Fix the following DTC warnings:
Warning (simple_bus_reg): Node /soc/system-bus@58c00000/support_card@1,1f00000/ethernet@00000000 simple-bus unit address format error, expected "0"
Warning (simple_bus_reg): Node /soc/system-bus@58c00000/support_card@1,1f00000/uart@000b0000 simple-bus unit address format error, expected "b0000"
Warning (simple_bus_reg): Node /soc/smpctrl@59800000 simple-bus unit address format error, expected "59801000"
When booting from ARM Trusted Firmware, U-Boot runs in EL1-NS.
The boot flow is as follows:
BL1 -> BL2 -> BL31 -> BL33 (i.e. U-Boot)
This boot sequence works fine for LD11 SoC (Cortex-A53), but LD20
SoC (Cortex-A72) hangs in U-Boot. The solution I found is to
read sctlr_el1 and write back the value as-is. This should be
no effect, but surprisingly fixes the problem for LD20 to boot.
I do not know why.
The MODEL field is 3 bit wide.
- Add #undef CONFIG_DM_MMC_OPS to omap3_logic in the SPL build case, to
match other TI platforms in the same situation.
This patch adds support for TV encoder clocks which will be used later.
Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net>
Newer SoCs use same TV encoder unit. Split it out so it can be reused
with new DM video driver.
The following options are migrated over fully now:
- USB_EHCI_ATMEL
- USB_EHCI_MARVELL
- USB_EHCI_MX6
- USB_EHCI_MX7
- USB_EHCI_MSM
- USB_EHCI_ZYNQ
- USB_EHCI_GENERIC
This also requires fixing the depends on USB_EHCI_MARVELL as it's used
by Orion5X and Kirkwood as well.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
In order to be able to migrate the various SoC EHCI CONFIG options we
first need to finish the switch from CONFIG_USB_EHCI to
CONFIG_USB_EHCI_HCD.
The symbol CONFIG_OMAP_VC_I2C_HS_MCODE always uses the default value.
Restructure the comment and code such that if a need arises later to use
another value we can address this then.
The symbols CONFIG_OMAP3_GPIO_X control if we enable the clocks for a
given GPIO bank in U-Boot. select the required banks for each target.
In some cases we need to also migrate from CONFIG_USB_EHCI (deprecated,
in include/configs/) to CONFIG_USB_EHCI_HCD as we only require the GPIO
bank to be enabled if USB is also enabled.
While in theory this value could be used in places outside of "omap5"
(such as OMAP4), we only make use of it today in OMAP5, so place the
Kconfig entry there. Given that Kconfig lets us provide a default, we
drop CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC entirely. The contents of
doc/README.omap-reset-time make a good help entry, so adjust them
slightly and delete the file. Move the comment about range to where we
use the value now, and have Kconfig enforce the upper bound.
In the two cases in the code where we use CONFIG_OMAP as a useful test
currently we can make use of CONFIG_ARCH_OMAP2PLUS instead. With that
changed we can drop all defines of CONFIG_OMAP. While in here,
CONFIG_OMAP3430 is only defined and then never used, so drop.
This code has been unused since the removal of the "omap2" platforms,
remove.
The SMPEN bit is located in the cpuectlr_el1 register and not the
cpuactlr_el1 register. Adjust the comment accordingly and also fix
a spelling error.
Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
CC: Mingkai Hu <mingkai.hu@nxp.com>
CC: Gong Qianyu <Qianyu.Gong@nxp.com>
CC: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
CC: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
CC: York Sun <york.sun@nxp.com>
CC: Albert Aribaud <albert.u.boot@aribaud.net>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig.
We do not need two options for the same feature. Deprecate the
former.
This commit was generated with the sed script 's/GENERIC_MMC/MMC/'
and manual fixup of drivers/mmc/Kconfig.
Drop use of this long-deprecated option for powerpc.
This option is pretty old. It predates CONFIG_SYS_I2C which is itself
deprecated in favour of driver model. Disable it for all boards.
Also drop I2C options which depend on this.
Change tbu/l type to unsigned int.
>From the timer file for arm,
"(((unsigned long long)gd->arch.tbu) << 32) | gd->arch.tbl;" is used,
This piece code is based on tbu/tbl is 32bits, so change the type to
unsigned int.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
The variable grf is only referenced if EARLY_DEBUG is defined so move the
declaration to be under the existing guard.
For early debug, the following configs needs to be enabled:
CONFIG_DEBUG_UART=y
CONFIG_DEBUG_UART_OMAP=y
CONFIG_DEBUG_UART_BASE=0x44e09000
CONFIG_DEBUG_UART_CLOCK=48000000
CONFIG_DEBUG_UART_SHIFT=2
CONFIG_DEBUG_UART_ANNOUNCE=y
CONFIG_DEBUG_UART=y
For DRA7xx:
CONFIG_DEBUG_UART_BASE=0x4806a000
For AM57xx:
CONFIG_DEBUG_UART_BASE=0x48020000
am335x supports various sysclk frequencies which can be determined
using sysboot pins. PLLs should be configures based on this
sysclk frequency. Add PLL configurations for all supported
frequencies.
Update MPU frequencies and voltages as per the latest
DM[1] dated: OCT 2011 Revised APRIL 2016, Section 5.4.
Below is the consolidated data:
MPU values for PG 2.0 and later(Package ZCZ and ZCE):
| | ZCZ | ZCE |
| | VDD[V] | ARM [MHz] | VDD[V] | ARM [MHz] |
| NITRO | 1.325 | 1000 | NA | NA |
| TURBO | 1.26 | 800 | NA | NA |
|OPP120 | 1.20 | 720 | NA | NA |
|OPP100 | 1.10 | 600 | 1.10 | 600 |
| OPP50 | 0.95 | 300 | 0.95 | 300 |
There is no eFuse blown on PG1.0 Silicons due to which there is
no way to detect the maximum frequencies supported. So default
to OPP100 for which both frequency and voltages are common on both
the packages.
[1] http://www.ti.com/lit/ds/symlink/am3356.pdf
This configuration should be valid for all F7 family devices in general.
Here is the regions info:
- Region0 : 4GB : cacheable & executable.
- Region1 : 512MB : text area : strogly ordered & executable.
- Region2 : 512MB : peripherals : device memory & non-executable.
- Region3 : 512MB : peripherals : device memory & non-executable.
- Region4 : 512MB : cortexM area: strongly ordered & non-executable.
Higher region number overrides the lower region configuration.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Cortex-M archs support option memory protection unit (MPU). MPU is used
to set the memory types, attributes, access permissions for different regions,
cache policies of the device.
e.g. using MPU it is possible to configure memory region as device memory
or strongly ordered, memory attributes like execute never, cache policies
like write-back or write-through.
Data cache memory needs to be disabled before handing over control to
linux kernel. This patch populates the cleanup_before_linux stub.
Add functionality to flush & invalidate all the dcache using the
prototype declared in common header file.
[trini: Add dummy functions for the not-enabled case]
The boston memory map isn't suited to the simple "all memory starting
from 0" approach that the MIPS arch_fixup_fdt() implementation takes.
Instead we need to indicate the first 256MiB of DDR from 0 and the rest
from 0x90000000. Implement ft_board_setup to do that.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Move the MIPS Coherence Manager (CM) Global Configuration Registers
(GCRs) away from the region of the physical address space which the
Boston board's parallel flash is found in, such that we can access all
of flash without clobbering GCRs.
Without adding a prompt for CONFIG_MIPS_CM_BASE, Kconfig doesn't allow
defconfigs to set it. Provide the prompt in order to allow for that.
Fixes commit a186d26, which missed including SFR NeufBox config from bmips
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Shrink brcm,bcm6328-mc size to avoid overlapping with other controllers
Shrink brcm,bcm6358-mc size to avoid overlapping with other controllers
am335x_evm SPL is very close to its limit in SRAM space.
Switch to use tiny printf to reclaim some size.
Enable SPL_DM on all AM335x based TI platforms.
http://patchwork.ozlabs.org/patch/751300/
No reason to use a separate load script for am33xx than using
omap-common load script.
This is to aid platforms that uses OF_PLATDATA.
Adding support for fdt fixup to update the
memory node in device tree for falcon boot.
This is needed for single stage or falcon
bootmode, to pass memory configuration to
kernel through DT memory node.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Declare the size of ddr very early in spl, so that this can be
used to enable cache.
At present there is not operation to invalidate a cache range. This seems
to be needed to fill out the cache operations. Add an implementation based
on the flush operation.
This should be uint64_t to match its definition in common.h. Fix it.
This adds a new firefly-rk3399 board, MIPI support for rk3399 and
rk3288, rk818 pmic support, mkimage improvements for rockchip and a few
other things.
