path: root/arch
2015-01-30ARM: armv7 fix spelling of SCTRLPeng Fan
SCTLR is the abbreviation of System Control Register, so we should use SCTLR but not SCTRL. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-01-30vexpress64: support the Juno Development PlatformLinus Walleij
The Juno Development Platform is a physical Versatile Express device with some differences from the emulated semihosting models. The main difference is that the system is split in a SoC and an FPGA where the SoC hosts the serial ports at totally different adresses. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-30vexpress64: get rid of CONFIG_SYS_EXTRA_OPTIONSLinus Walleij
The Versatile Express ARMv8 semihosted FVP platform is still using the legacy CONFIG_SYS_EXTRA_OPTIONS method to configure some compile-time flags. Get rid of this and create a Kconfig entry for the FVP model, and a selectable bool for the semihosting library. The FVP subboard is now modeled as a target choice so we can eventually choose between different ARMv8 versatile express boards (FVP, base model, Juno...) this way. All dependent symbols are updated to reflect this. The 64bit Versatile Express board symbols are renamed VEXPRESS64 so we have some chance to see what is actually going on. Tested on the FVP fast model. Acked-by: Steve Rae <srae@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-01-26Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-01-26Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-01-26Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-01-26ARM: zynq: List qspi, smc and nand baseaddressesMichal Simek
Add missing addresses to the list. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-26ARM: zynq: List nand, qspi and jtag boot modesMichal Simek
Use full boot mode list in SPL. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-26ARM: zynq: slcr: Dont modify the reserved bitsSiva Durga Prasad Paladugu
Set only the 0-3 bits of the FPGA_RST_CTRL register as other bits should not be set to 1. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Reviewed-by: Peter Crosthwaite <peter.crosthwaite@xilinx.com> Reviewed-by: Nathan Rossi <nathan.rossi@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-26ARM: zynq: ddrc: Setup half of memory only for ECC caseMichal Simek
Setup half of memory from ram_size for ECC case. All the time the same board can be configured with or without ECC. Based on ECC case detection use half of memory with the same configuration. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-26ARM: zynq: Remove empty lineMichal Simek
Trivial patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-26ARM: zynq: Enable the Neon instructionsMichal Simek
Added the lowlevel_init to enable the Neon instructions. Initially the u-boot was causing undefined instruction exception if loaded through tcl, and working fine if loaded through FSBL. The exception was causing in convertion formula of given time to ticks. It was because, the Neon instructions were disabled and hence causing the undefined exception. In FSBL case, the FSBL was enabling the Neon instructions. Hence, added the lowlevel_init to enable the Neon instructions. Also enable neon instructions for non-xilinx toolchain. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Radhey Shyam Pandey <radheys@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-01-25Merge branch 'master' of git://git.denx.de/u-boot-marvellTom Rini
2015-01-25ARM: kirkwood: fix cpu info for 6282 device idLuka Perkov
Signed-off-by: Luka Perkov <luka@openwrt.org> Acked-By: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Stefan Roese <sr@denx.de>
2015-01-24fsl/ls1021qds: Add deep sleep supporttang yuantian
Add deep sleep support on Freescale LS1021QDS platform. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> [York Sun: Fix conflict in fdt.c] Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-24x86: ivybridge: Drop the Kconfig MRC cache informationSimon Glass
This is now stored in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-24x86: config: Enable hook for saving MRC configurationSimon Glass
Add a hook to ensure that this information is saved. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-24x86: Implement a cache for Memory Reference Code parametersSimon Glass
The memory reference code takes a very long time to 'train' its SDRAM interface, around half a second. To avoid this delay on every boot we can store the parameters from the last training sessions to speed up the next. Add an implementation of this, storing the training data in CMOS RAM and SPI flash. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-24x86: dts: Add SPI flash MRC details for chromebook_linkSimon Glass
Correct the SPI flash compatible string, add an alias and specify the position of the MRC cache, used to store SDRAM training settings for the Memory Reference Code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-24x86: Use ipchecksum from net/Simon Glass
The existing IP checksum function is only accessible to the 'coreboot' cpu. Drop it in favour of the new code in the network subsystem. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-23ls102xa: fdt: Disable QSPI and DSPI in NOR/NAND/SD bootAlison Wang
As QSPI/DSPI and IFC are pin multiplexed, QSPI and DSPI are only enabled in QSPI boot, and disabled in other boot modes. IFC is enabled in NOR/NAND/SD boot, and disabled in QSPI boot. This patch will add fdt support for the above rules. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23arm: ls102xa: Update snoop settings for CCI-400Alison Wang
CAAM is connected to CCI-400 S0 slave interface. Disable snooping for S0 will cause CAAM self test failure. This patch is to enable snooping for S0 slave interface. These CCI-400 operations are moved to board_early_init_f() to be initialized earlier. For S4 slave interface, issuing of snoop requests and DVM message requests are enabled. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23ARM: HYP/non-sec: Make variable gic_dist_addr as a local onetang yuantian
Defining variable gic_dist_addr as a globe one prevents some functions, which use it, from being used before relocation which is the case in the deep sleep resume process on Freescale SoC platforms. Besides, we can always get the GIC base address by calling get_gicd_base_address() without referring gic_dist_addr. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23crypto/fsl: Add fixup for crypto nodeRuchika Gupta
Era property is added in the crypto node in device tree. Move the code to do so from arch/powerpc/mpc8xxx/fdt.c to drivers/sec/sec.c so that it can be used across arm and powerpc platforms having crypto node. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> [York Sun: Fix commit message indentation] Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23arm: ls102xa: Add dummy gpio.h to enable CONFIG_OF_CONTROLRuchika Gupta
If CONFIG_OF_CONTROL is enabled, lib/fdtdec.c is compiled. It includes <asm/gpio.h> and then <asm/gpio.h> includes <asm/arch/gpio.h>. As a result, all the SoCs that enable CONFIG_OF_CONTROL must have <asm/arch/gpio.h> even if they do not support GPIO. The right fix would be to split the lib/fdtdec.c to remove dependency on GPIO.This commit adds a dummy <asm/arch/gpio.h> to support OF_CONTROL for LS102x platform. This dummy header will be removed after FDT-GPIO stuff is fixed correctly. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23ls102xa: etsec: Select ge0_clk125 for eTSEC clock muxing as defaultAlison Wang
This patch reverts to use ge0_clk125 for eTSEC clock muxing. For SAI and CAN which are pin multiplexed with RGMII1 in EC1 of RCW, ge2_clk125 will be used via hwconfig. Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-01-23arm/ls1021a: Add workaround for DDR erratum A008378York Sun
Internal memory controller counters can reach a bad state after training in DDR4 mode if accumulated ECC or DBI mode is eanbled. Signed-off-by: York Sun <yorksun@freescale.com>
2015-01-23x86: Fix various code format issues in start16.SBin Meng
Various minor code format issues are fixed in start16.S: - U-boot -> U-Boot - 32bit -> 32-bit - Use TAB instead of SPACE to indent - Move the indention location of the GDT comment block Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Test mtrr support flag before accessing mtrr msrBin Meng
On some x86 processors (like Intel Quark) the MTRR registers are not supported. This is reflected by the CPUID (EAX 01H) result EDX[12]. Accessing the MTRR registers on such processors will cause #GP so we must test the support flag before accessing MTRR MSRs. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Save mtrr support flag in global dataBin Meng
CPUID (EAX 01H) returns MTRR support flag in EDX bit 12. Probe this flag in x86_cpu_init_f() and save it in global data. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Add missing DECLARE_GLOBAL_DATA_PTR for mtrr.cBin Meng
arch/x86/cpu/mtrr.c has access to the U-Boot global data thus DECLARE_GLOBAL_DATA_PTR is needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Fix out of bounds irq handlers accessSebastien Ronsse
Using coreboot-x86_defconfig, the following error occurred prior to this modification: CC arch/x86/lib/interrupts arch/x86/lib/interrupts.c: In function ‘do_irqinfo’: arch/x86/lib/interrupts.c:134:24: error: iteration 16u invokes undefined behavior [-Werror=aggressive-loop-optimizations] if (irq_handlers[irq].handler != NULL) { ^ arch/x86/lib/interrupts.c:133:2: note: containing loop for (irq = 0; irq <= CONFIG_SYS_NUM_IRQS; irq++) { ^ cc1: all warnings being treated as errors scripts/Makefile.build:275: recipe for target 'arch/x86/lib/interrupts.o' failed make[1]: *** [arch/x86/lib/interrupts.o] Error 1 Makefile:1093: recipe for target 'arch/x86/lib' failed make: *** [arch/x86/lib] Error 2 Change-Id: I3572a822081b72ab760f1eb99442e1161d3d167e Signed-off-by: Sebastien Ronsse <sronsse@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-23x86: Support ROMs on other archsSimon Glass
We shouldn't assume that the VGA ROM can always be loaded at c0000. This is only true on x86 machines. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-01-23powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200Masahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2015-01-23powerpc: mpc5xxx: PM520 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Josef Wagner <Wagner@Microsys.de>
2015-01-23powerpc: mpc5xxx: remove Total5200 board supportMasahiro Yamada
2015-01-23powerpc: ppc4xx: remove PPChameleonEVB, CATcenter boardsMasahiro Yamada
These boards are still non-generic boards. It is a good thing that we can drop board-specific hack code from drivers/mtd/nand/nand_base.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
2015-01-23powerpc: mpc85xx: remove P2020DS board supportMasahiro Yamada
2015-01-23powerpc: mpc85xx: remove P2020COME board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2015-01-23powerpc: mpc85xx: remove P1_P2_RDB boardsMasahiro Yamada
These boards are still non-generic boards: P1011RDB, P1022RDB, P2010RDB, P2020RDB Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com>
2015-01-23powerpc: mpc83xx: remove MPC8360ERDK, EMPC8360EMDS supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2015-01-23Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-01-22Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2015-01-22Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2015-01-22Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2015-01-23ARM: UniPhier: add SG_MEMCONF macros for DDR channel 2Masahiro Yamada
PH1-sLD3, PH1-LD6b have DDR channel 2. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-23ARM: UniPhier: rename SG_MEMCONF_* macros for readabilityMasahiro Yamada
Match the suffixes of SG_MEMCONF_* macros with SZ_* macros defined by <linux/sizes.h> for readability. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-23ARM: UniPhier: use <linux/sizes.h> for readabilityMasahiro Yamada
2015-01-23ARM: UniPhier: remove non-sense inline directivesMasahiro Yamada
The inlining is done by GCC when needed, there is no need to do it explicitly. Furthermore, the inline keyword does not force-inline the code, but is only a hint for the compiler. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-01-23ARM: UniPhier: add static to local functionsMasahiro Yamada
