path: root/arch
2014-01-21powerpc:mpc85xx: Add ifc nand boot support for TPL/SPLPo Liu
Using the TPL method for nand boot by sram was already supported. Here add some code for mpc85xx ifc nand boot. - For ifc, elbc, esdhc, espi, all need the SPL without section .resetvec. - Use a clear function name for nand spl boot. - Add CONFIG_SPL_DRIVERS_MISC_SUPPORT to compile the fsl_ifc.c in spl/Makefile; Signed-off-by: Po Liu <Po.Liu@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/mpc85xx: Fix a typo in workaround message for DDR erratum A003474York Sun
Unfortunately a typo presents "DDR-A003473" instead of "DDR-A003474". Signed-off-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/85xx: update erratum a006379Shengzhou Liu
Enable Erratum A006379 for T2080, T2081, T4160, B4420. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc/83xx: Add support for get_svr() for 83xx devicesRamneek Mehresh
Defines get_svr() for 83xx devices Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-20ARM: bcm2835: fix mailbox timeoutStephen Warren
My original intention was to have a 100ms timeout. However, the timer operations used return values in ms not us, so we ended up with a 100s timeout instead. Fixing this exposes that some operations need longer to operate than 100ms, so bump the timeout up to a whole second. Reported-by: Andre Heider <a.heider@gmail.com> Reviewed-by: Andre Heider <a.heider@gmail.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-01-20ARM: rpi_b: power on SDHCI and USB HW modulesStephen Warren
Send RPC commands to the VideoCore to turn on the SDHCI and USB modules. For SDHCI this isn't needed in practice, since the firmware already turned on the power in order to load U-Boot. However, it's best to be explicit. For USB, this is necessary, since the module isn't powered otherwise. This will allow the kernel USB driver to work. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-01-20Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-01-17mx6: Revert "mx6: soc: Disable VDDPU regulator"Fabio Estevam
Commit 022298278 (mx6: soc: Disable VDDPU regulator) is causing kernel hang for people using FSL kernel 3.0.35 and 3.10, so revert it for now. Reported-by: Otavio Salvador <otavio@ossystems.com.br> Reported-by: Pierre Aubert <p.aubert@staubli.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-01-16Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-01-16arm: rmobile: Add SH QSPI base register addressNobuhiro Iwamatsu
This adds base register address of SH QSPI. Currently, SH QSPI is used only from R8A7790 and R8A7791. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-15Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-15mx6: Add initial support for the Hummingboard soloFabio Estevam
SolidRun has designed the Hummingboard board based on mx6q/dl/solo. Add the initial support for the mx6 solo variant. More information about this hardware can be found at: http://imx.solid-run.com/wiki/index.php?title=Carrier-One_Hardware (Carrier-One was the previous name of Hummingboard). Based on the work from Jon Nettleton <jon.nettleton@gmail.com>. Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-01-15mx6: clock: Pass the frequency as argument of enable_fec_anatop_clock()Fabio Estevam
Provide an argument to enable_fec_anatop_clock() to specify the clock frequency that will be generated. No changes are made to mx6slevk, which uses the default 50MHz fec clock. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-14Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-01-14arm: use canonical sub mnemonicAndreas Bießmann
Building some arm boards with older binutils may produce errors like this: ---8<--- crt0.S: Assembler messages: crt0.S:70: Error: register expected, not '#(184)' -- `sub sp,#(184)' --->8--- Use canonical version of the subtract mnemonic to avoid those issues. Reported-by: Alexey Smishlayev <alexey@xtech2.lv> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-01-14Merge 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-14arm: put .hash, .got.plt and .machine_param back in binariesAlbert ARIBAUD
Some targets will build fine but not boot if sections .hash and .got.plt are not present in the binary. Add them back. Also, Exynos machines require .machine_param section in SPL. Add it. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
2014-01-13Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-01-13ARM: pxa: Fix OneNAND SPL buildsMarek Vasut
The OneNAND SPL used on PXA is slightly obscure. Due to the OneNAND limitation, where we have only the first 1KiB of the OneNAND available upon power-up as a memory-mapped area, from which the CPU starts executing, we place only the most essential code into this first 1KiB . This code copies the rest of the SPL into SRAM and jumps to it. This code is stored in section .text.0 . The rest of the SPL is stored in section .text.1 . When running the OBJCOPY on the SPL, it will preserve only .text section, but the .text.0 and .text.1 are stripped away from the result, thus making the SPL binary empty. The patch adds additional -j parameters to the OBJCOPY for PXA during the SPL build, which will preserve the .text.0 and .text.1 sections. Moreover, this patch also adds missing functions into the .text.0 section, since otherwise the PXA270 with 1KiB-window OneNAND won't be able to boot. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com>
2014-01-13usb: ehci: exynos: set/reset hsic physInderpal Singh
The controller has 3 ports. The port0 is for USB 2.0 Phy, port1 and port2 are for HSIC phys. The usb 2.0 phy is already being setup. This patch sets up the hsic phys. Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org>
2014-01-13imx6: make use of lldiv(..)Christian Gmeiner
Commit 762a88ccf8540948fbf8c31b40a29d1e0684a25b introduces a 64-bit division without using the lldiv() function, which pulls in previously unused libgcc stuff. Signed-off-by: Måns Rullgård <mans@mansr.com> Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Bringing in the MMC tree means that CONFIG_BOUNCE_BUFFER needed to be added to include/configs/exynos5-dt.h now. Conflicts: include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2014-01-10gpio: zynq: Add dummy gpio routinesJagannadha Sutradharudu Teki
GPIO dummy routines are required for fdt build, may be removed these dependencies once the u-boot fdt is fully optimized. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10dts: zynq: Add basic fdt supportJagannadha Sutradharudu Teki
This patch provides a basic fdt support for zynq u-boot. zynq-7000.dtsi-> initial arch dts file zynq-zed.dts -> initial zed board dts file more devices should be added in subsequent patches. u-boot build: once configuring of a board done for building dtb with zynq-zed.dts as an input zynq-uboot> make DEVICE_TREE=zynq-zed Enabled CONFIG_OF_SEPARATE for building dtb separately. There is a new binary called u-boot-dtb.bin which is a u-boot with devicetree supported. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10zynq: Add support to find bootmodeJagannadha Sutradharudu Teki
Added support to find the bootmodes by reading slcr bootmode register. this can be helpful to autoboot the configurations w.r.t a specified bootmode. Added this functionality on board_late_init as it's not needed for normal initializtion part. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-10armv8: Use __aarch64__ rather than CONFIG_ARM64 in some casesTom Rini
The toolchain sets __aarch64__ for both LE and BE. In the case of posix_types.h we cannot reliably use config.h as that will lead to problems. In the case of byteorder.h it's clearer to check the EB flag being set in either case instead. Cc: David Feng <fenghua@phytium.com.cn> Signed-off-by: Tom Rini <trini@ti.com> Amended by Albert ARIBAUD <albert.u.boot@aribaud.net> to actually remove the config.h include from the posix_types.h files, with permission from Tom Rini.
2014-01-09Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2014-01-09Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2014-01-09arm64: core supportDavid Feng
Relocation code based on a patch by Scott Wood, which is: Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: David Feng <fenghua@phytium.com.cn>
2014-01-09socfpga/dwmmc: Adding DesignWare MMC driver support for SOCFPGAChin Liang See
To add the DesignWare MMC driver support for Altera SOCFPGA. It required information such as clocks and bus width from platform specific files (SOCFPGA handoff files) Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Rajeshwari Shinde <rajeshwari.s@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-01-09sh: sh2: Remove CONFIG_SH2A definition from asm/processor.hNobuhiro Iwamatsu
SH2 and SH2A use a common header. Both checks are not necessary. This removes CONFIG_SH2A definition from asm/processor.h. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-09sh: sh4: Remove CONFIG_SH4A definition from source codeNobuhiro Iwamatsu
SH4 and SH4A are compatible. But some instructions are different from these. In Linux kernel, It is treated as a separate CPU, but for now, I think that there is no need to divide especially in the U-Boot. This removes CONFIG_SH4A definition from source code, SH4A is treated as SH4. And this fix white space. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2014-01-08sandbox: Add a prototype for cleanup_before_linux()Simon Glass
This function is defined but has no prototype declaration. Add it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Add facility to save/restore sandbox stateSimon Glass
It is often useful to be able to save out the state from a sandbox test run, for analysis or to restore it later to continue a test. Add generic infrastructure for doing this using a device tree binary file. This is a flexible tagged file format which is already supported by U-Boot, and it supports hierarchy if needed. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
2014-01-08sandbox: Allow reading/writing of RAM bufferSimon Glass
It is useful to be able to save and restore the RAM contents of sandbox U-Boot either for setting up tests, for later analysys, or for chaining together multiple tests which need to keep the same memory contents. Add a function to provide a memory file for U-Boot. This is read on start-up and written when shutting down. If the file does not exist on start-up, it will be created when shutting down. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Add -i option to enter interactive modeSimon Glass
Normally when U-Boot starts with a command (-c option) it quits when the command completes. Normally this is what is requires, since the test is likely complete. Provide an option to jump into the console instead, so that debugging or other tasks may be performed before quitting. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Allow the console to work earlierSimon Glass
With sandbox, errors and problems may be reported before console_init_f() is executed. For example, an argument may not parse correctly or U-Boot may panic(). At present this output is swallowed so there is no indication what is going wrong. Adjust the console to deal with a very early sandbox setup, by detecting that there is no global_data yet, and calling os functions in that case. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Implement the bootm command for sandboxSimon Glass
When sandbox does a 'bootm' to run a kernel we cannot actually execute it. So just exit sandbox, which is essentially what U-Boot does on other archs. Also, allow sandbox to use bootm on any kernel, so that it can be used to test booting of kernels from any architecture. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Allow return from board_init_f()Simon Glass
The execution flow becomes easier if we can return from board_init_f() as ARM does. We can control things from start.c instead of having to call back into that file from other places. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Correct help message <arg> garblingSimon Glass
The <arg> is displayed for options with no argument, and omitted for those with an argument. Swap this around. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-01-08sandbox: Improve/augment memory allocation functionsSimon Glass
Implement realloc() and free() for sandbox, by adding a header to each block which contains the block size. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Hung-ying Tyan <tyanh@chromium.org>
2014-01-08sh: sh2: Change CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQNobuhiro Iwamatsu
CONFIG_SYS_HZ of SH2 is not used as frequency of base timer. This is the correct clock of CMT. This changes from CONFIG_SYS_HZ to CONFIG_SH_CMT_CLK_FREQ, in order to use CONFIG_SYS_HZ as clock of CMT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-01-08sh: sh4: Add CONFIG_SH4 definition to config.mk of SH4Nobuhiro Iwamatsu
2014-01-08sh: sh3: Add CONFIG_SH3 definition to config.mk of SH3Nobuhiro Iwamatsu
2014-01-08sh: sh2: Add CONFIG_SH2 definition to config.mk of SH2Nobuhiro Iwamatsu
2014-01-06Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-01-06Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: include/micrel.h The conflict above was trivial, caused by four lines being added in both branches with different whitepace.
2014-01-03arm: mx5: Add fuse supply enable in fsl_iimSergey Alyoshin
Enable fuse supply before fuse programming and disable after. Signed-off-by: Sergey Alyoshin <alyoshin.s@gmail.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2014-01-03ARM: mx6: Allow enablement of FEC Anatop based clock for all MX6Otavio Salvador
The enable_fec_anatop_clock method should be available for all MX6 variant as it is not MX6 SoloLite specific. This moves the code out of the #ifdef/#endif and we make it conditional to CONFIG_FEC_MXC instead. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2014-01-03imx: Easy enabling of SION per-pin using MUX_MODE_SION helper macroOtavio Salvador
The macro allows easy setting in per-pin, as for example: ,---- | imx_iomux_v3_setup_pad(MX6_PAD_NANDF_D1__GPIO_2_1 | MUX_MODE_SION); `---- The IOMUX_CONFIG_SION allows for reading PAD value from PSR register. The following quote from the datasheet: ,---- | ... | 28.4.2.2 GPIO Write Mode | The programming sequence for driving output signals should be as follows: | 1. Configure IOMUX to select GPIO mode (Via IOMUXC), also enable SION if need | to read loopback pad value through PSR | 2. Configure GPIO direction register to output (GPIO_GDIR[GDIR] set to 1b). | 3. Write value to data register (GPIO_DR). | ... `---- This fixes the gpio_get_value to properly work when a GPIO is set for output and has no conflicts. Thanks for Benoît Thébaudeau <benoit.thebaudeau@advansee.com>, Fabio Estevam <fabio.estevam@freescale.com> and Eric Bénard <eric@eukrea.com> for helping to properly trace this down. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
