path: root/arch
2012-09-21Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-09-21Merge remote-tracking branch 'u-boot-imx/master'Albert ARIBAUD
2012-09-20Flex bus definition update for Coldfire 5253.Jason Jin
originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> ---- The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with the 5235 processor. The registers in struct fbcs are different sizes from those in the 5235. Also, the defines are a little different. This is what I have so far. Comments? ---- Reformat the patch manually by Jason Jin Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-20ColdFire: Queued SPI driverRichard Retanubun
This patch adds a driver for Freescale Colfire Queued SPI bus. Coded to work with 8 bits per transfer to use with SPI flash. CPOL, CPHA, and CS_ACTIVE_HIGH can be configured. Tested with MCF5270 which have 4 chip selects. Activate by #define CONFIG_CF_QSPI in board config. Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
2012-09-20ColdFire: Clean up checkpatch warnings for MCF54451 and MCF54455Alison Wang
Signed-off-by: Alison Wang <b18965@freescale.com>
2012-09-20ColdFire: Clean up checkpatch warnings for MCF547x and MCF548xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF523xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF532x/MCF537x/MCF5301xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF52x2Alison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF5227xAlison Wang
2012-09-20ColdFire: Add clear and set bits macros for ColdFire platformAlison Wang
2012-09-20ColdFire: Update the bitops for ColdFire platformAlison Wang
This patch uses the general ffs definition to replace the platform ffs definition. This patch also fixes the build error by adding hweightN definition for m5329evb and m5373evb. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-09-18ARM: Remove apollon boardMarek Vasut
This board is the only board that still sticks to OneNAND IPL. Remove this board, since we have SPL around for a while and OneNAND is well supported in the SPL framework. The board can be revived if necessary. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Tom Rini <trini@ti.com>
2012-09-18dm: sparc: Fixup the compile warnings in sparc codeMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: u-boot-dm@lists.denx.de
2012-09-17Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
2012-09-17MX6: drop binary constants from iomux headerStefano Babic
Constants set with binary value (0b...) are not compiled from old toolchain when used by the clrsetbits_le32 macro. Replaces them with the corresponding hex value. The error reported (for example with the mx6qsabrelite board) is something like: mx6qsabrelite.c:369:1: error: invalid suffix "b101" on integer constant mx6qsabrelite.c:369:1: error: invalid suffix "b10010" on integer constant mx6qsabrelite.c:369:1: error: invalid suffix "b0000" on integer constant mx6qsabrelite.c:369:1: error: invalid suffix "b10001" on integer constant Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-09-14Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2012-09-12Merge branch 'master' of git://www.denx.de/git/u-boot-mmcTom Rini
2012-09-11microblaze: board: Use bi_flashstart instead of CONFIG_SYS_FLASH_BASEMichal Simek
Prepare for device-tree driven configuration. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: Clean microblaze initializationMichal Simek
Move board specific function to board_init function in board/ folder Remove externs from generic board.c Use board_init_f function in board.c file. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: timer: Prepare for device-tree initializationMichal Simek
Fix CONFIG_SYS_HZ usage in board config. Do not use hardcoded value. Use CONFIG_SYS_HZ instead. Separate static configuration to single block. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-09-11microblaze: intc: Coding style cleanupMichal Simek
Just coding style cleanup. Remove unneeded externs. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: intc: Registering interrupt should return valueMichal Simek
Return value to find out if un/registration was succesful. Signed-off-by: Michal Simek <monstr@monstr.eu>
2012-09-11microblaze: board: Remove compilation warningMichal Simek
Variable is used when CONFIG_SYS_FLASH_CHECKSUM is used. Warning log: board.c: In function 'board_init': board.c:101: warning: unused variable 's' Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net>
2012-09-11microblaze: Add support for device tree driven board configurationMichal Simek
This is minimum code required to be able to use device-tree for u-boot initialization. Currently only for device driver initialization. Linker script change ensures DTB to be aligned for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net> CC: Simon Glass <sjg@chromium.org>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-10tegra20: usb: rework set_host_modeLucas Stach
This allows for two things: - VBus GPIO may be used on other ports than the OTG one - VBus GPIO may be low active if specified by DT Signed-off-by: Lucas Stach <dev@lynxeye.de> CC: Stephen Warren <swarren@wwwdotorg.org> CC: Tom Warren <TWarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10MX: set a common place to share code for Freescale i.MXStefano Babic
Up now only MX5 and MX6 can share code, because they have a common source directory in cpu/armv7. Other not armv7 i.MX can profit of the same shared code. Move these files into a directory accessible for all, similar to plat-mxc in linux. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-09-07tegra: nand: Add Tegra NAND driverJim Lin
A device tree is used to configure the NAND, including memory timings and block/pages sizes. If this node is not present or is disabled, then NAND will not be initialized. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-07tegra: fdt: Add NAND controller binding and definitionsSimon Glass
Add a NAND controller along with a bindings file for review. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-07tegra: Add NAND support to funcmuxSimon Glass
Add selection of NAND flash pins to the funcmux. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-06mx31: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX31 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Helmut Raiger <helmut.raiger@hale.at>
2012-09-06Fix mx31_decode_pllBenoît Thébaudeau
The MFN bit-field of the PLL registers represents a signed value. See the reference manual. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-06mx35 timer: Switch to 32-kHz sourceBenoît Thébaudeau
Switch the mx35 timer driver to the 32-kHz clock source to avoid calling mxc_get_clock() again and again, and to be consistent with the timer drivers of other i.MX SoCs. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-06mx35: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX35 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-06mx25: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX25 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Matthias Weisser <weisserm@arcor.de>
2012-09-06mx35: Fix clock dividersBenoît Thébaudeau
The clock dividers that were used do not match at all the reference manual. They were either completely broken, or came from an early silicon revision incompatible with the current one. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-09-06mx35: Add definitions for clock gate valuesBenoît Thébaudeau
2012-09-06mx35: Fix decode_pllBenoît Thébaudeau
2012-09-06omap4 i2c: add support for i2c bus 4Koen Kooi
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
2012-09-05mmc: s5p_sdhci: fixed wrong function argumentJaehoon Chung
Useless code is removed, and get buswidth value. buswidth value will be used to choice the 4bit or 8bit. (Now used 4bit mode in sdhci.c by default) Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Kyungmin Park <kyungin.park@samsung.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-09-05Merge remote-tracking branch 'u-boot-ti/master' into mAlbert ARIBAUD
2012-09-04am33xx: Remove redundant timer configTom Rini
We have the timer code in arch/arm/cpu/armv7/omap-common/timer.c that has been configuring and enabling the timer, so remove our code that does the same thing by different methods. Tested on EVM GP, SK-EVM and Beaglebone. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-04OMAP3: video: add macros to set display parametersStefano Babic
Add a common macros to set the registers for horizontal and vertical timing. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-09-04video: drop duplicate set of DISPC_CONFIG registerStefano Babic
2012-09-04OMAP3: add definition of CTRL_WKUP_CTRL registerArnout Vandecappelle (Essensium/Mind)
AM/DM37x SoCs add the CTRL_WKUP_CTRL register. It contains the GPIO_IO_PWRDNZ bit, which is required to be set to enable the I/O pads of gpio_126, gpio_127 and gpio_129. Signed-off-by: Arnout Vandecappelle (Essensium/Mind) <arnout@mind.be> Cc: Tom Rini <trini@ti.com>
2012-09-04arm: Adds board_postclk_init to the init_sequence.Markus Hubig
The board_postclk_init() function can be used to perform operations that requires a working timer early within the U-Boot init_sequence. Signed-off-by: Markus Hubig <mhubig@imko.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-04MX28: Fixup the ad-hoc use of DIGCTL_MICROSECONDSMarek Vasut
Use proper struct-based access for this register in the SPL code. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <festevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-04Merge branch 'master' of git://git.denx.de/u-boot-avr32Wolfgang Denk
* 'master' of git://git.denx.de/u-boot-avr32: net:macb: add line break avr32:portmux: fix setup for macb1 avr32: Remove redundant LDSCRIPT definition Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-09-03avr32:portmux: fix setup for macb1Andreas Bießmann
Use portd_mask instead of portc_mask to setup the pins for port D. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
