These fields is not used on sparc, so punt them.
This is used by both powerpc and arm, but I think it still qualifies as
architecture-specific.
Move this field into arch_global_data and tidy up.
This does not appear to be used, so punt it.
Move these fields into arch_global_data and tidy up.
Move arbiter_event_attributes and arbiter_event_address into
Move these fields into arch_global_data and tidy up. The bExtUart field
Move ips_clk and csb_clk into arch_global_data and tidy up.
Move ipb_clk and pci_clk into arch_global_data and tidy up.
Move the quantative easing fields into arch_global_data and tidy up.
Move these fields into arch_global_data and tidy up. This is needed for
both ppc and m68k since they share the i2c driver.
[trini: Update for bsc9132qds.c, b4860qds.c]
Move al mpc83xx fields into arch_global_data and tidy up. Also indent
the nested #ifdef for clarity.
Move vco_out, cpm_clk, scc_clk, brg_clk into arch_global_data and tidy
up. Leave pci_clk on its own since this should really depend only on
CONFIG_PCI and not any particular chip type.
PPC has several of these fields, selected by chip type, although only one
is ever compiled in.
Instead, use a single field. It would be nice if this could be selected
by CONFIG_PCI, but some chips (e.g. mpc5xxx) use pci_clk even when
CONFIG_PCI is not enabled.
These fields are not used on x86, so punt them.
[trini: Add arch/x86/cpu/cpu.c changes after Graeme's comments]
We currently assume that the global data pointer is at the start of
struct global_data. We want to remove this restriction, and it is
easiest to do this in C.
Remove the asm code and add equivalent code in C.
This idea was proposed by Graeme Russ here:
http://patchwork.ozlabs.org/patch/199741/
[trini: Apply Graeme Russ' comments
http://patchwork.ozlabs.org/patch/206305/ here, re-order]
Remove this unused field.
[trini: Address tlb_size in this patch as well]
This field doesn't appear to be used for anything important, so drop it.
Move these fields into arch_global_data.
We plan to move architecture-specific data into a separate structure so
that we can make the rest of it common.
As a first step, create struct arch_global_data to hold these fields.
Initially it is empty.
This patch applies to all archs at once. I can split it if this is really
a pain.
No one expects to end up in a delayed environment if
CONFIG_DELAY_ENVIRONMENT isn't defined.
Signed-off-by: Lucas Stach <dev@lynxeye.de>
Acked-by: Allen Martin <amartin@nvidia.com>
The patch adds an unified linker script file which
can be used for all currently supported MIPS targets.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Xiangfu Liu <xiangfu@openmobilefree.net>
The OUTPUT_FORMAT command in linker scripts
was always misused due to some endianess and
toolchain problems.
Use GCC flags to ensure proper output format,
and get rid of the OUTPUT_FORMAT commands in
the board specific u-boot.lds files.
The current code uses four instructions and a
temporary register to calculate the relocation
offset and to adjust the gp register.
The relocation offset can be calculated directly
from the CONFIG_SYS_MONITOR_BASE constant and from
the destination address. The resulting offset can
be used to adjust the gp pointer.
This approach makes the code a bit simpler because
it needs two instructions only.
The difference between the address of the original
and the relocated _GLOBAL_OFFSET_TABLE_ is always
the same as the relocation offset.
The relocation offset is already computed and it is
available in the 's1/t6' register. Use that to adjust
the relocated _G_O_T_ address, instead of calculating
the offset again from the _gp value.
When CoreNet Fabric (CCF) internal resources are consumed by the cores,
inbound SRIO messaging traffic through RMan can put the device into a
deadlock condition.
This errata workaround forces internal resources to be reserved for
upstream transactions. This ensures resources exist on the device for
upstream transactions and removes the deadlock condition.
The Workaround is for the T4240 silicon rev 1.0.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
If property 'fsl,sec-era' is already present, it is updated.
This property is required so that applications can ascertain which
descriptor commands are supported on a particular CAAM version.
Signed-off-by: Vakul Garg <vakul@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Configuring custom memory init value using CONFIG_MEM_INIT_VALUE in
the board config file doesn't work and memory is always initialized
to the value 0xdeadbeef. Only use this default value if a board doesn't
define CONFIG_MEM_INIT_VALUE.
Cc: Andy Fleming <afleming@freescale.com>
e6500 implements MMUv2 and supports power-of-2 page sizes rather than
power-of-4. Add support for such pages.
The BSC9132 is a highly integrated device that targets the evolving
Microcell, Picocell, and Enterprise-Femto base station market subsegments.
The BSC9132 device combines Power Architecture e500 and DSP StarCore SC3850
core technologies with MAPLE-B2P baseband acceleration processing elements
to address the need for a high performance, low cost, integrated solution
that handles all required processing layers without the need for an
external device except for an RF transceiver or, in a Micro base station
configuration, a host device that handles the L3/L4 and handover between
sectors.
The BSC9132 SoC includes the following function and features:
- Power Architecture subsystem including two e500 processors with
512-Kbyte shared L2 cache
- Two StarCore SC3850 DSP subsystems, each with a 512-Kbyte private L2
cache
- 32 Kbyte of shared M3 memory
- The Multi Accelerator Platform Engine for Pico BaseStation Baseband
Processing (MAPLE-B2P)
- Two DDR3/3L memory interfaces with 32-bit data width (40 bits including
ECC), up to 1333 MHz data rate
- Dedicated security engine featuring trusted boot
- Two DMA controllers
- OCNDMA with four bidirectional channels
- SysDMA with sixteen bidirectional channels
- Interfaces
- Four-lane SerDes PHY
- PCI Express controller complies with the PEX Specification-Rev 2.0
- Two Common Public Radio Interface (CPRI) controller lanes
- High-speed USB 2.0 host and device controller with ULPI interface
- Enhanced secure digital (SD/MMC) host controller (eSDHC)
- Antenna interface controller (AIC), supporting four industry
standard JESD207/four custom ADI RF interfaces
- ADI lanes support both full duplex FDD support & half duplex TDD
- Universal Subscriber Identity Module (USIM) interface that
facilitates communication to SIM cards or Eurochip pre-paid phone
cards
- Two DUART, two eSPI, and two I2C controllers
- Integrated Flash memory controller (IFC)
- GPIO
- Sixteen 32-bit timers
Signed-off-by: Naveen Burmi <NaveenBurmi@freescale.com>
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
This patch adds the ability for the FSL DDR interactive debugger to
automatically run the sequence of commands stored in the ddr_interactive
environment variable. Commands are separated using ';'.
ddr_interactive=compute; edit c0 d0 dimmparms caslat_X 0x3FC0; go
Signed-off-by: James Yang <James.Yang@freescale.com>
Add copy command which allows copying of DIMM/controller settings.
This saves tedious retyping of parameters for each identical DIMM
or controller.
