This board has been orphaned for more than 6 months.
It is the last board defining CONFIG_APM821XX.
The code inside #ifdef CONFIG_APM821XX should be removed too.
These boards have been orphaned for more than 6 months.
The definitions for div ratio supposed to be in hex and were added
in dec by mistake.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
scsi_scan() must be called as part of scsi_init() and not
as part of sata_init().
Signed-off-by: Roger Quadros <rogerq@ti.com>
On OMAP platforms, SATA controller provides the SCSI subsystem
so implement scsi_init().
Get rid of the unnecessary sata_init() call from dra7xx-evm
and omap5-uevm board files.
Removed settings in unsupported register fields. They didn’t
do anything, and in most cases, were not documented in the
reference manual.
Changed register settings to comply with JEDEC required values.
Changed timing parameters because they included full clock
periods that were doing nothing.
Signed-off-by: Anthony Felice <tony.felice@timesys.com>
[rebased on v2014.10-rc2]
Signed-off-by: Stefan Agner <stefan@agner.ch>
Add command to enable and disable the bridges between HPS and FPGA.
This patch does have a checkpatch issue with the assembler portion,
checkpatch correctly complains that there should be no whitespace
before quoted newline. I do not agree that fixing this specific
checkpatch issue will improve the readability, thus this one is not
addressed.
Cc: Dinh Nguyen <dinguyen@altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Move icache_enable() and dcache_enable() function calls from
board code into the CPU code and into the enable_caches()
function. This is how the cache enabling code was designed
to work.
Acked-by: Pavel Machek <pavel@denx.de>
Add code which configures the AMBA NIC-301 and the SCU on the SoCFPGA .
The code sets the access permissions for the CPU to the AMBA slaves such
that the CPU can access them in both secure and non-secure mode.
Cc: Chin Liang See <clsee@altera.com>
Configure the PL310 address filter to make sure DRAM is mapped to 0x0.
This code also configures the "remap" register of NIC-301 and sets the
required 'mpuzero' bit.
Add register definition for the NIC-301 used on SoCFPGA.
Add the Snoop Control Unit register definition file.
Add missing system manager bits from Altera U-Boot to make the code
comparable. These are the bits which depend on the FPGA manager.
Add function to enable and disable FPGA bridges. This code is used
by the FPGA manager to disable the bridges before programming the
FPGA and will later be also used by the initialization code for the
chip to put the chip into well defined state during startup.
Add code necessary to program the FPGA part of SoCFPGA from U-Boot
with an RBF blob. This patch also integrates the code into the
FPGA driver framework in U-Boot so it can be used via the 'fpga'
command.
Signed-off-by: Pavel Machek <pavel@denx.de>
V2: Move the not-CPU specific stuff into drivers/fpga/ and base
this on the cleaned up altera FPGA support.
Cosmetic change to the print_cpuinfo() function output. Align the
output with the rest of initial output produced by U-Boot.
Add CPU function to register and initialize the dw_mmc SD controller.
This allows us to use the HPS SDMMC block.
Add function to initialize the EMAC blocks upon board startup.
The preprocessor guards against building on SoCFPGA-VT and against
SPL build are not needed as those are handled implicitly via both
SPL framework and the socfpga_cyclone5.h config file, which will
not define CONFIG_DESIGNWARE_ETH if building for SoCFPGA-VT.
We cannot handle two EMAC ethernet blocks yet, therefore the ifdefs.
Once there is hardware using both EMAC blocks, this ifdef will have
to go.
Add functions to reset the EMAC ethernet blocks. We cannot handle
two EMAC ethernet blocks yet, therefore the ifdefs. Once there is
hardware using both EMAC blocks, this ifdef will have to go.
The timer reload value is a property of the timer hardware and there
is no reason for this to be configurable. Place this into the timer
driver just like on the other hardware.
Acked-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Add the missing pieces from the reference clock code from Altera. This
puts the code on par with the Altera U-Boot fork for all but the SDRAM
self-refresh bits, which are not part of this patch.
Clean up the clock code definitions so they are aligned with mainline
standards. There are no functional changes in this patch.
Pull out functions to read frequency of Main clock VCO and
PLL clock VCO as the code is duplicated multiple times.
Add the entire bulk of code to read out clock configuration from the SoCFPGA
CPU registers. This is important for MMC, QSPI and UART drivers as otherwise
they cannot determine the frequency of their upstream clock.
V2: Fixed the L4 MP clock divider and synced the clock code with latest
rocketboards codebase (thanks Dinh for pointing this out)
The inlining is done by GCC when needed, there is no need to do it
explicitly. Furthermore, the inline keyword does not force-inline
the code, but is only a hint for the compiler. Scrub this hint.
The bit definitions for clock manager are complete chaos. Implement
some basic logical order into them.
Clean up the system manager register definition and add the missing
register definitions in place.
This adds watchdog disable. It is neccessary for running Linux kernel.
V2: Move RSTMGR_PERMODRST_L4WD0_LSB to reset_manager.h
Reset watchdog only if CONFIG_HW_WATCHDOG is undefined (the default)
Sort the list of functional block addresses and fix indentation.
No functional change.
Acked-by: Chin Liang See <clsee@altera.com>
Add base addresses for all subsystems as documented in the
Cyclone V HPS documentation.
Add configuration for the write-allocate mode of L1 D-Cache on ARM.
This is needed for D-Cache operation on Cortex-A9 on the SoCFPGA .
This commit allows to build Panasonic UniPhier family:
PH1-LD4, PH1-Pro4, PH1-sLD8
These are used by Panasonic UniPhier SoC family.
With some versions of gcc (that we know of 4.6.3 and 4.8.2 are affected)
it is necessary to specify --bss-plt to get the final blrl in the
_GOT2_TABLE_. Without this the last symbol does not get it's address
relocated. For the P2041RDB board this ended up being
NetArpWaitTimerStart which caused the ARP packets to timeout
immediately.
Signed-off-by: Joakim Tjernlund <joakim.tjernlund@transmode.se>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Acked-by: Joakim Tjernlund <joakim.tjernlund@transmode.se>
Acked-by: Scott Wood <scottwood@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
LS1021AQDS has a variant with DDR4 slot. This patch adds a new defconfig
for this variant to enable DDR4 support. RAW timing parameters are not
added for DDR4. The board timing parameters are only tuned for single-
rank 1600 and 1800MT/s with Micron DIMM 9ASF51272AZ-2G1A1 due to DIMM
availability.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Alison Wang <alison.wang@freescale.com>
Secondary cores need to be released from holdoff by boot release
registers. With GPP bootrom, they can boot from main memory
directly. Individual spin table is used for each core. Spin table
and the boot page is reserved in device tree so OS won't overwrite.
Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
DP-DDR is used for DPAA, separated from main memory pool for general
use. It has 32-bit bus width and use a standard DDR4 DIMM (64-bit).
U-boot has been initializing DDR for the main memory. The presumption
is the memory stays as a big continuous block, either linear or
interleaved. This change is to support putting some DDR controllers
to separated space without counting into main memory. The standalone
memory controller could use different number of DIMM slots.
This commit moves:
CONFIG_OF_CONTROL
CONFIG_OF_SEPARATE
CONFIG_OF_EMBED
CONFIG_OF_HOSTFILE
Because these options are currently not supported for SPL,
the "Device Tree Control" menu does not appear in the SPL
configuration.
Note:
zynq-common.h should be adjusted so as not to change the
default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME.
Cc: Stephen Warren <swarren@nvidia.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
The macro MIN, MAX is defined as the aliase of min, max,
respectively.
Each CPU of PowerPC has its default linker script under the CPU
directory, except mpc8xx.
Every mpc8xx board has its own linker script under the board
directory, resulting in lots of duplication of linker scripts.
I notice eight mpc8xx boards have the same linker script.
We can decrease the number of linker scripts by putting a single
default linker script, arch/powerpc/cpu/mpc8xx/u-boot.lds.
"0x00" is a valid serdes protocol for QorIQ parts, and can not be
used to test whether the serdes is enabled or disabled.
Signed-off-by: Ebony Zhu <b45385@freescale.com>
Fix following issues in USB device-tree fixup:
- returns when either dr_mode or phy_type not defined.
This was terminating fix-up when only either property
was defined in hwconfig string
- updates dr_mode_type or dr_phy_type with junk value when
their index is -1. Now these are updated only when their
respective index is pointing to relevant types
in modes[] and phys[] array
- dr_mode_type and dr_phy_type were not NULL for
each controller
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Tested-by: Luka Perkov <luka@openwrt.org>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Using CPU_HAS_PCR micro to present the SoC has pcr
(peripheral control register).
Signed-off-by: Bo Shen <voice.shen@atmel.com>
