With the changes in commit 588efcdd72fc ("powerpc: Don't use relative
include for config.h in global_data.h") fixing the root of the problem,
we no longer need this re-inclusion.
This reverts commit f6c0d365d3e8ee8e4fd3ebe2ed957c2bca9d3328.
Cc: Matt Merhar <mattmerhar@protonmail.com>
As there is an arch/powerpc/include/asm/config.h file using "" to get
config.h here can lead to using that rather than include/config.h. This
in turn can lead to a mismatch in the size of gd.
Tested-by: Matt Merhar <mattmerhar@protonmail.com>
Linux uses the prefix "ethernet" whereas u-boot uses "eth". This is from
the linux tree:
$ grep "eth[0-9].*=.*&" arch/**/*dts{,i}|wc -l
0
$ grep "ethernet[0-9].*=.*&" arch/**/*dts{,i}|wc -l
633
In u-boot device trees both prefixes are used. Until recently the only
user of the ethernet alias was the sandbox test device tree. This
changed with commit fc054d563bfb ("net: Introduce DSA class for Ethernet
switches"). There, the MAC addresses are inherited based on the devices
sequence IDs which is in turn given by the device tree.
Before there are more users in u-boot and both worlds will differ even
more, rename the alias prefix to "ethernet" to match the linux ones.
Also adapt the test cases and rename any old aliases in the u-boot
device trees.
Cc: David Wu <david.wu@rock-chips.com>
Signed-off-by: Michael Walle <michael@walle.cc>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- fsl-qoriq: Bug fixes related pfe, eth, thermal node, vid.c, cpu release,
mmc, usb, env, etc for Layerscape boards
- powerpc: Update Maintainers for some boards.
- ae350 related dts fixes.
Change the USB erratum number A-050106 to A-050204 as A-050106 is
a duplicate and never be published.
Fixes 0cfa00cdb94 (“armv8: Add workaround for USB erratum A-050106”)
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
Under DM, we rely on u-boot's device tree to provide the correct PHY
addresses. The board_fix_fdt callback is intended to be used for
device tree fixups before relocation. Unfortunately, this isn't an
option when booting from flash since the device tree isn't writable
before relocation.
This patch introduces the CONFIG_T2080RDB_REV_D option to signal that a
board revision D or up is the target. The config option is used to set
the correct Aquantia PHY address in the board's u-boot device tree.
Defconfig files with the option enable explicitly are added for
convenience.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
The EXPU1 design is a new 40G capable ethernet service unit card for
Hitachi-Powergrids wired-com product lines.
The base SoC is same as for already added SELI8 card, consequently the
already added u-boot support for SELI8 is reused.
Signed-off-by: Rainer Boschung <rainer.boschung@hitachi-powergrids.com>
Signed-off-by: Aleksandar Gerasimovski <aleksandar.gerasimovski@hitachi-powergrids.com>
[Fixed new line error at EOF]
Address and size cells on SOC are set to 1. But gpio nodes are specified
with 2 cells. This fixes the gpio nodes to correct cells.
Signed-off-by: Lasse Klok Mikkelsen <lkmi@prevas.dk>
Reviewed-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Add properties related to eMMC HS400 mode for esdhc1.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Read Linux PPFE firmware from flash partition and pass it to Linux through
FDT entry. So that we can avoid placing PPFE firmware in Linux rootfs.
(FDT may increase at max by 64KB)
Signed-off-by: Chaitanya Sakinam <chaitanya.sakinam@nxp.com>
Signed-off-by: Anji J <anji.jagarlmudi@nxp.com>
Signed-off-by: Biwen Li <biwen.li@nxp.com>
Enable eMMC HS400 workarounds for LX2160A/LX2162A.
For cpu release command, check whether PSCI is supported firstly,
if supported, use PSCI to kick off secondary cores, otherwise still
use spin table.
Signed-off-by: Jiafei Pan <Jiafei.Pan@nxp.com>
[Fixed checkpatch alignment CHECKs]
Current logic in riscv_get_ipi() for Andes PLICSW does not look
correct. The mask to test IPI pending bits for a hart should be
left shifted by (8 * gd->arch.boot_hart), just the same as what
is done in riscv_send_ipi().
Fixes: 8b3e97badf97 ("riscv: add functions for reading the IPI status")
Reviewed-by: Rick Chen <rick@andestech.com>
Tested-by: Rick Chen <rick@andestech.com>
At present the AE350 SPL defconfig is using OF_PRIOR_STAGE. The
intention was to use gdb to load device tree before running U-Boot
SPL/proper from RAM. When we switch to OF_SEPARATE we will have to
use our own DT but without "u-boot,dm-spl" in several essential
nodes, SPL does not boot.
Let's add all the required "u-boot,dm-spl" for SPL config.
All the device nodes that refer to plic0 as their interrupt parent
have 2 cells encoded in their interrupts property, but plic0 only
provides 1 cell in #interrupt-cells which is incorrect.
Reviewed-by: Leo Yu-Chi Liang <ycliang@andestech.com>
PLIC nodes don't have child nodes, so #address-cells is not needed.
There are two spaces before "debug' in bootargs. Drop one.
The SPDX license header is currently missing. Add one.
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
u-boot-imx-20210616
- imxrt : fixes, USB, imxrt1020-evk
- imx8m:
fix for verdin-imx8mm
Add conga-QMX8 board
- imx6 :
documentation for pico-imx6:
Add SeeedStudio NPI-IMX6ULL Support
ventana: DM PCI
- imx7d:
added SMEGW01 board
CI : https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/7765
It was noticed that the clock isn't continuously enabled when there is
no link. This is because the 125MHz clock is derived from the internal
PLL which seems to go into some kind of power-down mode every once in a
while. The LS1028A expects a contiuous clock. Thus enable the PLL all
the time.
Also, the RGMII pad voltage is wrong, it was configured to 2.5V (that is
the VDDH regulator). The correct voltage is 1.8V, i.e. the VDDIO
regulator.
https://source.denx.de/u-boot/custodians/u-boot-microblaze
Xilinx changes for v2021.07-rc5
zynqmp:
- Fix ANALOG_BUS value after powerup
- Disable EFI_CAPSULE_ON_DISK_EARLY
zynqmp-gqspi:
- Fix write issue
The default register configuration after powerup for PSSYSMON_ANALOG_BUS
register is incorrect. Hence, fix this in SPL by writing correct fixed
value. It follows UG1085 chapter 'PS SYSMON Analog_Bus' and reflects commit
sw_apps:zynq ("056ca65d44549ce27f716d423e8dfdefeee7440c")
in Xilinx:embeddedsw[1].
[1] https://github.com/Xilinx/embeddedsw
Signed-off-by: Adrian Fiergolski <adrian.fiergolski@fastree3d.com>
Add nodes for SPI NOR partitions to the device tree of Turris MOX, as
are in Linux' device tree.
Signed-off-by: Marek Behún <marek.behun@nic.cz>
Add nodes for indicator LED and reset button so that board code can
implement board factory reset mechanism.
Reviewed-by: Pali Rohár <pali@kernel.org>
Add support for Storopack's SMEGW01 board, which is an
IoT gateway based on the i.MX7D SoC.
Based on the original U-Boot work done by Phytec.
Signed-off-by: Fabio Estevam <festevam@denx.de>
CPU: Freescale i.MX6ULL rev1.1 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 49C
Reset cause: POR
Model: Seeed NPi iMX6ULL Dev Board with NAND
Board: Seeed NPi i.MX6ULL Dev Board
DRAM: 512 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
In: serial@2020000
Out: serial@2020000
Err: serial@2020000
Net: FEC0
Working:
- Eth0
- MMC/SD
- NAND
- UART 1
- USB host
Signed-off-by: Navin Sankar Velliangiri <navin@linumiz.com>
Note:
Changes in v2:
* removed unnecessary space in imx6ull-seeed-npi-imx6ull-dev-board.dts file.
* Used SZ_2M for CONFIG_SYS_MALLOC_LEN size allocation.
Add i.MX8QM qmx8 congatec board support
U-Boot 2021.07-rc3-00528-gc9a966d9dd (May 31 2021 - 15:21:25 +0200)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
Model: Congatec QMX8 Qseven series
Board: conga-QMX8
Build: SCFW 494c97f3, SECO-FW d63fdb21, ATF 09c5cc9
Boot: SD2
DRAM: 6 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... OK
In: serial@5a060000
Out: serial@5a060000
Err: serial@5a060000
switch to partitions #0, OK
mmc2 is current device
Net:
Error: ethernet@5b040000 address not set.
No ethernet found.
Hit any key to stop autoboot: 0
Signed-off-by: Oliver Graute <oliver.graute@kococonnector.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Ye Li <ye.li@nxp.com>
Cc: uboot-imx <uboot-imx@nxp.com>
Frequency requested by ddrphy_init_set_dfi_clk from fracpll uses MHZ()
macro, which expands the value provided to the Hz range without taking into
account the precise Hz setting. This causes the frequency of 266 MHz not ot
be found in the imx8mm_fracpll_tbl, since it is entered there with a
precise Hz value. This in turn causes the boot hang in SPL, as proper DDR
fracpll frequency cannot be determined.
Correct the value in imx8mm_fracpll_tbl to match the one expanded by
MHZ(266) macro, rounding it down to MHz range only.
Signed-off-by: Andrey Zhizhikin <andrey.zhizhikin@leica-geosystems.com>
Cc: "NXP i.MX U-Boot Team" <uboot-imx@nxp.com>
Fixes: 825ab6b406 ("driver: ddr: Refine the ddr init driver on imx8m")
Enable driver model support for FEC ethernet which allows us to remove
the iomux and board_eth_init function. Replace the toggling of the ethernet
phy reset with dt configuration.
Enable driver model support for PCI which allows us to remove the
eth1000_initialize() call. Additionally enable PCI_INIT_R to scan for
PCI devices on init such as the e1000 that is present on the GW552x.
Convert board_pci_fixup to use dm callback and remove pcidisable env
variable which is not supported for DM_PCI and thus leave PCI always
enabled during init.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Clock initialization functionality has ambitious debug messages, which are
printed out when failures are triggered during execution:
- Separate frequency table lookup functions have the the same output that
makes it impossible to understand which function failed and produced the
output
- PLL decoding routine has a generic debug statement printed, which does
not state the actual value failed to be found
Extend the output for both cases with prefixing table lookup functions
output with function name, and report the failed value in PLL decoding
routine.
A simple prototyping board with one microSD port, one Ethernet port,
2 USB ports, I2C, SPI, GPIO, and UART interfaces.
Signed-off-by: Oleh Kravchenko <oleg@kaa.org.ua>
Board designed for quick prototyping and has one microSD port,
2 Ethernet ports, 2 USB ports, I2C, SPI, CAN, RS-485, GPIO,
UART interfaces, and 2 RGB LEDs.
Enable usbotg1 port node as host usb.
Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
Usb is now supported so add all required nodes for it in imxrt1050.
Add support for usb1 and usb2 present on i.IMXRT.
We need those macros to instruct drivers on how to behave for SoC specific
quirks, so let's add it as done for other i.MX SoCs.
i.MXRT1020 supports gpio5, so let's add a node for it.
imxrt1020-evk-u-boot.dtsi file
At the moment a lot of u-boot,dm-spl properties are present in board .dts
file but this is not correct since u-boot,dm-spl property is u-boot
specific and must be listed into the separate imrt1020-evk-u-boot.dtsi
file. So let's move every u-boot,dm-spl property present in
imxrt1020-evk.dts to imxrt1020-evk-u-boot.dtsi file.
imxrt1050-evk-u-boot.dtsi file
specific and must be listed into the separate imrt1050-evk-u-boot.dtsi
imxrt1050-evk.dts to imxrt1050-evk-u-boot.dtsi file.
We don't need lcdif to be enable in SPL, so let's remove u-boot,dm-spl.
Lcdif needs both "pix" and "axi" clocks to be enabled so let's add them to
lcdif node.
Since we assume pll5 is the default lcdif clock source let's move
assigned-clocks(-parents) properties to .dtsi file.
Now device_type = "memory" is mandatory to allow u-boot to read memory
node, so let's add it to memory node.
Timer needs to be already enabled in spl, so let's add its node to spl dtb.
Let's set gpt1 as u-boot timer.
Enable gpt1 timer.
Add gpt1 node for using it as timer.
Let's add node label to osc to be used as clock source for other nodes.
