Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Resynchronize memcpy/memset with kernel and build them explicitly
in Thumb2 mode (unified syntax). Those assembler files can be
built and linked in ARM mode too, however when calling them from
Thumb2 built code, the stack got corrupted and the copy did not
succeed (the exact details have not been traced back). Hoever,
the Linux kernel builds those files in Thumb2 mode. Hence U-Boot
should build them in Thumb2 mode too when CONFIG_SYS_THUMB_BUILD
is set.
Also add implicit-it=always to AFLAGS when building for Thumb2.
Furthermore add no-warn-deprecated option to AFLAGS to rid of
deprecated unified syntax:
arch/arm/lib/memcpy.S: Assembler messages:
arch/arm/lib/memcpy.S:153: Warning: conditional infixes are deprecated in unified syntax
arch/arm/lib/memcpy.S:154: Warning: conditional infixes are deprecated in unified syntax
DDR leveling parameters are board specific, hence we should be able
to set them differently per board. Extract the leveling parameters
in a seperate struct to be able to set them per board.
With the new JEDEC standardized initialization parameter, the
initialization takes longer than 200us. Use the status bit to
determine whether the memory initialization was completed.
Also use recommended JEDEC defaults for t_INIT.
Vybrid product family consists of several rather similar SoC which
can be determined by softare during boot time. This allows to use
the variable ${soc} for Linux device tree files.
Enables caches which provides a rather huge speedup of the boot
loader. Also mark the on-chip RAM as cachable since this is the
area U-Boot runs from.
Since we use the same UART to download U-Boot and get the U-Boot
prompt, it is quite hard to switch between the download program
and the terminal emulator within the boot delay. This patch
disables the automatic boot by setting the bootdelay to -1 when
using the recovery mode (serial downloader).
Detect VF5xx CPU's by reading the CPU count register. Also we can
guess the second number of the CPU type (VF6x0) which indicates the
presence of a L2 cache.
The boot ROM was not able to detect bad blocks in the U-Boot area
due to disabled "bad block marking swap" functionality. The
description of this field is a bit unclear, but tests show that
skipping bad blocks in U-Boot area only work if this field is set
to 0.
Enable the SCSC (Slow Clock Source Controller) and select the
external 32KHz oscillator. This improves accuracy of the RTC.
This adds initial support for Colibri VF50/VF61 based on Freescale
Vybrid SoC. The board support package is based on Freescale Tower
board, with following differences:
- CPU clocked at 500MHz
- Use PLL2 as DDR3 clock (400MHz)
- New Machine ID
- Console on UART1 (Colibri UART_A)
- Ethernet on FEC1
- Enabled command line editing
- PLL5 based RMII clocking (e.g. no external crystal)
- UART_A and UART_C I/O muxing
- Boot from OCRAM gfxRAM
- Boot from NAND by default
Tested on Colibri VF50/VF61 booting using serial loader over UART.
Add an additional target which prepends the u-boot.imx image with
0x400 padding bytes. On Vybrid, this is required for NAND boot
devices. The configuration CONFIG_IMX_NAND enables this image
for a board.
Add writebcb command which creates a NAND Boot Configuration Block
at the beginning of the active flash device. The offset of the
boot firmware are specified using arguments, at least one location
is mandatory.
Currently only the FCB (Firmware Configuration Block) is supported,
the DBBT (Discovered Bad Block Table) is optional and is not
used currently.
The firmware, e.g. U-Boot (along with the IVT header and a 0x400
long prefix) need to be written to NAND seperatly.
In order to avoid code duplication move the DDR initialization to
the common place under imx-common. Currently, only TREF, TRFC,
COL_DIFF and ROW_DIFF can be choosen from board file.
Prepare v2014.10
Implement an API that can be used by drivers to allocate memory from a
pool that is mapped uncached. This is useful if drivers would otherwise
need to do extensive cache maintenance (or explicitly maintaining the
cache isn't safe).
The API is protected using the new CONFIG_SYS_NONCACHED_MEMORY setting.
Boards can set this to the size to be used for the non-cached area. The
area will typically be right below the malloc() area, but architectures
should take care of aligning the beginning and end of the area to honor
any mapping restrictions. Architectures must also ensure that mappings
established for this area do not overlap with the malloc() area (which
should remain cached for improved performance).
While the API is currently only implemented for ARM v7, it should be
generic enough to allow other architectures to implement it as well.
Signed-off-by: Thierry Reding <treding@nvidia.com>
README
size_t is the canonical type to represent variables that contain a size.
Use it instead of signed integer. Physical addresses can be larger than
32-bit, so use a more appropriate type for them as well. phys_addr_t is
a type that is 32-bit on systems that use 32-bit addresses and 64-bit if
the system is 64-bit or uses a form of physical address extension to use
a larger address space on 32-bit systems. Using these types the same API
can be implemented on a wider range of systems.
Remove two gratuituous blank lines, uses u32 (instead of int) as the
type for values that will be written to a register, moves the beginning
of the variable declaration section to a separate line (rather than the
one with the opening brace) and keeps the function signature on a single
line where possible.
The Jetson TK1 has an ethernet NIC connected to the PCIe bus and routes
the second root port to a miniPCIe slot. Enable the PCIe controller and
the network driver to allow the device to boot over the network.
Add the device tree node for the PCIe controller found on Tegra124 SoCs.
Add a device tree node for the GIC v2 found on the Cortex-A15 CPU
complex of Tegra124. U-Boot doesn't use this but subsequent patches will
add device tree nodes that reference it by phandle.
The Beaver has an ethernet NIC connected to the PCIe bus. Enable the
PCIe controller and the network device driver so that the device can
In addition the board has a mini-PCIe expansion slot.
The PCIe bus on Cardhu is routed to the dock connector. An ethernet NIC
is available on the dock over the PCIe bus. Enable the PCIe controller
and the network device driver so that the device can boot over the
network.
Add the device tree node for the PCIe controller found on Tegra30 SoCs.
Add a device tree node for the GIC found on Tegra30. U-Boot doesn't use
it directly but subsequent patches will add device tree nodes that
The TrimSlice has an ethernet NIC connected to the PCIe bus. Enable the
PCIe controller and the network driver so that the device can boot over
the network.
Add the device tree node for the PCIe controller found on Tegra20 SoCs.
Add the PCIe and SATA lane configuration to the Jetson TK1 device tree,
so that the XUSB pad controller can be appropriately configured.
The XUSB pad controller is used for pinmuxing of the XUSB, PCIe and SATA
lanes.
This controller was introduced on Tegra114 to handle XUSB pads. On
Tegra124 it is also used for PCIe and SATA pin muxing and PHY control.
Only the Tegra124 PCIe and SATA functionality is currently implemented,
with weak symbols on Tegra114.
Tegra20 and Tegra30 also provide weak symbols for these functions so
that drivers can use the same API irrespective of which SoC they're
being built for.
Implement the powergate API that allows various power partitions to be
power up and down.
This reset is required for PCIe and the corresponding ID therefore needs
to be defined. The enumeration value for this was properly defined on
some SoCs but not on others. Similarly, some contained it in the mapping
of peripheral IDs to clock IDs, other didn't. This patch defines it
consistently for all supported SoC generations.
This function is required by PCIe and SATA. This patch implements it on
Tegra20, Tegra30 and Tegra124. It isn't implemented for Tegra114 because
it doesn't support PCIe or SATA.
Update Apalis T30 as per the following commits
c369139234c03b1494394d12cd27009f47aa6606
tegra: dts: Add serial port details
461be2f96e4b87e5065208c6659a47dd0ad9e9f8
kconfig: remove redundant "string" type in arch and board Kconfigs
f1ef2b62339526df3b921bcfefd174ce76d4c624
kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfig
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Add missing chosen stdout-path device tree node. This got missed by
commit
On popular request this now completes the Warren's work started for
TK1:
aeb3fcb35956461077804720b8a252d50758d7e0
ARM: tegra: Use mem size from MC rather than ODMDATA
In addition to the move of using the Tegra memory controller (MC)
register rather than ODMDATA for T20, T30 and T114 as well it further
uses the generic get_ram_size() function (see "common/memsize.c")
<supposed to be used in each and every U-Boot port>TM. Added benefit is
that it should <catch 99% of hardware related (i. e. reliably
reproducible) memory errors> as well.
Thoroughly tested on the various Toradex line of Tegra modules
available which unfortunately does not include T114 and T124 (yet at
least) plus on the Jetson TK1.
Based-on-work-by: Stephen Warren <swarren@nvidia.com>
Based-on-work-by: Tom Warren <twarren@nvidia.com>
These boards have been orphaned for more than 6 months.
This board has been orphaned for more than 6 months.
It is the last board defining CONFIG_APM821XX.
The code inside #ifdef CONFIG_APM821XX should be removed too.
The definitions for div ratio supposed to be in hex and were added
in dec by mistake.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
scsi_scan() must be called as part of scsi_init() and not
as part of sata_init().
Signed-off-by: Roger Quadros <rogerq@ti.com>
On OMAP platforms, SATA controller provides the SCSI subsystem
so implement scsi_init().
Get rid of the unnecessary sata_init() call from dra7xx-evm
and omap5-uevm board files.
This patch adds board support for the Toradex Apalis T30 a computer on
module which can be used on different carrier boards.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot and environment storage
- Gigabit Ethernet (once Thierry's PCIe as well as my E1000 resp. i210
fixes hit mainline)
- MMC/SD cards (both 8-bit as well as 4-bit slot)
- USB client/host (dual role port as client e.g. for DFU/UMS, other two
ports as host)
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit 90a565acf3a18c61170ec0e0b2046c98cb7ecc85)
rmobile/lowlevel_init_ca15.S are common in r8a7790, r8a7791 and r8a7794 of
rmobile SoCs. The initialize L2 cache in lowlevel_init_ca15.S only needed
for Cortex-A15. The r8a7794 is Cortex-A7, not Cortex-A15.
This adds Skip to initialize L2 cache when r8a7794.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
rmobile/lowlevel_init_ca15.S are common in r8a7790 and r8a7791 of
rmobile SoC. But L2 cache of r8a7791 does not use L2CTLR[5].
This adds fix to set L2CTLR [5] only when the r8a7790.
This removes duplicate initialization of l2ctlr.
