by: Ying Zhang <b40530@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
