Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: u-boot-dm@lists.denx.de
Prepare for device-tree driven configuration.
Acked-by: Stephan Linz <linz@li-pro.net>
Move board specific function to board_init function in board/ folder
Remove externs from generic board.c
Use board_init_f function in board.c file.
Fix CONFIG_SYS_HZ usage in board config.
Do not use hardcoded value. Use CONFIG_SYS_HZ instead.
Separate static configuration to single block.
Just coding style cleanup.
Remove unneeded externs.
Return value to find out if un/registration was succesful.
Variable is used when CONFIG_SYS_FLASH_CHECKSUM is used.
Warning log:
board.c: In function 'board_init':
board.c:101: warning: unused variable 's'
This is minimum code required to be able to use device-tree
for u-boot initialization.
Currently only for device driver initialization.
Linker script change ensures DTB to be aligned
for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE.
CC: Simon Glass <sjg@chromium.org>
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
Useless code is removed, and get buswidth value.
buswidth value will be used to choice the 4bit or 8bit.
(Now used 4bit mode in sdhci.c by default)
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Kyungmin Park <kyungin.park@samsung.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
* 'master' of git://git.denx.de/u-boot-avr32:
net:macb: add line break
avr32:portmux: fix setup for macb1
avr32: Remove redundant LDSCRIPT definition
Use portd_mask instead of portc_mask to setup the pins for port D.
Since commit 50a47d0523e8efebe912bef539a77ffd42116451
(net: punt bd->bi_ip_addr) booting old 2.4.x ppc kernels
is broken due to changed offsets of the fields in struct bd_t.
Offsets of the fields after removed bi_ip_addr are wrong,
causing wrong bus clocks and console baudrate configurations
and various other issues. Re-add the bi_ip_addr field to preserve
backward compatibility with older ppc kernels. Setting bi_ip_addr
in board.c is not really needed, grepping in the 2.4 linux tree
shows that bi_ip_addr is not accessed there. Adding bi_ip_addr
to struct bd_t for other arches isn't needed it seems. bd_t is
not used by other arches in the 2.4 linux tree.
Acked-by: Wolfgang Denk <wd@denx.de>
wait_ticks() calls get_ticks() without building a back chain which
makes gdb unhappy when doing back trace. This can also cause
improper memory accesses.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
* 'master' of git://git.denx.de/u-boot-usb:
MUSB driver: Timeout is never detected as the while loop does not end
usb: fix ulpi_set_vbus prototype
pxa25x: Add UDC registers definitions
USB: Fix strict aliasing in ohci-hcd
usb: Optimize USB storage read/write
ehci: Optimize qTD allocations
usb_stor_BBB_transport: Do not delay when not required
usb_storage: Remove EHCI constraints
usb_storage: Restore non-EHCI support
ehci-hcd: Boost transfer speed
ehci: cosmetic: Define used constants
ehci: Fail for multi-transaction interrupt transfers
arm:trats: Enable g_dnl composite USB gadget with embedded DFU function on TRATS
arm:trats: Support for USB UDC driver at TRATS board.
dfu:cmd: Support for DFU u-boot command
dfu: MMC specific routines for DFU operation
dfu: DFU backend implementation
dfu:usb: DFU USB function (f_dfu) support for g_dnl composite gadget
dfu:usb: Support for g_dnl composite download gadget.
ehci: cosmetic: Define the number of qt_buffers
AVR32's LD script uses a standard location that is now automatically detected by
the main Makefile, so its definition in AVR32's config.mk is now obsolete and
redundant.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Fix the name error
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Signed-off-by: Łukasz Dałek <luk0104@gmail.com>
Define ARCH_MXC for i.MX devices. This is useful to identify features or
behaviors common to all i.MX SoCs.
The i.MX28 is omitted because its architecture is a bit different (like imx/mxc
vs. mxs in Linux).
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
For representing a timeout value, it makes more sense to pass it as
'unsigned int'.
Align this structure to DMA alignment size.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
The gpio api has been tested on an armadeus apf27.
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
Allow usage of the imx-common/iomux-v3.h framework by including pad settings
for the i.MX51. The content of the file is taken from Linux kernel at
commit 5d23b39 plus the required changes to make it work in U-Boot.
The contained pad settings are the minimum required to make an Efika MX boot
and get all the currently-implemented peripherals working in U-Boot.
It is recommended that this file not be just a dumping ground for pins but
only contain the settings required for all the boards using it.
Changes for v2:
* reference commit id from Linux kernel
* additionally roll in the USB pads
* removed GPIO_NUMBER define
Signed-off-by: Matt Sealey <matt@genesi-usa.com>
The DRAM initialization, after SPL has complete, is exactly the same
for all mxs SoCs so we should name it accordinly.
The following boards has been changed:
* apx4devkit
* m28evk
* mx28evk
* sc_sps_1
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
The internal Ethernet controller is only available on i.MX28
processors so it needs to use CONFIG_MX28 guardian to avoid having
this code called in others.
All other header are going to use i.MX23 so we change this for
consistency.
The imx_decode_pll() function does not exist for mx5, so remove its declaration.
Each i.MX has its own gpio.h, defining the same structure.
The internal GPIO controller has the same layout
(at least for the register used by u-boot) and can be shared.
Tested-by: Matt Sealey <matt@genesi-usa.com>
commit d92591a (mxs: Convert sys_proto.h prefixes to 'mxs') introduced
a mxs_dram_init() function, which is not used anywhere.
Fix it, so that the following warning goes away:
mx28evk.c: In function ‘dram_init’:
mx28evk.c:67:2: warning: implicit declaration of function ‘mx28_dram_init’ [-Wimplicit-function-declaration]
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
The elftosb call needs to use a target param specific for i.MX28. This
patch allow for later addition of i.MX233.
Add cpu_mmc_init() function to make it easy to init a single eSDHC instance.
Do not pretend to have initialized mmc successfully if CONFIG_FSL_ESDHC is not
defined. Instead, only implement a custom cpu_mmc_init() when it does something.
This is useful for forcing the ROM's
usb downloader to activate upon a watchdog reset.
Or, you can boot from either SD Card.
Currently, support added for MX53 and MX6Q
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Note: MX53 support untested.
Move mx6 specific defines to arch-mx6 directory.
Coding style cleanup:
- Remove useless parentheses.
- Use tabs for indentations and alignments.
Round up tick_to_time() value instead of truncating it. This avoids stopping
waits instantly for low usec values, and this generally guarantees that the code
always waits for at least the requested duration.
Now that the main i.MX features work fine with dcache enabled, enabled it by
default if CONFIG_SYS_DCACHE_OFF is not defined.
This driver has been tested on board armadeus apf27.
