path: root/arch
2018-01-19Merge git://git.denx.de/u-boot-arcTom Rini
2018-01-19configs: stm32: move config flag from defconfig to KconfigPatrice Chotard
Move system flags from defconfig to mach-stm32/Kconfig Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-19serial: stm32: Rename serial_stm32x7.c to serial_stm32.cPatrice Chotard
Now this driver is used across stm32f4, stm32f7 and stm32h7 SoCs family, give it a generic name. Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
2018-01-19ARM: qemu-arm: Add support for AArch64Tuomas Tynkkynen
This adds support for '-machine virt' on AArch64. This is rather simple: we just add TARGET_QEMU_ARM_xxBIT to select a few different Kconfig symbols, provide the ARMv8 memory map from the board file and add a new defconfig based on the 32-bit defconfig. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-19arm: mach-omap2: Remove secure certificate name printingAndrew F. Davis
The signing certificate name is always 15 chars long, but need not be null terminated. One solution is then to use printf precision modifiers to only print this many chars ("%.15s"), but tiny printf does not support this, so lets just drop printing the cert name for now. Signed-off-by: Andrew F. Davis <afd@ti.com>
2018-01-19arm: am33xx: security: Fix size calculation on headerMadan Srinivas
Fix the size calculation in the verify boot. The header size should be subtracted from the image size, not be assigned to the image size. Fixes: 0830d72bb9f8 ("arm: am33xx: security: adds auth support for encrypted images") Signed-off-by: Madan Srinivas <madans@ti.com> Signed-off-by: Dan Murphy <dmurphy@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19ARM: dts: omap3-beagle{-xm}: Add support for BeagleBoardDerald D. Woods
This commit adds OMAP3 BeagleBoard devicetree files from Linux v4.15-rc5. This includes standard OMAP34XX board revisions as well as the 'xM' which is OMAP36XX. Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
2018-01-19ARM: dts: am574x-idk: Add initial supportLokesh Vutla
Add initial dts support for am574x-idk Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19board: ti: am57xx: Enable CMD_DDR3Lokesh Vutla
Enable CMD_DDR3 on all am57xx based platforms. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19board: ti: am574x-idk: Add hw data supportLokesh Vutla
Update prcm, voltages and pinmux support for am574x-idk. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19arm: dra762: Add support for device package identificationLokesh Vutla
DRA762 comes in two packages: - ABZ: Pin compatible package with DRA742 with DDR@1333MHz - ACD: High performance(OPP_PLUS) package with new IPs Both the above packages uses the same IDCODE hence needs to differentiate using package information in DIE_ID_2. Add support for the same. Also update clock, ddr, emif information. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19cmd: ti: Generalize cmd_ddr3 commandLokesh Vutla
Keystone and DRA7 based TI platforms uses same EMIF memory controller. cmd_ddr3 command is customized for keystone platforms, make it generic so that it can be re used for DRA7 platforms. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19arm: keystone: Move cmd_ddr3 to a common placeLokesh Vutla
Move cmd_ddr3 to cmd/ti in order to make it build for non-keystone TI platforms. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Rename to ddr3.c not cmd_ddr3.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-19arm: emif-common: Add suppport for enabling ECCLokesh Vutla
For data integrity, the EMIF1 supports ECC on the data written or read from the SDRAM. Add support for enabling ECC support in EMIF1. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Krunal Bhargav <k-bhargav@ti.com>
2018-01-19arm: emif-common: Add ecc specific emif registersLokesh Vutla
This is a slight difference in emif_ddr_phy_status register offsets for DRA7xx EMIF and older versions. And ecc registers are available only in DRA7xx EMIC. Add support for this difference and ecc registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19drivers: dma: ti-edma3: add support for memory fillTero Kristo
Add support for simple memory fill operation. With large data sizes it is much faster to use EDMA for memory fill rather than CPU. Signed-off-by: Tero Kristo <t-kristo@ti.com>
2018-01-19arm: am33xx: Avoid writing into reserved DPLL dividerLokesh Vutla
DPLL DRR doesn't have an M4 divider. But the clock driver is trying to configure M4 divider as 4(writing into a reserved register). Fixing it by making M4 divider as -1. Reported-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19board: ti: K2G FC SoC 1GHz and DDR3 1066 MT/s supportRex Chang
Added support for K2G EVM with FlipChip SoC of which ARM/DDR3 runs at 1GHz/1066 MT/s. The patch is also backward compatible with old revision EVM and EVM with WireBond SoC. Their ARM/DDR3 run at 600MHz/800 MT/s. The new SoC supports 2 different speeds at 1GHz and 600MHz. Modyfied the CPU Name to show which SoC is used in the EVM. Modified the DDR3 configuration to reflect New SoC supports 2 different CPU and DDR3 speeds, 1GHz/1066MT and 600MHz/800MT. Added new inline function board_it_k2g_g1() for the new FlipChip 1GHz, and set the u-boot env variable board_name accordingly. Modified findfdt script in u-boot environment variable to include new k2g board type. Signed-off-by: Rex Chang <rchang@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-01-19board: ti: dra7xx: Select MCAN instead of DCAN on DRA76 EVMVignesh R
MCAN can be accessed via DCAN1 or DCAN2. Determining which DCAN instance to use if any at all is done through CTRL_CORE_CONTROL_SPARE_RW.SEL_ALT_MCAN. Since general pinmuxing is handled in U-boot. Handle this additional pinmuxing requirement in U-boot to ensure that MCAN is used by default via the DCAN1 pins. Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Vignesh R <vigneshr@ti.com> [fcooper@ti.com: Update commit message and use DCAN1 not DCAN2 for MCAN] Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Faiz Abbas <faiz_abbas@ti.com>
2018-01-19mmc: omap_hsmmc: Fix incorrect bit operations for disabling a bitKishon Vijay Abraham I
omap_hsmmc driver uses "|" in a couple of places for disabling a bit. While it's okay to use it in "mmc_reg_out" (since mmc_reg_out has a _mask_ argument to take care of resetting a bit), it's incorrectly used for resetting flags in "omap_hsmmc_send_cmd". Fix it here by using "&= ~()" to reset a bit. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-19mmc: omap_hsmmc: Add support for DMA (ADMA2)Kishon Vijay Abraham I
The omap hsmmc host controller can have the ADMA2 feature. It brings better read and write throughput. On most SOC, the capability is read from the hl_hwinfo register. On OMAP3, DMA support is compiled out. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-19ARC: Invalidate instruction and data caches early on bootEugeniy Paltsev
This is useful to make sure no stale data exists in caches after bootloaders. The worst thing could be some lines of cache were locked in a bootloader for example during DDR recalibration and never unlocked. This may lead to really unpredictable issues later down the line. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-01-19ARC: HSDK: DTS: Add cgu-clk nodeEugeniy Paltsev
Add cgu-clk (clock generation unit) node to HSDK device tree. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-01-19ARC: Cache: Fix style violations reported by checkpatchEugeniy Paltsev
2018-01-19ARC: Cache: Disable IOC by defaultEugeniy Paltsev
We'd like to keep IOC HW at the same state as t is right after reset when we start Linux kernel so there will be no re-configuration of IOC on the go. The point is U-Boot doesn't benefit a lot from IOC as it doesn't do a lot of DMA operations especially on multiple cores simultaneously. At the same time re-configuration of IOC in run-time might become quite a tricky experience because we need to make sure there're no DMA trannsactions in flight otherwise unexpected consequencses might affect us much later and debugging those kinds of issues will be a real nightmare. That said let's make our life easier a little bit. Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-01-19ARC: ARCv2: Cache: Fixed operation without IOCEugeniy Paltsev
Previous SLC management implementation is broken. Seems like it was never sufficiently tested probably because most of the time IOC was used instead (i.e. no manual cache operations were done). Now if we disable IOC in U-boot we'll get a lot of errors while using DMA-enabled peripherals. This time we fix it by substitution of broken per-line SLC operations region operations as it is done in the Linux kernel (we took it from v4.14 which is the latest stable as of today). Among other things this implementation might be a bit faster because instead of iteration over each and every cache line we're taking care about entire region in one go. Main changes: * Replaced __slc_line_op (per line operations) by __slc_rgn_op (region operations). * Reworked __slc_entire_op to get rid of __after_slc_op and __before_slc_op functions. Note flush fix (flush only instead of flush-n-inv when OP_FLUSH is used, see [1] for more details) is already incorporated here. * Added SLC invalidation to invalidate_icache_all(). * Added (start >= end) check to invalidate_dcache_range() and flush_dcache_range() as some buggy drivers pass region start == end. * Added read-out of MMU BCR so we may know if PAE40 exists in HW and then act on a particular AUX regs accordingly. [1] http://lists.infradead.org/pipermail/linux-snps-arc/2018-January/003357.html Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-01-18omap: Update the base address of the MMC controllersJean-Jacques Hiblot
Align the base address defined in header files with the base address used in the DTS. This will facilitate the introduction of the DMA support. Of all HSMMC users, only omap3 doesn't have the 0x100 reserved region at the top. This region will be used to determine if the controller supports DMA transfers Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-18Revert "omap_hsmmc: update struct hsmmc to accommodate omap3 from DT"Jean-Jacques Hiblot
This reverts commit 46831c1a4cda75d92f7ad18d4e2b1eb196c62b2f. This reserved area at the beginning of struct hsmm, will be used later to support ADMA Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-17Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2018-01-16Merge git://git.denx.de/u-boot-i2cTom Rini
2018-01-16imx: mx7ulp: modify lpi2c seq numberPeng Fan
Modify the lpi2c alias seq number to align with device. Then no need to add 4 to get the device index. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2018-01-15armv8: secure firmware: fix incorrect unit address in node nameAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Remove the unit address from the config node name when U-Boot deals with secure firmware FIT images. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2018-01-15doc: fix incorrect usage of DT node unit addressAndre Przywara
The DT spec demands a unit-address in a node name to match the "reg" property in that node. Newer dtc versions will throw warnings if this is not the case. Fix all occurences in various documentation files where this was not observed, to not give bad examples to the reader. Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2018-01-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-01-15db410c: add reserved-memory node to dtsRob Clark
If lk lights up display and populates simple-framebuffer node, it will also setup a reserved-memory node (needed by simplefb on linux). But it isn't clever enough to cope when the reserved-memory node is not present. Signed-off-by: Rob Clark <robdclark@gmail.com>
2018-01-15db410c: replace reset driver with psciJorge Ramirez-Ortiz
this should be the norm for armv8 platforms. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db410c: update wlan and bt mac addresses from firmwareJorge Ramirez-Ortiz
The firmware that runs before u-boot modifies u-boot's device tree adding the local-mac-address and local-bd-address properties for the compatibles "qcom,wcnss-bt" and "qcom,wcnss-wlan". This commit reads that firmware, retrieves the properties and fixups the device tree that is passed to the kernel before booting. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15db820c: stop autoboot when vol- pressedJorge Ramirez-Ortiz
2018-01-15db820c: enable pmic gpios for pm8994Jorge Ramirez-Ortiz
2018-01-15db820c: add qualcomm dragonboard 820C supportJorge Ramirez-Ortiz
This commit adds support for 96Boards Dragonboard820C. The board is based on APQ8086 Qualcomm Soc, complying with the 96Boards specification. Features - 4x Kyro CPU (64 bit) up to 2.15GHz - USB2.0 - USB3.0 - ISP - Qualcomm Hexagon DSP - SD 3.0 (UHS-I) - UFS 2.0 - Qualcomm Adreno 530 GPU - GPS - BT 4.2 - Wi-Fi 2.4GHz, 5GHz (802.11ac) - PCIe 2.0 - MIPI-CSI, MIPI-DSI - I2S U-Boot boots chained from LK (LK implements the fastboot protocol) in 64-bit mode. For detailed build instructions see readme.txt in the board directory. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15arm: mach-snapdragon: refactor clock driverJorge Ramirez-Ortiz
In preparation to add support for the Dragonboard820c (APQ8096), refactor the current Snapdragon clock driver. No new functionality has been added. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2018-01-15armv8/ls1088a: configure PMU's PCTBENR to enable WDTZhang Ying-22455
The SP805-WDT module on LS1088A requires configuration of PMU's PCTBENR register to enable watchdog counter decrement and reset signal generation. The watchdog clock needs to be enabled first. Signed-off-by: Zhang Ying-22455 <ying.zhang22455@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15board: ls1012a: LS1012A-2G5RDB board supportBhaskar Upadhaya
LS1012A-2G5RDB belongs to LS1012A family with features 2 2.5G SGMII PFE MAC, SATA, USB 2.0/3.0, WiFi DDR, eMMC, QuadSPI, UART. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15armv8/kconfig: Align boards of same family at one placeBhaskar Upadhaya
Align boards belonging to LS1012A, LS2080A SoC at one place. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-01-15dm: core: parse chosen nodeRob Clark
This is the node that would contain, for example, the framebuffer setup by an earlier stage. Signed-off-by: Rob Clark <robdclark@gmail.com>
2018-01-14arm: imx: hab: Add hab_failsafe console commandBryan O'Donoghue
hab_failsafe when called puts the part into BootROM recovery mode. This will allow u-boot scripts to script the dropping down into recovery mode. => hab_failsafe Shows the i.MX7 appear as "hiddev0,hidraw5: USB HID v1.10 Device [Freescale SemiConductor Inc SP Blank ULT1] " in a Linux dmesg thus allowing download of a new image via the BootROM USB download protocol routine. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Sven Ebenfeld <sven.ebenfeld@gmail.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Breno Matheus Lima <brenomatheus@gmail.com> Tested-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-14arm: imx: hab: Implement hab_rvt_failsafeBryan O'Donoghue
This patch implements the basic callback hooks for hab_rvt_check_failsafe for BootROM code using the older BootROM address layout - in my test case the i.MX7. Code based on new BootROM callbacks will just do nothing and there's definitely a TODO to implement that extra functionality on the alternative BootROM API. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Sven Ebenfeld <sven.ebenfeld@gmail.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Breno Matheus Lima <brenomatheus@gmail.com> Tested-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-14arm: imx: hab: Define rvt_failsafe()Bryan O'Donoghue
The hab_rvt_failsafe() callback according to the HABv4 documentation: "This function provides a safe path when image authentication has failed and all possible boot paths have been exhausted. It is intended for use by post-ROM boot stage components, via the ROM Vector Table." Once invoked the part will drop down to its BootROM USB recovery mode. Should it be the case that the part is in secure boot mode - only an appropriately signed binary will be accepted by the ROM and subsequently executed. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Sven Ebenfeld <sven.ebenfeld@gmail.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Breno Matheus Lima <brenomatheus@gmail.com> Tested-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-14arm: imx: hab: Make imx_hab_is_enabled globalBryan O'Donoghue
It will be helpful to boot commands to know if the HAB is enabled. Export imx_hab_is_enabled() now to facilitate further work with this data-point in a secure-boot context. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Sven Ebenfeld <sven.ebenfeld@gmail.com> Cc: George McCollister <george.mccollister@gmail.com> Cc: Breno Matheus Lima <brenomatheus@gmail.com> Tested-by: Breno Lima <breno.lima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-14arm: imx: hab: Make authenticate_image() return zero on open boardsBryan O'Donoghue
The BootROM will not successfully process a HAB image passed by u-boot unless the board has been set into locked mode. Some of the existing usages of authenticate_image() expect and rely on unlocked boards doing the following 1. Not calling into the BootROM authenticate_image() callback 2. Returning a pass status for authenticate_image() calls anyway A previous patch removed the necessity to call into imx_hab_is_enabled() twice. This patch ensures the reliance on authenticate_image() returning zero is maintained. Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Suggested-by: Breno Matheus Lima <brenomatheus@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <peng.fan@nxp.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Sven Ebenfeld <sven.ebenfeld@gmail.com> Cc: George McCollister <george.mccollister@gmail.com> Tested-by: Breno Lima <breno.lima@nxp.com>
