path: root/arch/x86/include/asm/i8259.h
2015-11-13x86: Fix cosmetic issues in the i8254 and i8259 codesBin Meng
This cleans up i8254 and i8259 codes to fix several cosmetic issues, like coding convention and some comments improvement. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-25x86: Refactor interrupt_init()Bin Meng
Rename interrupt_init() in arch/x86/lib/pcat_interrupts.c to i8259_init() and create a new interrupt_init() in arch/x86/cpu/interrupt.c to call i8259_init() followed by a call to cpu_init_interrupts(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-08-04Convert ISO-8859 files to UTF-8Albert ARIBAUD
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source tree, which could cause issues with the patchwork review system. This commit converts all ISO-8859 files to UTF-8. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
