- Convert the non-relocation part of board_init_f to spl_board_init, turn on CONFIG_SPL_BOARD_INIT in the configs.
- Remove duplicated code.
- Add spl_boot_device() that returns the statically chosen boot device.
We move the spl_nand_load_image function to common/spl. This will allow
for easier integration of SPL-boots-Linux code on other arches.
In SPL (CONFIG_SPL_FRAMEWORK) board_init_f must setup the stack pointer,
clear the BSS and call board_init_r. We mark this as weak as some
platforms may need to perform additional initalization at this point.
We provide a gd that we know will be in a usable location, once the BSS
has been cleared to help with this as well. Finally, we no longer call
relocate_code so remove that from the armv7 version.
Next, both board_init_f and jump_to_image_linux are going to be
inherently arch-specific, so move these versions to arch/arm/lib/spl.c
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
This is an OMAP/related-specific function, move calling it to
spl_board_init() and turn on CONFIG_SPL_BOARD_INIT on the boards that
enabled NAND and didn't enable this already.
- Remove includes we don't need
- Switch some printf statements to puts
- Convert some printf statements to debug, introduce new puts statements
- In most cases saying just "No mkimage signature, assuming
u-boot.bin" or similar is sufficient. This also means the non-DEBUG
case doesn't need printf, in the core of SPL.
- The other case here is that PLAIN_VERSION provided what we wanted
already, so just use it.
Move the default omap/related-centric board_mmc_init to
arch/arm/cpu/armv7/omap-common/boot-common.c and move the type defines
to <asm/spl.h>. Also use mmc->read_bl_len rather than MMCSD_SECTOR_SIZE
Move the SPL prototypes from <asm/omap_common.h> into <asm/spl.h> and
add <asm/arch/spl.h> for arch specific portions of CONFIG_SPL_FRAMEWORK.
We can only attempt to setup a malloc pool if
CONFIG_SYS_SPL_MALLOC_START is defined, and not all boards require it.
Make the call depend on the define.
This detection code doesn't (and can't) do anything currently, so
remove.
Signed-off-by: Pavel Machek <pavel@denx.de>
Only omap4/5 currently have a meaningful set of display text and overo
had been adding a function to display nothing. Change how this works to
be opt-in and only turned on for omap4/5 now.
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations
in various board.c files to get rid of one checkpatch.pl warning.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
Commit 86c6326 "ARM: arm1176: enable instruction cache in
arch_cpu_init()" defined arch_cpu_init() in a file that is shared across
all arm1176 SoCs. tnetv107x already implemented this function, which
caused linking to break. Move the new conflicting arch_cpu_init() into
arm1176/bcm2835/init.c so that it doesn't conflict; grep indicates this
function is usually defined at the SoC-level, not the CPU-level, at least
for ARM.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
- remove internal pull-ups on data and CMD: they are not needed
as pull-ups are add on board.
- add MCI power switch on PIO
RGMII is unsed on CM board: some PIO are not
needed and are used for other things.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
[fix Conflicts]
Signed-off-by: Josh Wu <josh.wu@atmel.com>
[merge with mainline pmecc]
LCDC: using has_lcdc() function to avoid error register
NET: using has_emac() and has_gmac to avoid error register
Use the same ID as SAM9X5. Do not propagate upstream.
[fix conflicts, not use 9X5's mach type code.]
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG
information.
If this data is not present, the kernel misconfigures the TZIC, which results in
the timer interrupt handler never being called, so the kernel deadlocks while
calibrating its delay.
Suggested-by: Greg Topmiller <Greg.Topmiller@jdsu.com>
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <festevam@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with
the 5235 processor. The registers in struct fbcs are different sizes from
those in the 5235. Also, the defines are a little different.
This is what I have so far. Comments?
Reformat the patch manually by Jason Jin
Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
This patch adds a driver for Freescale Colfire Queued SPI bus.
Coded to work with 8 bits per transfer to use with SPI flash.
CPOL, CPHA, and CS_ACTIVE_HIGH can be configured.
Tested with MCF5270 which have 4 chip selects.
Activate by #define CONFIG_CF_QSPI in board config.
Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
