Increase lib_sysinfo memrange entry number to 32 to sync with coreboot.
This allows a complete E820 table to be reported to the kernel, as on
some platforms (eg: Bayley Bay) having only 16 entires does not cover
all the memory ranges.
The existing IP checksum function is only accessible to the 'coreboot' cpu.
Drop it in favour of the new code in the network subsystem.
Movie setup_pch_gpios() in the ich6-gpio driver to the board support
codes, so that the driver does not need to know any platform specific
stuff (ie: include the platform specifc chipset header file).
Including <linux/compiler.h> is enough for general use.
When not relying on Coreboot for GPIO init the GPIOs must be set up
correctly. This is currently done statically through a rather ugly method.
As the GPIOs are figured out they can be moved to the device tree and set
up as needed rather than all at the start.
In this implementation, board files should call ich_gpio_set_gpio_map()
before the GPIO driver is used in order to provide the GPIO information.
We use the early PCI interface so that this driver can now be used before
relocation.
This code doesn't follow the normal approach of having its arch-specific
definitions in an arch-specific directory. Add a new arch-specific file
and make use of it.
[trini Don't remove some copyrights by accident]
Coreboot provides a lot of useful timing information. Provide a facility
to add this to bootstage on start-up.
The libfdt.h file is the definition file for libfdt. It is unnecessary
to include other fdt header files (the necessary ones are pulled in
by libfdt.h).
Signed-off-by: Gerald Van Baren <gvb@unssw.com>
and, if including libfdt.h which includes libfdt_env.h in
the correct order, don't include fdt.h before libfdt.h.
this is needed to get the fdt type definitions set from
the project environment before fdt.h uses them.
Cc: Jerry Van Baren <gvb.uboot@gmail.com>
To maintain the initialization state of the timestamp facility, thesq
pointer to the CBMEM section containing the timestamp table should be
kept in the .data section (so that it is maintained across u-boot
relocation).
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
This change turns on the code which allows u-boot to add
timestamps to the timestamp table created by coreboot.
Since u-boot does not use the tsc_t like structure to represent
HW counter readings, this structure is being replaced by 64 bit
integer.
The timestamp_init() function is now initializing the base timer
value used by u-boot to calculate the HW counter increments.
Timestamp facility is initialized as soon as the timestamp table
pointer is found in the coreboot table. The u-boot generated
timer events' ID will start at 1000 to clearly separate u-boot
events from coreboot events in the timer trace.
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
Add support for decoding tags for GPIOs, compile/build info, cbmem and
other features.
Signed-off-by: Gabe Black <gabeblack@chromium.org>
This change also forces the lib_sysinfo structure to be in the .data
section. Otherwise it ends up in the .bss section. U-boot assumes that it
doesn't need to copy it over during relocation, and instead fills that
whole section with zeroes. If we really were booting from ROM that would be
appropriate, but we need some information from the coreboot tables (memory
size) before then and have to fill that structure before relocation. We
skirt u-boot's assumption by putting this in .data where it assumes there
is still read only but non-zero data.
