path: root/arch
2017-08-14Merge branch 'master' of git://git.denx.de/u-boot-rockchipTom Rini
2017-08-13stm32f1: remove stm32f1 supportPatrice Chotard
A few years ago STM32F1 SoCs support has been added : 0144caf22ce6acd5c gpio: stm32: add stm32f1 support 2d18ef2364fd3561a ARMv7M: add STM32F1 support But neither STM32F1 dedicated defconfig nor board was associated to these commits. Got confirmation from Tom Rini and Matt Porter to remove all this code [1] [1] http://u-boot.10912.n7.nabble.com/Remove-STM32F1-support-td301603.html Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-13ARM: OMAP5: Enable support for AVS0 for OMAP5 production devicesNishanth Menon
OMAP5432 did go into production with AVS class0 registers which were mutually exclusive from AVS Class 1.5 registers. Most OMAP5-uEVM boards use the pre-production Class1.5 which has production efuse registers set to 0. However on production devices, these are set to valid data. scale_vcore logic is already smart enough to detect this and use the "Nominal voltage" on devices that do not have efuse registers populated. On a test production device populated as follows: MPU OPP_NOM: => md.l 0x04A0021C4 1 4a0021c4: 03a003e9 .... (0x3e9 = 1.01v) vs nom voltage of 1.06v MPU OPP_HIGH: => md.l 0x04A0021C8 1 4a0021c8: 03400485 ..@. MM OPP_NOM: => md.l 0x04A0021A4 1 4a0021a4: 038003d4 .... (0x3d4 = 980mV) vs nom voltage of 1.025v MM OPP_OD: => md.l 0x04A0021A8 1 4a0021a8: 03600403 ..`. CORE OPP_NOM: => md.l 0x04A0021D8 1 4a0021d8: 000003cf .... (0x3cf = 975mV) vs nom voltage of 1.040v Since the efuse values are'nt currently used, we do not regress on existing pre-production samples (they continue to use nominal voltage). But on boards that do have production samples populated, we can leverage the optimal voltages necessary for proper operation. Tested on: a) 720-2644-001 OMAP5UEVM with production sample. b) 750-2628-222(A) UEVM5432G-02 with pre-production sample. Data based on OMAP5432 Technical reference Manual SWPU282AF (May 2012-Revised Aug 2016) NOTE: All collaterals on OMAP5432 silicon itself seems to have been removed from ti.com, though EVM details are still available: http://www.ti.com/tool/OMAP5432-EVM Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-08-13ARM: OMAP5: Remove OPP_LOW Definitions for ES2.0Nishanth Menon
ES2.0 descopes OPP_LOW definition. So remove it from macros defined. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2017-08-13stm32: remove redundant 'else if'xypron.glpk@gmx.de
The if in the else branch is superfluous. We can use a simple if. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13arm: mvebu: avoid possible NULL dereferencexypron.glpk@gmx.de
It does not make sense to check if info is NULL after dereferencing it. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-08-13armv7m: mpu_config add missing breakxypron.glpk@gmx.de
For DEVICE_NON_SHARED the newly assigned value of attr is overwritten due to a missing break. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13bcm281xx: clock: avoid possible NULL dereferencexypron.glpk@gmx.de
It does not make sense first to dereference c and then to check if it is NULL. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13arm: bcm235xx: clk_set_rate avoid possible NULL derefxypron.glpk@gmx.de
It does not make sense first to dereference c and then to check if it is NULL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13arm: bcm235xx: avoid possible NULL dereferencexypron.glpk@gmx.de
It does not make sense to first dereference c and then check if it is NULL. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13arm: spear: do not return random value from stackxypron.glpk@gmx.de
If the NOR device is not available do not return a random value from the stack. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-08-13rockchip: rk322x: update max-frequency for mmc nodeKever Yang
mmc using 150000000 as max-frequency like what rk3288 sets. This can speed up the mmc read/write, the actual mmc clock is: Before this patch: 37.125M After this patch: 49.5M Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-13rockchip: dts: rk322x: add sdmmc device nodeKever Yang
add node for sdmmc in dts and rk3229-evb. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-13rockchip: rk322x: set the DDR region as non-secure in SPLKever Yang
Disable the ddr secure region setting in SPL and the ddr memory becomes non-secure, every one can access it. the trust firmware like OPTEE should have the correct setting for it after SPL if there is one. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-13rockchip: rk3288: fix EMMC_DIV_MASK definition in headerKever Yang
It should be '<<' instead of '<' for _MASK definition, fix it. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: move SPL_LDSCRIPT to KconfigPhilipp Tomsich
With the new way of doing things (i.e. the hierarchical selection of SPL_LDSCRIPT via Kconfig) in place, this moves the SPL_LDSCRIPT setting for the RK3368 from defconfig back into Kconfig. With this done, there should be no lingering cases of SPL_LDSCRIPT outside of Kconfig files. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13spl: add hierarchical defaults for SPL_LDSCRIPTPhilipp Tomsich
With SPL_LDSCRIPT moved to Kconfig (and this being a 'string' config node), all the lingering definitions in header files will cause warnings/errors due to the redefinition of the configuration item. As we don't want to pollute the defconfig files (and values should usually be identical for entire architectures), the defaults are moved into Kconfig. Kconfig will always pick the first default that matches, so please keep these values at the end of each file (to allow any board-specific Kconfig, which will be included earlier) to override with an unconditional default setting. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3188: rock: adjust for SPL/TPL splitPhilipp Tomsich
With the changes to split SPL/TPL for the RK3368, I apparently missed some needed adjustments to the RK3188 Kconfig and rock_defconfig. This fixes build-issues for the rock board after applying the RK3368 enablement (and SPL/TPL) set that resulted from TPL_SERIAL_SUPPORT, TPL_ROCKCHIP_BACK_TO_BROM and TPL_TINY_MEMSET being separate symbols now. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: add u-boot specific dts for rk3368 based boardsAndy Yan
Device drivers like debug serial, dmc should be enabled before relocation, so add u-boot.dtsi files to contain devices that should be marked as dm-pre-reloc. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: remove setup of secure timer from TPL/SPLPhilipp Tomsich
When using DM timers w/ the timer0 block within the RK3368, we no longer depend on the ARMv8 generic timer counting. This allows us to drop the secure timer initialisation from the TPL and SPL stages. The secure timer will later be set up by ATF, which starts the ARMv8 generic timer. Thus, there will be a dependency from Linux to the ATF through the ARMv8 generic timer... this seems reasonable, as Linux will require the ATF (and PSCI) to start up the secondary cores anyway (in other words: we don't add any new dependencies). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13dts: rk3368: make timer0 accessible for SPL and TPLPhilipp Tomsich
To use it with the DM timer driver in SPL and TPL, timer0 needs to be marked as pre-reloc. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13dm: timer: normalise SPL and TPL supportPhilipp Tomsich
To fully support DM timer in SPL and TPL, we need a few things cleaned up and normalised: - inclusion of the uclass and drivers should be an all-or-nothing decision for each stage and under control of $(SPL_TPL_)TIMER instead of having the two-level configuration with TIMER and $(SPL_TPL_)TIMER_SUPPORT - when $(SPL_TPL_)TIMER is enabled, the ARMv8 generic timer code can not be compiled in This normalises configuration to $(SPL_TPL_)TIMER and moves the config options to drivers/timer/Kconfig (and cleans up the collateral damage to some defconfigs that had SPL_TIMER_SUPPORT enabled). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13moveconfig: migrate TPL_STACK, TPL_TEXT_BASE and TPL_MAX_SIZEPhilipp Tomsich
We can finally drop TPL_STACK, TPL_TEXT_BASE and TPL_MAX_SIZE off the whitelist (this time it's really happening!) and migrate the setting (only used on the RK3368-uQ7 so far) into Kconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: mark TPL as not inheriting its stack, text-base and size ↵Philipp Tomsich
from SPL The RK3368 needs to have a different base-address and stack-pointer for its TPL stage. Now that we want to do this via Kconfig, we need to tick the appropriate 'TPL_NEEDS_...' boxes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13armv8: TPL_STACK will always be defined, so test CONFIG_TPL_NEEDS_SEPARATE_STACKPhilipp Tomsich
Now that TPL_STACK has been moved off the whitelist (ok, I'm lying: the 'moving off the whitelist' part comes in once moveconfig runs... which will be a few commits down the line) and added to Kconfig, we need to test CONFIG_TPL_NEEDS_SEPARATE_STACK to see whether the value from TPL_STACK should be used or whether we try to inherit whatever SPL uses. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: Kconfig: preset TPL_LDSCRIPT via Kconfig for the RK3368Philipp Tomsich
Set TPL_LDSCRIPT in Kconfig, so we don't have to pollute our header file. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-13rockchip: board: lion-rk3368: add support for the RK3368-uQ7Philipp Tomsich
The RK3368-uQ7 (codenamed 'Lion') is a micro-Qseven (40mm x 70mm, MXM-230 edge connector compatible with the Qseven specification) form-factor system-on-module based on the octo-core Rockchip RK3368. It is designed, supported and manufactured by Theobroma Systems. It provides the following features: - 8x Cortex-A53 (in 2 clusters of 4 cores each) - (on-module) up to 4GB of DDR3 memory - (on-module) SPI-NOR flash - (on-module) eMMC - Gigabit Ethernet (with an on-module KSZ9031 PHY) - USB - HDMI - MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group) - various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...) Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: mark SPL and TPL as supported for ROCKCHIP_RK3368Philipp Tomsich
With SPL and TPL support for the RK3368 in place, mark SPL and TPL as supported from Kconfig for the RK3368. As this is primarily tested on the RK3368-uQ7, we'll leave it to board's individual defconfig to enable. Also enable DEBUG_UART_BOARD_INIT for the RK3368, so we get output during the early boot-up, as we turn on TPL and SPL. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: add SPL supportPhilipp Tomsich
Adds SPL support for the RK3368 (assuming that our TPL stage has initialised DRAM and set up the memory firewall). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: spl: make spl-boot-order code reusable (split from rk3399)Philipp Tomsich
In order to reuse the support for the u-boot,spl-boot-order property from the rk3399, we split it into a reusable module that can be included by the SPL code for any of our boards. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: add TPL supportPhilipp Tomsich
This adds the TPL support for the RK3368, including the u-boot-tpl.lds. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: dts: add DMC node in rk3368.dtsiPhilipp Tomsich
For full SPL support, including DRAM initialisation, we need a few nodes from the DTS: this commit adds the DMC (DRAM controller) node, the service_msch (memory scheduler) node and marks GRF, PMUGRF and CRU as 'u-boot,dm-pre-reloc'. In addition to this, we also include the dt-binding for the DMC to allow DTS files including this DTSI to refer to the symbolic constants for the DDR3 bin and for the memory-schedule. Note that the DMC contains both the memory regions for the (Designware) protocol controller as well as the DDR PHY. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: add DRAM controller driver with DRAM initialisationPhilipp Tomsich
This adds a DRAM controller driver for the RK3368 and places it in drivers/ram/rockchip (where the other DM-enabled DRAM controller drivers for rockchip devices should also be moved eventually). At this stage, only the following feature-set is supported: - DDR3 - 32-bit configuration (i.e. fully populated) - dual-rank (i.e. no auto-detection of ranks) - DDR3-1600K speed-bin This driver expects to run from a TPL stage that will later return to the RK3368 BROM. It communicates with later stages through the os_reg2 in the pmugrf (i.e. using the same mechanism as Rockchip's DDR init code). Unlike other DMC drivers for RK32xx and RK33xx parts, the required timings are calculated within the driver based on a target frequency and a DDR3 speed-bin (only the DDR3-1600K speed-bin is support at this time). The RK3368 also has the DDRC0_CON0 (DDR ch. 0, control-register 0) register for controlling the operation of its (single-channel) DRAM controller in the GRF block. This provides for selecting DDR3, mobile DDR modes, and control low-power operation. As part of this change, DDRC0_CON0 is also added to the GRF structure definition (at offset 0x600). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: Makefile: streamline SPL/TPL configurationPhilipp Tomsich
Handling TPL and SPL in the Makefile for mach-rockchip was based on nested if checks and/or if-else-if paths. This can be simplified and made more readable by using $(SPL_TPL_) and by introducing intermediate variables for the aggregation of SPL and TPL features. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13net: gmac_rockchip: Add support for the RK3368 GMACPhilipp Tomsich
The GMAC in the RK3368 once again is identical to the incarnation in the RK3288 and the RK3399, except for where some of the configuration and control registers are located in the GRF. This adds the RK3368-specific logic necessary to reuse this driver. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-13rockchip: clk: rk3368: add support for GMAC (SLCK_MAC) clockPhilipp Tomsich
To enable the GMAC on the RK3368, we need to set up the clocking appropriately to generate a tx_clk for the MAC. This adds an implementation that implements the use of the <&ext_gmac> clock (i.e. an external 125MHz clock for RGMII provided by the PHY). This is the clock setup used by the boards currently supported by U-Boot (i.e. Geekbox, Sheep and RK3368-uQ7). This includes the change from commit - rockchip: clk: rk3368: define GMAC_MUX_SEL_EXTCLK Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: clk: rk3368: implement MMC/SD clock reparentingPhilipp Tomsich
The original clock support for MMC/SD cards on the RK3368 suffered from a tendency to select a divider less-or-equal to the the one giving the requested clock-rate: this can lead to higher-than-expected (or rather: higher than supported) clock rates for the MMC/SD communiction. This change rewrites the MMC/SD clock generation to: * always generate a clock less-than-or-equal to the requested clock * support reparenting among the CPLL, GPLL and OSC24M parents to generate the highest clock that does not exceed the requested rate In addition to this, the Linux DTS uses HCLK_MMC/HCLK_SDMMC instead of SCLK_MMC/SCLK_SDMMC: to match this (and to ensure that clock setup always works), we adjust the driver appropriately. This includes the changes from: - rockchip: clk: rk3368: convert MMC_PLL_SEL_* definitions to shifted-value form Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: clk: rk3368: define DMA1_SRST_REQ and DMA2_SRST_REQPhilipp Tomsich
On he RK3368, we need to temporarily disable security on the DMA engines during TPL and SPL to allow the MMC host to DMA into DRAM. To do so, we need to reset the two DMA engines, which in turn requires the DMA1_SRST_REQ and DMA2_SRST_REQ constants to refer to the appropriate bits in the CRU. As the ATF correctly initialises security (and only leaves EL3 after doing so), this can not pose a security issue. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: pinctrl: rk3368: move IOMUX bit-definitions to pinctrl driverPhilipp Tomsich
There is no real reason to keep the bit-definitions for the IOMUX in the grf header file (which defines the register layout of the GRF block): these should only be used by our pinctrl driver (with the possible exception of early debug-init code in TPL/SPL). This moves the relevant definitions from the grf_rk3368.h header into the pinctrl driver pinctrl_rk3368.c. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: dts: add sgrf nodePhilipp Tomsich
We will to drop device security temporarily (until the ATF initialises it fully) from the TPL/SPL stage: this requires access to some registers in the SGRF. This adds the sgrf node to the rk3368.dtsi, so we can then bind a syscon device onto it and access its memory ranges. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: grf: use shifted-constantsPhilipp Tomsich
The RK3368 GRF header was still defines with a shifted-mask but with non-shifted function selectors for the IOMUX defines. As the RK3368 support is still fresh enough to allow a quick change, we do this now before having more code use this. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-13rockchip: rk3368: syscon: SGRF support for OF_PLATDATAPhilipp Tomsich
In TPL we will need to configure security in the SGRF of the RK3368. This change adds support for the SGRF as a syscon device, so we can retrieve its address range through the syscon API in TPL (and can avoid having to hard-code the address). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: syscon: MSCH/PMUGRF/GRF support for OF_PLATDATAPhilipp Tomsich
The RK3368 has both a limited TPL size (just 0x7000 bytes) and the added challenge of booting in AArch64, which increases the code size for TPL (particularily when using the LP64 programming model). For this reason we expect the RK3368 to always use OF_PLATDATA for its TPL stage. This change adds support for the MSCH, PMUGRF and GRF register regions in syscon, which are necessary for initialising the RK3368's DRAM controller. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: pmugrf: add definitions for os_reg[0..3]Philipp Tomsich
On the RK3368 we use a TPL-stage similar to Rockchip's DDR init (i.e. it initialises DRAM, leaves some info for the next stage and returns to the BootROM). To allow compatibility with Rockchip's DDR init code, we use the same register os_reg2 in pmugrf for passing this info (i.e. DRAM size and configuration) between stages. This change adds the definitions for os_reg[0] through os_reg[3] to the pmugrf structure for the RK3368. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: improve Kconfig text for the RK3368Philipp Tomsich
The RK3368 option in Kconfig referred to the RK3328 (copy-and-paste) and had a few typos and unnecessarily used UTF-8 characters. While fixing this, I also reformatted and further clarified the text (e.g. made the grouping into a a big and little cluster of 4 cores each explicit). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: Makefile: allow selective inclusion of sdram_common.o from ↵Philipp Tomsich
TPL/SPL/U-Boot The utility functions in sdram_common.c will be useful both for some SPL implementations (and if unused, the linked will discard these anyway) and for the full U-Boot stage. This changes selects sdram_common.o through the $(SPL_TPL_) macro to allow better control of its inclusion through the CONFIG_ROM, CONFIG_SPL_RAM or CONFIG_TPL_RAM options. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13armv8: spl: Support separate stack for TPLPhilipp Tomsich
To allow a TPL and SPL to run from different addresses/memories, we need to split setup of the TPL and SPL stacks. To do so, we introduce CONFIG_TPL_STACK (not listed in Kconfig) which can be used to override the initial stack pointer for TPL. To provide backward compatibility for existing boards, this is added as an optional configuration item and the normal search order (i.e. SPL_STACK, then SYS_STACK) apply if not defined. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-13armv8: move low-level assembly functions into function-sectionsPhilipp Tomsich
TPL builds today don't need to call into firmware or set up the MMU (if this changes, it should be controlled through a config option whether to include this or not), but include the needed support code for this anyway. By moving these unused low-level functions into seperate function-sections, the linker can garbage-collect the unused sections. Note that (if DM support is enabled), there will be a call to the cache-flushing code from alloc_priv(...) in drivers/core/device.c. This then add 52 bytes of binary size (an increase from 20589 to 20641 bytes) compared to completely removing this code. Even for a feature-rich TPL (including DM support as for the RK3368), this equates to a size difference of significantly more than 10% in TPL binary size. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: back-to-bootrom: simplify the #ifdef-check for LIBCOMMON in TPL/SPLPhilipp Tomsich
With the finer-grained control over LIBCOMMON_SUPPORT for TPL/SPL (i.e. with the newly introduced distinction between TPL_LIBCOMMON_SUPPORT and SPL_LIBCOMMON_SUPPORT), we can simplify the #ifdef-check to simply use CONFIG_IS_ENABELD. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [fixed up to use 'puts' and LIBCOMMON:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-13rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPLPhilipp Tomsich
The back-to-bootrom option is rather unfortunately named CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM instead of CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM), we need to rename it. At the same time, we introduce a TPL_ variant of the option to give us finer-grained control over when it should be used. This change is motivated by our RK3368 boot process, which returns to the boot ROM only from the TPL stage, but not from the SPL stage. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:] [fixed inverted CONFIG_IS_ENABLED test for rk3288:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> include/configs/rock.h: undef
