path: root/arch
2014-12-08Merge git://git.denx.de/u-boot-mpc85xxTom Rini
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-12-08Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2014-12-09ARM: UniPhier: detect the number of flash banks at run-timeMasahiro Yamada
Some UniPhier boards are equipped with an expansion slot that some optional SRAM/NOR-flash cards can be attached to. So, run-time detection of the number of flash banks would be more user-friendly. Until this commit, UniPhier boards have achieved this by (ab)using board_flash_wp_on() because the boot failed if flash_size got zero. Fortunately, this problem was solved by commit 70879a92561a (flash: do not fail even if flash_size is zero). Now it is possible to throw away such a tricky workaround. This commit also enables CONFIG_SYS_MAX_FLASH_BANKS_DETECT for further refactoring. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-09ARM: UniPhier: extend register area of init page table for PH1-sLD3Masahiro Yamada
0x20000000-0x2fffffff: assigned to ARM mpcore (sLD3 only) 0xf0000000-0xffffffff: assigned to Denali NAND controller (sLD3 only) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-09ARM: UniPhier: add device tree sources for PH1-sLD3Masahiro Yamada
2014-12-09ARM: UniPhier: add more device nodes to device treeMasahiro Yamada
Add I2C controller and NAND controller devices. Fix indentation too. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08blackfin: include <linux/compiler.h> rather than define __iomemMasahiro Yamada
The macro __iomem is defined in include/linux/compiler.h. Let's include it rather than double __iomem defines. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.adi@gmail.com>
2014-12-08Replace <compiler.h> with <linux/compiler.h>Masahiro Yamada
Including <linux/compiler.h> is enough for general use. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08powerpc: mpc8xx: remove hermes board supportMasahiro Yamada
This board sprinkles #ifdef(CONFIG_HERMES) over various global files such as include/common.h, common/board_r.c, common/cmd_bdinfo.c. Let's zap such an ill-behaved board. It has not been converted to generic board yet and mpc8xx is old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2014-12-08ARM: rpi: rename rpi_b to rpiStephen Warren
The U-Boot port runs on a variety of RPi models, not just the B. So, rename the port to something slightly more generic. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08ARM: rpi_b: detect board revisionStephen Warren
Detect the board revision early during boot, and print the decoded model name. Eventually, this information can be used for tasks such as: - Allowing/preventing USB device mode; some models have a USB device on- board so only host mode makes sense. Others connect the SoC directly to the USB connector, so device-mode might make sense. - The on-board USB hub/Ethernet requires different GPIOs to enable it, although luckily the default appears to be fine so far. - The compute module contains an on-board eMMC device, so we could store the environment there. Other models use an SD card and so don't support saving the environment (unless we store it in a file on the FAT boot partition...) Set $fdtfile based on this information. At present, the mainline Linux kernel doesn't contain a separate DTB for most models, but I hope that will change soon. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-12-08ARM: UniPhier: merge UniPhier config headers into a single fileMasahiro Yamada
Some configurations have been moved to Kconfig and the difference among the config headers of UniPhier SoC variants is getting smaller and smaller. Now is a good time to merge them into a single file. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08ARM: UniPhier: move support card select to KconfigMasahiro Yamada
There are two kinds of expansion boards which are often used for the UniPhier platform and they are only exclusively selectable. It can be better described by the "choice" menu of Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-08ARM: UniPhier: move CONFIG_UNIPHIER_SMP to KconfigMasahiro Yamada
2014-12-08ARM: UniPhier: use boot_is_swapped() macro for readabilityMasahiro Yamada
2014-12-07ARM: UniPhier: remove Denali NAND controller fixup codeMasahiro Yamada
This ugly work-around code is unnecessary since commit f09eb52b3ffc (mtd: denali: set some registers after nand_scan_ident()). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-12-05powerpc/mpc85xx: use correct dma compatible for several SoCsTudor Laurentiu
Newer qoriq socs have an updated dma ip block with a different compatible. Let's make sure we use the proper string so that the dmas get their liodn. In order to have the means to specify the compatible string, the liodn setting macros were updated to receive a new parameter for it. The following SoCs were changed to use the new compatible: T1023/4, T1040, T2080/1, T4240, B4860. Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05t1024qds: increase IO drive strengthShengzhou Liu
Increase IO drive strength to fix FCS error on RGMII ports on T1024QDS. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05net/fman: update 10GEC to fit new SoCShengzhou Liu
fm_standard_init() initializes each 10G port by FM_TGEC_INFO_INITIALIZER. but it needs different implementation of FM_TGEC_INFO_INITIALIZER on different SoCs. on SoCs earlier(e.g. T4240, T2080), the notation between 10GEC and MAC as below: 10GEC1->MAC9, 10GEC2->MAC10, 10GEC3->MAC1, 10GEC4->MAC2 on SoCs later(e.g. T1024, etc), the notation between 10GEC and MAC as below: 10GEC1->MAC1, 10GEC2->MAC2 so we introduce CONFIG_FSL_FM_10GEC_REGULAR_NOTATION to fit the new SoCs on which 10GEC enumeration is consistent with MAC enumeration. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t1024rdb: Add T1024 RDB board supportShengzhou Liu
T1024RDB is a Freescale Reference Design Board that hosts the T1024 SoC. T1024RDB board Overview ----------------------- - T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3L SDRAM memory controller with ECC and interleaving support - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - Two 10M/100M/1G RGMII ports on-board - one 10Gbps XFI interface - PCIe: Three PCIe controllers: one PCIe Slot and two Mini-PCIe connectors. - SerDes: 4 lanes up to 10.3125GHz - IFC: 128MB NOR Flash, 512MB NAND Flash and CPLD - eSPI: 64MB N25Q512 SPI flash. - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - USB: Two Type-A USB2.0 ports with internal PHY - eSDHC: Support SD, SDHC, SDXC and MMC/eMMC - I2C: Four I2C controllers - UART: Two UART serial ports Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT Fix Kconfig by adding SUPPORT_SPL] Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t1024qds: Add T1024 QDS board supportShengzhou Liu
T1024QDS is a high-performance computing evaluation, development and test platform for T1024 QorIQ Power Architecture processor. T1024QDS board Overview ----------------------- - T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - Two 10M/100M/1G RGMII ports on-board - Three 1G/2.5Gbps SGMII ports - Four 1Gbps QSGMII ports - one 10Gbps XFI or 10Base-KR interface - SerDes: 4 lanes up to 10.3125GHz Supporting SGMII/QSGMII, XFI, PCIe, SATA and Aurora - PCIe: Three PCI Express controllers with five PCIe slots. - IFC: 128MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA - Video: DIU supports video up to 1280x1024x32 bpp. - Chrontel CH7201 for HDMI connection. - TI DS90C387R for direct LCD connection. - Raw (not encoded) video connector for testing or other encoders. - QUICC Engine block - 32-bit RISC controller for flexible support of the communications peripherals - Serial DMA channel for receive and transmit on all serial channels - Two universal communication controllers, supporting TDM, HDLC, and UART - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - eSPI: Three SPI flash devices. - SATA: one SATA 2.O. - USB: Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB) - eSDHC: Support SD, SDHC, SDXC and MMC/eMMC. - I2C: Four I2C controllers. - UART: Two UART on board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT Fix Kconfig by adding SUPPORT_SPL] Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/mpc85xx: Add T1024/T1023 SoC supportShengzhou Liu
Add support for Freescale T1024/T1023 SoC. The T1024 SoC includes the following function and features: - Two 64-bit Power architecture e5500 cores, up to 1.4GHz - private 256KB L2 cache each core and shared 256KB CoreNet platform cache (CPC) - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration - Four MAC for 1G/2.5G/10G network interfaces (RGMII, SGMII, QSGMII, XFI) - High-speed peripheral interfaces - Three PCI Express 2.0 controllers - Additional peripheral interfaces - One SATA 2.0 controller - Two USB 2.0 controllers with integrated PHY - Enhanced secure digital host controller (SD/eSDHC/eMMC) - Enhanced serial peripheral interface (eSPI) - Four I2C controllers - Four 2-pin UARTs or two 4-pin UARTs - Integrated Flash Controller supporting NAND and NOR flash - Two 8-channel DMA engines - Multicore programmable interrupt controller (PIC) - LCD interface (DIU) with 12 bit dual data rate - QUICC Engine block supporting TDM, HDLC, and UART - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - Support for hardware virtualization and partitioning enforcement - QorIQ Platform's Trust Architecture 2.0 Differences between T1024 and T1023: Feature T1024 T1023 QUICC Engine: yes no DIU: yes no Deep Sleep: yes no I2C controller: 4 3 DDR: 64-bit 32-bit IFC: 32-bit 28-bit Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/mpc85xx: Update LIODN entries for T1040Priyanka Jain
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/b4860qds: add workaround for XFIShaohui Xie
XFI does not work stable on current board, it's due to heat sink issue, to make it work stable the board needs additional heat sink, enable two XFI lanes only. Right now we do not have such an erratum for the issue, so use a define CONFIG_SYS_FSL_B4860QDS_XFI_ERR to identify it. The workaround will only be used in XFI protocols and only if the hwconfig indicates that XFI is prefered. A new VSC3308 config function is used instead of re-use the original function, to avoid making the function complex and ugly. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-0585xx/b4860: Add alternate serdes protocols for B4860/B4420Shaveta Leekha
Addded Alternate options with LC VCO for following protocols: 0x02 --> 0x01 0x08 --> 0x07 0x18 --> 0x17 0x1E --> 0x1D 0x49 --> 0x48 0x6F --> 0x6E 0x9A --> 0x99 0x9E --> 0x9D Signed-off-by: Shaveta Leekha <shaveta@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/mpc85xx: modify erratum A007186Zhao Qiang
T2080 v1.0 has this errata while v1.1 has fixed this errata by hardware, add a new function has_errata_a007186 to check the SVR_SOC_VER, SVR_MAJ and SVR_MIN first, if the sil has errata a007186, then run the errata code, if not, doesn't run the code. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05board/t104xrdb: Conditional workaround of errata A-008044Prabhakar Kushwaha
Workaround of Errata A-008044 was implemented without errata number and it is enabled by default. Errata A-008044 is only valid for T1040 Rev 1.0. So put errata number and make it conditional. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/mpc85xx:Put errata number for T104x NAND boot issuePrabhakar Kushwaha
When device is configured to load RCW from NAND flash IFC_A[16:31] are driven low after RCW loading. Hence Devices connected on IFC_CS[1:7] and using IFC_A[16:31] lines are not accessible. Workaround is already in-place. Put the errata number to adhere errata handling framework. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05mpc85xx/t2080: Fix parsing DDR ratio for new revisionYork Sun
T2080 rev 1.1 changes MEM_RAT in RCW, which requires new parsing for ratio, the same way as T4240 rev 2.0. Signed-off-by: York Sun <yorksun@freescale.com> CC: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2014-12-05powerpc/t2080: add serdes2 protocol 0x2eShengzhou Liu
Add serdes2 protocol 0x2e. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-04arm: am33xx: Handle NAND+I2C boot-device the same way as NANDStefan Roese
Re-map NAND&I2C boot-device to the "normal" NAND boot-device. Otherwise the SPL boot IF can't handle this device correctly. Somehow booting with Hynix 4GBit NAND H27U4G8 on Siemens Draco leads to this boot-device passed to SPL from the BootROM. With this change, Draco boots just fine into main U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Roger Meier <r.meier@siemens.com> Cc: Samuel Egli <samuel.egli@siemens.com>
2014-12-04beagle_x15: add board support for Beagle x15Felipe Balbi
BeagleBoard-X15 is the next generation Open Source Hardware BeagleBoard based on TI's AM5728 SoC featuring dual core 1.5GHZ A15 processor. The platform features 2GB DDR3L (w/dual 32bit busses), eSATA, 3 USB3.0 ports, integrated HDMI (1920x108@60), separate LCD port, video In port, 4GB eMMC, uSD, Analog audio in/out, dual 1G Ethernet. For more information, refer to: http://www.elinux.org/Beagleboard:BeagleBoard-X15 Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap: add support for am57xx devicesFelipe Balbi
just add a few ifdefs around because this device is very similar to dra7xxx. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap_common: expose tps659038 and dra7xx_dpllsFelipe Balbi
expose those two definitions so they can be used by another board which we're adding in upcoming patches. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap5: sdram: mark emif_get_ext_phy_ctrl_const_regs __weakFelipe Balbi
this will allow for boards to overwrite those in case memory setup is different. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap5: make hw_init_data weakFelipe Balbi
this way we can let boards overwrite based on what they need. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap-common: emif: allow to map memory without interleavingFelipe Balbi
If we want to have two sections, one on each EMIF, without interleaving, current code wouldn't enable emif2. Fix that problem. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: dra7xx: prcm: add missing registersFelipe Balbi
some boards might want to use USB1 for host, without fiddling those registers it'll be impossible. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04arm: omap5: tps659038: rename regulator definesFelipe Balbi
Those regulators don't have any coupling with what they supply, so remove the suffixes in order to not confuse anybody. Signed-off-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-12-04Merge branch 'sandbox' of git://git.denx.de/u-boot-x86Tom Rini
2014-12-01Merge git://git.denx.de/u-boot-x86Tom Rini
2014-11-27Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2014-11-28ARM: UniPhier: enable Device Tree controlMasahiro Yamada
2014-11-28usb: UniPhier: support OF configurationMasahiro Yamada
If CONFIG_OF_CONTROL is defined, search device tree nodes that are compatible with "panasonic,uniphier-ehci" and take the base address from their "reg" property. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Marek Vasut <marex@denx.de>
2014-11-28serial: UniPhier: support OF configurationMasahiro Yamada
This commit implements the ofdata_to_platdata handler for the UniPhier serial driver and adds serial device nodes to the device tree sources. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-28ARM: UniPhier: add device tree sourcesMasahiro Yamada
This commit adds basic device tree sources for UniPhier SoCs/boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-28ARM: UniPhier: add dummy gpio.h to enable CONFIG_OF_CONTROLMasahiro Yamada
If CONFIG_OF_CONTROL is enabled, lib/fdtdec.c is compiled. It includes <asm/gpio.h> and then <asm/gpio.h> includes <asm/arch/gpio.h>. Consequently, all the SoCs that enable CONFIG_OF_CONTROL must have <asm/arch/gpio.h> even if they do not support GPIO. In the first place, GPIO has nothing to do with OF_CONTROL. It is wrong that lib/fdtdec.c includes GPIO functions; it should be split into two files, FDT-common things and GPIO things. It is, however, a pretty big work to fix that correctly. This is a compromised commit to add a dummy <asm/arch/gpio.h> to support OF_CONTROL for UniPhier platform. This dummy header will be removed after FDT-GPIO stuff is fixed correctly. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-11-28ARM: UniPhier: do not compile platform data when CONFIG_OF_CONTROL=yMasahiro Yamada
