Implement support for CONFIG_SERIAL_MULTI into leon3 serial driver.
This driver was so far only usable directly, but this patch also adds
support for the multi method. This allows using more than one serial
driver alongside the leon3 driver. Also, add a weak implementation
of default_serial_console() returning this driver.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Tom Rini <trini@ti.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Implement support for CONFIG_SERIAL_MULTI into leon2 serial driver.
driver alongside the leon2 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into iop480 serial driver.
driver alongside the iop480 driver. Also, add a weak implementation
Cc: Stefan Roese <sr@denx.de>
Implement support for CONFIG_SERIAL_MULTI into mpc85xx serial driver.
driver alongside the mpc85xx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into both SCC and SMC mpc8260
serial drivers. These drivers were so far only usable directly, but this
patch also adds support for the multi method. This allows using more than
one serial driver alongside the mpc8260 drivers. Also, add a weak
implementation of default_serial_console() returning this driver.
Implement support for CONFIG_SERIAL_MULTI into mpc8220 serial driver.
driver alongside the mpc8220 driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into mpc5xx serial driver.
driver alongside the mpc5xx driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into JZ serial driver.
driver alongside the JZ driver. Also, add a weak implementation
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Implement support for CONFIG_SERIAL_MULTI into asc serial driver.
driver alongside the asc driver. Also, add a weak implementation
Implement support for CONFIG_SERIAL_MULTI into au1x00 serial driver.
driver alongside the au1x00 driver. Also, add a weak implementation
Rework the emulation of serial console via JTAG from simple ad-hoc
implementation of serial port routines to CONFIG_SERIAL_MULTI and
enable CONFIG_SERIAL_MULTI unconditionally for blackfin.
In order for the JTAG serial console to take precedence over all
other serial ports available in system, implement override for
default_serial_console call returning this JTAG serial console.
This brings in a bit of a growth of size, but eventually will allow
us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole
U-Boot and maintain only one serial subsystem.
Cc: Mike Frysinger <vapier@gentoo.org>
Rename the serial_register_bfin_uart() to bfin_initialize_serial()
to be consistent with the rest of the naming. Next, remove it's
prototype from serial.h and properly insert it into serial.c as
the rest of the serial initialization functions.
Move the registration of serialN_device ports from default
serial_initialize() into driver specific function called from
serial_initialize(). This slims down the serial_initialize() call
to a bare tracker of all possible serial port registration routines
in U-Boot.
The newly implemented mpc512x_serial_initialize() function, which is
implemented inside of the mpc512x serial driver allows encapsulation
of serialN_device within the mpc512x serial driver itself.
Also, remove the exports of serialN_device from include/serial.h
as they are no longer needed. This is simply because the implementation of
default_serial_console() is wrapped into the mpx512x serial driver and
the default console is picked by CONFIG_SERIAL<N> macro in config file.
Move the registration of serial_smc and serial_scc ports from
default serial_initialize() into CPU specific function called from
in U-Boot.
The exports of both serial_scc_device and serial_smc_device can
not yet be removed as they are still used in default_serial_console()
calls.
Properly spell out the whole structure member names when an initialized
varible is instantiated from the struct serial_driver. In case the
structure definition for struct serial_driver undergoes reordering,
there will be no impact on variables defined based on this structure.
Cc: C Nauman <cnauman@diagraph.com>
Rename .init() to .start() and .uninit() to .stop() in struct
serial_device. This allows aligning struct serial_device with
closer to struct stdio_dev. The real goal here is to allow
these two structures to converge together and eventually make
one to be a superset of the other.
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Under option -munaligned-access, gcc can perform local char
or 16-bit array initializations using misaligned native
accesses which will throw a data abort exception. Fix files
where these array initializations were unneeded, and for
files known to contain such initializations, enforce gcc
option -mno-unaligned-access.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Switch to usign call cc-option for -mno-unaligned-access as
Albert had done previously as that's really correct]
The restore sequence in lowlevel_init was in the wrong order,
causing lr to lose its original value and be set equal to ip
instead. Also, its use of the stack clashes with that of
s_init, so move the s_init call after the restore and turn
it into a tail-optimized branch.
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
lowlevel_init() of rmobile badly assumed that ip register holds return address.
The commit "63ee53a7 armv7 cpu_init_crit: Simplify code" breaks this assumption.
This patch removes this bad assumption and simplify code.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
This patch aims at ensuring that the 2012.10 release works
out-of-the-box on as many targets as possible, by reinstating
commit 5347560f5427bcdd48a563b62180481606ac8044, which adds
option -mno-unaligned-access to armv7 builds.
This patch will be overriden immediately after release of 2012.10.
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Signed-off-by: Chin Liang See <clsee@altera.com>
Signed-off-by: Pavel Machek <pavel@denx.de>
Acked-by: Tom Trini <trini@ti.com>
Cc: Wolfgang Denx <wd@denx.de>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
v8: Remove no_return attribute for reset_cpu
Based on v2012.10-rc2
Add timer driver.
CC: Joe Hershberger <joe.hershberger@gmail.com>
CC: Marek Vasut <marex@denx.de>
When the u-boot address of destination equal to __start,
no relocation. relocation offset(r9) = 0.
Signed-off-by: Zhong Hongbo <bocui107@gmail.com>
Tested-by: Stefano Babic <sbabic@denx.de>
ARM boards need to change device tree settings as well
These options are just duplicated from arch/arm/cpu/armv7/config.mk
We don't need to return to cpu_init_crit after calling lowlevel_init, so
lowlevel_init can directly return to the caller of cpu_init_crit.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Disable sibling call optimization based on binutils version. This is
to work around a bug in the assember in binutils versions < 2.22.
Branches to weak symbols can be incorrectly optimized in thumb mode to
a short branch (b.n instruction) that won't reach when the symbol gets
preempted.
http://sourceware.org/bugzilla/show_bug.cgi?id=12532
Signed-off-by: Allen Martin <amartin@nvidia.com>
Acked-by: Tom Rini <trini@ti.com>
The bootm initrd image copy to ram can collide with the stack in cases
where the print buffer size is large (i.e. 1K). The result is intermittent
initrd decompression errors depending on the initrd size MOD 4KB since
the initrd start address is 4KB aligned.
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
include/common.h has the reset_cpu defined already. No need to
re-define here.
Acked-By: Prafulla Wadaskar <Prafulla@marvell.com>
Size of the SDRAM chips might differ between any two (otherwise
identical) instances of the same board.
So add a function kw_sdram_size_adjust() which reads out the current
ram size for a given bank, and adjusts the Kirkwood's SDRAM window size
register accordingly.
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Some boards might be equipped with different SDRAM configurations.
When that is the case, CPU CS Window Size Register (CS[0]n Size)
should be set to the biggest value through board.cfg file; then its
value can be fixed at runtime according to the detected SDRAM size.
Therefore, implement kw_sdram_bs_set().
cc: Marek Vasut <marex@denx.de>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Remove the defines and do this with a C-struct.
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
It's now possible to use the gpio driver interface
for s3c2440. This patch add iomux definitions too.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
Rmobile common timer driver diverts the same driver as SH architecture.
When it builds at the same place with source, it is no problem, but when
it builds out of source, it cannot build.
This patch revises this problem.
Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This supports ethernet driver of RMOBILE R8A7740.
The Armadillo-800EVA board has Renesas R-Mobile R8A7740, 512MB DDR3-SDRAM,
Ethernet, and more.
This patch supports the following functions:
- 512MB DDR3-SDRAM
- Serial console (SCIF)
- Ethernet MAC(MII) & PHY(SMSC)
Signed-off-by: Hideyuki Sano <hideyuki.sano.dn@renesas.com>
Renesas R8A7740 has GPIO based PFC. This privode framework of PFC.
The code included in this base from linux kernel.
Renesas R8A7740 is CPU with Cortex-A9.
This supports the basic register definition and GPIO.
Some rmobile SoC has TMU base timer function. This supports TMU.
There is rmobile without ICCICR.
ICCICR is initialized only when ICCICR is defined.
According to SoC document, revision info is separated to integer part and
fracton part.
So I separete rmobile_get_cpu_rev() to rmobile_get_cpu_rev_integer() and
rmobile_get_cpu_rev_fraction().
CPU info register was read wrongly by mistake. And function rmobile_get_cpu_rev() was not called properly.
Add dummy member to struct sh73a0_rwdt in sh73a0.h.
Without this, initializing watch dog timer goes wrong.
Latest rmobile code was tested by using old gcc (gcc-4.4).
When we use gcc-4.6 (or later), the build is made, but does not work.
This solves a problem not to work by add -march=armv5 to compiple option
when we built in gcc-4.6 (or later).
I tested by linaro's compiler version 2012.04-20120426.
Do soft power on reset in U-Boot reset command.
