When U-boot is loaded via verified boot it starts at the
_x86boot_start entry point and promptly disables caching,
resulting in about a 500ms hit to boot time.
BUG=chrome-os-partner:8518
TEST=boot on lumpy with RW BIOS and gather timestamps
to observe 500ms less time spent in u-boot init.
Change-Id: I4eb1ad5ebcb20a156fef77452030e47a5e510115
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/18371
Reviewed-by: Stefan Reinauer <reinauer@google.com>
BUG=chromium-os:23496
TEST=build and boot on Waluigi, Cardhu by enabling
CONFIG_TEGRA_LP0 and CONFIG_TEGRA3_WARMBOOT.
odification of the work done by:
a. Jimmy Zhang <jimmzhang@nvidia.com>
b. Yen Lin <yelin@nvidia.com>
c. Wei Ni <wni@nvidia.com>
Change-Id: If2fa63ccd23341694955bca25fb5cfc4a8a805ad
Reviewed-on: https://gerrit.chromium.org/gerrit/13800
warmboot_avp.h needs to be present in include/arch-tegra
in order to use it for Tegra3.
TEST=build for Seaboard
Change-Id: I3f369194e4002e8257c9d2ff37253bc20733138d
Reviewed-on: https://gerrit.chromium.org/gerrit/15394
TEST=build for Cardhu, Waluigi and Seaboard
Change-Id: I6d26502d1ecc393b266ffe06b540f59c595e19ae
Reviewed-on: https://gerrit.chromium.org/gerrit/14811
Change-Id: Ifa06f941798ff242197dcd31f4091567d91fe4b2
Reviewed-on: https://gerrit.chromium.org/gerrit/14810
Change-Id: I74bb2418ab996e362060351de3ba7efd538ffd87
Reviewed-on: https://gerrit.chromium.org/gerrit/14809
Change-Id: I20ac75c71d86d65ff422ff3f4f966a69718f4f91
Reviewed-on: https://gerrit.chromium.org/gerrit/14808
These registers would be useful for the warmboot code.
Change-Id: I58f52b6b8653d72b2e842ee44bdf3632eff304a2
Reviewed-on: https://gerrit.chromium.org/gerrit/14690
Would be useful for the warmboot code.
Change-Id: I271f6cdcc0248337e516c2c32014c6ec4f08fb15
Reviewed-on: https://gerrit.chromium.org/gerrit/14689
code.
Change-Id: I8da1ed3a382e1b65247236cb19f527f81d8ecaac
Reviewed-on: https://gerrit.chromium.org/gerrit/14688
Change-Id: Iacd6fdb178afbfdb978dbe53bbe2766916bf26f9
Reviewed-on: https://gerrit.chromium.org/gerrit/14685
Change-Id: I32dbfa02ac1d6954b3a7e515914fbc0b6695f98b
Reviewed-on: https://gerrit.chromium.org/gerrit/14683
split the LP0 code for tegra2 into common
LP0 code and chip specific warm boot code
Change-Id: Ie04bf9ac17482a37afd0f4515dc3aafeb4f48ae7
Reviewed-on: https://gerrit.chromium.org/gerrit/15883
This reverts commit 4c7502242627f64d91432cb4958be5f93f65fbff
Don't think this is the cause of http://code.google.com/p/chromium-os/issues/detail?id=26116, but it was in the same batch so I'm reverting in the process.
Change-Id: Icc013ced6c22e29d569ee4ca8ef73522154ec1a8
Reviewed-on: https://gerrit.chromium.org/gerrit/15561
Reviewed-by: Brian Harring <ferringb@chromium.org>
Tested-by: Brian Harring <ferringb@chromium.org>
This reverts commit 9a3fbb5f0b02382c7abe0cf40a4f08abbf269d05
Broke tegra2: http://code.google.com/p/chromium-os/issues/detail?id=26116
Change-Id: I7d35211c6ebce7a10750cb1033c6f8ba9a0f63bc
Reviewed-on: https://gerrit.chromium.org/gerrit/15560
move away from the current method, where we add wb_end() immediately
after wb_start() and then use the function addresses to calculate the
WB code size. Add a .lds script to expose __wb_end after wb_start() in
the .text section and then reference this variable in the WB size
calculation code.
TEST=build on Seaboard. Verified that uboot.map has the correct address
assigned to __wb_end and that LP0 works reliably.
Change-Id: I170277f00b450d38063018453faf44d5a38abaaa
Reviewed-on: https://gerrit.chromium.org/gerrit/14682
Change-Id: Id9756c08f61502affa8beee636d883d01468e6ec
Reviewed-on: https://gerrit.chromium.org/gerrit/13799
As clock source for graphics related clocks is different
for Tegra2 and Tegra3, define it under platform specific
directories.
TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi.
Original work by -
Mayuresh Kulkarni <mkulkarni@nvidia.com>
Change-Id: I6cee11df5e75eaf3836565c4fa4f3ab3e45d8cac
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/14700
Set display parent clock separately for Tegra2 and Tegra3.
TEST=Built ok for Cardhu Walgui and Seaboard. Tested on Waluigi.
Change-Id: Ie03d37b8dda77dcfcb72e70c34e769a23323e598
Reviewed-on: https://gerrit.chromium.org/gerrit/14697
Add a case for returning RAM size as 2GB by reading
PMC scratch20 register.
Change-Id: I5dc8fdf7cd9718e5dd2ca24cd1f467c5b6e9a6aa
Reviewed-on: https://gerrit.chromium.org/gerrit/14696
Move pwfm.c and display.c under common folder tegra-common.
TEST=Built ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi.
Change-Id: I23c5f02270dde7bfdd6e1d26ed9984385986194e
Reviewed-on: https://gerrit.chromium.org/gerrit/14694
Implement arch_phys_memset so that it can set memory at physical addresses
above 4GB using PAE paging. Because there are only 5 page tables in PAE mode,
1 PDPT and 4 PDTs, those tables are statically allocated in the BSS. The
tables must be 4K page aligned and are declared that way, and because U-Boot
starts as 4K aligned and the relocation code relocates it to a 4K aligned
address, the tables work as intended.
While paging is turned on, all 4GB are identity mapped except for one 2MB
page which is used as the window into high memory. This way, U-Boot will
continue to work as expected when running code that expects to access memory
freely, but the code can still get at high memory through its window.
The window is put at 2MB so that it's 2MB page aligned, low in memory to be
out of the way of things U-Boot is likely to care about, and above the lowest
1MB where lots of random things live.
BUG=chrome-os-partner:7579
TEST=From the original, larger patch:
Built and booted on Lumpy, Stumpy, and Kaen. Looked at the log to see
that the regions in high memory are listed as cleared. Artificially injected
a range to "clear" with 0xA5 and then 0x5A which was over the framebuffer and
covered part or all of the screen on Lumpy. Verified that the screen was
partially or completely filled with an appropriate looking color. Had U-Boot
print the PDTs it was generating to verify that the high address bits were
preserved. Identity mapped only some of memory and verified that things that
should be mapped were accessible and things that shouldn't be weren't.
Signed-off-by: Gabe Black <gabeblack@google.com>
Change-Id: I1b3a038009de4312edba56ced1a91f9b0f6858b4
Reviewed-on: https://gerrit.chromium.org/gerrit/14418
Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
Tested-by: Gabe Black (Do Not Use) <gabeblack@google.com>
When this code picked an area for U-Boot to relocate to, it was making sure
that there was enough space for U-Boot's various sections. It wasn't taking
into account the space needed for the heap and stack, however, so if it
happened to pick a very small region those areas might overlap with something
they shouldn't. This change fixes that.
Also, this change replaces the ROUND macro with the new rounddown introduced
in a previous change. It was assumed that ROUND rounded down, in contrast to
the other rounding function in common.h, roundup. It turns out that ROUND
rounds up even more agressively than roundup. If the value being rounded is
already exactly a multiple of the rounding amount, ROUND will still increase
it to the next multiple.
Because the region U-Boot had been choosing has plenty of space, there should
be no functional difference with this change.
TEST=Built and booted on Lumpy, Stumpy, and Kaen.
Change-Id: I39a45be6487ed0f60ea0900fb10632da5b312ebe
Reviewed-on: https://gerrit.chromium.org/gerrit/14222
The use of post-increment with a do-while loop results in
the loop going one step too far when handling relocation fixups.
In about 1/100 cases this would cause it to hang.
BUG=chromium-os:25121
TEST=boot with serial enabled and extra debug to dump
the relocation addresses to ensure that it stops when
getting to the end of the rel.dyn section.
Change-Id: I4d3686d9c90ccfd0df0dd4d8a6483c534c93d3f2
Reviewed-on: https://gerrit.chromium.org/gerrit/14290
Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
Reviewed-by: Ronald G. Minnich <rminnich@chromium.org>
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
Because calculate_relocation_address now uses the e820 map, it will be able
to avoid addresses over 32 bits and regions that are at high addresses but
not big enough for U-Boot. It also means we can remove the hack which
limitted U-Boot's idea of the size of memory to less than 4GB.
BUG=None
TEST=Built and booted on Lumpy. Built on Kaen.
Change-Id: I3ada4e5325ae3a0e652cf79486970e967aef6da6
Reviewed-on: https://gerrit.chromium.org/gerrit/14152
The way these are declared is different upstream, so these are being added in
a separate change to make rebasing easier.
BUG=None
Change-Id: If84e0c36bd3615a561dec80eb71741c78db869b3
Reviewed-on: https://gerrit.chromium.org/gerrit/14211
Different systems may have different mechanisms for picking a suitable place
to relocate U-Boot to.
BUG=None
TEST=Built and booted on Lumpy. Built for Kaen.
Change-Id: If3b9983865917307a4f546e8a1c35260a5dba7a4
Reviewed-on: https://gerrit.chromium.org/gerrit/14151
Commit-Ready: Gabe Black (Do Not Use) <gabeblack@google.com>
These types should be 64 bits long to reflect the fact that physical
addresses and the size of physical areas of memory are more than 32 bits
long.
BUG=None
Change-Id: I58bc69051db027d6eb718ec1c92a3d4afa2b7561
Reviewed-on: https://gerrit.chromium.org/gerrit/14150
When relocating symbols, U-Boot only relocates the ones that fall within the
range of address that are actually being moved. This change makes the upper
bound of that region closed (less than or equal to) instead of open (less
than) so that the __bss_end symbol is processed as well.
BUG=None
Change-Id: Ic1ee7402621dc266b3776ea5bdf3254ef51bc4ac
Reviewed-on: https://gerrit.chromium.org/gerrit/14148
Reviewed-by: Bill Richardson <wfrichar@chromium.org>
U-boot is unable to actually use that memory and it can
cause problems with relocation if it tries to.
BUG=chrome-os-partner:6730
TEST=successfully boot on stumpy with a memory map
that ends up having 6MB remapped above 4GB.
Change-Id: I9ecde227bc0337145a7c0a6a929cfe0636fc2178
Reviewed-on: https://gerrit.chromium.org/gerrit/13923
This allows booting without a display, mostly as a way of calculating
the time that LCD init and maintenance costs us. Perhaps we might
integrate the lcd and video APIs within U-Boot - it would be a much
nicer solution. With that in mind I feel it is not work refactoring
this into three separate (lcd, video, none) files to implement the
display API.
BUG=chromium-os:22938
TEST=build and boot on Kaen
Change-Id: Iea4656f8939f7f2fd78292827091de4ee379954b
Reviewed-on: https://gerrit.chromium.org/gerrit/13369
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
While we wait for the new relocation stuff to come down from upstream,
this uses memset/memcpy() to do the business. Saves about 20ms on boot.
Change-Id: I958b9f53f27c67d4da2fa0f7a2148c59ed48f7aa
Reviewed-on: https://gerrit.chromium.org/gerrit/13215
Commit-Ready: Simon Glass <sjg@chromium.org>
Delay serial console calls and do them later, to support the
CONFIG_DELAY_CONSOLE option.
Change-Id: Ie15a887843a8b5f29fce055f7a2e17b7fc1e614f
Reviewed-on: https://gerrit.chromium.org/gerrit/13209
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
When DEBUG is enabled, display important clocks during init.
Change-Id: Ic27e7d79bdcd9cf44d94ec25c52fc8776ddc7d04
Reviewed-on: https://gerrit.chromium.org/gerrit/13205
Relocation takes about 40ms of the boot time, so add a timer to track it.
Change-Id: If936bc8ff9a23f6dd885f60e845a597ac7edad97
Reviewed-on: https://gerrit.chromium.org/gerrit/13203
u-boot would load the environment from flash unconditionally
on x86. This is a security issue when booting ChromeOS in normal mode.
Add a function that looks at the device tree variable load_env to
determine whether to load it.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
BUG=none
TEST=boot tested on Stumpy
Change-Id: I7e4655e151b7421ec8ff9d0ce40b6de17bfede5d
Reviewed-on: https://gerrit.chromium.org/gerrit/12987
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
TEST=built Seaboard and Waluigi OK
Signed-off-by: Tom Warren <twarren@nvidia.com>
Change-Id: I954cdb71eb80a3cf48f44b9a7183a2cafcb7755b
Reviewed-on: https://gerrit.chromium.org/gerrit/12442
Some clocks cannot be set to the final value until we have the fdt
and know what PLLP should be set to. For now the only example is
coresight - so this adds a call to update this clock once the A9
is up and running with the fdt.
TEST=build and boot on Seaboard, T33, Kaen
Change-Id: I7a07306cfb0a24cec4dcdb08cac78659a1afc73f
Reviewed-on: https://gerrit.chromium.org/gerrit/12251
This setting is now in the fdt, so remove the CONFIG item.
Change-Id: I336a6cc2140c725fdda85330efe617f82f205a90
Reviewed-on: https://gerrit.chromium.org/gerrit/12250
We want to use the fdt inside board_early_init_f(), so check for its
presence earlier in the pre-reloc init sequence.
Change-Id: I66fdaf976ddb419b754cc20374db4ffdcca16a09
Reviewed-on: https://gerrit.chromium.org/gerrit/12247
Since PLLP can be set to two different values, make it a parameter
to the function that sets up the PLLs.
Change-Id: I81ccc1cc3356796793ec2dd4ab22ed7fbd52f01d
Reviewed-on: https://gerrit.chromium.org/gerrit/12245
This is using the latest patch recommendation from Dilan at Nvidia, we adjust
the ordering to clear bypass earlier and remove the delay.
This patch was run successfully for over 2000 reboots.
BUG=chrome-os-partner:6145
TEST=Manual
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
Change-Id: I9ef2f12d5c8abae86791f50b0f5e0e5a4249d947
Reviewed-on: https://gerrit.chromium.org/gerrit/12385
Reviewed-by: Micah Catlin <micahc@google.com>
Commit-Ready: Bernie Thompson <bhthompson@chromium.org>
Tested-by: Bernie Thompson <bhthompson@chromium.org>
This function is better off in architecture code than board code.
This is quite an invasive change unfortunately.
Change-Id: I17764b134c25b684666d2c0fae2d255ac80e61b1
Reviewed-on: https://gerrit.chromium.org/gerrit/12244
intermittent hang
Currently with 200uS delay after PLL for stability.
TEST=None
Originaly-Reviewed-on: https://gerrit.chromium.org/gerrit/11091
Originaly-Reviewed-by: Bernie Thompson <bhthompson@chromium.org>
Originaly-Tested-by: Bernie Thompson <bhthompson@chromium.org>
Originaly-Commit-Ready: Katie Roberts-Hoffman <katierh@chromium.org>
Originaly-Reviewed-by: Katie Roberts-Hoffman <katierh@chromium.org>
Signed-off-by: Doug Anderson <dianders@chromium.org>
Change-Id: Idcb95d4698ea856785be8a8232c08c89309af887
Reviewed-on: https://gerrit.chromium.org/gerrit/12158
BUG=chromium-os:21033
TEST=built Seaboard & Waluigi OK. Booted my Waluigi to cmd prompt OK.
MMC, SPI and I2C still work fine, as does UART.
More can be done at a later date to cleanup AP20.c for T30 (and
rename/move it, since AP20 is a T2x name) and use new T30 V/W clock
enables/resets/sources/etc.
Change-Id: Ia3a86c519481fffde6926e1fece1dcf898d199c9
Reviewed-on: https://gerrit.chromium.org/gerrit/11911
Tested-by: Tom Warren <twarren@nvidia.com>
This change finishes plumbing the initrd support built into the zboot
mechanism out to the command interface.
It also fixes a bug in the command declaration where the kernel size could
be passed as an optional second parameter but not enough arguments were
allowed.
BUG=chrome-os-partner:6715
TEST=Built and booted on a Lumpy with the U-Boot command line exposed. Used
the Linux kernel in the system partition and the initramfs used for recovery
to boot the system. Observed that the recovery scripts in the initramfs ran.
The hardest part about implementing this change was testing because it took
many attempts to build/find an initrd/initramfs and command line that would
actually work. I'm confident the problems I had were from not knowing how to
set up or use an initramfs properly, not from the U-Boot support itself.
Change-Id: Iccc5ff62e170e738dfb429a6b0ef9e27f0e7d8a9
Reviewed-on: https://gerrit.chromium.org/gerrit/12027
Tested-by: Gabe Black <gabeblack@chromium.org>
U-Boot Makefiles contain a number of tests for compiler features etc.
which so far are executed again and again. On some architectures
(especially ARM) this results in a large number of calls to gcc.
This patch makes sure to run such tests only once, thus largely
reducing the number of "execve" system calls.
Example: number of "execve" system calls for building the "P2020DS"
(Power Architecture) and "qong" (ARM) boards, measured as:
-> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board>
-> grep execve /tmp/foo | wc -l
Before: After: Reduction:
P2020DS 20555 15205 -26%
qong 31692 14490 -54%
As a result, built times are significantly reduced, typically by
30...50%.
Change-Id: I6e8c7c37cd13c56cb64d0a410514f2b9dc2d5adb
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Albert Aribaud <albert.aribaud@free.fr>
cc: Graeme Russ <graeme.russ@gmail.com>
cc: Mike Frysinger <vapier@gentoo.org>
(cherry picked from commit 77d94d2d86c055f015734cc4cd972a5de30fc5a2)
Reviewed-on: https://gerrit.chromium.org/gerrit/11806
Reviewed-by: Doug Anderson <dianders@chromium.org>
TEST=Built and booted OK on my Waluigi. UART is OK, mmc, spi, i2c OK.
Note that this is only valid with CONFIG_SYS_PLLP_BASE_IS_408MHZ.
No affect on Tegra2. Seaboard builds fine, BTW.
Change-Id: I05a367afd1e78a2170d7308a658ce64017850ca0
Reviewed-on: https://gerrit.chromium.org/gerrit/11811
Commit-Ready: Che-Liang Chiou <clchiou@chromium.org>
BUG=none
TEST=built Seaboard and Waluigi AOK
Change-Id: Ia860abf5ef3af66b3a39d4c57192455986b7a4f4
Reviewed-on: https://gerrit.chromium.org/gerrit/11704
Commit-Ready: Doug Anderson <dianders@chromium.org>
