An option is provided to avoid using SDL in U-Boot sandbox (and drop
support for the LCD). However the check in the Makefile is too late
and warnings are printed even if NO_SDL=y is given.
Adjust the order to avoid this warning.
Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
When a command is passed into sandbox using the '-c' argument the
command is run directly. This is most helpful when running tests (such
as test-dm.sh). Previously the exit code was an unused enum. Change it
to be the actual return code from the command so that the script calling
sandbox can know if the command succeeded (tests passed). Also remove
the now completely unused "exit_state" in sandbox.
Since we have src, div and pre-div mask bits defined corresponding
to peripherals, calculation of clock specific to I2C appears
redundant and confusing. Using clk_bit_info struct we can write
calculations generic to all peripherals which makes code easy to
understand and free from peripheral specific exceptions.
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
We have assumed and kept mask bits for divider and pre-divider
as 0xf and 0xff, respectively. But these mask bits change from
one peripheral to another, and hence, need to be specified in
accordance with the peripherals.
Replacing SoC and peripheral specific function calls with generic
clock_get_periph_rate calls to get the peripheral clocks.
Also, removing dead code of peripheral and SoC specific function
implementations which was used earlier for fetching peripheral clocks.
This code is not being used anymore because of the introduction
of generic clock_get_periph_rate function.
exynos5_get_periph_rate function reads incorrect div for
SDMMC2 & 3. It also reads prediv and does division only for
SDMMC0 & 2 when actually various other peripherals need that.
Adding changes to fix these mistakes in periph rate calculation.
We planned to fetch peripheral rate through one generic API per
peripheral. These generic peripheral functions are in turn
expected to fetch apt values from a function refactored as
per SoC versions. This patch adds support for fetching peripheral
rates for Exynos5420 and Exynos5800.
Moving exynos5420_get_pll_clk function definition up in the
code to keep it together with rest of SoC_get_pll_clk functions.
This makes code more legible and also removes the need of
declaration when called before the position of definition in
code. Also, renaming exynos5420_get_pll_clk to
exynos542x_get_pll_clk because it is being used for both Exynos
5420 and 5800.
Apparently, members of clk_bit_info array do not map correctly
to the members of enum periph_id. This mapping got broken after
we changed periph_id(s) to reflect interrupt number instead of
their position in a sequence. This patch intends to fix above
mentioned issue.
Exynos5420 has different registers with other exynos5 SoCs to control
usb device phy, so need separated function to enable exynos5420 usb
device phy.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
This needs for special handling of nRESET_OUT line(GPD1-0 gpio) for eMMC
memory to perform complete reboot on Odroid XU3 board.
This needs for special handling of nRESET_OUT line(GPK1-2 gpio) for eMMC
memory to perform complete reboot on Odroid X2/U3 boards.
The most exynos used the "Ratio + 1" as div value.
And value at register is "Ratio".
So if want to set exact value, it needs to subtract one.
Value at register ("Ratio") = div - 1
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
ARC HS and ARC EM are new cores based on ARCv2 ISA which is binary
incompatible with ISAv1 (AKA ARCompact).
Significant difference between ISAv2 and v1 is implementation of
interrupt vector table.
In v1 it is implemented in the same way as on many other architectures -
as a special location where user may put whether code executed in place
(if machine word of space is enough) or jump to a full-scale interrupt
handler.
In v2 interrupt table is just an array of adresses of real interrupt
handlers. That requires a separate section for IVT that is not encoded
as code by assembler.
This change adds support for following cores:
* ARC EM6 (simple 32-bit microcontroller without MMU)
* ARC HS36 (advanced 32-bit microcontroller without MMU)
* ARC HS38 (advanced 32-bit microcontroller with MMU)
As a part of ARC HS38 new version of MMU (v4) was introduced.
Also this change adds AXS131 board which is the same DW ARC SDP base board but
with ARC HS38 CPU tile.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
r8a7794 uses ARM SoC of CA7 base. If we want to use dcache on CA7, we
need to enable SMP bit of Auxiliary Control Register.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
SILK is an entry level development board based on R-Car E2 SoC (R8A7794)
This commit supports the following peripherals:
- SCIF, I2C, Ethernet, QSPI, MMC, USB Host
Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com>
Reviewed-by: Tom Rini <trini@ti.com>
Move this option to Kconfig and update all boards.
With driver model the number of PIO ports is defined by platform data, so
remove it from the header file.
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
Remove driver model CONFIGs from the board config headers and use Kconfig
instead.
instead.
instead.
instead.
instead.
Remove driver model CONFIGs from the board config header and use Kconfig
instead.
These additional nodes need to be provided to get U-Boot to boot correctly
on the Canyonlands / Glacier board:
- chosen path to the console-uart
- reg-shift set to 0 in the uart device nodes
This permits us to use linux/linkage.h on PowerPC machines.
This comes from the device tree or a call to get_uart_clock().
Define an _end symbol indicating the end of u-boot.bin. Also add some dummy
words into the link script to ensure that u-boot.bin will always extend
that far. There may be a better way of doing this.
This is required at present for device tree control. The ppc4xx does support
GPIOs but does not seem to have a proper driver. So this file is empty.
Call this function to set up our early memory.
The canyonlands.h config file works with canyonlands, glacier and arches
boards. Bring in the device tree files for these from Linux 3.17.
Switch to generic board so that this board will not be broken/removed.
Add a new ramboot config for glacier so that it is possible to test U-Boot
loaded over Ethernet instead of using JTAG.
Many CONFIG options have an unnecessary value of 1. CONFIG_440 is set in
the various board config files. Also simplify the CONFIG_440 check in
config.mk
Enable this in the Kconfig so that PowerPC boards can use device tree to
configure U-Boot.
When booting in JTAG mode, there is no way to use soft break-points, and
no way of knowing when SPL has finished executing (so the user can issue
a 'halt' command to load u-boot.bin for example)
Add a debug output and simple loop to stop execution at the completion of
the SPL initialisation as a pseudo break-point when booting in JTAG mode
Signed-off-by: Graeme Russ <gruss@tss-engineering.com>
Section 4.1.2 of Freescale Application Note AN4199 describes the
configuration required to operate the mx28 from a 5V source without a
battery.
This patch changes the behaviour of the dropout control of the DC-DC
converter (refer to section 11.12.9 of the mx28 Application Processor
Reference Manual - Document Number: MCIMX28RM, Rev 2, 08/2013) to the
following:
- Always use 4P2 Linear Regulator if CONFIG_SYS_MXS_VDD5V_ONLY is defined
- Switch between 4P2 Linear Regulator and Battery, using whichever has
the highest voltage if CONFIG_SYS_MXS_VDD5V_ONLY isnot set (this is
the same as the pre-patch behaviour)
Signed-off-by: Damien Gotfroi <dgotfroi@greenwatch.be>
It is difficult to track down fail to boot issues in the mxs SPL.
Implement the following to make it easier:
- Add debug outputs to allow tracing of SPL progress in order to track
where failure to boot occurs. DEUBUG and CONFIG_SPL_SERIAL_SUPPORT must
be defined to enable debug output in SPL
- Add TODO comments where it is not clear if the code is doing what it
is meant to be doing, even tough the board boots properly (these comments
refer to existing code, not to any code added by this patch)
Should use AIPS3 configuration address 0x0227C000 to set AIPS3,
not the AIPS3 base address.
Additional, replace AIPS1_BASE_ADDR to AIPS3_ARB_BASE_ADDR to align with
AIPS1 and AIPS2, and resolve the AIPS3_ARB_BASE_ADDR undefine problem.
Signed-off-by: Ye.Li <B37916@freescale.com>
Update fuse_bank0_regs structure according reference mannual.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
