path: root/arch
2014-02-22arch: bcm281xx: Initial commit of bcm281xx architecture codeDarwin Rambo
Add bcm281xx architecture support code including a clock framework and chip reset. Define register block base addresses for the bcm281xx architecture and create an empty gpio header file required when CONFIG_CMD_GPIO is set. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Tim Kryger <tkryger@linaro.org>
2014-02-22arch: kona: Initial commit of kona-common architecture codeDarwin Rambo
The Kona architecture is present on a number of Broadcom mobile SoCs including the bcm281xx family of chips. Signed-off-by: Darwin Rambo <drambo@broadcom.com> Reviewed-by: Steve Rae <srae@broadcom.com> Reviewed-by: Tim Kryger <tkryger@linaro.org>
2014-02-20Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: Makefile drivers/net/npe/Makefile These two conflicts arise from commit 0b2d3f20 ("ARM: NET: Remove the IXP NPE ethernet driver") and are resolved by deleting the drivers/net/npe/Makefile file and removing the CONFIG_IXP4XX_NPE line from Makefile.
2014-02-19kbuild,tegra124: add dummy obj- for KbuildMasahiro Yamada
In Kbuild, every makefile must have non-empty obj- or obj-y. Otherwise, built-in.o will not be created and the link stage will fail. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Move CONFIG_DISPLAY_CPUINFO to MakefileMasahiro Yamada
If the whole code is surrounded by #ifdef(CONFIG_ ) .. #endif, it should be moved to Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: generate multiple device tree blobsMasahiro Yamada
It is convenient to have all device trees on the same SoC compiled. It allows for later easy repackaging without the need to re-run the make file. - Build device trees with the same SoC under arch/$(ARCH)/dts - Copy the one specified by CONFIG_DEFAULT_DEVICE_TREE or DEVICE_TREE=... to dts/dt.dtb Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19dts: re-write dts/Makefile more simply with KbuildMasahiro Yamada
Useful rules in scripts/Makefile.lib allows us to easily generate a device tree blob and wrap it in assembly code. We do not need to parse a linker script to get output format and arch. This commit deletes ./u-boot.dtb since it is a copy of dts/dt.dtb. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use scripts/Makefile.cleanMasahiro Yamada
This commit refactors cleaning targets such as clean, clobber, mrpropper, distclean with scripts/Makefile.clean. By using scripts/Makefile.clean, we can recursively descend into subdirectories and delete generated files there. We do not need add a big list of generated files to the "clean" target. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19kbuild: add dummy obj-y to create built-in.oMasahiro Yamada
We are going to switch over to Kbuild in upcoming commits. Each makefile must have non-empty obj- or obj-y to generate built-in.o on Kbuild. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19kbuild: change out-of-tree buildMasahiro Yamada
This commit changes the working directory where the build process occurs. Before this commit, build process occurred under the source tree for both in-tree and out-of-tree build. That's why we needed to add $(obj) prefix to all generated files in makefiles like follows: $(obj)u-boot.bin: $(obj)u-boot Here, $(obj) is empty for in-tree build, whereas it points to the output directory for out-of-tree build. And our old build system changes the current working directory with "make -C <sub-dir>" syntax when descending into the sub-directories. On the other hand, Kbuild uses a different idea to handle out-of-tree build and directory descending. The build process of Kbuild always occurs under the output tree. When "O=dir/to/store/output/files" is given, the build system changes the current working directory to that directory and restarts the make. Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>" syntax for descending into sub-directories. (We can write it like "make $(obj)=<sub-dir>" with a shorthand.) This means the current working directory is always the top of the output directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-02-19microblaze: remove an empty file arch/microblaze/lib/time.cMasahiro Yamada
Commit 779bf42c moved timer functions from arch/microblaze/lib/time.c to arch/microblaze/cpu/timer.c. But the empty file, arch/microblaze/lib/time.c has been remaining probably for a human mistake. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-02-19ARM: O5/dra7xx: Add SATA boot supportDan Murphy
Add the SATA boot support for OMAP5 and dra7xx. Renamed the omap_sata_init to the common init_sata(int dev) for commonality in with sata stack. Added the ROM boot device ID for SATA. Signed-off-by: Dan Murphy <dmurphy@ti.com> Reviewed-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-19Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-19imx6 SION bit has to be on for the pins that are used as ENET_REF_CLKAndy Ng
Signed-off-by: Andy Ng <andreas2025@gmail.com>
2014-02-19arm: zynq: correct the argument to lldivSiva Durga Prasad Paladugu
Typecast the argument with unsigned long long for proper calculation of lldiv Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Add support for U-BOOT SPLMichal Simek
SPL is using ps7_init.c/h files which are generated from design tools which have to be copied to boards/xilinx/zynq folder before compilation. BSS section is moved to SDRAM because fat support requires more space than SRAM size. Added: - MMC and QSPI support - Boot OS directly from SPL - Enable SPL command Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-02-19zynq: Update CLK in bdinfoMichal Simek
ARM has specific clk entries which should be also setup. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Implement dump clock commandSoren Brinkmann
Enable and implement dump clock command which shows soc frequencies. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19net: zynq_gem: Calculate clock dividers dynamicallySoren Brinkmann
Remove hard coded clock divider setting and use the Zynq clock framework to dynamically calculate appropriate dividers at run time. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19net: zynq_gem: Move RCLK details out of driverSoren Brinkmann
The GEM driver should not need to know about Zynq specific details of RCLK related registers and bitfields in the SLCR. Move those details to the slcr driver. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: timer: Fix hangs if network activity attempted after about one hourMichal Simek
Cortex-A9 MPCore TRM' from ARM (ARM DDI 0407G ID072711) describes in the section 4.1.1 how this value calculation should be done. This patch fixes the problem if network activity such as ping or tftp is attempted after u-boot has been idle for an hour, it hangs, and cannot control-C out of it. Signed-off-by: Uday Hegde <udayh@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: timer: Migrate to zynq clock frameworkSoren Brinkmann
Remove hardcoded frequencies in favor of Zynq clock framework. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Provide a framework to read clock frequenciesSoren Brinkmann
2014-02-19zynq: serial: Simplify serial driver initializationMichal Simek
Define both serial uarts in the driver and return default uart based on board configuration. - Move baseaddresses to hardware.h - Define default baudrate and clock values Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Move bootmode to headersMichal Simek
These numbers will be reused by SPL. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Enable dcache supportMichal Simek
Enable dcache. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19Merge branch 'u-boot-pxa/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-02-17Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2014-02-14ARM: bcm2835: fix mbox POWER_STATE_RESP_ON valueStephen Warren
Typo: The correct value is 1 not 2. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-02-13zynq: Fix elf header generationMichal Simek
This patch is here because of: "arm: keep all sections in ELF file" (sha1: 47ed5dd031d7d2c587e6afd386e79ccec1a1b7f7) Our tools expect to have elf with only LOAD header. Without this fix also PHDR, INTERP and DYNAMIC headers are available in ELF. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-13ARM: bcm2835: config.mk isn't neededStephen Warren
The entries in config.mk were needed so that U-Boot could be built with an old version of the Raspberry Pi Foundation's toolchain. Without them, the build would error out with: ...-ld: error: .../libgcc.a(_bswapsi2.o) uses VFP register arguments, u-boot does not However, none of the 3 toolchains in the latest version of their tools.git, nor the Ubuntu/Linaro ARM compilers in at least Ubuntu Quantal or Saucy, need these options set in order to compile a working U-Boot. Hence, remove the options for simplicity. Reported-by: Tom Rini <trini@ti.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Andreas Färber <afaerber@suse.de>
2014-02-13Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-11Merge branch 'master' of git://git.denx.de/u-boot-armStefano Babic
2014-02-11ARM: imx6: fix wrong fec clkMarkus Niebel
imx_get_fecclk() returns enet_ref instead of ipg. Since the clock is used to calculate the prescaler for the MDIO interface wrong values can be calculated. Tested on a custom MX6S board with 100MBit interface Signed-off-by: Markus Niebel <Markus.Niebel@tqs.de>
2014-02-11mx6: Enable L2 cache supportFabio Estevam
Add L2 cache support and enable it by default. Configure the L2 cache in the same way as done by FSL kernel: http://git.freescale.com/git/cgit.cgi/imx/linux-2.6-imx.git/tree/arch/arm/mach-mx6/mm.c?h=imx_3.0.35_4.1.0 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-02-11mx6: Distinguish mx6dual from mx6quadFabio Estevam
Currently when we boot a mx6dual U-boot reports that it is a mx6quad. Report it as MX6D instead: CPU: Freescale i.MX6D rev1.2 at 792 MHz Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano babic <sbabic@denx.de> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2014-02-11imx: Introduce a header for the imx cpu versionsFabio Estevam
Instead of duplicating the CPU definitions at mx5 and mx6 sys_proto.h header files, introduce a common header to centralize such definitions. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-02-11imx6: make sure MMDC_CHx_MASK is clear to avoid warm reset failureAnson Huang
Boot ROM may mask MMDC_CHx_MASK in CCM_CCDR(such as i.MX6SL TO1.2), it will cause warm reset fail, need to clear this MMDC_CHx_MASK field to make sure all the i.MX6 series SOCs reset function work. Otherwise, uboot "reset" command will fail, tested on i.MX6SL EVK board with TO1.2. Signed-off-by: Anson Huang <b20788@freescale.com>
2014-02-11imx6: ensure AHB clock is 132MHz in low freq boot modeAnson Huang
For low freq boot mode(ARM boot up with 396MHz), ROM will not set AHB clock to 132MHz, and the reset value of AHB divider is incorrect which will lead to wrong AHB rate, need to correct it. To enable low freq boot mode, need to set BOOT_CFG2[2] to high, tested on i.MX6Q/DL SabreSD board and i.MX6SL EVK board. Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Anson Huang <b20788@freescale.com>
2014-02-10exynos: clock: use the clear and set bits macros.Inha Song
Use setbits/clrbits macro instead of readl/writel function. (Suggested by Wolfgang) Signed-off-by: Inha Song <ideal.song@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-10exynos: clock: fixed that cfg is set to wrong value.Inha Song
This patch fixed that cfg value is set to wrong value. Because it didn't read the related register. Signed-off-by: Inha Song <ideal.song@samsung.com> Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-02-07SPL: Add CONFIG_SUPPORT_EMMC_BOOT support to CONFIG_SPL_FRAMEWORKTom Rini
We use the switch CONFIG_SUPPORT_EMMC_BOOT today to enable some additional features of the eMMC boot partitions. Add support for being told that we have booted from one of these partitions to the spl framework and implement this on TI OMAP/related. Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07MMC: DWMMC: Correct the CLKDIV register valueRajeshwari S Shinde
This patch corrects the divider value written to CLKDIV register. Since SDCLKIN is divided inside controller by the DIVRATIO value set in the CLKSEL register, we need to use the same output clock value to calculate the CLKDIV value. as per user manual: cclk_in = SDCLKIN / (DIVRATIO + 1) Input parameter to mmc_clk is changed to dwmci_host, since we need the same to read DWMCI_CLKSEL register. This improves the read timing values for channel 0 on SMDK5250 from 0.288sec to 0.144sec Signed-off-by: Rajeshwari S Shinde <rajeshwari.s@samsung.com> Acked-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-02-07arc: add library functionsAlexey Brodkin
These are library functions used by ARC700 architecture. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2014-02-07arc: add cpu filesAlexey Brodkin
2014-02-07arc: add architecture header filesAlexey Brodkin
These are header files used by ARC700 architecture. Also note that "arch-arc700/hardware.h" is only required for compilation of "designware_i2c" driver which refers to "asm/arch/hardware.h". It would be good to fix mentioned driver sometime soon but it will cause changes in ARM board configs that use "designware_i2c". Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Francois Bedard <fbedard@synopsys.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
