path: root/arch/xtensa
2018-02-23xtensa: clean up CONFIG_SYS_TEXT_ADDRMax Filippov
Drop CONFIG_SYS_MEMORY_TOP. Rename CONFIG_SYS_TEXT_ADDR to XTENSA_SYS_TEXT_ADDR. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
2017-10-02xtensa: Use asm-generic/io.hPaul Burton
Convert the xtensa architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for xtensa this is primarily a matter of moving code. This has only been build-tested, feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Max Filippov <jcmvbkbc@gmail.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Make relocation functions genericSimon Glass
This header file is used by three archs. It could be used by all of them since relocation is a common function. Move it into a generic file. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-23Remove arch/${ARCH}/include/asm/errno.hMasahiro Yamada
Unlike Linux, nothing about errno.h is arch-specific in U-Boot. As you see, all of arch/${ARCH}/include/asm/errno.h is just a wrapper of <asm-generic/errno.h>. Actually, U-Boot does not export headers to user-space, so we just have to care about the consistency in the U-Boot tree. Now all of include directives for <asm/errno.h> are gone. Deprecate <asm/errno.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-09-23arch, board: squash lines for immediate returnMasahiro Yamada
Remove unneeded variables and assignments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com> Reviewed-by: Angelo Dureghello <angelo@sysam.it>
2016-08-15xtensa: add support for the 'xtfpga' evaluation boardChris Zankel
The 'xtfpga' board is actually a set of FPGA evaluation boards that can be configured to run an Xtensa processor. - Avnet Xilinx LX60 - Avnet Xilinx LX110 - Avnet Xilinx LX200 - Xilinx ML605 - Xilinx KC705 These boards share the same components (open-ethernet, ns16550 serial, lcd display, flash, etc.). Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add core information for the de212 processorMax Filippov
DE212 is a general purpose xtensa processor without full MMU. Core information files are autogenerated from the processor description and are not meant to be edited. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add core information for the dc233c processorMax Filippov
DC233C is an xtensa processor with full MMUv3 capable of running Linux. Core information files are autogenerated from the processor description and are not meant to be edited. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add core information for the dc232b processorChris Zankel
DC232B is an xtensa processor with full MMUv2 capable of running Linux. Core information files are autogenerated from the processor description and are not meant to be edited. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15xtensa: add support for the xtensa processor architecture [2/2]Chris Zankel
The Xtensa processor architecture is a configurable, extensible, and synthesizable 32-bit RISC processor core provided by Tensilica, inc. This is the second part of the basic architecture port, adding the 'arch/xtensa' directory and a readme file. Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
