These GPIO_PORTx macros should be in gpio.h, but not in imx-regs.h.
Also, imx-regs.h and iomux-v3.h has same macro defintion for
GPIO_PORTx, and both of them are included in mxc_i2c.c(include
mxc_i2c.h). This will incur build warnings with macro redefinition.
Since iomux-v3.h is not compatible with mx27, we can not simply
include iomux-v3.h for mx27, so move the GPIO_PORTx to gpio.h to
fix the build warning.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Increase the LCD size to 1366x768.
These files use error numbering, so add the include.
This function should return a useful error for U-Boot, rather than -1.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
It is convenient for some boards to implement save_boot_params() in C rather
than assembler. Provide a way to return in this case.
Commit 47ed5dd0 dropped the .got section from U-Boot binaries. This is needed
for some relocations, and causes failures if missing. Add it back.
This name is used in Linux, so use it in U-Boot.
This commit adds support for the OHCI companion controller, which makes
usb-1 devices directly plugged into to usb root port work.
Note for now this switches usb-keyboard support for sunxi back from int-queue
support to the old interrupt polling method. Adding int-queue support to the
ohci code and switching back to int-queue support is in the works.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
With d6b72da0 we started including this file unconditionally. This
isn't allowed in a file that we also use on armv8. This will get
cleaned up a bit better once we really start using these same features
(and have similar fdt updates needed) on armv8.
All the Tegra boards borrow the files from board/nvidia/common/
directory, i.e., board/nvidia/common/* are not vendor-common files,
but SoC-common files.
Move NVIDIA common files to arch/arm/mach-tegra/ to clean up
Makefiles.
As arch/arm/mach-tegra/board.c already exists, this commit renames
board/nvidia/common/board.c to arch/arm/mach-tegra/board2.c,
expecting they will be consolidated as a second step.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Tom Warren <twarren@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The secure world code is relocated to the MB just below the top of 4G, we
reserve it in the FDT (by setting CONFIG_ARMV7_SECURE_RESERVE_SIZE) but it is
not protected in h/w.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
Tested-by: Thierry Reding <treding@nvidia.com>
Tested-by: Ian Campbell <ijc@hellion.org.uk>
Upstream Linux is broken with default configs when PSCI, thus non-secure
mode is enabled. So the user should explicitly enable this mode, e.g.
when she disabled CONFIG_CPU_IDLE in Linux (in which case it's safe to
use). We can revert this workaround once Linux got fixed.
Make sure to enable the SMMU when booting the kernel in non-secure mode.
This is necessary because some of the SMMU registers are restricted to
TrustZone-secured requestors, hence the kernel wouldn't be able to turn
the SMMU on. At the same time, enable translation for all memory clients
for the same reasons. The kernel will still be able to control SMMU IOVA
translation using the per-SWGROUP enable bits.
Signed-off-by: Thierry Reding <treding@nvidia.com>
We only set CNTFRQ in arch_timer_init for the boot CPU. But this has to
happen for all cores.
Fixing this resolves problems of KVM with emulating the generic
timer/counter.
These registers can be used to prevent non-secure world from accessing a
megabyte aligned region of RAM, use them to protect the u-boot secure monitor
code.
At first I tried to do this from s_init(), however this inexplicably causes
u-boot's networking (e.g. DHCP) to fail, while networking under Linux was fine.
So instead I have added a new weak arch function protect_secure_section()
called from relocate_secure_section() and reserved the region there. This is
better overall since it defers the reservation until after the sec vs. non-sec
decision (which can be influenced by an envvar) has been made when booting the
os.
[Jan: tiny style adjustment]
This is based on Thierry Reding's work and uses Ian Campell's
preparatory patches. It comes with full support for CPU_ON/OFF PSCI
services. The algorithm used in this version for turning CPUs on and
off was proposed by Peter De Schrijver and Thierry Reding in
http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/210881. It
consists of first enabling CPU1..3 via the PMC, just to powergate them
again with the help of the Flow Controller. Once the Flow Controller is
in place, we can leave the PMC alone while processing CPU_ON and CPU_OFF
PSCI requests.
Tegra boards will have to initialize power management for the PSCI
support this way.
Will be used for unpowergating CPUs.
In this case the secure code lives in RAM, and hence the memory node in
the device tree needs to be adjusted. This avoids that the OS will map
and possibly access the reservation.
Add support for setting CONFIG_ARMV7_SECURE_RESERVE_SIZE to carve out
such a region. We only support cutting off memory from the beginning or
the end of a RAM bank as we do not want to increase their number (which
would happen if punching a hole) for simplicity reasons
This will be used in a subsequent patch for Jetson-TK1.
I will need mc_security_cfg0/1 in a future patch and I added the rest while
debugging, so thought I might as well commit them.
Use a per-CPU variable for saving the target PC during CPU_ON
operations. This allows us to run this service independently on targets
that have more than 2 cores and also core-local power control.
CC: Marc Zyngier <marc.zyngier@arm.com>
This algorithm will be useful on Tegra as well, plus we will need it for
making _psci_target_pc per-CPU.
_sunxi_cpu_entry can be converted completely into a reusable
psci_cpu_entry. Tegra124 will use it as well.
As with psci_disable_smp, also the enabling is designed to be overloaded
in cased SMP is not controlled via ACTLR.
Move parts of sunxi's psci_cpu_off into psci_cpu_off_common, namely
cache disabling and flushing, clrex and the disabling of SMP for the
dying CPU. These steps are apparently generic for ARMv7 and will be
reused for Tegra124 support.
As the way of disabled SMP is not architectural, though commonly done
via ACLTR, the related function can be overloaded.
Will be required for obtaining the ID of the current CPU in shared PSCI
functions. The default implementation requires a dense ID space and only
supports a single cluster. Therefore, the functions can be overloaded in
cases where these assumptions do not hold.
CONFIG_ARMV7_VIRT depends on CONFIG_ARMV7_NONSEC, thus doesn't need to
be taken into account additionally. CONFIG_ARMV7_PSCI is only set on
boards that support CONFIG_ARMV7_NONSEC, and it only works on those.
CC: Tang Yuantian <Yuantian.Tang@freescale.com>
CC: York Sun <yorksun@freescale.com>
CC: Steve Rae <srae@broadcom.com>
CC: Andre Przywara <andre.przywara@linaro.org>
Tested-by: Alison Wang <alison.wang@freescale.com>
Add full link training as a fallback in case the fast link training
fails.
Acked-by: Anatolij Gustschin <agust@denx.de>
Connect up the clocks and the eDP driver to make these displays work with
Tegra124-based devices.
Add the various host1x peripherals to allow an eDP display to be connected.
Allow this to be used by other Tegra SoCs.
Add functions to provide access to the display clocks on Tegra124 including
setting the clock rate for an EDP display.
Create a function which sets the source clock for a peripheral, given
the number of mux bits to adjust. This can then be used more generally.
For now, don't export it.
The get_pll() function can do the wrong thing if passed values that are
out of range. Add checks for this and add a function which can return
a 'simple' PLL. This can be defined by SoCs with their own clocks.
This peripheral is required to get the LCD display running. Add it to
tegra124 and also bring in the binding file from Linux 3.18
Add required setup for the LCD display, and a function to provide the
board ID. This requires GPIOs to be available prior to relocation.
Some LCDs require a PMIC to be set up - add a function for this.
Add a way of displaying a numeric board ID on start-up.
This is only used by Nvidia boards, so move it into nvidia/common to
simplify things.
When enabling a PWM, allow the existing clock rate and source to stand
unchanged.
This is needed for tegra124 also, so make it common and add a header file
for tegra124.
TARGET_DUMMY was introduced to resolve the same problem as commit
"arch: Make board selection choices optional"
http://git.denx.de/?p=u-boot.git;a=commit;h=a26cd04920dc069fd6e91abb785426cf6c29f45f
Latter implementation is much cleaner and appropriate.
And anyways TARGET_DUMMY is no longer required.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Remove board support for afeb9260, tny_a9260, and sbc35_a9g20.
They have not been converted into Generic Board yet.
See doc/README.generic-board for details.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
As doc/README.ARC says, pre-build ARC toolchains are available at
the Synopsys GitHub page.
The bin files are prefixed with arc(eb)-buildroot-linux- for earlier
releases, but with arc(eb)-snps-linux- for the latest releases.
The symbolic links prefixed with arc(eb)-linux- are also available
for all the release, so those prefixes can be used as the default
CROSS_COMPILE regardless of the toolchains version/variants.
By making the board selections optional, every defconfig will include
the board selection when running savedefconfig so if a new board is
added to the top of the list of choices the former top's defconfig will
still be correct.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
As this board seems to be unmaintained for quite some time, and its
not moved to the generic board ingrastructure, lets remove it.
This will also enable us to remove the CONFIG_AUTOBOOT_DELAY_STR2
and CONFIG_AUTOBOOT_STOP_STR2 macros, as this sc3 board is the
only one using one of this macros. A removal patch will follow
soon.
Cc: Juergen Beisert <jbeisert@eurodsn.de>
Acked-by: Heiko Schocher <hs@denx.de>
This patch adds device tree for the ST Micro stv0991 board & enables
device tree control. Progressively device tree support for the drivers
being used will also be added.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Add the stm32F4 board's serial ports support.
User can use it easily.
The user only need to edit the number of the usart.
The patch also fix the serial print out.
Last, this version of patch fix the first patch checkpatch.pl error.
Thanks to Kamil Lulko.
Signed-off-by: kunhuahuang <huangkunhua@gmail.com>
