path: root/arch
2015-10-23nios2: Split timer code into timer.cThomas Chou
Move the timer code from interrupts.c into timer.c . Eliminate the installation of timer interrupt handler, which is no longer used. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: Switch to generic timerThomas Chou
Zap almost all of the ad-hoc timer code from interrupts.c and use the code in lib/time.c instead. Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: enable device tree control of U-BootThomas Chou
This patch adds device tree control of U-Boot to nios2 boards. The example dts is taken from Linux kernel. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: define _end in link scriptThomas Chou
Since commit 44c6e6591cb451ae606f8bde71dd5fb7b4002544 "rename _end to __bss_end__" , the _end was removed. But we need it now for separated device tree control, ie, CONFIG_OF_SEPARATE . The _end is used by fdtdec_setup() to find the blob. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-10-23nios2: remove gp assignments in link scriptThomas Chou
Since we don't use gp for small data with option "-G0", we use gp as global data pointer. The _gp location is not needed. The ALIGN(16) was for gp only. It is removed, so that we can get correct address of dtb in u-boot-dtb.bin image. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: enlarge the code relocation rangeThomas Chou
As we will use u-boot-dtb.bin, the code relocation range should be adjusted to accommodate the additional dtb. It might be overkilled to look into dtb header to find the dtb size, so we will simply use CONFIG_SYS_MONITOR_LEN. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2015-10-23nios2: BSS should be cleared only after board_init_fThomas Chou
As dtb in u-boot-dtb.bin overlapped the BSS section, we should delay the clearing of BSS until dtb is relocated in board_init_f(). Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Marek Vasut <marex@denx.de>
2015-10-23nios2: permit device tree control of U-BootThomas Chou
Enable this in the Kconfig so that nios2 boards can use device tree to configure U-Boot. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-10-22am437x: Add am57xx_evm_defconfig using CONFIG_DMMugunthan V N
Import various DT files for am57xx-beagle-x15 from Linux Kernel v4.2 Add config file for this board, enable DM, DM_GPIO, DM_SERIAL and DM_MMC. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-10-22am437x: Add am437x_sk_evm_defconfig using CONFIG_DMMugunthan V N
Import various DT files for am437x-sk-evm from Linux Kernel v4.2 Add config file for this board, enable DM, DM_GPIO, DM_SERIAL and DM_MMC. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22am437x: Add am437x_gp_evm_defconfig using CONFIG_DMMugunthan V N
Import various DT files for am4372, an43xx pinctrl and am437x-gp-evm from Linux Kernel v4.2 Add config file for this board, enable DM, DM_GPIO, DM_SERIAL and DM_MMC. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22omap_hsmmc: update struct hsmmc to accomodate base address from DTMugunthan V N
Existing driver gets the actual omap hammc base address + 0x100 bytes as the first 0x100 bytes is not used by the driver. But with DM conversion the base address from DT is different, to accommodate the offset adding res0[0x100] to struct hsmmc. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22dra7xx: Add dra74_evm_defconfig using CONFIG_DMMugunthan V N
Import various DT files for dra7-evm from Linux Kernel v4.2 Add config file for this board, enable DM and DM_GPIO Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22ARM: dts: k2g: Add DT supportLokesh Vutla
Add basic DT support for k2g evm. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: add SD card and eMMC supportRoger Quadros
Add MMC support for k2g Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-10-22driver: net: keystone_net: add support for rgmii phyVitaly Andrianov
In K2G, Ethernet doesn't support SGMII instead it support RGMII, adding support to the driver to connect to RGMII phy. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22driver: net: keystone_net: fix phy mode configurationMugunthan V N
Phy mode is a board property and it can be different between multiple board and ports, so it should not be hardcoded in driver to one specific mode. So adding a field in eth_priv_t structure to pass phy mode to driver. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: update keystone nav rx queue numbersVitaly Andrianov
update K2G nav rx queue number Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Correct base addressesVitaly Andrianov
Coreect base addresses for SPI, Queue Manager, Ethernet, GPIO, and MSMC segments. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add support for pin mux configurationVitaly Andrianov
Add api for configuring pin mux. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add ddr3 infoVitaly Andrianov
Add ddr3 related info Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add PSC infoVitaly Andrianov
Add psc information for k2g Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add clock informationVitaly Andrianov
Add clock information for Galileo Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2015-10-22ARM: k2g: Add pll dataVitaly Andrianov
Add pll data for k2g Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add kconfig supportLokesh Vutla
Add Kconfig support Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: k2g: Add support for CPU detectionLokesh Vutla
Adding CPU detection support for Keystone2 Galileo. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: keystone2: Use dtb images by defaultLokesh Vutla
Now that OF_CONTROL is enabled on all keystone2 platforms, build the default images with DT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: dts: k2e: Enable OF_CONTROL and DMLokesh Vutla
Import k2e specific DT files from Linux Kernel and enable OF_CONTROL, DM, DM_SERIAL. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: dts: k2l: Enable OF_CONTROL and DMLokesh Vutla
Import k2l specific DT files from Linux Kernel and enable OF_CONTROL, DM, DM_SERIAL. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: dts: k2hk: Enable OF_CONTROL and DMLokesh Vutla
Import k2hk specific DT files from Linux Kernel and enable OF_CONTROL, DM, DM_SERIAL. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: dts: keystone2: Do not use LPAE addresses in U-BootLokesh Vutla
Keystone dts files assumes that LPAE is enabled and top level root node uses 64bit addresses. This breaks the keystone boot with CONFIG_OF_CONTROL enabled. So do not use 64 bit addresse in U-Boot DT. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: dts: Keystone2: Import generic dt files from Linux KernelLokesh Vutla
Import various generic dts files from Linux kernel so that all keystone2 platforms can be DT in U-boot. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22ARM: keystone2: Fix serial port initLokesh Vutla
With CONFIG_DM_SERIAL is enabled NS16550_init() cannot be called directly. Driver probe should be taking care of this. So call this function only when DM_SERIAL is not enabled. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-10-22sandbox: Introduce dummy remoteproc nodesNishanth Menon
Introduce dummy devices for sandbox remoteproc device and enable it by default Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-22omap-common: Common get_board_serial function to pass serial through ATAGPaul Kocialkowski
Since there is a common function to grab the serial number from the die id bits, it makes sense have one to parse that serial number and feed it to the serial ATAG. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap-common: Common serial and usbethaddr functions based on die idPaul Kocialkowski
Now that we have a common prototype to grab the omap die id, functions to figure out a serial number and usb ethernet address can use it directly. Those also get an omap_die_id prefix for better consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap5: omap_die_id supportPaul Kocialkowski
This introduces omap5 support for omap_die_id, which matches the common omap_die_id definition. It replaces board-specific code to grab the die id bits. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap4: omap_die_id supportPaul Kocialkowski
This introduces omap4 support for omap_die_id, which matches the common omap_die_id definition. It replaces board-specific code to grab the die id bits. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap3: omap_die_id supportPaul Kocialkowski
This replaces the previous get_dieid definition with omap_die_id, that matches the common omap_die_id definition. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap-common: Common omap_die_id definitionPaul Kocialkowski
This introduces a common definition for omap_die_id, that aims at providing a common interface for accessing omap platform's die id bits. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-21Merge git://git.denx.de/u-boot-x86Tom Rini
2015-10-21x86: Add support for Advantech SOM-6896George McCollister
Advantech SOM-6896 is a Broadwell U based COM Express Compact Module Type 6. This patch adds support for it as a coreboot payload. On board SATA and SPI are functional. On board Ethernet isn't functional but since it's optional and ties up a PCIe x4 that is otherwise brought out, this isn't a concern at the moment. USB doesn't work since the xHCI driver appears to be broken. Signed-off-by: George McCollister <george.mccollister@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-21x86: ivybridge: Enable the MRC cacheBin Meng
This works correctly now, so enable it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Dropped malloc() and adjusted commit message: Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: ivybridge: Measure the MRC code execution timeSimon Glass
This code takes about 450ms without the MRC cache and about 27ms with the cache. Add a debug timer so that this time can be displayed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: ivybridge: Fix car_uninit() to correctly set run stateSimon Glass
At present a missing $ causes this code to hang when using the MRC cache/ Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: ivybridge: Check the RTC return valueSimon Glass
The RTC can fail, so check the return value for reads. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: ivybridge: Use 'ret' instead of 'rcode'Simon Glass
For consistency, use 'ret' to handle a return value. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: chromebook_link: Enable the debug UARTSimon Glass
Add support for the debug UART on link. This is useful for early debugging. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-21x86: Init the debug UART if enabledSimon Glass
If the debug UART is enabled, get it ready for use at the earliest possible opportunity. This is not actually very early, but until we have a stack it is difficult to make it work. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
