path: root/arch/x86
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-18fdt: Implement weak arch_fixup_fdt()Alexey Brodkin
Only ARM and in some configs MIPS really implement arch_fixup_fdt(). Others just use the same boilerplate which is not good by itself, but what's worse if we try to build with disabled CONFIG_CMD_BOOTM and enabled CONFIG_OF_LIBFDT we'll hit an unknown symbol which was apparently implemented in arch/xxx/lib/bootm.c. Now with weak arch_fixup_fdt() right in image-fdt.c where it is used we get both items highlighted above fixed. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2018-01-30x86: quark: Fix unused warningsTom Rini
The variable t_rfc is never used, so drop it. The variables ddr_wctl and ddr_wcmd are only used in certain manual instances, so guard their declaration by the same check as their use. Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-30x86: acpi: Use an API to get the ACPI RSDP table addressBin Meng
At present the acpi_rsdp_addr variable is directly referenced in setup_zimage(). This changes to use an API for better encapsulation and extension. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2018-01-30x86: zImage: Propagate acpi_rsdp_addr to kernel via boot parametersAndy Shevchenko
New field acpi_rsdp_addr, which has been introduced in boot protocol v2.14 [1], in boot parameters tells kernel the exact address of RDSP ACPI table. Knowing it increases robustness of the kernel by avoiding in some cases traversal through a part of physical memory. It will slightly reduce boot time by the same reason. [1] See Linux kernel commit 2f74cbf ("x86/boot: Add the ACPI RSDP address to struct setup_header::acpi_rdsp_addr") @ https://git.kernel.org/pub/scm/linux/kernel/git/tip/tip.git/commit/?id=2f74cbf for the details. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: updated the kernel commit git URL and fixed one style issue] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-30x86: zImage: Move subarch assignment out of cmd_line checkAndy Shevchenko
The commit 20bfac0599bd ("x86: zImage: add Intel MID platforms support") introduced an assignment of subarch field in boot parameters, though missed the right place of doing that. It doesn't matter if we have or not a kernel command line supplied, we just set that field. Although guard it by protocol version which supports it. Fixes: 20bfac0599bd ("x86: zImage: add Intel MID platforms support") Cc: Vincent Tinelli <vincent.tinelli@intel.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-30x86: Fix reference to QEMU variant of write_acpi_tables()Andy Shevchenko
The commit eece493a7ac1 ("cmd: qfw: bring ACPI generation code into qfw core") moves ACPI related code to another file and missed an update of references in acpi_table.c. Do it now. Fixes: eece493a7ac1 ("cmd: qfw: bring ACPI generation code into qfw core") Cc: Miao Yan <yanmiaobest@gmail.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-30x86: tangier: Make _CRS for BTH0 Serialized to avoid warningAndy Shevchenko
ASL compiler warns: ASL board/intel/edison/dsdt.asl board/intel/edison/dsdt.asl.tmp 238: Method (_CRS, 0, NotSerialized) Remark 2120 - Control Method should be made Serialized ^ (due to creation of named objects within) Do as suggested by ASL compiler. Fixes: 5d8c4ebd95e2 ("x86: tangier: Add Bluetooth to ACPI table") Reported-by: Ferry Toth <fntoth@gmail.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-01-08x86: tangier: Add Bluetooth to ACPI tableAndy Shevchenko
As defined on reference board followed by Intel Edison a Bluetooth device is attached to HSU0, i.e. PCI 0000:04.1. Describe it in ACPI accordingly. Note, we use BCM2E95 ID here as one most suitable for such device based on the description in commit message of commit 89ab37b489d1 ("Bluetooth: hci_bcm: Add support for BCM2E95 and BCM2E96") in the Linux kernel source tree. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-08x86: tangier: Use actual GPIO hardware numbersAndy Shevchenko
The recent commit 03c4749dd6c7 ("gpio / ACPI: Drop unnecessary ACPI GPIO to Linux GPIO translation") in the Linux kernel reveals the issue we have in ACPI tables here, i.e. we must use hardware numbers for GPIO resources and, taking into consideration that GPIO and pin control are *different* IPs on Intel Tangier, we need to supply numbers properly. Besides that, it improves user experience since the official documentation for Intel Edison board is referring to GPIO hardware numbering scheme. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-01-08x86: Move commands from under arch/x86 to cmd/x86/Tom Rini
We only need to compile and link these files when building for full U-Boot. Move them to under cmd/x86/ to make sure they aren't linked in and undiscarded due to u_boot_list_2_cmd_* being included). Cc: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-21x86: tangier: Use official ACPI HID for FLIS IPAndy Shevchenko
FLIS IP since now gets its own ACPI ID. Drop PRP0001 workaround in favour of official ACPI HID. Corresponding kernel commit dabd4bc6de2b pinctrl: intel: merrifield: Introduce ACPI device table in the pin control subsystem tree [1] targeting v4.16. [1]: https://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl.git/commit/?h=for-next&id=dabd4bc6de2b Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-11-30x86: lib: Implement standalone __udivdi3 etc instead of libgcc onesStefan Roese
This patch removes the inclusion of the libgcc math functions and replaces them by functions coded in C, taken from the coreboot project. This makes U-Boot building more independent from the toolchain installed / available on the build system. The code taken from coreboot is authored from Vadim Bendebury <vbendeb@chromium.org> on 2014-11-28 and committed with commit ID e63990ef [libpayload: provide basic 64bit division implementation] (coreboot git repository located here [1]). I modified the code so that its checkpatch clean without any functional changes. [1] git://github.com/coreboot/coreboot.git Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-30Revert "x86: bootm: Fix FIT image booting on x86"Anatolij Gustschin
This reverts commit 13c531e52a09b4e6ffa8b5a1457199b0a574cb27. The error message with FIT style image mentioned in the above commit only happens when booting using FIT image containing bzImage kernel and without setup node (setup.bin). The current documentation for x86 FIT support in doc/uImage.FIT/x86-fit-boot.txt mentions that kernel's setup.bin file is required for building x86 FIT images. The above commit breaks FIT images generated as described in the documentation. Revert it to allow booting with images built in the documented way. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-30x86: don't compare pointers to 0Heinrich Schuchardt
x86_vendor_name is defined as static const char *const x86_vendor_name[] So its elements should not be compared to 0. Remove superfluous paranthesis. Problem identified with Coccinelle. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-30x86: qemu: Move Cache-As-RAM memory from area mapped to ROMAnton Gerasimov
ROM has been made read-only in qemu recently (namely commit 208fa0e4: "pc: make 'pc.rom' readonly when machine has PCI enabled"). So this patch restores compatibility between U-Boot and qemu. Signed-off-by: Anton Gerasimov <anton@advancedtelematic.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: mention qemu commit title in the commit message] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-11-17pylibfdt: compile pylibfdt only when dtoc/binman is necessaryMasahiro Yamada
Currently, pylibfdt is always compiled if swig is installed on your machine. It is really annoying because most of targets (excepts x86, sunxi, rockchip) do not use dtoc or binman. "checkbinman" and "checkdtoc" are wrong. It is odd that the final build stage checks if we have built necessary tools. If your platform depends on dtoc/binman, you must be able to build pylibfdt. If swig is not installed, it should fail immediately. I added PYLIBFDT, DTOC, BINMAN entries to Kconfig. They should be property select:ed by platforms that need them. Kbuild will descend into scripts/dtc/pylibfdt/ only when CONFIG_PYLIBFDT is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: acpi: Put sleepstates.asl to the common placeBin Meng
The supported sleep states are generic on Intel processors. Move the ASL definition to the common place. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: fsp: graphics: Add some notes about the graphics info hobBin Meng
On some platforms (eg: Braswell), the FSP will not produce the graphics info HOB unless you plug some cables to the display interface (eg: HDMI) on the board. Add such notes in the FSP video driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: braswell: cherryhill: Update dts for SPI lock downBin Meng
Intel Braswell FSP requires SPI controller settings to be locked down, let's do this in the chrryhill.dts and remove previous Kconfig option. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27Revert "x86: fsp: Configure SPI opcode registers before SPI is locked down"Bin Meng
This reverts commit 1e6ebee667da47fd3a87839a239a7574c66f5659. It's not appropriate to call the Intel SPI driver specific stuff in the FSP codes. We may add a simple DTS property "intel,spi-lock-down" and let the Intel SPI driver call these stuff instead. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-27x86: Fix ACPI resume dependency to MRC cacheBin Meng
In an S3 resume path, MRC cache is mandatory. Enforce the dependency in the Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27env: x86: braswell: Set ENV_IS_IN_SPI_FLASH as defaultBin Meng
Imply does not work for a Kconfig choice. Update ENV_IS_IN_SPI_FLASH to be the default one for Intel Braswell. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: braswell: Fix unexpected crash during Linux kernel bootBin Meng
It was observed that when booting Linux kernel on Intel Cherry Hill board, unexpected crash happens quite randomly. Sometimes kernel just oops, while sometimes kernel throws MCE errors and hangs: mce: [Hardware Error]: Machine check events logged mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 4: c400000000010151 mce: [Hardware Error]: TSC 0 ADDR 130f3f2c0 mce: [Hardware Error]: PROCESSOR 0:406c3 TIME 1508160686 SOCKET 0 APIC 0 microcode 363 This looks like a hardware error per mcelog. After debugging, it seems turning off turbo mode on the processor does not expose this behavior, although U-Boot runs OK with turbo mode on. Suspect it is related to an errata of Braswell processor. To fix this, remove the Braswell cpu driver which does the turbo mode configuration, and switch to use the generic cpu-x86 driver. Also there is a configuration option in the FSP that turns on the turbo mode and that has been turned off too. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-19x86: baytrail: fsp: Move Azalia update codes to boardBin Meng
Azalia configuration may be different across boards, hence it's not appropriate to do that in the SoC level. Instead, let's make the SoC update_fsp_azalia_configs() routine as a weak version, and do the actual work in the board codes. So far it seems only som-db5800-som-6867 board enables the Azalia. Move the original codes into som-db5800-som-6867.c. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-19x86: baytrail: fsp: Use a function to update the Azalia config pointerBin Meng
At present we directly pass the Azalia config pointer to the FSP UPD. This updates to use a function to do the stuff, like Braswell does. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-19x86: fsp: Consolidate Azalia header fileBin Meng
So far there are two copies of Azalia struct defines with one in baytrail and the other one in braswell. This consolidates these two into one, put it in the common place, and remove the prefix pch_ to these structs to make their names more generic. This also corrects reset_wait_timer from us to ms. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-19x86: Turn off running VGA ROM during S3 resumeBin Meng
This is only needed when graphics console is used. For kernel with native graphics driver, this can be turned off to speed up. Change this option's default to n in the Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-19x86: baytrail: Fix unstable ACPI S3 resumeBin Meng
It was observed that when booting a Ubuntu 16.04 kernel, doing ACPI S3 suspend/resume sometimes causes the Ubuntu kernel hang forever. The issue is however not reproduced with a kernel built from i386/ x86_64 defconfig configuration. The unstability is actually caused by unexpected interrupts being generated during the S3 resume. For some unknown reason, FSP (gold4) for BayTrail configures the GPIO DFX5 PAD to enable level interrupt (bit 24 and 25). As this pin keeps generating interrupts during an S3 resume, and there is no IRQ requester in the kernel to handle it, the kernel seems to hang and does not continue resuming. Clear the mysterious interrupt bits for this pin. Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Reviewed-by: Stefan Roese <sr@denx.de>
2017-10-07x86: tangier: Enable ACPI support for Intel TangierAndy Shevchenko
Intel Tangier SoC is a part of Intel Merrifield platform which doesn't utilize ACPI by default. Here is an attempt to unleash ACPI flexibility power on Intel Merrifield based platforms. The change brings minimum support of the devices that found on Intel Merrifield based end user device. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-02x86: Use asm-generic/io.hPaul Burton
Convert the x86 architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for x86 this is primarily a matter of moving code. This has only been build-tested, feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: ivybridge: remove unused variablesHeinrich Schuchardt
legacy_hole_base_k and legacy_hole_size_k are defined but not used. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-16dm: x86: Allow TSC timer to be used before DM is readySimon Glass
With bootstage we need access to the timer before driver model is set up. To handle this, put the required state in global_data and provide a new function to set up the device, separate from the driver's probe() method. This will be used by the 'early' timer also. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-16x86: Support Intel Cherry Hill boardBin Meng
This adds support to Intel Cherry Hill board, a board based on Intel Braswell SoC. The following devices are validated: - serial port as the serial console - on-board Realtek 8169 ethernet controller - SATA AHCI controller - EMMC/SDHC controller - USB 3.0 xHCI controller - PCIe x1 slot with a graphics card - ICH SPI controller with an 8MB Macronix SPI flash - Integrated graphics device as the video console Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: braswell: Disable PUNIT power configuration for B0 steppingBin Meng
FSP's built-in UPD configuration enables PUNIT power configuration, but on B0 stepping, this causes CPU hangs in fsp_init(). Disable it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: braswell: Add FSP configurationBin Meng
Add FSP related configuration for Braswell. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: braswell: Add microcode for B0/C0/D0 stepping SoCBin Meng
This adds microcode device tree fragment for Braswell B0 (406C2), C0 (406C3) and D0 (406C4) stepping SoC. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: Add Intel Braswell SoC supportBin Meng
This adds initial Intel Braswell SoC support. It uses Intel FSP to initialize the chipset. Similar to its predecessor BayTrail, there are some work to do to enable the legacy UART integrated in the Braswell SoC. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: fsp: Update fsp command to show spec 1.1 headerBin Meng
FSP spec 1.1 adds 3 new APIs and their offsets are in the header. Update the 'fsp hdr' command to show these new entries. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: dm: video: Add a framebuffer driver that utilizes VBTBin Meng
When a VBT is given to an FSP that supports graphics initialization, the FSP will produce a graphics info HOB that contains all necessary information for the linear frame buffer of the integrated graphics device. This adds a DM video driver for it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: dts: Include Intel Video BIOS Table in the ROM imageBin Meng
Now that binman is able to recognize the Video BIOS Table entry, add such one in the u-boot.dtsi. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: Add Video BIOS Table (VBT) related Kconfig optionsBin Meng
This adds Kconfig options for Video BIOS Table which is normally required if you are using an Intel FSP firmware that is complaint with spec 1.1 or later to initialize the integrated graphics device. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: fsp: Add FSP_GRAPHICS_INFO_HOBBin Meng
This adds a new HOB type for graphics information introduced in FSP spec 1.1. When graphics capability is included in FSP and enabled, FSP produces an FSP_GRAPHICS_INFO_HOB as described in the EFI PI specification which provides information about the graphics mode and framebuffer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-16x86: fsp: Update struct common_buf for FSP spec 1.1Bin Meng
FSP spec 1.1 adds one more member to the struct common_buf to determine the memory size that can be reserved by FSP below "top of low usable memory" for bootloader usage. This new member uses the reserved space so that it is still compatible with previous FSP spec 1.0. A new HOB (FSP_HOB_RESOURCE_OWNER_BOOTLOADER_TOLUM_GUID) is also published when common_buf.tolum_size is valid and non zero. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-12dma: import linux/dma-direction.h to consolidate enum dma_data_directionMasahiro Yamada
Import include/linux/dma-direction.h from Linux 4.13-rc7 and delete duplicated definitions of enum dma_data_direction. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-09-02x86: baytrail: acpi: Add full reset bit to the reset register value in FADTBin Meng
It was noticed a few times, that the reboot from Linux (reboot command) is different from the reboot (reset command) under U-Boot. The U-Boot version does seem to reset the board more deeply (PCI cards etc) than the Linux reboot. This is actually caused by missing full reset bit in the reset register value in the ACPI FADT table. Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stefan Roese <sr@denx.de>
2017-08-24x86: tangier: kconfig: Guard tangier-specific optionsBin Meng
These options should not be exposed to other platforms. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-08-24x86: baytrail: Fix turbo enableBin Meng
CPU_INTEL_TURBO_NOT_PACKAGE_SCOPED must be turned on for Baytrail. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
