path: root/arch/x86
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19x86: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-06sc520: fix build warning about unused temp varMike Frysinger
Building the eNET_SRAM board fails for me: sc520_timer.c: In function 'sc520_udelay': sc520_timer.c:81:7: error: variable 'temp' set but not used [-Werror=unused-but-set-variable] cc1: all warnings being treated as errors make[1]: *** [sc520_timer.o] Error 1 Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-01-04x86: Convert board_init_f_r to a processing loopGraeme Russ
Create an init function array for board_init_f_r - This finalises the migration to a purely array based initialisation mechanism Also tweak a few comments while we are at it so everything is 'correct' -- Changes for v2: - Renamed to a more apt name - Fix bug in set_reloc_flag_r - Re-instate gd->flags = boot_flags; in board_init_f - Added commit message
2012-01-04x86: Split init functions out of board.cGraeme Russ
This patch moves towards reducing board.c to simply a set of init cores for the three initialisation phases (Flash, Flash/RAM, and RAM), a set of three init function arrays and a init function array processing function
2012-01-04x86: Move relocation code out of board.cGraeme Russ
2012-01-04x86: Move setup_pcat_compatibility() out of board.cGraeme Russ
This function simply does not belong in board.c -- Changes for v2: - Added commit message
2012-01-04x86: Move do_go_exec() out of board.cGraeme Russ
-- Changes for v2: - None
2012-01-04CHECKPATCH: arch/x86/lib/*Graeme Russ
2012-01-04x86: Tweak IDT and GDT for alignment and readabilityGraeme Russ
-- Changes for v2: - Renamed to better reflect nature of changes
2012-01-04x86: Allow cache before copy to RAMGraeme Russ
2012-01-04x86: Create weak init_cache() and default enable_caches() functionsGraeme Russ
-- Changes for v2: - Tweaked commit title
2012-01-04x86: Set GD_FLG_RELOC after entering in-RAM copy of U-BootGraeme Russ
2012-01-04x86: Use fs for global dataGraeme Russ
Use the base address of the 'F' segment as a pointer to the global data structure. By adding the linear address (i.e. the 'D' segment address) as the first word of the global data structure, the address of the global data relative to the 'D' segment can be found simply, for example, by: fs movl 0, %eax This makes the gd 'pointer' writable prior to relocation (by reloading the Global Desctriptor Table) which brings x86 into line with all other arches NOTE: Writing to the gd 'pointer' is expensive (but we only do it twice) but using it to access global data members (read and write) is still fairly cheap -- Changes for v2: - Rebased against changes made to patch #3 - Removed extra indent - Tweaked commit message
2012-01-04x86: Rework relocation calculationsGraeme Russ
This commit introduces no functional changes - It simply re-arranges the calculations so that adding to them in future commits will be cleaner -- Changes for v2: - Fixed typo in title - Added commit message
2012-01-04x86: Simplify Flash-to-RAM code execution transitionGraeme Russ
Move the relocation offset calculation out of assembler and into C. This also paves the way for the upcoming init sequence simplification by adding the board_init_f_r flash to RAM transitional function -- Changes for v2: - Added commit message - Minor adjustment to new stack address comment
2012-01-04x86: Rework Global Descriptor Table loadingGraeme Russ
The inline assembler is ugly and uses hard coded magic numbers. Make it more elegant to allow cleaner implementation of future GDT related patches. The compiler seems smart enough to generate the same code anyway -- Changes for v2: - Rebased against revised patch #3 - Use GDT size define instead of magic number - Added commit message
2012-01-04x86: Remove GDR related magic numbersGraeme Russ
-- Changes for v2: - Use an enum - Add defined for GDT size (previously added in patch 7) - Use X86_ namespace (as per Linux headers)
2012-01-04x86: Speed up copy-to-RAM and clear BSS operationsGraeme Russ
The implementations of memcpy and memset are now the optimised versions from glibc, so use them instead of simple copy loops -- Changes for v2: - Removed unneeded brackets
2012-01-02x86: Import glibc memcpy implementationGraeme Russ
Taken from glibc version 2.14.90 -- Changes for v2: - None
2011-12-19x86: Add support for specifying an initrd with the zboot commandGabe Black
This change finishes plumbing the initrd support built into the zboot mechanism out to the command interface. It also fixes a bug in the command declaration where the kernel size could be passed as an optional second parameter but not enough arguments were allowed. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Refactor the zboot innards so they can be reused with a vboot imageGabe Black
If vboot successfully verifies a kernel, it will leave it in place and basically ready to boot. The zeropage table which is part of the x86 boot protocol is at the end of the kernel, though, instead of the beginning, and because the image is already in place there's no need to copy it around. This change refactors the code which implements the zboot command so that the configuration of the zeropage table and loading the pieces of the kernel into memory are done separately. Also, because the command line goes before the zeropage table in vboot which is somewhat incompatible with the normal protocol, where to put the command line is a now a parameter instead of being hard coded. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Add infrastructure to extract an e820 table from the coreboot tablesGabe Black
Also approximate the size of RAM using the largest RAM address available in the tables. There may be areas which are marked as reserved which are actually at the end of RAM. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Add support for booting Linux using the 32 bit boot protocolGabe Black
This change conditionally modifies the zboot command so that it can use the 32 bit boot protocol. This is necessary because the 16 bit realmode entry point assumes that it can call BIOS services which neither coreboot nor u-boot provide. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Clean up the x86 zimage code in preparation to extend itGabe Black
This change cleans up some formatting issues in the zimage handling code, and converts it from using offsets added to a base pointer to using the available structure definitions which were already being included. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Import code from coreboot's libpayload to parse the coreboot tableGabe Black
This change also forces the lib_sysinfo structure to be in the .data section. Otherwise it ends up in the .bss section. U-boot assumes that it doesn't need to copy it over during relocation, and instead fills that whole section with zeroes. If we really were booting from ROM that would be appropriate, but we need some information from the coreboot tables (memory size) before then and have to fill that structure before relocation. We skirt u-boot's assumption by putting this in .data where it assumes there is still read only but non-zero data. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-12-19x86: Initial commit for running as a coreboot payloadGabe Black
Add a target for running u-boot as a coreboot payload in boards.cfg, a board, CPU and a config. This is a skeleton implementation which always reports the size of memory as 64 MB. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-11-29x86: Wrap small helper functions from libgcc to avoid an ABI mismatchGabe Black
When gcc compiles some 64 bit operations on a 32 bit machine, it generates calls to small functions instead of instructions which do the job directly. Those functions are defined in libgcc and transparently provide whatever functionality was necessary. Unfortunately, u-boot can be built with a non-standard ABI when libgcc isn't. More specifically, u-boot uses -mregparm. When the u-boot and libgcc are linked together, very confusing bugs can crop up, for instance seemingly normal integer division or modulus getting the wrong answer or even raising a spurious divide by zero exception. This change borrows (steals) a technique and some code from coreboot which solves this problem by creating wrappers which translate the calling convention when calling the functions in libgcc. Unfortunately that means that these instructions which had already been turned into functions have even more overhead, but more importantly it makes them work properly. To find all of the functions that needed wrapping, u-boot was compiled without linking in libgcc. All the symbols the linker complained were undefined were presumed to be the symbols that are needed from libgcc. These were a subset of the symbols covered by the coreboot code, so it was used unmodified. To prevent symbols which are provided by libgcc but not currently wrapped (or even known about) from being silently linked against by code generated by libgcc, a new copy of libgcc is created where all the symbols are prefixed with __normal_. Without being purposefully wrapped, these symbols will cause linker errors instead of silently introducing very subtle, confusing bugs. Another approach would be to whitelist symbols from libgcc and strip out all the others. The problem with this approach is that it requires the white listed symbols to be specified three times, once for objcopy, once so the linker inserts the wrapped, and once to generate the wrapper itself, while this implementation needs it to be listed only twice. There isn't much tangible difference in what each approach produces, so this one was preferred. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-11-29x86: Import the glibc memset implementationGabe Black
The new implementation is about twice as fast as the old. This is from glibc-2.14, sysdeps/i386/memset.c. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-11-29x86: Fix a few recently added bugsGabe Black
Signed-off-by: Gabe Black <gabeblack@chromium.org> Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-11-29x86: Don't relocate symbols which point to things that aren't relocatedGabe Black
This change adds an upper bound for symbols which are fixed up after u-boot is relocated into RAM. This way portions that are left at their original location can be referred to without having to manually fix up any pointers. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-11-29x86: Fix how the location of the realmode and bios blobs are calculatedGabe Black
There are two blobs embedded into the u-boot image which are linked to run at an address which is different from where they actually end up in the ROM, one called "realmode" and one called "bios". There are realmode_setup and bios_setup functions which prepare those blobs by copying them into the location they're supposed to run from, among other things. During u-boot relocation from ROM to RAM, the text and a few data segments are copied over. The realmode and bios sections are not copied, and so the only place they can be read from is their original location in the ROM. Looking specifically at the bios blob, there are symbols defined in the linker script called __bios_start and __bios_size which are defined to be the start and size of the blob in the ROM. In the bios_setup function, there seem to be two mistakes happening. First, the offset from ROM to RAM is being added to __bios_start which implies that this code expects to use the copy moved to RAM. No such copy is made, so that's wrong. More subtly, when u-boot relocates itself, it goes through all of the relocations stored in .rel.dyn and fixes them up. This has the effect of transforming the __bios_start reference in bios_setup so that it refers to the version in RAM (if one existed) instead of the one in ROM. To correct for that, the offset actually needs to be subtracted out again to translate the address back into the ROM. The net effect is that for both blobs, a + needs to be changed to a -. Signed-off-by: Gabe Black <gabeblack@chromium.org>
2011-11-29x86: Misc cleanupsGraeme Russ
2011-11-29x86: Misc PCI touchupsGraeme Russ
2011-11-29x86: Ensure IDT and GDT remain 16-byte aligned post relocationGraeme Russ
Some CPUs have strict alignment requirements for these tables Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-11-29x86: Provide more configuration granularityGraeme Russ
Planned future ports requires more granularity for some options Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-11-29x86: Add multiboot headerGraeme Russ
By adding a multiboot header, U-Boot can be loaded by GRUB2. Using GRUB2 to bootstrap U-Boot is useful for using an existing BIOS to get an initial U-Boot port up and running before implementing the low-level reset vector code, SDRAM init, etc. and overwriting the BIOS Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-11-29sc520: Create arch asm-offsetsGraeme Russ
2011-11-29x86: Punt cold- and warm-boot flagsGraeme Russ
Nobody uses them anyway Signed-off-by: Graeme Russ <graeme.russ@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-29cosmetic: checkpatch cleanup of arch/x86/lib/*.cGraeme Russ
2011-11-29cosmetic: checkpatch cleanup of arch/x86/cpu/sc520/*.cGraeme Russ
2011-11-29cosmetic: checkpatch cleanup of arch/x86/cpu/*.cGraeme Russ
2011-11-29x86: Call hang() on unrecoverable exceptionGraeme Russ
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-02x86: Fix a compiler warning in arch/x86/lib/realmode.cGabe Black
Ensure that the value being passed to a %d format specifier is of type int. Signed-off-by: Gabe Black <gabeblack@chromium.org>
