These types should be 64 bits long to reflect the fact that physical
addresses and the size of physical areas of memory are more than 32 bits
long.
BUG=None
TEST=Built and booted on Lumpy.
Change-Id: I58bc69051db027d6eb718ec1c92a3d4afa2b7561
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/14150
This cleans up the rom caching optimization implemented in coreboot (and
needed throughout u-boot runtime.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
BUG=chrome-os-partner:6585
TEST=boot coreboot on stumpy
Change-Id: I7242c9c2b0546c633be8fb8ebc815ed6e6fda4d1
Reviewed-on: https://gerrit.chromium.org/gerrit/11138
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
... rather than parsing the coreboot option table
BUG=none
TEST=boot tested on Stumpy
Change-Id: I0814dd6c37cf826fda55a0f4acd6a1763b0626db
Reviewed-on: https://gerrit.chromium.org/gerrit/10758
I ran four iterations with the two implementations and used Vadim's CBMEM
infrastructure to measure the time they took. These are all in microseconds,
and the timestamp portion of the raw output of cbmem.py is included in the bug.
The new implementation is about twice as fast as the old.
Old:
1. 418,286
2. 418,302
3. 418,298
4. 418,290
New:
1. 184,800
2. 194,629
3. 194,188
4. 192,718
BUG=chrome-os-partner:6487
TEST=Booted on Stumpy.
Change-Id: Iba398929cbba395e10851d676ae9d356ae670f41
Reviewed-on: http://gerrit.chromium.org/gerrit/10284
Reviewed-by: Mike Frysinger <vapier@chromium.org>
Commit-Ready: Gabe Black <gabeblack@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
Allow redirection of console output prior to console initialisation to a
temporary buffer.
To enable this functionality, the board (or arch) must define:
- CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer
- CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer
- CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes)
The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes
Any earlier characters are silently dropped.
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Change-Id: I3c4caad276b9e981ebea0a0fb79d85ee3a3bcb7d
Reviewed-on: http://gerrit.chromium.org/gerrit/8686
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
A few CBMEM table entries are included in coreboot to let u-boot
discover the locations of those entries. They all are passed
using the same structure within coreboot table. This patch makes
use of that structure for all communicated entries (timestam,
console and MRC cache).
It does not make sense to keep types of pointers in the sysinfo
table, as nobody but the respective users of those fields use the
types. Let's keep the pointers as void *, this also allows to
reduce the amount of include files in systinfo.h and hide the
timestamp structures in timestamp.c.
BUG=chrome-os-partner:4200
TEST=manual
. build the new firmware and program it on a stumpy
. restart the machine
. after it comes up to ChromeOS, run the cbmem.py utility
Observe that timstamp values are displayed, and there is an entry
with index 1000 (added by u-boot to the coreboot timestamp
table).
Change-Id: Icb808145c4c62cee939eceb3d5bf5afb3bcd00d9
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/8711
Reviewed-by: Stefan Reinauer <reinauer@google.com>
global_data.h defines a number of offset constants which are used by assembly
to access the global data structure. These were partially correct but out of
date. This change corrects them.
BUG=None
TEST=Built and booted twostop on Alex.
Change-Id: I0989ee7dae0ef095af54b6df9137e925da3e74a6
Reviewed-on: http://gerrit.chromium.org/gerrit/8395
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-by: Gabe Black <gabeblack@chromium.org>
This CL separates the HW timestamp acquisition into an inline
function and provides interface to set the base time (to be
retrieved from coreboot table).
BUG=chromium-os:20733
TEST=manual
. build the new firmaware image
. bring up a stumpy with the new image to ChromeOS
. examine crossystem reported timer values.
Observe that the values start with zero and increase
monotonously.
Change-Id: I4ede0a55112e061e9d3790f01c8ca41a8539364b
Reviewed-on: http://gerrit.chromium.org/gerrit/8215
This change adds code to process the timestamp table infiormation
in case it is included in the coreboot table.
coreboot/timestamp.h had to be modified to make it possible to
compile in u-boot environment. The upcoming change will modify
the timestamp handling code borrowed from coreboot under
http://gerrit.chromium.org/gerrit/8164.
TEST=manual
. brought up a stumpy to ChromeOS login screen.
Change-Id: I008b5e4c971cbb13de2f055f53da6384035df5eb
Reviewed-on: http://gerrit.chromium.org/gerrit/8222
BUG=chrome-os-partner:6077
TEST=none
Change-Id: I417ea3da24dc0cff17aa83ef799fabe78e4b1da5
Reviewed-on: http://gerrit.chromium.org/gerrit/8143
Tested-by: Stefan Reinauer <reinauer@google.com>
Commit-Ready: Stefan Reinauer <reinauer@google.com>
This patch prevents u-boot from "spamming" random progress codes on
a port 80 "post card".
The previous version of this patch just removed the delays in the "slow"
IO functions, as they do not need to be slow, however, this patch is
less intrusive.
It uses another unused port that is often used by BIOSes (and the Linux
Kernel) for small delay timing purposes.
BUG=none
TEST=boot coreboot+u-boot, see the right post codes come up.
Change-Id: I9d1cc6de4472f5bb1f7b5ec6959273bfbfaa760b
Reviewed-on: http://gerrit.chromium.org/gerrit/7778
First - make sure the ahci driver compiles and links properly when
building for x86 platforms.
Then it turned out that when trying to use AHCI driver on an x86
platform with an Intel AHCI controller, the driver does not operate
properly if the requested amount of blocks to read was exceeding 255.
It is probably possible to specify 0 as the block count and the driver
will read 256 blocks, but it was decided to limit the number of blocks
read at once to 128 (it should be a power of 2 for the optimal
performance of solid state drives).
BUG=chromium-os:19837
TEST=manual
. program updated image (including vbexport SATA support extension)
on an Alex.
. restart the machine and enter `vboot_twostop' at u-boot prompt.
Observe ChromeOS booting all the way to login screen.
Change-Id: I7224ca14ae60f414db6dbe9e2f0a649312a9459c
Reviewed-on: http://gerrit.chromium.org/gerrit/7232
Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
On X86 systems where VDAT address is passed to the kernel through
ACPI the u-boot must retrieve the address from the coreboot table
and make it available to the vboot wrapper.
This change accomplishes just that utilizing the coreboot changes
which include the vdat area address and size into the coreboot
table.
Another modification is removing conditional compilation for
including fields in the sysinfo table. The thing is that the code
is not conditionally compiled anyways, so keeping an extra
pointer in a table even if not needed is not a problem.
BUG=chrome-os-partner:5707
TEST=manual
. program the new firmware on an Alex
. bring up ChromeOS
. try running crossystem
It was reporting errors before (when displaying data retrieved
from VDAT). It displays sensible values now.
Change-Id: Ib4090049092f7963a1b1705409d2beea8a9abfac
Reviewed-on: http://gerrit.chromium.org/gerrit/6868
Tested-by: Vadim Bendebury <vbendeb@google.com>
Reviewed-on: http://gerrit.chromium.org/gerrit/6919
If vboot successfully verifies a kernel, it will leave it in place and
basically ready to boot. The zeropage table which is part of the x86 boot
protocol is at the end of the kernel, though, instead of the beginning, and
because the image is already in place there's no need to copy it around. This
change refactors the code which implements the zboot command so that the
configuration of the zeropage table and loading the pieces of the kernel into
memory are done separately. Also, because the command line goes before the
zeropage table in vboot which is somewhat incompatible with the normal
protocol, where to put the command line is a now a parameter instead of being
hard coded.
BUG=chrome-os-partner:4552
TEST=Built and booted a legacy kernel with both the 32 bit and 16 bit boot
protocols. Like other, earlier changes to this code only a current kernel which
doesn't exercise old protocol features was tested. This change is more
significant than the others and so may break booting old kernels. Also, the
bootm command was not tested on x86. We need to decide if that command makes
any sense to keep/support.
Change-Id: I09f6d0e2d46b4ce499f31c8073571968dba51b8a
Reviewed-on: http://gerrit.chromium.org/gerrit/5545
The problem turned out to be due to inconsistent compile flag
settings when compiling the same include file in different .c
files.
BUG=chromium-os:19263
TEST=manual
Build and run coreboot on Alex. It used to crash before this
change in case gd was located at fixed address, it comes to the
u-boot prompt now.
Change-Id: Ia34284630b865ef715f1f6d0061620f1d6643b7b
Reviewed-on: http://gerrit.chromium.org/gerrit/6206
This change makes the Alex u-boot use configuration settings
coming from the device tree supplied by coreboot through the
coreboot table.
The device tree now includes the necessary console configuration
information.
Code is added to retrieve the device tree pointer from the
coreboot table, the appropriate coreboot structures and tag
values are being duplicated in
arch/i386/include/asm/ic/coreboot/tables.h. The pointer to the
FDT is added to the global data structure, it is initialized as
soon as it is retrieved from the coreboot table.
For some reason placing the global data structure anywhere but in
the .data segment causes the system to crash. This phenomenon
will be investigated shortly, this commit is an intermediate step
to get the device tree handover used by other coreboot/u-boot
contributors.
Core retrieving the device tree from CBFS is not needed anymore
and gets removed.
BUG=chrome-os-partner:5248
TEST=manual
. build the new image and program it on Alex
. restart the target, observe the console output
The target boots all the way to u-boot prompt.
Change-Id: I087cf70362ede0873be37fa5a98aa66a0b979d8f
Reviewed-on: http://gerrit.chromium.org/gerrit/6132
The i386 version of io.h depends on the phys_addr_t type which is defined in
types.h. It wasn't including that explicitly, and was working presumably
because the other files including it had already included types.h themselves
directly or indirectly. This change fixes that.
BUG=chrome-os-partner:4722
TEST=Built and booted on x86-alex.
Change-Id: I4a4a0b12bcadd807bc87a17219f705bfa5ae98e3
Reviewed-on: http://gerrit.chromium.org/gerrit/5375
BUG=chrome-os-partner:3912
TEST=run vboot_twostop and see cros_gpio output
Change-Id: Ic926765afa5b7d56ed475dc4c9e39a0dc99bcdf0
Reviewed-on: http://gerrit.chromium.org/gerrit/5292
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
Using the tables defined by coreboot retrieve and cache
information of where the VBNV area is kept in the CMOS.
Populate VBNV access functions to actually read and write this
area.
TEST=manual
. built and booted u-boot on an Alex.
. compiled u-boot for kaen.
. verified using some extra code that vbnv area is reported as
16 bytes at offset 52 (0x34).
Change-Id: Icf6a54e12b7458af9f9c213b4afe30437565706b
Reviewed-on: http://gerrit.chromium.org/gerrit/5079
TEST=Built and booted u-boot on an Alex.
Change-Id: I3d60b4e3c212976b160f0ca3a3b026a3945ca954
Reviewed-on: http://gerrit.chromium.org/gerrit/4702
This function provides an opportunity for some last minute cleanup and
reconfiguration before control is handed over to Linux. It's possible this
may need to do something in the future, but for now it's left empty. It's set
up as a weak symbol so it can be overridden if necessary on a case by case
basis.
Change-Id: Ia59436b2a9d499ff659b2f41668cf951f2f7d999
Reviewed-on: http://gerrit.chromium.org/gerrit/4698
This change adds a pointer to the global data structure in i386 to point to
the device tree. This mirrors an identical pointer in ARM.
BUG=chrome-os-partner:4993
Change-Id: I96710993bb35327ce5c4aa78aa5da763dc72109e
Reviewed-on: http://gerrit.chromium.org/gerrit/4696
hardcoded values for Alex, needs work. Early adopters version.
BUG=chrome-os-partner:4522
TEST=build coreboot, have a console on your screen
Change-Id: I0d9a4abac51bb0c17a085d96d3f8ddec9a72985c
Reviewed-on: http://gerrit.chromium.org/gerrit/3411
This change makes the coreboot parsing code record the location of
informational strings to potentially display later. The code used to just
ignore them.
BUG=chrome-os-partner:3907
TEST=Built and booted on an Alex with an instrumented version of u-boot that
printed out the strings, verified that the strings were reasonable.
Change-Id: I0623cc5009278b8564ff631d572deb73ffd857a1
Reviewed-on: http://gerrit.chromium.org/gerrit/3223
This change adds support for a CONFIG_NO_REALMODE_CODE config option that
excludes the realmode/bios code other than reset code from the build.
BUG=chrome-os-partner:3913
TEST=Built and booted with this option turned on and off.
Change-Id: Ia248d491d7d67c5c3119129742c449d8246b7d43
Reviewed-on: http://gerrit.chromium.org/gerrit/3221
This change conditionally modifies the zboot command so that it can use the 32
bit boot protocol. This is necessary because the 16 bit realmode entry point
assumes that it can call BIOS services which neither coreboot nor u-boot
provide.
BUG=chrome-os-partner:4700
TEST=Built and booted using the legacy and 32 bit boot protocols. Used dmesg to
verify that the e820 memory map was successfully picked up by the kernel when
using the 32 bit protocol.
Change-Id: Ibd7d0989a2bef16affb1c3dd268ef9a72461597f
Reviewed-on: http://gerrit.chromium.org/gerrit/3220
BUG=chrome-os-partner:3906
TEST=Printed out information from the tables on Alex.
Change-Id: I29d635bbfa76bc2a48ad8e15011a5e03f86e56e0
Reviewed-on: http://gerrit.chromium.org/gerrit/3218
This change cleans up some formatting issues in the zimage handling code, and
converts it from using offsets added to a base pointer to using the available
structure definitions which were already being included.
TEST=Successfully boot into chromeos on Alex.
Change-Id: I2790d28355ca262f114c1538c3a64802d52ccea5
Reviewed-on: http://gerrit.chromium.org/gerrit/3217
TEST=Booted and verified that the table parsing function didn't return an error.
Change-Id: I835c8982e5a1b5acfd0c82e064e844815c326f1c
Reviewed-on: http://gerrit.chromium.org/gerrit/3118
U-boot needs a host controller or "hose" to interact with the PCI busses
behind them. This change installs a host controller during initialization of
the coreboot "board" which implements some of X86's basic PCI semantics. This
relies on some existing generic code, but also duplicates a little bit of code
from the sc520 implementation. Ideally we'd eliminate that duplication at some
point.
It looks like in order to scan buses beyond bus 0, we'll need to tell u-boot's
generic PCI configuration code what to do if it encounters a bridge,
specifically to scan the bus on the other side of it.
BUG=chrome-os-partner:4511
TEST=Booted into u-boot through coreboot, ran the pci command, and saw a
reasonable looking scan of bus 0.
Change-Id: Id3689625e40106c37a273c8409883d1515fcfaa9
Reviewed-on: http://gerrit.chromium.org/gerrit/2603
I suspect these includes where usually available because something else
included them earlier or because they were brought in transitively.
BUG=chrome-os-partner:3905
TEST=Built coreboot u-boot.
Change-Id: Ib3de0d30b3707dd2469322b639224addb23839da
Reviewed-on: http://gerrit.chromium.org/gerrit/2185
Change-Id: Idac7d917f921cbcb5d11ca24ade062558e2d5304
Reviewed-on: http://gerrit.chromium.org/gerrit/2018
The arch/i386/include/asm/ic/pci.h header file include definitions which were
not generic to i386 and where specifically for SC520. This change moves that
header into a directory which more accurately reflects that.
Change-Id: Icb4774f5c8d280904bbe1fa5cba42bdce002fcc0
Reviewed-on: http://gerrit.chromium.org/gerrit/2016
