path: root/arch
2012-03-18bootstage: arm: Add bootstage calls in board and bootmSimon Glass
Add calls to bootstage before and after relocation, and just before jumping to the OS. The idea here is you can call bootstage_report() to get a report. Additionally, if you define CONFIG_BOOTSTAGE_REPORT then a report is printed automatically by U-Boot just before jumping to the kernel. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Convert progress numbers 20-41 to enumsSimon Glass
2012-03-18bootstage: Use show_boot_error() for -ve progress numbersSimon Glass
Rather than the caller negating our progress numbers to indicate an error has occurred, which seems hacky, add a function to indicate this. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-17Merge branch 'master' of git://git.denx.de/u-boot-avr32Wolfgang Denk
* 'master' of git://git.denx.de/u-boot-avr32: atmel_mci.h: remove outdated register macros doc/git-mailrc: add <me> to avr32 alias ATMEL: remove old atmel_mci driver ATMEL: use generic mmc framework
2012-03-17Merge branch 'sandbox' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'sandbox' of git://git.denx.de/u-boot-blackfin: sandbox: mark os_exit as noreturn sandbox: add getopt support sandbox: allow processing before main loop sandbox: add concept of sandbox state sandbox: disable fortification sandbox: u-boot.lds: tweak style sandbox: add get_{tbclk,ticks} sandbox: enable GPIO driver sandbox: gpio: add basic driver for simulating GPIOs sandbox: add flags for open() call sandbox: config: enable fdt and snprintf() options sandbox: fdt: add support for CONFIG_OF_CONTROL sandbox: add lseek helper sandbox: add ifdef protection to os.h sandbox: add required header to os.c sandbox: sort header files in os.c
2012-03-13ATMEL: remove old atmel_mci driverSven Schnelle
All boards are using the gen_atmel_mci driver now, so no need to carry the old driver around. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-03-13ATMEL: use generic mmc frameworkSven Schnelle
gen_atmel_mci works on AVR32 as well, so no need to use the legacy mmc driver. This also has the nice side effect of being able to use SDHC cards an those boards. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-03-12sandbox: add getopt supportSimon Glass
This adds simple command-line parsing to sandbox. The idea is that it sets up the state with options provided, and this state can then be queried later, as needed. New flags are declared with the SB_CMDLINE_OPT_SHORT helper macro, pointers are automatically gathered up in a special section, and then the core code takes care of gathering them up and processing at runtime. This way there is no central place where we have to store a list of flags with ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: allow processing before main loopSimon Glass
In order to pass command line arguments to sandbox we need to be able to act on them. So take control back at the end of board_init_r() from where we can call the main loop or do something else. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add concept of sandbox stateSimon Glass
The state exists through the life of U-Boot. It can be adjusted by command line options and perhaps later through a config file. It is available to U-Boot through state_...() calls (within sandbox code). The primary purpose of this is to contain the "hardware" state. It should only be used by sandbox internal code. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: disable fortificationMike Frysinger
Since we provide all our own library calls, the fortification from glibc just gets in our way (which some distros enable by default). Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: u-boot.lds: tweak styleMike Frysinger
We use tabs for indentation, not spaces. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: gpio: add basic driver for simulating GPIOsSimon Glass
This provides a way of simulating GPIOs by setting values which are seen by the normal gpio_get/set_value() calls. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add flags for open() callSimon Glass
This provides a way for callers to create files for writing. The flags are translated at runtime, for the ones we support. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: fdt: add support for CONFIG_OF_CONTROLSimon Glass
This adds support for a controlling fdt, mirroring the ARM implementation. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add lseek helperMike Frysinger
Follow up patches want to be able to seek fd's. Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: add required header to os.cSimon Glass
We should include the sys/time.h header to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: sort header files in os.cSimon Glass
Tidy this up as the list is long and likely to get longer. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-08sh: timer: Remove unnecessary variable 'ticks'Nobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Reported-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-06Merge branch 'master' of git://git.denx.de/u-boot-x86Wolfgang Denk
* 'master' of git://git.denx.de/u-boot-x86: sc520: fix build warning about unused temp var
2012-03-06Stop using builtin_run_command()Simon Glass
Boards can select either the 'built-in' parser or the hush parser. We should not call builtin_run_command() if we are using the hush parser. We use run_command() instead, since it knows how to call the correct parser. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06Rename run_command() to builtin_run_command()Simon Glass
The current run_command() is only one of the parsing options - the other is hush. We should not call run_command() when the hush parser is being used. So we rename this function to better explain its purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-06sc520: fix build warning about unused temp varMike Frysinger
Building the eNET_SRAM board fails for me: sc520_timer.c: In function 'sc520_udelay': sc520_timer.c:81:7: error: variable 'temp' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors make[1]: *** [sc520_timer.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-04Remove execute permissions from source filesThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2012-03-03ppc: Change memsz variable to signed charSimon Glass
This seems to be unsigned char for no good reason. Tidy this up and remove the casts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-03m68k: Change memsz to a signed char to avoid warningSimon Glass
There doesn't seem to be any reason for using uchar here, so change it to char. This fixes a warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-03Merge branch 'master' of git://git.denx.de/u-boot-nds32Wolfgang Denk
* 'master' of git://git.denx.de/u-boot-nds32: nds32/board.c: add PCI prompt at boot up nds32/ag101/watchdog.S: add linkage support nds32: add linkage support
2012-02-28nds32/board.c: add PCI prompt at boot upMacpaul Lin
add PCI prompt at boot up for probing PCI device Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-02-28nds32/ag101/watchdog.S: add linkage supportMacpaul Lin
Add linkage support to watchdog.S. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-02-28nds32: add linkage supportMacpaul Lin
Add linkage support. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2012-02-27armv7: omap3: leave outer cache enabledAneesh V
Mainline kernel for OMAP3 doesn't enable L2 cache It expects L2$ to be enabled by ROM-code/bootloader. Leaving L2$ enabled can be troublesome in cases where the L2 cache is not under CP15 control, such as in Cortex-A9. This problem is explained in detail in the commit dc7100f4080952798413fb63bb4134b22c57623a However, this problem doesn't apply to Cortex-A8 because L2$ in Cortex-A8 is under CP15 control and hence the generic armv7 maintenance opertions work for it. As such we can make an exception for OMAP3 and leave the L2$ enabled when we jump to kernel. This is done by removing the strongly-linked implementation of v7_outer_cache_disable() and allowing it to fall back to the weakly linked implementation that doesn't do anything. Signed-off-by: Aneesh V <aneesh@ti.com>
2012-02-27tt01: add video supportHelmut Raiger
The video setup for the Epson display is provided. Addtionally some extra info is displayed next to the Linux logo. Make get_cpu_rev() publicly available (added to sys_proto.h). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27net: fec_mxc: add 1000 Mbps selectionTroy Kisky
Define FEC_QUIRK_ENET_MAC and add to arch-mx6/imx-regs.h Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-27am33xx: ddr_defs.h: Change DDR timingsChase Maupin
* For cold silicon the DDR timings need to be relaxed in order for the device to boot with DDR at 266MHz * Fix proposed by James Doublesin Signed-off-by: Chase Maupin <Chase.Maupin@ti.com>
2012-02-27davinci: cleanup davinci_sync_env_enetaddr() fucntionHadli, Manjunath
check for the return status for eth_getenv_enetaddr_by_index() and eth_setenv_enetaddr() functions and print appropriate message on failure. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-02-27mx35: generic: Let get_reset_cause be defined only when ↵Fabio Estevam
CONFIG_DISPLAY_CPUINFO is selected get_reset_cause() function is only used inside print_cpuinfo(), so let it be defined only when CONFIG_DISPLAY_CPUINFO is selected. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx6q: Add support for ECSPI through mxc_spi driverEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mxc_spi: move machine specifics into CPU headersEric Nelson
Move (E)CSPI register declarations into the imx-regs.h files for each supported CPU Introduce two new macros to control conditional setup MXC_CSPI - Used for processors with the Configurable Serial Peripheral Interface (MX3x) MXC_ECSPI - For processors with Enhanced Configurable... (MX5x, MX6x) Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: define GPIO macros for translating between ordinals and port:indexEric Nelson
The interface to the mxc_gpio driver uses integer (ordinal) values to refer to all GPIOs on the i.MX processors. The registers themselves and much of the i.MX documentation are banked in groups of 32, and these macros allow the use of the port:index numbering for clarity. GPIO_NUMBER() converts to ordinal value from port:index GPIO_PORT() returns the port of an ordinal value GPIO_INDEX() returns the index or offset of the ordinal. Discussion on the mailing list at http://lists.denx.de/pipermail/u-boot/2012-January/116927.html Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2012-02-27MX27: add missing get_tbclk()Stefano Babic
2012-02-27MX28: Fix get_timer() / get_tbclk() issueMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@gmail.com>
2012-02-27mx28: fix SPL code to make USB booting workMatthias Fuchs
This patch fixes booting i.MX28 CPUs via USB download. In this mode the CPU's bootrom implements a USB HID device that accepts a bootstream. When downloading the bootstream via USB, first the SPL code is received and executed. Then the u-boot image is received and called. The USB bootmode is interrupt driven. This patch fixes two things: 1) The ARM's fast interrupt mode is disabled when the SPL code has been run. So save and restore the CPSR register. 2) Save and restore c1 control register: the exception vector location needs to be set back to bootrom space to make the USB interrupts work again. The SPL code needs to change this option for the ram size probing. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-02-27i.MX28: Fix VDDIO and VDDA setupMarek Vasut
The DC power STS shouldn't be checked if booting off 5V supply. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Robert Deliën <robert@delien.nl> Cc: Fabio Estevam <festevam@gmail.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2012-02-27MX5/MX6: add missing get_ticks() and get_tbclk()Stefano Babic
commit f31a911fe (arm, post: add missing post_time_ms for arm) enables get_ticks and get_tbclk for all arm based boards, MX5/MX6 have not yet implemented. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Dirk Behme <dirk.behme@de.bosch.com> CC: Jason Liu <jason.hui@linaro.org> CC: Marek Vasut <marek.vasut@gmail.com>
2012-02-27MX31: add missing get_tbclk()Stefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27MX35: add missing get_ticks() and get_tbclk()Stefano Babic
2012-02-23microblaze: avoid interrupt race conditionsStephan Linz
The interrupt acknowledge action have to run after the registered interrupt handler. So we have a chance to bear out the corresponding interrupt request in the corresponding controller hardware. With this reordering, we optain a proper interrupt handling for level triggered interrupt sources -- for example the new axi_timer v1.02.a introduced in ISE 13.2. Signed-off-by: Stephan Linz <linz@li-pro.net> Acked-by: Michal Simek <monstr@monstr.eu>
