The crash was occuring in env_relocate because it was being called prior
to mmc_initialize. This patch moves the MMC initialization earlier in
the init process.
This patch also cleans up the env_relocate_spec code in env_mmc.c
Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org>
The patch adds a utility function and defines
to set the pad as it is done in linux.
Adds support for the ARM quad-core Cortex-A9 processor
This system includes a motherboard(Versatile Express), daughterboard
(Coretile), and SOC(Cortex-A9 quad core). The serial port, ethernet,
and flash systems work with these additions. The naming convention
is:
SOC -> CortexA9 quad core = ca9x4
daughterboard -> Coretile = ct
motherboard -> Versatile Express = vxp
This gives ca9x4_ct_vxp.c as the board support file.
Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
Merge several sizes.h in asm/arch subdirectories into a single
asm/sizes.h file.
Fixup usage of asm/arch/sizes.h in some files to use the merged file.
For all Kirkwood boards so far dram_init function is duplicated
dram_init function is moved to dram.c and relevant code from all
board specific files removed
If any board needs specific dram init handling than standard one,
then, a macro CONFIG_SYS_BOARD_DRAM_INIT should be defined in
board config header file and the dram_init function can be put
in board specific source file
For ex. keymile boards
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
Signed-off-by: Chris Moore <moore@free.fr>
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Earlier Device Identification register was used to detect
the type for SoC, considering 88F6282 support to be added,
It is not possible to detect the same using current
algorithm.
With this patch, device ID is being read using PCIE devid
register, also valid chip revision ID will also be read and
displayed
No boards utilize the warm reset entry point, so remove it.
This puts the board info struct in a known state and allows the removal
of other code which initialized board info fields to 0.
Microblaze little-endian toolchain should export
__MICROBLAZEEL__.
Microblaze hasn't supported NET_MULTI support.
This patch proposes to migrate the davinci_emac driver to using the
eth_device->write_hwaddr function pointer as suggested by Ben Warren.
All the davinci boards had the behaviour, prior to this patch, of
sync'ing the environment variable enetaddr with the MAC address read
from non-volatile storage on boot -- when the two locations disagreed,
the environment variable value took precendence. This patch keeps the
same behaviour but lets eth_initialize take care of it.
This patch refactors davinci_emac setup in the boards so that the MAC
address is read from non-volatile storage into the environment variable
and then the environment variable value is use in eth_intialize. The
only exception is the direct call to davinci_eth_set_mac_addr made by
the da830evm board init which was changed into an assignment of the
enetaddr field.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Tested-by: Nick Thompson <nick.thompson@ge.com>
Generalized misuse of ble within relocation and bss
initialization loops caused one iteration too many.
Instead of ble ('branch if lower or equal'), use
blo ('branch if lower').
While we're at it, fix all 'addreee' typos.
pumping line-rate traffic though a p4080 rev.2, which
is configured to encrypt packets prior to forwarding through
an IPsec tunnel, gets this error:
of_platform ffe302000.jq: DECO: desc idx 22: LIODN error. DECO was trying
to share from itself or from another DECO but the two Non-SEQ LIODN
values didn't match or the "shared from" DECO's Descriptor required that
the SEQ LIODNs be the same and they aren't.
Since high traffic rates cause DECOs to begin to start sharing
shared descriptors amongst themselves, and DECOs inherit job queue
LIODNs when accessing shared descriptors, and a recently discovered
rev.2 h/w erratum requires all sharing job queues in a partition
have same liodn assignment, reassign the first job queue's liodn
assignment to the rest.
Manual was updated to add a new register for disabling CDQ speculation.
u-boot.bin can be loaded at any 4-byte aligned memory location and directly
'jumped' to using the 'go' command using the load address as the start
address. Doing so performs a 'warm boot' which skips memory initialisation
and other low-level initialisations, relocates U-Boot to upper memory and
starts U-Boot in RAM as per normal 'cold boot'
Provides a small speed increase and prepares for fully relocatable image.
Downside is the TEXT_BASE, bss, load address etc must ALL be aligned on a
a 4-byte boundary which is not such a terrible restriction as everything
is already 4-byte aligned anyway
Tidy up the linker script and discard some sections to save space
Create more generic names for the symbols exported from the linker script
By reserving space for the Global Data immediately below the stack during
assembly level initialisation, the C declaration of the static global data
can be removed, along with the 'RAM Bootstrap' function. This results in
cleaner code, and the ability to pass boot-up flags from assembler into C
By using another register, reduce code size by one instruction
%ebx will hold low-level boot flags and must be preserved
Using %ebp as a return pointer prevents creating 'load anywhere' images
To allow for 'load anywhere' images, the %ebp return pointer 'hack' must
be removed, so we cannot have two 'calls' to get_mem_size
Progress indication is not relocation friendly so remove it in
preperation for full relocatability support
Change to:
- reparam=3
- no-from-pointer
- no-stack-protector
- preferred-stack-boundary=2
- no-top-level-reorder
These options make the code a little smaller and faster
Perform some basic code cleanups of the x86 files
Linux has C macros and code to load the GTD after switching to Protected
Mode. Using these greatly simplifies the assembler code
Follow the discussion of Charles Manning and Mike Frysinger.
Using gc_sections helps reduce image size.
The header of recent Linux Kernels includes the size of the image, and
therefore is not needed to be passed to zboot. Still process the third
parameter (size of image) in the event that an older kernel is being loaded
Relocation is not board-specific for the x86 architectrure, so
CONFIG_RELOC_FIXUP_WORKS can be defined globally in the config.h
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
The PCU_E board has long reached EOL, and support for it is no longer
relevant in current versions of U-Boot. Remove it.
When disabled the PIT runs until it reaches the CPIV value.
The Linux PIT driver stops the PIT and waits until it stopped. This can
take over 100ms. Simply stopping in u-boot isn't sufficient as the PIT
will still be running when Linux is waiting until it stopped.
So, we stop it in u-boot by setting the compare value to a value slightly
greater than the current running counter to make the PIT stopped in short
time.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Acked-by: Jens Scharsig <js_at_ng@scharsoft.de>
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
