path: root/arch
2014-10-10powerpc: mpc5xxx: remove board support for MVBC_P and MVSMRMasahiro Yamada
These boards have been orphaned for more than 6 months. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10powerpc: mpc83xx: remove board support for MERGERBOX and MVBLM7Masahiro Yamada
2014-10-10powerpc: ppc4xx: remove board support for bluestoneMasahiro Yamada
This board has been orphaned for more than 6 months. It is the last board defining CONFIG_APM821XX. The code inside #ifdef CONFIG_APM821XX should be removed too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10powerpc: ppc4xx: remove board support for CRAYL1Masahiro Yamada
This board has been orphaned for more than 6 months. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-10powerpc: ppc4xx: remove board support for KAREF and METROBOXMasahiro Yamada
2014-10-10ARM: keystone: clock: fix main pll ratio div definitionsKhoronzhuk, Ivan
The definitions for div ratio supposed to be in hex and were added in dec by mistake. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-10ARM: OMAP5+: sata: Move scsi_scan() to the right placeRoger Quadros
scsi_scan() must be called as part of scsi_init() and not as part of sata_init(). Signed-off-by: Roger Quadros <rogerq@ti.com>
2014-10-10OMAP5+: sata/scsi: Implement scsi_init()Roger Quadros
On OMAP platforms, SATA controller provides the SCSI subsystem so implement scsi_init(). Get rid of the unnecessary sata_init() call from dra7xx-evm and omap5-uevm board files. Signed-off-by: Roger Quadros <rogerq@ti.com>
2014-10-07Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-10-07vf610twr: Tune DDR initialization settingsAnthony Felice
Removed settings in unsupported register fields. They didn’t do anything, and in most cases, were not documented in the reference manual. Changed register settings to comply with JEDEC required values. Changed timing parameters because they included full clock periods that were doing nothing. Signed-off-by: Anthony Felice <tony.felice@timesys.com> [rebased on v2014.10-rc2] Signed-off-by: Stefan Agner <stefan@agner.ch>
2014-10-06arm: socfpga: Add command to control HPS-FPGA bridgesMarek Vasut
Add command to enable and disable the bridges between HPS and FPGA. This patch does have a checkpatch issue with the assembler portion, checkpatch correctly complains that there should be no whitespace before quoted newline. I do not agree that fixing this specific checkpatch issue will improve the readability, thus this one is not addressed. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Wolfgang Denk <wd@denx.de>
2014-10-06arm: socfpga: Move cache_enable to CPU codeMarek Vasut
Move icache_enable() and dcache_enable() function calls from board code into the CPU code and into the enable_caches() function. This is how the cache enabling code was designed to work. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: nic301: Add NIC-301 configuration codePavel Machek
Add code which configures the AMBA NIC-301 and the SCU on the SoCFPGA . The code sets the access permissions for the CPU to the AMBA slaves such that the CPU can access them in both secure and non-secure mode. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: pl310: Map SDRAM to 0x0Marek Vasut
Configure the PL310 address filter to make sure DRAM is mapped to 0x0. This code also configures the "remap" register of NIC-301 and sets the required 'mpuzero' bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: nic301: Add NIC-301 GPV register fileMarek Vasut
Add register definition for the NIC-301 used on SoCFPGA. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: scu: Add SCU register fileMarek Vasut
Add the Snoop Control Unit register definition file. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: sysmgr: Add FPGA bits into system managerMarek Vasut
Add missing system manager bits from Altera U-Boot to make the code comparable. These are the bits which depend on the FPGA manager. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: reset: Add function to reset FPGA bridgesMarek Vasut
Add function to enable and disable FPGA bridges. This code is used by the FPGA manager to disable the bridges before programming the FPGA and will later be also used by the initialization code for the chip to put the chip into well defined state during startup. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: fpga: Add SoCFPGA FPGA programming interfacePavel Machek
Add code necessary to program the FPGA part of SoCFPGA from U-Boot with an RBF blob. This patch also integrates the code into the FPGA driver framework in U-Boot so it can be used via the 'fpga' command. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> V2: Move the not-CPU specific stuff into drivers/fpga/ and base this on the cleaned up altera FPGA support.
2014-10-06arm: socfpga: misc: Align print_cpuinfo() outputPavel Machek
Cosmetic change to the print_cpuinfo() function output. Align the output with the rest of initial output produced by U-Boot. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: misc: Add SD controller initPavel Machek
Add CPU function to register and initialize the dw_mmc SD controller. This allows us to use the HPS SDMMC block. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: misc: Add proper ethernet initializationPavel Machek
Add function to initialize the EMAC blocks upon board startup. The preprocessor guards against building on SoCFPGA-VT and against SPL build are not needed as those are handled implicitly via both SPL framework and the socfpga_cyclone5.h config file, which will not define CONFIG_DESIGNWARE_ETH if building for SoCFPGA-VT. We cannot handle two EMAC ethernet blocks yet, therefore the ifdefs. Once there is hardware using both EMAC blocks, this ifdef will have to go. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: reset: Add EMAC reset functionsMarek Vasut
Add functions to reset the EMAC ethernet blocks. We cannot handle two EMAC ethernet blocks yet, therefore the ifdefs. Once there is hardware using both EMAC blocks, this ifdef will have to go. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: timer: Pull the timer reload value from config fileMarek Vasut
The timer reload value is a property of the timer hardware and there is no reason for this to be configurable. Place this into the timer driver just like on the other hardware. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: clock: Sync with reference codeMarek Vasut
Add the missing pieces from the reference clock code from Altera. This puts the code on par with the Altera U-Boot fork for all but the SDRAM self-refresh bits, which are not part of this patch. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: clock: Clean up bit definitionsMarek Vasut
Clean up the clock code definitions so they are aligned with mainline standards. There are no functional changes in this patch. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: clock: Trim down code duplicationMarek Vasut
Pull out functions to read frequency of Main clock VCO and PLL clock VCO as the code is duplicated multiple times. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: clock: Add code to read clock configurationPavel Machek
Add the entire bulk of code to read out clock configuration from the SoCFPGA CPU registers. This is important for MMC, QSPI and UART drivers as otherwise they cannot determine the frequency of their upstream clock. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> V2: Fixed the L4 MP clock divider and synced the clock code with latest rocketboards codebase (thanks Dinh for pointing this out)
2014-10-06arm: socfpga: clock: Drop nonsense inlining from clock manager codeMarek Vasut
The inlining is done by GCC when needed, there is no need to do it explicitly. Furthermore, the inline keyword does not force-inline the code, but is only a hint for the compiler. Scrub this hint. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: clock: Implant order into bit definitionsMarek Vasut
The bit definitions for clock manager are complete chaos. Implement some basic logical order into them. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: sysmgr: Clean up system managerMarek Vasut
Clean up the system manager register definition and add the missing register definitions in place. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-06arm: socfpga: Add watchdog disable for socfpgaPavel Machek
This adds watchdog disable. It is neccessary for running Linux kernel. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> V2: Move RSTMGR_PERMODRST_L4WD0_LSB to reset_manager.h Reset watchdog only if CONFIG_HW_WATCHDOG is undefined (the default)
2014-10-06arm: socfpga: Clean up base address fileMarek Vasut
Sort the list of functional block addresses and fix indentation. No functional change. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2014-10-06arm: socfpga: Complete the list of base addressesPavel Machek
Add base addresses for all subsystems as documented in the Cyclone V HPS documentation. Signed-off-by: Pavel Machek <pavel@denx.de> Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2014-10-06arm: cache: Add support for write-allocate D-CacheMarek Vasut
Add configuration for the write-allocate mode of L1 D-Cache on ARM. This is needed for D-Cache operation on Cortex-A9 on the SoCFPGA . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@altera.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Pavel Machek <pavel@denx.de> Acked-by: Pavel Machek <pavel@denx.de>
2014-10-05ARM: UniPhier: add Kconfig and defconfigMasahiro Yamada
This commit allows to build Panasonic UniPhier family: PH1-LD4, PH1-Pro4, PH1-sLD8 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-05ARM: UniPhier: add UniPhier SoC support codeMasahiro Yamada
These are used by Panasonic UniPhier SoC family. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-26Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2014-09-26Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-09-25powerpc: add --bss-plt to LDFLAGSChris Packham
With some versions of gcc (that we know of 4.6.3 and 4.8.2 are affected) it is necessary to specify --bss-plt to get the final blrl in the _GOT2_TABLE_. Without this the last symbol does not get it's address relocated. For the P2041RDB board this ended up being NetArpWaitTimerStart which caused the ARP packets to timeout immediately. Signed-off-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Signed-off-by: Chris Packham <judge.packham@gmail.com> Acked-by: Joakim Tjernlund <joakim.tjernlund@transmode.se> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-25board/ls1021aqds: Add DDR4 supportYork Sun
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig for this variant to enable DDR4 support. RAW timing parameters are not added for DDR4. The board timing parameters are only tuned for single- rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM availability. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com>
2014-09-25armv8/fsl-lsch3: Release secondary cores from boot hold off with Boot PageYork Sun
Secondary cores need to be released from holdoff by boot release registers. With GPP bootrom, they can boot from main memory directly. Individual spin table is used for each core. Spin table and the boot page is reserved in device tree so OS won't overwrite. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
2014-09-25ARMv8/ls2085a_emu: Enable DP-DDR as standalone memory blockYork Sun
DP-DDR is used for DPAA, separated from main memory pool for general use. It has 32-bit bus width and use a standard DDR4 DIMM (64-bit). Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-25driver/ddr: Restruct driver to allow standalone memory spaceYork Sun
U-boot has been initializing DDR for the main memory. The presumption is the memory stays as a big continuous block, either linear or interleaved. This change is to support putting some DDR controllers to separated space without counting into main memory. The standalone memory controller could use different number of DIMM slots. Signed-off-by: York Sun <yorksun@freescale.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-09-24cosmetic: replace MIN, MAX with min, maxMasahiro Yamada
The macro MIN, MAX is defined as the aliase of min, max, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-09-24mpc8xx: move common linker scripts into the CPU directoryMasahiro Yamada
Each CPU of PowerPC has its default linker script under the CPU directory, except mpc8xx. Every mpc8xx board has its own linker script under the board directory, resulting in lots of duplication of linker scripts. I notice eight mpc8xx boards have the same linker script. We can decrease the number of linker scripts by putting a single default linker script, arch/powerpc/cpu/mpc8xx/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2014-09-24powerpc/mpc85xx: Serdes protocol "00" is supportedEbony Zhu
"0x00" is a valid serdes protocol for QorIQ parts, and can not be used to test whether the serdes is enabled or disabled. Signed-off-by: Ebony Zhu <b45385@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24powerpc/8xxx: Fix in USB device-tree fixupramneek mehresh
Fix following issues in USB device-tree fixup: - returns when either dr_mode or phy_type not defined. This was terminating fix-up when only either property was defined in hwconfig string - updates dr_mode_type or dr_phy_type with junk value when their index is -1. Now these are updated only when their respective index is pointing to relevant types in modes[] and phys[] array - dr_mode_type and dr_phy_type were not NULL for each controller Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-09-24arm: kirkwood: spi.h: Add some missing parenthesisStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Tested-by: Luka Perkov <luka@openwrt.org> Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
