path: root/arch
2015-08-02imx: mx6ul_14x14_evk add basic board supportPeng Fan
1. Add USDHC, I2C, UART, 74LV, USB, QSPI support. 2. Support SPL 3. CONFIG_MX6UL_14X14_EVK_EMMC_REWORK is introduced, this board default supports sd for usdhc2, but can do hardware rework to make usdhc2 support emmc. Boot Log: U-Boot SPL 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59) reading u-boot.img reading u-boot.img U-Boot 2015.07-rc3-00124-g35d727b (Jul 20 2015 - 18:40:59 +0800) CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C)CPU: Thermal invalid data, fuse: 0x0 - invalid sensor device Reset cause: POR Board: MX6UL 14x14 EVK I2C: ready DRAM: 512 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: CPU Net Initialization Failed No ethernet found. Hit any key to stop autoboot: 0 Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx:mx6ul add dram spl configuration and header filePeng Fan
1. Define two structures mx6ul_iomux_ddr_regs and mx6ul_iomux_grp_regs. 2. Add a new function mx6ul_dram_iocfg to configure dram io. 3. Refactor MMDC1 macro, discard "#ifdef CONFIG_MX6SX". Since only mmdc0 channel exists on i.MX6SX/UL, redefine MMDC1 macro support runtime check, but not hardcoding #ifdef macros. 4. Introduce mx6ul-ddr.h, which includes the register address for DRAM IO configuration. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6 add PAD_CTL_SPEED_LOW for i.MX6SX/ULPeng Fan
PAD_CTL_SPEED_LOW for i.MX6SX/UL is (0 << 6) Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul update soc related settingsPeng Fan
1.Update WDOG settings. 2.No need to gate/ungate all PFDs for i.MX6UL. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-08-02imx: mx6ul select SYS_L2CACHE_OFFPeng Fan
i.MX6UL features an Cortex-A7 core, it does not have PL310 as other i.MX6 chips. To Cortex-A7 core, If D-Cache is enabled, L2 Cache is enabled. There is on specific switch for on/off L2 Cache, so default select SYS_L2CACHE_OFF. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx:mx6ul add clock supportPeng Fan
1. Add enet, uart, i2c, ipg clock support for i.MX6UL. 2. Correct get_periph_clk, it should account for MXC_CCM_CBCDR_PERIPH_CLK2_PODF_MASK. 3. Refactor get_mmdc_ch0_clk to make all i.MX6 share one function, but not use 'ifdef'. 4. Use CONFIG_FSL_QSPI for enable_qspi_clk, but not #ifdef CONFIG_MX6SX. 5. Use CONFIG_PCIE_IMX for pcie clock settings, use CONFIG_CMD_SATA for sata clock settings. In this way, we not need "#if defined(CONFIG_MX6Q) || defined....", only need one CONFIG_PCIE_IMX in header file. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx-common: timer: add i.MX6UL supportPeng Fan
Add i.MX6UL GPT timer support. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul Add CONFIG_SYS_CACHELINE_SIZE for i.MX6ULPeng Fan
Since i.MX6UL's cache line size is 64bytes, need to define the macro CONFIG_SYS_CACHELINE_SIZE to 64 for i.MX6UL. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul: Update imx registers head filePeng Fan
1. Update imx register base address for i.MX6UL. 2. Remove duplicated MXS_APBH/GPMI/BCH_BASE. 3. Remove #ifdef for register addresses that equal to "AIPS2_OFF_BASE_ADDR + 0x34000" for different chips. 4. According fuse map, complete fuse_bank4_regs. 5. Move AIPS3_ARB_BASE_ADDR and AIPS3_ARB_END_ADDR out of #ifdef CONFIG_MX6SX, because we can use runtime check Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02imx: mx6ul: Add pins IOMUX head filePeng Fan
Add i.MX6UL pins IOMUX file which defines the IOMUX settings for choose. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-08-02imx: mx6ul: Add i.MX6UL CPU typePeng Fan
Add MXC_CPU_MX6UL for i.MX6UL CPU type which is got at runtime from DIGPROG register. But the value has been occupied by MXC_CPU_MX6D which is not real id from DIGPROG register, so change i.MX6D to value 0x67 which was not occupied. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com>
2015-08-02arm: mx6: kconfig: don't select CPU_V7 per boardNikita Kiryanov
CPU_V7 is already selected by ARCH_MX6, so no point in selecting it again by boards that depend on ARCH_MX6. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-08-02arm: mx6: cm-fx6: move cm-fx6 target under ARCH_MX6Nikita Kiryanov
cm-fx6 is an MX6 based board, and the menuconfig hierarchy should reflect that. Make TARGET_CM_FX6 dependant on ARCH_MX6. Cc: Stefano Babic <sbabic@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-08-02imx: mx6qp Enable PRG clock for IPUPeng Fan
The i.MX6DQP has a PRG module, need to enable its clock for using IPU. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Brown Oliver <B37094@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-08-02imx: mx6: hab : Remove the cache issue workaroud in hab for i.MX6QPYe.Li
Since the i.MX6QP has fixed the issue in boot ROM, so remove the workaround for i.MX6QP. Signed-off-by: Ye.Li <B37916@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-08-02imx: mx6: ccm: Change the clock settings for i.MX6QPPeng Fan
Since i.MX6QP changes some CCM registers, so modify the clocks settings to follow the hardware changes. In c files, use runtime check and discard #ifdef. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Signed-off-by: Ye.Li <B37916@freescale.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-08-02imx: add cpu type for i.MX6QP/DPPeng Fan
Add cpu type for i.MX6QP/DP. This patch also fix is_mx6dqp(), since get_cpu_rev can return MXC_CPU_MX6QP and MXC_CPU_MX6DP, we should use: (is_cpu_type(MXC_CPU_MX6QP) || is_cpu_type(MXC_CPU_MX6DP)). Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-07-31Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2015-07-31powerpc/t4240: update serdes tableShaohui Xie
Serdes Lanes availability on T4160 and T4080 are same, which serdes 2 & 3 support 8 Lanes, but serdes 1 & 4 support only 4 Lanes E/F/G/H, Lanes A/B/C/D are not available, updated the serdes table accordingly with some minor fix. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-31powerpc/mpc85xx: SECURE BOOT-Copy Boot Script on RAMAneesh Bansal
For running Chain of Trust when doing Secure Boot from NAND, the Bootscript header and bootscript must be copied from NAND to RAM(DDR). The addresses and commands for the same have been defined. Signed-off-by: Saksham Jain <saksham@freescale.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-31powerpc/mpc85xx: SECURE BOOT- NAND secure boot target for P3041Aneesh Bansal
Secure Boot Target is added for NAND for P3041. For mpc85xx SoCs, the core begins execution from address 0xFFFFFFFC. In case of secure boot, this default address maps to Boot ROM. The Boot ROM code requires that the bootloader(U-boot) must lie in 0 to 3.5G address space i.e. 0x0 - 0xDFFFFFFF. In case of NAND Secure Boot, CONFIG_SYS_RAMBOOT is enabled and CPC is configured as SRAM. U-Boot binary will be located on SRAM configured at address 0xBFF00000. In the U-Boot code, TLB entries are created to map the virtual address 0xFFF00000 to physical address 0xBFF00000 of CPC configured as SRAM. Signed-off-by: Saksham Jain <saksham@freescale.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-31armv8: caches: Added routine to set non cacheable regionSiva Durga Prasad Paladugu
Added routine mmu_set_region_dcache_behaviour() to set a particular region as non cacheable. Define dummy routine for mmu_set_region_dcache_behaviour() to handle incase of dcache off. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2015-07-29Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2015-07-28powerpc/mpc85xx: Correct CONFIG_USB_MAX_CONTROLLER_COUNT for p1025Nikhil Badola
Correct the value CONFIG_USB_MAX_CONTROLLER_COUNT macro to 1 for p1025 as it has one USB controller Signed-off-by: Nikhil Badola <nikhil.badola@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-28powerpc/t1024: update fman liodn for mac1Shengzhou Liu
MAC1 acts as 1G/10G dual-role MAC on T1024. We introduce macro SET_FMAN_RX_10G_TYPE2_LIODN for 10G MACs which have same Port ID and same offset of address with 1G MAC. Update it to match with the setting of fman in t1024 device tree, otherwise there is no 'fsl,liodn' in /proc/device-tree/soc@ffe000000/fman@400000/port@88000/ Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-28powerpc/T104xD4: Add Secure boot support for T104xD4RDB platformsgaurav rana
defconfig files are added and SFP version for these platforms is updated. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-07-28T210: Add support for 64-bit T210-based P2571 boardTom Warren
Based on Venice2, incorporates Stephen Warren's latest P2571 pinmux table. With Thierry Reding's 64-bit build fixes, this will build and and boot in 64-bit on my P2571 (when used with a 32-bit AVP loader). Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28P2571: dts: Add DT file for Tegra210 P2571 boardTom Warren
Based on T124 Venice2. SDMMC1 is SD-card slot. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28ARM: Tegra210: Add support to common Tegra source/config filesTom Warren
Derived from Tegra124, modified as appropriate during T210 board bringup. Cleaned up debug statements to conserve string space, too. This also adds misc 64-bit changes from Thierry Reding/Stephen Warren. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-07-28ARM: Tegra210: Add SoC code/include files for T210Tom Warren
All based off of Tegra124. As a Tegra210 board is brought up, these may change a bit to match the HW more closely, but probably 90% of this is identical to T124. Note that since T210 is a 64-bit build, it has no SPL component, and hence no cpu.c for Tegra210. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28Tegra: Rework KConfig options to allow 64-bit builds (T210)Tom Warren
Moved Tegra config options to mach-tegra/Kconfig so that both 32-bit and 64-bit builds can co-exist for Tegra SoCs. T210 will be 64-bit only (no SPL) and will require a 32-bit AVP/BPMP loader. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28Tegra210: Fix 64-bit build warning about save_boot_params_ret()Tom Warren
Simon's 'tegra124: Implement spl_was_boot_source()' needs a prototype for save_boot_params_ret() to build cleanly for 64-bit Tegra210. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28ARM: tegra: Initialize timer earlierThierry Reding
A subsequent patch will enable the use of the architected timer on ARMv8. Doing so implies that udelay() will be backed by this timer implementation, and hence the architected timer must be ready when udelay() is first called. The first time udelay() is used is while resetting the debug UART, which happens very early. Make sure that arch_timer_init() is called before that. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-07-28ARM: tegra: Use standard cache enable for 64-bitThierry Reding
On 64-bit SoCs the I-cache isn't enabled in early code, so the default cache enable functions for 64-bit ARM can be used. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-07-28ARM: tegra: Restrict usable RAM to 32-bit on 64-bit SoCsThierry Reding
Most peripherals on Tegra can do DMA only to the lower 32-bit address space, even on 64-bit SoCs. This limitation is typically overcome by the use of an IOMMU. Since the IOMMU is not entirely trivial to set up and serves no other purpose (I/O protection, ...) in U-Boot, restrict 64-bit Tegra SoCs to the lower 32-bit address space for RAM. This ensures that the physical addresses of buffers that are programmed into the various DMA engines are valid and don't alias to lower addresses. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-07-28armv8/cache: Fix page table creationThierry Reding
While generating the page tables, a running integer index is shifted by SECTION_SHIFT (29) and causes overflow for any integer bigger than 7. The page tables therefore alias to the same 8 sections and cause U-Boot to hang once the MMU is enabled. Fix this by making the index a 64-bit unsigned integer and so avoid the overflow. swarren notes: currently "i" ranges from 0..8191 on all ARM64 boards, and "j" varies depending on RAM size; from 4 to 11 for a board with 4GB at physical address 2GB, as some Tegra boards have. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Reserve PCIe ECAM address range in the E820 tableBin Meng
We should mark PCIe ECAM address range in the E820 table as reserved otherwise kernel will not attempt to use ECAM. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: qemu: Turn on PCIe ECAM address range decoding on Q35Bin Meng
Turn on PCIe ECAM address range decoding on Q35. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: qemu: Enable writing MP tableBin Meng
Enable writing MP table for QEMU boads (i440fx and q35). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Allow cpu-x86 driver to be probed for UPBin Meng
Currently cpu-x86 driver is probed only for SMP. We add the same support for UP when there is only one cpu node in the deive tree. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: qemu: Enable I/O APIC chip select on PIIX3Bin Meng
The PIIX3 chipset does not integrate an I/O APIC, instead it supports connecting to an external I/O APIC which needs to be enabled manually. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: mpspec: Move writing ISA interrupt entry after PCIBin Meng
On some platforms the I/O APIC interrupt pin#0-15 may be connected to platform pci devices' interrupt pin. In such cases the legacy ISA IRQ is not available so we should not write ISA interrupt entry if it is already occupied. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: mpspec: Allow platform to determine how PIRQ is connected to I/O APICBin Meng
Currently during writing MP table I/O interrupt assignment entry, we assume the PIRQ is directly mapped to I/O APIC INTPIN#16-23, which however is not always the case on some platforms. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Convert to use driver model pci on queensbay/crownbayBin Meng
Move to driver model pci for Intel queensbay/crownbay. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-07-28x86: pci: Do not assign irq 0 to pci deviceBin Meng
IRQ 0 is reserved and should not be assigned to pci device. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: pci: Assign pci irqs to all functionsBin Meng
We need walk through all functions within a PCI device and assign their IRQs accordingly. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Enable DM RTC support for all x86 boardsBin Meng
Add a RTC node in the device tree to enable DM RTC support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> (Squashed in 'x86: Fix RTC build error on ivybridge')
2015-07-28x86: Change pci option rom area MTRR setting to cacheableBin Meng
Turn on cache on the pci option rom area to improve the performance. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Simplify architecture defined exception handling in irq_llsr()Bin Meng
Instead of using switch..case for architecture defined exceptions, simply unify the handling by printing a message of exception name, followed by registers dump then halt the CPU. With this unification, it also fixes the wrong exception numbers for #MF/#AC/#MC/#XM which should be 16/17/18/19 not 15/16/17/18. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Display correct CS/EIP/EFLAGS when there is an error codeBin Meng
Some exceptions cause an error code to be saved on the current stack after the EIP value. We should extract CS/EIP/EFLAGS from different position on the stack based on the exception number. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
