Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL
framework, enable on all of the previously using boards. We move the
spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave
the NAND one in-place as we plan to replace it later in this series.
We use common/spl to avoid linker problems with respect to merging
constant strings in objects. Otherwise all strings in common/ will be
linked in and kept which grows SPL in size too much.
This is an OMAP/related-specific function, move calling it to
spl_board_init() and turn on CONFIG_SPL_BOARD_INIT on the boards that
enabled NAND and didn't enable this already.
- Remove includes we don't need
- Switch some printf statements to puts
- Convert some printf statements to debug, introduce new puts statements
- In most cases saying just "No mkimage signature, assuming
u-boot.bin" or similar is sufficient. This also means the non-DEBUG
case doesn't need printf, in the core of SPL.
- The other case here is that PLAIN_VERSION provided what we wanted
already, so just use it.
Move the default omap/related-centric board_mmc_init to
arch/arm/cpu/armv7/omap-common/boot-common.c and move the type defines
to <asm/spl.h>. Also use mmc->read_bl_len rather than MMCSD_SECTOR_SIZE
Move the SPL prototypes from <asm/omap_common.h> into <asm/spl.h> and
add <asm/arch/spl.h> for arch specific portions of CONFIG_SPL_FRAMEWORK.
We can only attempt to setup a malloc pool if
CONFIG_SYS_SPL_MALLOC_START is defined, and not all boards require it.
Make the call depend on the define.
This detection code doesn't (and can't) do anything currently, so
remove.
Signed-off-by: Pavel Machek <pavel@denx.de>
Only omap4/5 currently have a meaningful set of display text and overo
had been adding a function to display nothing. Change how this works to
be opt-in and only turned on for omap4/5 now.
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations
in various board.c files to get rid of one checkpatch.pl warning.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
Commit 86c6326 "ARM: arm1176: enable instruction cache in
arch_cpu_init()" defined arch_cpu_init() in a file that is shared across
all arm1176 SoCs. tnetv107x already implemented this function, which
caused linking to break. Move the new conflicting arch_cpu_init() into
arm1176/bcm2835/init.c so that it doesn't conflict; grep indicates this
function is usually defined at the SoC-level, not the CPU-level, at least
for ARM.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG
information.
If this data is not present, the kernel misconfigures the TZIC, which results in
the timer interrupt handler never being called, so the kernel deadlocks while
calibrating its delay.
Suggested-by: Greg Topmiller <Greg.Topmiller@jdsu.com>
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Fabio Estevam <festevam@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with
the 5235 processor. The registers in struct fbcs are different sizes from
those in the 5235. Also, the defines are a little different.
This is what I have so far. Comments?
Reformat the patch manually by Jason Jin
Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
This patch adds a driver for Freescale Colfire Queued SPI bus.
Coded to work with 8 bits per transfer to use with SPI flash.
CPOL, CPHA, and CS_ACTIVE_HIGH can be configured.
Tested with MCF5270 which have 4 chip selects.
Activate by #define CONFIG_CF_QSPI in board config.
Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
Signed-off-by: Alison Wang <b18965@freescale.com>
This patch uses the general ffs definition to replace the
platform ffs definition.
This patch also fixes the build error by adding hweightN
definition for m5329evb and m5373evb.
This board is the only board that still sticks to OneNAND IPL.
Remove this board, since we have SPL around for a while and
OneNAND is well supported in the SPL framework. The board can
be revived if necessary.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Tom Rini <trini@ti.com>
Cc: u-boot-dm@lists.denx.de
Constants set with binary value (0b...) are not compiled
from old toolchain when used by the clrsetbits_le32 macro.
Replaces them with the corresponding hex value.
The error reported (for example with the mx6qsabrelite board)
is something like:
mx6qsabrelite.c:369:1: error: invalid suffix "b101" on integer constant
mx6qsabrelite.c:369:1: error: invalid suffix "b10010" on integer constant
mx6qsabrelite.c:369:1: error: invalid suffix "b0000" on integer constant
mx6qsabrelite.c:369:1: error: invalid suffix "b10001" on integer constant
Prepare for device-tree driven configuration.
Acked-by: Stephan Linz <linz@li-pro.net>
Move board specific function to board_init function in board/ folder
Remove externs from generic board.c
Use board_init_f function in board.c file.
Fix CONFIG_SYS_HZ usage in board config.
Do not use hardcoded value. Use CONFIG_SYS_HZ instead.
Separate static configuration to single block.
Just coding style cleanup.
Remove unneeded externs.
Return value to find out if un/registration was succesful.
Variable is used when CONFIG_SYS_FLASH_CHECKSUM is used.
Warning log:
board.c: In function 'board_init':
board.c:101: warning: unused variable 's'
This is minimum code required to be able to use device-tree
for u-boot initialization.
Currently only for device driver initialization.
Linker script change ensures DTB to be aligned
for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE.
CC: Simon Glass <sjg@chromium.org>
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate.
Convert tegra20_ source file and function names to tegra_, also.
Upcoming Tegra30 port will use common code/defines/names where possible.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This allows for two things:
- VBus GPIO may be used on other ports than the OTG one
- VBus GPIO may be low active if specified by DT
Signed-off-by: Lucas Stach <dev@lynxeye.de>
CC: Stephen Warren <swarren@wwwdotorg.org>
CC: Tom Warren <TWarren@nvidia.com>
Up now only MX5 and MX6 can share code, because they have
a common source directory in cpu/armv7. Other not armv7
i.MX can profit of the same shared code. Move these files
into a directory accessible for all, similar to plat-mxc
in linux.
A device tree is used to configure the NAND, including memory
timings and block/pages sizes.
If this node is not present or is disabled, then NAND will not
be initialized.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Add a NAND controller along with a bindings file for review.
