Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
This is long over due. All but two net drivers have been converted, but
those have now been dropped.
The only thing left to do is actually delete all references to NET_MULTI
and code that is compiled when that is not defined. So here we scrub the
core code.
This pushes the ugly duplicated arch ifdef lists we maintain in various
image related files out to the arch headers themselves.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
The current post_log_word in global data is currently split into 2x
16 bits: half for the test start, half for the test success.
Since we alredy have more than 16 POST tests defined and more could
be defined, this may result in an overflow and the post_output_backlog
would not work for the tests defined further of these 16 positions.
An additional field is added to global data so that we can now support up
to 32 (depending of architecture) tests. The post_log_word is only used
to record the start of the test and the new field post_log_res for the
test success (or failure). The post_output_backlog is for this change
also adapted.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
For post to run on ARM, 3 things are needed:
- post_log_word to be defined in gd
- a post.h include in arch/arm/lib/board.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Allow redirection of console output prior to console initialisation to a
temporary buffer.
To enable this functionality, the board (or arch) must define:
- CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer
- CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer
- CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes)
The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes
Any earlier characters are silently dropped.
* 'master' of git://git.denx.de/u-boot-mpc85xx:
powerpc/p3060: Add SoC related support for P3060 platform
powerpc/85xx: Add support for setting up RAID engine liodns on P5020
powerpc/85xx: Refactor some defines out of corenet_ds.h
fm-eth: Add ability for board code to disable a port
powerpc/mpc8548: Add workaround for erratum NMG_LBC103
powerpc/mpc8548: Add workaround for erratum NMG_DDR120
powerpc/mpc85xxcds: Fix PCI speed
powerpc/mpc8548cds: Fix booting message
powerpc/p4080: Add support for secure boot flow
powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASH
powerpc/85xx: Add PBL & SECUREBOOT support on P3041/P5020DS boards
powerpc/p2041rdb: remove watch dog related codes
powerpc/p2041rdb: updated description of cpld command
powerpc/p2041rdb: add more ddr frequencies support
powerpc/p2041rdb: set sysclk according to status of physical switch SW1
powerpc/p2041rdb: update cpld reset command according to CPLD 2.0
powerpc/mpc8349emds: Migrate from spd_sdram to unified DDR driver
powerpc/mpc83xx: Migrate from spd_sdram to unified DDR driver
powerpc/mpc8xxx: Add DDR2 to unified DDR driver
powerpc/mpc8xxx: Fix picos_to_mclk() and get_memory_clk_period_ps()
powerpc/mpc8xxx: Add SPD EEPROM address for single controller 2 slots
powerpc/mpc8xxx: Fix DDR code for empty first DIMM slot and enable DQS_en
powerpc/85xx: Refactor P2041RDB to use common p_corenet files
powerpc/85xx: refactor common P-Series CoreNet files for FSL boards
powerpc/85xx: Enable CMD_REGINFO on corenet boards
powerpc/85xx: p2041rdb - Remove unused 'execute' perm in TLB entries
powerpc/85xx: Fix USB protocol definitions for P1020RDB
powerpc/corenet_ds: Use separated speed tables for UDIMM and RDIMM
powerpc/mpc8xxx: Move DDR RCW overriding to common code
powerpc/mpc8xxx: Extend CWL table
powerpc/85xx: Cleanup how SVR_MAJ() is defined on MPC8536
powerpc/85xx: Cleanup extern in corenet_ds board code
powerpc/p2041rdb: Add ethernet support on P2041RDB board
powerpc/85xx: Add networking support to P1023RDS
powerpc/hydra: Add ethernet support on P5020/P3041 DS boards
powerpc/85xx: Add FMan ethernet support to P4080DS
powerpc/85xx: Add support for FMan ethernet in Independent mode
powerpc/mpc8548cds: Cleanup mpc8548cds.c
powerpc/mp: add support for discontiguous cores
powerpc/85xx: corenet_ds - Remove unused 'execute' perm in TLB entries
fdt: Add new fdt_create_phandle helper
fdt: Rename fdt_create_phandle to fdt_set_phandle
powerpc/85xx: Fix compile warnings/errors if CONFIG_SYS_DPAA_FMAN isn't set
fsl_ifc: Add the workaround for erratum IFC A-003399(enabled on P1010)
powerpc/P1010: Add workaround for erratum P1010-A003549 (related to IFC)
fsl_ifc: Add the workaround for erratum IFC-A002769 (enable on P1010)
powerpc/85xx: Expanding the window of CCSRBAR in AS=1 from 4k to 1M
powerpc/85xx: Add NAND/NAND_SPL support to P1010RDB
nand: Freescale Integrated Flash Controller NAND support
powerpc/85xx: Add basic support for P1010RDB
powerpc/85xx: Add support for new P102x/P2020 RDB style boards
powerpc/85xx: relocate CCSR before creating the initial RAM area
powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macros
powerpc/85xx: Enable internal USB UTMI PHY on p204x/p3041/p50x0
powerpc/85xx: Add ULPI and UTMI USB Phy support for P1010/P1014
Add P3060 SoC specific information:cores setup, LIODN setup, etc
The P3060 SoC combines six e500mc Power Architecture processor cores with
high-performance datapath acceleration architecture(DPAA), CoreNet fabric
infrastructure, as well as network and peripheral interfaces.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Add support for Job Queue/Ring LIODN for the RAID Engine on P5020. Each
Job Queue/Ring combo needs one id assigned for a total of 4 (2 JQs/2
Rings per JQ). This just handles RAID Engine in non-DPAA mode.
Signed-off-by: Santosh Shukla <santosh.shukla@freescale.com>
The erratum NMG_LBC103 is LBIU3 in MPC8548 errata document.
Any local bus transaction may fail during LBIU resynchronization
process when the clock divider [CLKDIV] is changing. Ensure there
is no transaction on the local bus for at least 100 microseconds
after changing clock divider LCRR[CLKDIV].
Refer to the erratum LBIU3 of mpc8548.
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
Erratum NMG_DDR120 (DDR19 in MPC8548 errata document) applies to some
early version silicons. The default settings of the DDR IO receiver
biasing may not work at cold temperature. When a failure occurs,
a DDR input latches an incorrect value. The workaround will set the
receiver to an acceptable bias point.
Signed-off-by: Gong Chen
Pre u-boot Flow:
1. User loads the u-boot image in flash
2. PBL/Configuration word is used to create LAW for Flash at 0xc0000000
(Please note that ISBC expects all these addresses, images to be
validated, entry point etc within 0 - 3.5G range)
3. ISBC validates the u-boot image, and passes control to u-boot
at 0xcffffffc.
Changes in u-boot:
1. Temporarily map CONFIG_SYS_MONITOR_BASE to the 1M
CONFIG_SYS_PBI_FLASH_WINDOW in AS=1.
(The CONFIG_SYS_PBI_FLASH_WINDOW is the address map for the flash
created by PBL/configuration word within 0 - 3.5G memory range. The
u-boot image at this address has been validated by ISBC code)
2. Remove TLB entries for 0 - 3.5G created by ISBC code
3. Remove the LAW entry for the CONFIG_SYS_PBI_FLASH_WINDOW created by
PBL/configuration word after switch to AS = 1
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Signed-off-by: Kuldip Giroh <kuldip.giroh@freescale.com>
Acked-by: Wood Scott-B07421 <B07421@freescale.com>
- Remove code copying
- Reset address is setup from first stage bootloader
- Support reset vector setup on little endian
Use one memory space to detect little/big endian platforms.
The first unused address(0x28) is used instead 0x0 address (reset vectors).
Detection rewrited reset vector setup from first stage bootloader.
Workflow:
1. Store 0x28 to r7
2. Do little/big endian test
3. Restore r7 to 0x28
For example: Setup reset vectors if reset address is setup.
Setup user exception vector if user exception is enabled
Forget to remove debug code.
The EST SBC8260 is over 10 years old, and the SBC8240 older than
that. With the tiny amount of RAM (by today's standards), there
really isn't anyone interested in running the latest U-boot on
these EOL products anymore.
CC: jon.diekema@smiths-aerospace.com
There are some locations in the code which anticipate printf() being called
before the console is ready by squelching printf() on gd->have_console.
Move this squelching into printf(), vprintf(), puts() and putc(). Also
make tstc() and getc() return 0 if console is not yet initialised
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
* 'post' of git://git.denx.de/u-boot-blackfin:
Blackfin: uart: implement loop callback for post
Blackfin: bf537-stamp/bf548-ezkit: update POST flash block range
Blackfin: post: generalize led/button tests with GPIOs
Blackfin: bf537-stamp: drop uart/flash post tests
Blackfin: post: drop custom test list
Blackfin: bf537-stamp: convert to gpio post hotkey
When building the zmx25 target we get:
Configuring for zmx25 board...
generic.c:108: warning: 'get_reset_cause' defined but not used
Fix this warning by defining get_reset_cause only if CONFIG_DISPLAY_CPUINFO is defined.
The new output looks like this:
> clocks
PLL1 800 MHz
PLL2 665 MHz
PLL3 216 MHz
AHB 133000 kHz
IPG 66500 kHz
IPG PERCLK 665000 kHz
Acked-by: Jason Liu <jason.hui@linaro.org>
Cc: Jason Liu <jason.hui@linaro.org>
The PLL decoding algorithm didn't take into account many configuration bits.
Adjust it according to Linux kernel. Also, add PLL4 for MX53.
Cc: Jason Hui <jason.hui@linaro.org>
Tested-by: Jason Liu <Jason.hui@linaro.org>
Cc: Ben Warren <biggerbadderben@gmail.com>
Cc: Detlev Zundel <dzu@denx.de>
Turn on the watchdog WDZST bit so that watchdog timer does not count during low power modes.
Prior to applying this patch mx31pdk board got watchdog resets because when it booted in the Linux prompt
and there was no activity, the system entered into idle mode while watchdog timer was still active.
Fix this by disabling watchdog timer during idle mode.
Avoid the usage of extern in C file as pointed out by checkpatch.
Currently the reset cause is printed like:
CPU: Freescale i.MX31 rev 2.0 at 531 MHz.Reset cause: POR
Improve readability by adding a new line like it is done on other i.MX boards.
Print the source of reset during boot.
Print the silicon revison during boot.
Cc: Paulraj Sandeep <s-paulraj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
to add the "NOR Boot Configuration Word" on AM18xx based boards,
define CONFIG_SYS_DV_NOR_BOOT_CFG.
Building without option CONFIG_DISPLAY_CPUINFO leads to
this warning:
sys_info.c:50:14: warning: 'rev_s_37xx' defined but not used
Signed-off-by: Sanjeev Premi <premi@ti.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Config VMMC voltage to 3V for MMC/SD card slot
and PBIAS settings needed for OMAP4
Fixes MMC/SD detection on boot from eMMC.
Signed-off-by: Balaji T K <balajitk@ti.com>
Signed-off-by: Aneesh V <aneesh@ti.com>
Found a build erros when i ran MAKEALL.
So fix it.
split-up spl.c into spl.c, spl_mmc.c and spl_nand.c. This avoids problems
with missing defines if a board does not use mmc or nand. This includes
adding spl_ prefix to some functions which are now public. spl_image_t is now
a public type. Added some of the common functions to omap-common.h
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Implements the saving of boot params passed by OMAP3 ROM code.
Support for the new spl structure. Using the interface defined by Aneesh V for
OMAP4
Add NAND support for the new SPL structure.
OMAP3 relied on the memory config done by X-loader or Configuration Header. This
has to be reworked for the implementation of a SPL. This patch configures RAM
bank 0 if CONFIG_SPL_BUILD is set. Settings for Micron-RAM used by devkit8000
are added to mem.h
Moves the early UART clock setup setup_clocks_for_console() from
preloader_console_init() to s_init() of OMAP4.
This is done to prepare for OMAP3 integration.
This patch was posted seperatly to the mailinglist but I decidet - since it is
a prereqesit for this patch to add it. Former port to ML:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/104395
