Define base addresse for both MPH(USB1) and DR(USB2) controllers
for MPC834x socs
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
T1040 Soc has four personalities:
-T1040 (4 cores with L2 switch)
-T1042:Reduced personality of T1040 without L2 switch
-T1020:Reduced personality of T1040 with less cores(2 cores)
-T1022:Reduced personality of T1040 with 2 cores and without L2 switch
Update defines in arch/powerpc header files, Makefiles and in
driver/net/fm/Makefile to support all T1040 personalities
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
[York Sun: fixed Makefiles]
Acked-by: York Sun <yorksun@freescale.com>
Add DSS_ONOFF to polarity defines
Cc: Tom Rini <trini@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Acked-by: Anatolij Gustschin <agust@denx.de>
Add the missing "right" field to struct bcm2835_mbox_tag_overscan.
Signed-off-by: Andre Heider <a.heider@gmail.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The MPC824x processors have long reached EOL, and the PN62 board has
not seen any board-specific updates for more than a decade. It is now
causing build issues. Instead of wasting time on things nobody is
interested in any more, we rather drop this board.
Cc: Wolfgang Grandegger <wg@grandegger.com>
cc: Tom Rini <trini@ti.com>
This patch replaces the GPL-2.0 text with a GPL-2.0
SPDX-License-Identifier tag, and adds Imagination Technologies copyright
following my recent changes.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
board/compulab/cm_t35/Makefile
board/corscience/tricorder/Makefile
board/ppcag/bg0900/Makefile
drivers/bootcount/Makefile
include/configs/omap4_common.h
include/configs/pdnb3.h
Makefile conflicts are due to additions/removals of
object files on the ARM branch vs KBuild introduction
on the main branch. Resolution consists in adjusting
the list of object files in the main branch version.
This also applies to two files which are not listed
as conflicting but had to be modified:
board/compulab/common/Makefile
board/udoo/Makefile
include/configs/omap4_common.h conflicts are due to
the OMAP4 conversion to ti_armv7_common.h on the ARM
side, and CONFIG_SYS_HZ removal on the main side.
Resolution is to convert as this icludes removal of
CONFIG_SYS_HZ.
include/configs/pdnb3.h is due to a removal on ARM side.
Trivial resolution is to remove the file.
Note: 'git show' will also list two files just because
they are new:
include/configs/am335x_igep0033.h
include/configs/omap3_igep00x0.h
Without setting up the PIRQ[A:D] interrupt routes, PCI interrupts will
be left disabled. Linux does not set up this routing but relies upon it
having been set up by the bootloader, reading back the IRQ lines which
the PIRQ[A:D] signals have been routed to.
This patch routes PIRQA & PIRQB to IRQ 10, and PIRQC & PIRQD to IRQ 11.
This matches the setup used by YAMON.
Displaying a message on the LCD screen is a simple yet effective way to
show the user that the board has booted successfully.
This patch adds support for running on Malta boards using coreFPGA6
core cards, including support for the msc01 system controller used
with them. The system controller is detected at runtime allowing one
U-boot binary to run on a Malta with either.
Due to the PCI I/O base differing between Maltas using gt64120 & msc01
system controllers, the UART setup is modified slightly. A second UART
is added so that there is one pointing at the correct address for each
system controller. The Malta board then defines its own
default_serial_console function to select the correct one at runtime.
The incorrect UART will simply not function.
Tested on:
- A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both
with and without an L2 cache.
- QEMU.
This is in preparation for adapting this board to function correctly on
a physical MIPS Malta board. The board is moved into an "imgtec" vendor
directory at the same time in order to ready us for any other boards
supported by Imagination in the future.
For boards such as the MIPS Malta with an FPGA core card it is desirable
to be able to detect the L1 cache sizes at runtime, since they are not
dependant upon the board but on the FPGA bitstream in use. This patch
performs that detection when the CONFIG_SYS_[DI]CACHE_SIZE macros are
not defined by the board configuration. In cases where the sizes are
detected this patch also removes the restriction that the I-cache &
D-cache line sizes must be the same, as this is not necessarily true.
If the cache sizes are defined by a configuration then they will be
hardcoded as before, so this patch will not add overhead to such
boards.
Linux Kernel abolished include/linux/config.h long time ago.
(around version v2.6.18..v2.6.19)
We don't need to provide Linux copatibility any more.
This commit deletes include/linux/config.h
and fixes source files not to include this.
arch/sparc/cpu/leon3/start.S requires CONFIG_SYS_SPARC_NWINDOES
to be defined:
#ifndef CONFIG_SYS_SPARC_NWINDOWS
#error Must define number of SPARC register windows, default is 8
#endif
But it missed to include <config.h>, which always ended up in compile error.
This commit fixes this problem.
Cc: Daniel Hellstrom <daniel@gaisler.com>
Signed-off-by: Roger Meier <r.meier@siemens.com>
Acked-by: Bo Shen <voice.shen@atmel.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Add usb host support for at91sam9n12ek board.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Convert versatile to use the commmon timer code.
Convert tegra to use the commmon timer code.
Convert socfpga to use the commmon timer code.
Convert mx25 to use the commmon timer code.
Convert highbank to use the commmon timer code.
Convert sh to use the commmon timer code. Remove reset_timer and
set_timer as they are unused on sh.
Remove platform CONFIG_SYS_HZ definition for configs a-z*.
Easy to resolve conflict on the GPIO change.
arch/blackfin/cpu/Makefile
folder.
The gpio register mappings are different among blackfin processors.
Signed-off-by: Steven Miao <realmz6@gmail.com>
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
This commit fixes:
cpu.c:107: warning: ‘noreturn’ function does return
The change from 0x64656465 to 0x64646464 is to remove the weak pull
enabled on DQS, nDQS lines. This pulls the differential signals in the
same direction which is not intended. So disabling the weak pulls improves
signal integrity.
On the uEVM there are 4 DDR3 devices. The VREF for 2 of the devices is powered by
the OMAP's VREF_CA_OUT pins. The VREF on the other 2 devices is powered by the OMAP's
VREF_DQ_OUT pins. So the net effect here is that only half of the DDR3 devices were being
supplied a VREF! This was clearly a mistake. The second change improves the robustness of
the interface and was specifically seen to cure corruption observed at high temperatures
on some boards.
With the above two changes better memory stability was observed with extended
temperature ranges around 100C.
Signed-off-by: Sricharan R <r.sricharan@ti.com>
UART booting is supported on this SoC, but via UART3 rather than UART1.
Because of this we must change the board to use UART3 for all console
access (only one UART is exposed on this board and a slight HW mod is
required to switch UARTs).
Signed-off-by: Minal Shah <minal.shah@ti.com>
[trini: Make apply to mainline, reword commit]
There is a board-specific portion for calling watchdog enable itself, in
main U-Boot.
Create a common header file for the RTC IP block that is shared between
davinci and am33xx.
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Macpaul Lin <macpaul@gmail.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Before this commit, arch/sparc/lib/Makefile used
both COBJS and COBJS-y.
And it missed to add COBJS-y into OBJS.
This means bootm.o was never compiled even if
CONFIG_CMD_BOOTM=y
This patch moves S5PC, EXYNOS specific directory entries
from the toplevel Makefile to arch/arm/cpu/armv7/Makefile
using Kbuild descending feature.
This patch moves OMAP specific directory entries
from the toplevel Makefile and spl/Makefile
to arch/arm/cpu/armv7/Makefile using Kbuild descending feature.
This patch moves Tegra specific directory entries
to arch/arm/cpu/*/Makefile using Kbuild descending feature.
Cc: Tom Warren <TWarren@nvidia.com>
