There is only one line diff between LEON2 and LEON3 linker scripts:
- arch/sparc/cpu/leon2/start.o (.text)
+ arch/sparc/cpu/leon3/start.o (.text)
They can be written in the same way:
*/start.o (.text)
So, board/gaisler/grsim_leon2/u-boot.lds
and arch/sparc/cpu/leon3/u-boot.lds
can be merged into arch/sparc/cpu/u-boot.lds.
Cc: Daniel Hellstrom <daniel@gaisler.com>
The linker scripts of LEON3
- board/gaisler/grsim/u-boot.lds
- board/gaisler/gr_cpci_ax2000/u-boot.lds
- board/gaisler/gr_ep2s60/u-boot.lds
- board/gaisler/gr_xc3s_1500/u-boot.lds
are the same (except cosmetic differences such as indentation).
This commit merges them into arch/sparc/cpu/leon3/u-boot.lds.
The pad settings for DISP0_DATA02 and DISP0_DAT10 were not
set in the same way as DISP0_DAT00-23, causing much flicker
in parallel RGB displays on Dual-Lite and Solo processors.
These settings now match the i.MX6 Dual and Quad core versions.
Note that this fixes a regression in commit b47abc3 and that
this is the second time we've had a regression on these two
pads (See commit e654ddf).
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Newer AM437x silicon requires us to explicitly power up
the USB2 PHY. By implementing usb_phy_power() we can
achieve that.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Commit 3d622b78 (mx6: soc: Introduce set_ldo_voltage()) introduces
set_ldo_voltage() function that can be used to set the voltages
of any of the three LDO regulators controlled by the PMU_REG_CORE register.
Prior to this commit there was a single set_vddsoc() which only configured the
VDDSOC regulator.
Update the comments to align with the new set_ldo_voltage() implementation.
DIV_SELECT is used as Fout = Fin * div_select / 2.0, so we should do
the shift after the multiply to avoid rounding errors
Signed-off-by: Andre Renaud <andre@bluewatersys.com>
Fixes a bug when objcopy doesn't put .dtb.init.rodata section to resulting
u-boot.bin, so u-boot was unable to find embedded DTB.
Since ARRAY_SIZE macro is defined in include/common.h,
re-defining it in arch-specific files is redundant.
Acked-by: Sonic Zhang <sonic.zhang@analog.com>
Add invalidate_dcache_range() and flush_dcache_range() for the blackfin
architecture. Such functions already exist on this arch with different
names, so just forward the call.
This fixes the build of bf609-ezkit board as it uses
drivers/net/designware.c which requires the above functions.
Cc: Sonic Zhang <sonic.adi@gmail.com>, Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Vasili Galka <vvv444@gmail.com>
The csarX and cscrX registers in the fbcs_t struct are 16-bit for
CONFIG_M5235 and 32-bit wide otherwise. The code in cpu_init.c
accessed them always as 32-bit, effectively creating a wrong memory
access on M5235. Fixed that by choosing out_be16/out_be32 depending
on whether CONFIG_M5235 is defined or not.
Cc: Jason Jin <Jason.jin@freescale.com>
in_be16() shall be passed a pointer to register and not its value. This
is clearly a typo resulting in a wrong memory access, so fix it.
Cc: Alison Wang <b18965@freescale.com>, Jason Jin <Jason.jin@freescale.com>
This board is old enough and has no maintainer.
These boards are old enough and have no maintainers.
* This is done by limiting the ARM's bandwidth and setting DSS priority in
the EMIF controller to ensure underflows do not occur.
* Boot failures have been discovered due to a combination of routing issues and
non optimal ddr3 timings in the EMIF
* Since ddr3 timings are different after significant board layout changes
different timings are required for alpha, beta and production boards.
Signed-off-by: Franklin S. Cooper Jr <fcooper@ti.com>
The directory arch/${ARCH}/cpu/${CPU} does not exist
in avr32, blackfin, microblaze, nios2, openrisc, sandbox, x86.
These architectures have only one CPU type.
Defining CPU should not be required for such architectures.
This commit allows cpu field (= the 3rd field of boards.cfg)
to be kept blank.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
The code intends for the CM_DLL_READYST to be set, but
actually polls till any bit is set since the logical
AND is used instead of the bitwise one is used. Fix it.
cc: Lokesh Vutla <lokeshvutla@ti.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
To move the arch common function away from board folder to
arch/arm/cpu/armv7/socfpga folder. Its to avoid code duplication
for other non Altera dev kit which is using socfpga device.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Detlev Zundel <dzu@denx.de>
Cc: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Fix following compilation error when CONFIG_ARM64 is defined
Error: unknown or missing system register name at operand 2
-- `mrs x0,daifmsr daifset,#3'
Signed-off-by: Shaibal.Dutta <shaibal.dutta@broadcom.com>
Signed-off-by: Darwin Rambo <drambo@broadcom.com>
Reviewed-by: Darwin Rambo <drambo@broadcom.com>
cc: Tom Rini <trini@ti.com>
Scan Manager driver will be called to configure the IOCSR
scan chain. This configuration will setup the IO buffer settings
CC: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
To enable the DesignWare watchdog support at SOCFPGA
Cyclone V dev kit.
This patch returns back support for old ep93xx processors family
Signed-off-by: Sergey Kostanbaev <sergey.kostanbaev@gmail.com>
Cc: albert.u.boot@aribaud.net
This is not only more readable but also prevents a warning
about a missing prototype. The prototypes which are actually
missing are added.
cc: Albert Aribaud <albert.u.boot@aribaud.net>
Reviewed-by: Tom Rini <trini@ti.com>
LS2085A is an ARMv8 implementation. This adds board support for emulator
and simulator:
Two DDR controllers
UART2 is used as the console
IFC timing is tightened for speedy booting
Support DDR3 and DDR4 as separated targets
Management Complex (MC) is enabled
Support for GIC 500 (based on GICv3 arch)
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
Signed-off-by: J. German Rivera <German.Rivera@freescale.com>
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Adding support to load and start the Layerscape Management Complex (MC)
firmware. First, the MC GCR register is set to 0 to reset all cores. MC
firmware and DPL images are copied from their location in NOR flash to
DDR. MC registers are updated with the location of these images.
Deasserting the reset bit of MC GCR register releases core 0 to run.
Core 1 will be released by MC firmware. Stop bits are not touched for
this step. U-boot waits for MC until it boots up. In case of a failure,
device tree is updated accordingly. The MC firmware image uses FIT format.
Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
Signed-off-by: Shruti Kanetkar <Shruti@Freescale.com>
Freescale LayerScape with Chassis Generation 3 is a set of SoCs with
ARMv8 cores and 3rd generation of Chassis. We use different MMU setup
to support memory map and cache attribute for these SoCs. MMU and cache
are enabled very early to bootst performance, especially for early
development on emulators. After u-boot relocates to DDR, a new MMU
table with QBMan cache access is created in DDR. SMMU pagesize is set
in SMMU_sACR register. Both DDR3 and DDR4 are supported.
Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com>
Make MMU function reusable. Platform code can setup its own MMU tables.
CC: David Feng <fenghua@phytium.com.cn>
This is needed for accessing peripherals with 64-bit MMIO registers,
from ARMv8 processors.
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF
images and u-boot, and does this for virtual platforms by using
semihosting. This commit extends this idea by allowing u-boot to also
use semihosting to load the kernel/ramdisk/dtb. This eliminates the need
for a bootwrapper and produces a more realistic boot sequence with
virtual models.
Though the semihosting code is quite generic, support for armv7 in
fastmodel is less useful due to the wide range of available silicon
and the lack of a free armv7 fastmodel, so this change contains an
untested armv7 placeholder for the service trap opcode.
Please refer to doc/README.semihosting for a more detailed description
of semihosting and how it is used with the armv8 virtual platforms.
Cc: trini@ti.com
Cc: fenghua@phytium.com.cn
Cc: bhupesh.sharma@freescale.com
I2C read transactions are typically implemented as follows:
START(write) address REPEATED_START(read) data... STOP
However, Tegra's I2C driver currently implements reads as follows:
START(write) address STOP START(read) data... STOP
This sequence confuses at least the AS3722 PMIC on the Jetson TK1 board,
leading to corrupted read data in some cases. Fix the driver to chain
the transactions together using repeated starts to solve this.
Reviewed-by: Yen Lin <yelin@nvidia.com>
boards.cfg
Conflict was trivial between goni maintainer change and
lager_nor removal.
commit 67a04ab3ab8522a3a34491853e46105317580df5
fix the build for MX25. The same error
happens for VF610 SOC.
local_irq_save() should be a macro, not a function
because local_irq_save() saves flag to the given argument.
GCC is silent about this issue, but Clang warns:
In file included from lib/asm-offsets.c:15:
In file included from include/common.h:20:
In file included from include/linux/bitops.h:110:
arch/sandbox/include/asm/bitops.h:59:17:
warning: variable 'flags' is uninitialized when used here
[-Wuninitialized]
local_irq_save(flags);
That change causes another warning:
In file included from include/linux/bitops.h:110:0,
from include/common.h:20,
arch/sandbox/include/asm/bitops.h: In function ‘test_and_set_bit’:
arch/sandbox/include/asm/bitops.h:56:16: warning: unused variable ‘flags’ [-Wunused-variable]
So, flags should be set to __always_unused.
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Each node in the linked-list that os_dirent_ls() returns has its next
pointer set only when the next node is created. For the last node in the
list, there is no next node, so this never happens, and the next pointer
is never initialized. Explicitly initialize the next pointer so that it
isn't dangling. Without this, "sb ls" might crash.
Until now building the x86 arch boards required 32-bit toolchain. As
many x86_64 toolchains come with 32-bit support (multilib) that's a
good idea to enable build with such toolchains.
The change required was to specify the usage of 32-bit explicitly to
the compiler and the linker (-m32 and -m elf_i386 flags) and locate
the right libgcc path.
While the Exynos5420 chip is used in both Smdk5420 and in the Peach-Pit
line of devices, there could be other boards using the same chip, so a
common configuration file is being added (exynos5420.h) as well
as two common device tree files (exynos54xx.dtsi & exynos5420.dtsi).
The peach board as declared in boards.cfg is a copy of smdk5420
declaration. The configuration files are similar, but define different
default device trees, console serial ports and prompts.
The device tree files for smdk5420 and peach-pit inherit from the same
common file.
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Signed-off-by: Akshay Saraswat <akshay.s@samsung.com>
Macros defined in exynos5_setup.h specific to SMDK5420
are required for Peach-Pit too. Hence, replacing
CONFIG_SMDK5420 with CONFIG_EXYNOS5420 to enable these
macros for all the boards based on Exynos5420.
These files are taken from Linux 3.14.
