The kernel gets the ethernet MAC from the ethaddr variable, the omap boards for
devices with USB based eth adapters just set the usbethaddr which doesn't appear
to get passed to the kernel. The same Raspberry Pi code sets both ethaddr and
usbethaddr so lets do that so linux (tested 4.13 and 4.14) get a static rather
than a random MAC address, while not regressing users of usbethaddr.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
The DCLK_VOP_DIV_CON_MASK should cover only bits 8 through 15.
Fix this to remove an "integer-overflow on shifted constant" warning.
Fixes: 9246d9e ("rockchip: rk3128: add clock driver")
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
The PLL selector field for NANDC is only 2 bits wide.
This fixes an 'int-overflow on shift' warning.
On the RK3399-Q7, we want to trigger a full platform reset (so the
various software stacks supported don't have to deal with the same
complexities over and over again) in case that anything other than a
power-on reset occurred.
To do so, this defines the /config/sysreset-gpio property and has it
point to a GPIO that will perform a power-on reset of the entire
platform.
Tested-by: Klaus Goger <klaus.goger@theobroma-systems.com>
USB1 is connected to the on-module USB 3.0 hub and power to the hub
(actually it's a reset signal, modeled as a fixed regulator, that will
be released) should be enabled only during the first probing of the
device to avoid the hub from entering its low-power mode (where it
tries to attach on a fixed interval, but we always miss the timeslot
when U-Boot has the controller listening).
This adds a 'tsd,usb-port-power' stringlist to enable the
infrastructure in the board-specific usb_hub_reset_devices to find and
control the fixed regulator associated with control of the USB hub.
Tested-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
According to rk3036 TRM, should be set to '1' for the pll
integer mode, while the '0' means the frac mode.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
After the MASK MACRO update, we need to update the driver at the same time.
This is a fix to:
37943aa rockchip: rk3036: clean mask definition for cru reg
There is a fixed div-2 between PLL and clk_ddr/clk_ddrphy,
so we need to double to pll output and then ddr can work
in correct frequency.
evb-rk3128 is an evb from Rockchip based on rk3128 SoC:
- 2 USB2.0 Host port;
- 1 HDMI port;
- 2 10/100M eth port;
- 2GB ddr;
- 16GB eMMC;
- UART to USB debug port;
Add rk3128 pinctrl driver and grf/iomux structure definition.
Add rk3128 clock driver and cru structure definition.
RK3128 is a SoC from Rockchip with quad-core Cortex-A7 CPU
and mali400 GPU. Support Nand flash, eMMC, SD card, USB 2.0 host
and device, HDMI/LVDS/MIPI display.
Add dts binding header for rk3128, files origin from kernel.
Series-Changes: 2
- fix i2c address
- add saradc and usb phy node
- emmc using fifo mode for there is no dma support in rk3128 emmc
- add some clock id in cru.h
Rework the ULCB CPLD driver and make it into a sysreset driver,
since that is what the ULCB CPLD driver is mostly for.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Check if we are booting from NAND and let the bootrom
continue to load the rest of the bootloader
Signed-off-by: Sean Nyekjaer <sean.nyekjaer@prevas.dk>
It's the first 8 bits of the bootrom error register that
contain the boot error/fallback error code. Let's check that
and continue to boot from UART.
This patch removes the inclusion of the libgcc math functions and
replaces them by functions coded in C, taken from the coreboot
project. This makes U-Boot building more independent from the toolchain
installed / available on the build system.
The code taken from coreboot is authored from Vadim Bendebury
<vbendeb@chromium.org> on 2014-11-28 and committed with commit
ID e63990ef [libpayload: provide basic 64bit division implementation]
(coreboot git repository located here [1]).
I modified the code so that its checkpatch clean without any
functional changes.
[1] git://github.com/coreboot/coreboot.git
Cc: Bin Meng <bmeng.cn@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
This reverts commit 13c531e52a09b4e6ffa8b5a1457199b0a574cb27.
The error message with FIT style image mentioned in the above commit
only happens when booting using FIT image containing bzImage kernel
and without setup node (setup.bin). The current documentation for
x86 FIT support in doc/uImage.FIT/x86-fit-boot.txt mentions that
kernel's setup.bin file is required for building x86 FIT images.
The above commit breaks FIT images generated as described in the
documentation. Revert it to allow booting with images built in the
documented way.
Acked-by: Bin Meng <bmeng.cn@gmail.com>
x86_vendor_name is defined as
static const char *const x86_vendor_name[]
So its elements should not be compared to 0.
Remove superfluous paranthesis.
Problem identified with Coccinelle.
ROM has been made read-only in qemu recently (namely commit 208fa0e4:
"pc: make 'pc.rom' readonly when machine has PCI enabled"). So this
patch restores compatibility between U-Boot and qemu.
Signed-off-by: Anton Gerasimov <anton@advancedtelematic.com>
[bmeng: mention qemu commit title in the commit message]
This board is based on the Atmel sama5d3 eval boards.
Supporting the following features:
- Boot from NAND Flash
- Ethernet
- FIT
- SPL
Signed-off-by: Ben Whitten <ben.whitten@lairdtech.com>
Signed-off-by: Dan Kephart <dan.kephart@lairdtech.com>
This board is based on the Atmel 9x5 eval board.
- Ethernet
- FIT
- SPL
In U-Boot, this device tree is compatible with both the Torpedo and
SOM-LV kits. Let's rename it in the device tree since the U-Boot code and
show a more generic OMAP3 name. The code auto detects between the two and
loads the proper DTB file for Linux. This would eliminate the SOM-LV showing
the name Torpedo during boot and hopefully eliminate some confusion.
Add the SAMA5D2 PTC EK board and remove the SAMA5D2 PTC ENGI board
which was a prototype.
Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
Add a header for SAMA5D2 SMC since it's not compatible with
SAMA5D3 one.
[wenyou: fix the wrong base address of the SMC register]
MPU's region setup can be factorized between STM32F4/F7/H7 SoCs family
and used a common MPU's region config.
Only one exception for STM32H7 which doesn't have device area
located at 0xA000 0000.
For STM32F4, configure_clocks() need to be moved from arch_cpu_init()
to board_early_init_f().
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Vikas Manocha <vikas.manocha@st.com>
In order to factorize code between STM32F4 and STM32F7
migrate all structs related to RCC clocks in include/stm32_rcc.h
MMC block needs 48Mhz source clock, for that we choose
to select the SAI PLL.
Update also stm32_clock_get_rate() to retrieve the MMC
clock source needed in MMC driver.
STM32F4 uses a different RCC variant than STM32F7. For STM32F4
sdmmc clocks bit are located into dckcfgr register whereas there
are located into dckcfgr2 registers on STM32F7.
In both registers, bits CK48MSEL and SDMMC1SEL are located at
the same position.
Signed-off-by: Christophe Priouzeau <christophe.priouzeau@st.com>
STM32F4 doesn't get rcc.h file, to avoid compilation
issue, migrate RCC related defines from rcc.h to driver
file and remove rcc.h file.
Align the RCC compatible string with the one used by kernel.
It will allow to use the same clock driver for STM32F4
and STM32F7 and to manage the differences between the 2 SoCs
PWR IP is used to enable over-drive feature in
order to reach a higher frequency.
Get its base address from DT instead of hard-coded value
This node is needed to enable performance mode
when system frequency is set up to 200Mhz.
Add dts to support ftsdc010 dm flow on AG101P/AE3XX platform.
Signed-off-by: Rick Chen <rick@andestech.com>
Stop using the old ad-hoc SH I2C driver and use the new RCar IIC
driver instead. The SH I2C driver should be deprecated and removed
eventually.
Mark the PRR as u-boot,dm-pre-reloc in all Gen3 board DTs as it is
needed very early and turn on the CONFIG_SYSCON to allow the PRR
driver to bind as a syscon uclass.
Implement DM driver for the Renesas PRR into RCar cpu info and convert
all users with DM and OF enabled to this new driver. This means all of
the boards with DM and OF enabled can fetch PRR address from DT, which
is useful on ie. V3M which has different PRR address than the rest of
Gen3 SoCs.
The checkboard() function showing hard-coded board model for which the
U-Boot was built is superseded on Gen3 by show_board_info() displaying
the Model from device tree. Add small ifdef to stop compiling the
function into U-Boot.
Since both R8A7795 and R8A7796 now use the same files, unify the
Makefile entry to CONFIG_RCAR_GEN3.
Unify the R7A7795 and R8A7796 memory maps in memmap-gen3 and, for now,
select which one is used based on which SoC is selected. Since this is
done in C code instead of statically assigned now, the decision can be
taken by PRR SoC match as well, which will be done in a subsequent patch.
Replace the ad-hoc values in the PRR CPU ID table with macros,
so that users can use rmobile_get_cpu_type() can compare the
returned value with these macros to figure out on which CPU they
are running.
These files no longer contain anything useful, so remove them.
These old PFC tables are no longer needed as there is now a proper
PFC pinmux driver in drivers/pinctrl/renesas . Remove them .
Since the RCar Gen3 no longer uses the SH SDHI driver, but rather
uses the Matsushita SD driver, which loads all the properties from
device tree, these macros are no longer used, remove them.
The eMMC is 1V8 device only and the signaling is always 1V8,
fix the DT for ULCB to describe the hardware correctly.
Xilinx changes for v2018.1
Zynq:
- Add support for Syzygy and cc108 boards
- Add support for mini u-boot configurations (cse)
- dts updates
- config/defconfig updates in connection to Kconfig changes
- Fix psu_init handling
ZynqMP:
- SPL fixes
- Remove slcr.c
- Fixing r5 startup sequence
- Add support for external pmufw
- Add support for new ZynqMP chips
- dts updates
- Add support for zcu102 rev1.0 board
Drivers:
- nand: Support external timing setting and board init
- ahci: Fix wording
- axi_emac: Wait for bit, non processor mode, readl/write conversion
- zynq_gem: Fix SGMII/PCS support
Use more accurate description for Xilinx Zynq and ZynqMP based platforms.
With using driver model there shouldn't be a need to create separate
Kconfig config options.
