path: root/arch/x86/cpu
2019-06-22watchdog: tangier: Convert to use WDT classAndy Shevchenko
Convert legacy driver to use watchdog class. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Stefan Roese <sr@denx.de>
2019-05-19x86: coreboot: make it possible to process unhandled tagsChristian Gmeiner
coreboot makes it possible to add own entries into coreboot's table at a per mainboard basis. As there might be some custom ones it makes sense to provide a way to process them. Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-09Fix spelling of available.Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
2019-05-08x86: Add a way to jump from TPL to SPLSimon Glass
When TPL finishes it needs to jump to SPL with the stack set up correctly. Add a function to handle this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Update PCH to work in TPLSimon Glass
The early init should only happen once. Update the probe method to deal with TPL, SPL and U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: Support TPL in Intel common codeSimon Glass
Update the Makefie rules to ensure that the correct files are built when TPL is being used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Implement PCH_REQ_PMBASE_INFOSimon Glass
Implement this ioctl() to support power off. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: ivybridge: Implement PCH_REQ_PMBASE_INFOSimon Glass
2019-05-08x86: Add common Intel code for SPLSimon Glass
Add an implementation of arch_cpu_init_f() so that the x86 SPL code builds and identifies the CPU. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Select refcode and CPU code for SPLSimon Glass
Allow broadwell to build for SPL and include the reference code. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Allow booting from SPLSimon Glass
At present broadwell only supports booting straight into U-Boot proper. Add a separate init file to boot from SPL into U-Boot proper, and select it when SPL is in use. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: Allow 16-bit init to be in TPLSimon Glass
At present we support having 16-bit init be in SPL or U-Boot proper, but not TPL. Add support for this so that TPL can boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: Add support for starting from SPL/TPLSimon Glass
When a previous phase of U-Boot has run we need to adjust the init of subsequent states to avoid messing up the CPU state. Add a new version of the start logic for SPL, when it boots from TPL (start_from tpl.c) and a new version for U-Boot when it boots from SPL. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Split CPU initSimon Glass
Split the CPU init into two parts - the 'full' init which happens in the first U-Boot phase, and the rest of the init that happens on subsequent stages. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Move init of debug UART to cpu.cSimon Glass
At present the debug UART is set up in sdram.c which is not the best place since it has nothing in particular to do with SDRAM. Since we want to support initing this in SPL too, move it to a common file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: added 'broadwell' tag in the commit title] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Allow SDRAM init from SPLSimon Glass
At present, for broadwell, SDRAM is always set up in U-Boot proper since the 64-bit mode (which uses SDRAM init in SPL) is not supported. Update the code to allow SDRAM init in SPL instead so that U-Boot proper can be loaded into SDRAM and run from there. This allows U-Boot to be compressed to reduce space, since it is not necessary to run it directly from flash. It could later allow us to support 64-bit U-Boot on broadwell. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: broadwell: Improve SDRAM debugging outputSimon Glass
Add debugging during SDRAM init so that problems are easier to diagnose. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: Add a way to reinit the cpuSimon Glass
We cannot init the CPU fully both than once during a boot. Add a new function which can be called to figure out the CPU identity, but which does not change anything. For x86_64, this is empty for now. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: mp_init: Use proper error numbersSimon Glass
At present many of the functions in this file return -1 as an error number. which is -EPERM. Update the code to use real error numbers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: Update a stale comment about ifdtoolSimon Glass
We use binman to build the x86 image now. Update a comment which still refers to ifdtool. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-08x86: start64: Fix copyright messageSimon Glass
There is a typo in this header. Fix it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: broadwell: Add support for serial I/O devicesSimon Glass
Add support for initing the I2C device and ADSP on broadwell. These are needed for sound to work. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: broadwell: Don't bother probing the PCH for pinctrlSimon Glass
At present the pinctrl probes the PCH but since it only uses it to obtain a PCI address, this is no necessary. Avoiding this fixes one of the two co-dependent loops in broadwell. This driver really should be a proper pinctrl driver, but for now it remains a syscon device. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: broadwell: Add support for the ADSPSimon Glass
The Application Digital Signal Processor is used for sound processing with broadwell. Add a driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20sound: x86: link: Add sound supportSimon Glass
Add sound support for link, using the HDA codec implementation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-20x86: ivybridge: Add a way to get the HDA config settingSimon Glass
Add a way check to whether HD audio is enabled. Use ioctl() to avoid adding too many unusual operations to PCH. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-02-12x86: Use the existing GDT in the ROM for 64-bit U-Boot properBin Meng
It is unnecessary to use a RAM version GDT for 64-bit U-Boot proper. In fact we can just use the ROM version directly, which not only eliminates the risk of being overwritten by application, but also removes the complexity of patching the cpu_call64(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-12x86: Don't copy the cpu_call64() function to a hardcoded addressBin Meng
Before jumping to 64-bit U-Boot proper, SPL copies the cpu_call64() function to a hardcoded address 0x3000000. This can have potential conflicts with application usage. Switch the destination address to be allocated from the heap to avoid such risk. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-12x86: Change 4-level page table base address to low memoryBin Meng
At present the 4-level page table base address for 64-bit U-Boot proper is assigned an address that conflicts with CONFIG_LOADADDR. Change it to an address within the low memory range instead. Fixes crashes seen when 'dhcp' on QEMU x86_64 with "-net nic -net user,tftp=.,bootfile=u-boot". Reported-by: Alexander Graf <agraf@suse.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-26linker: Modify linker scripts to be more genericTom Rini
Make use of "IMAGE_MAX_SIZE" and "IMAGE_TEXT_BASE" rather than CONFIG_SPL_MAX_SIZE and CONFIG_SPL_TEXT_BASE. This lets us re-use the same script for both SPL and TPL. Add logic to scripts/Makefile.spl to pass in the right value when preprocessing the script. Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Jagan Teki <jagan@openedev.com> Cc: Maxime Ripard <maxime.ripard@bootlin.com> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: York Sun <york.sun@nxp.com> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Tested-by: Adam Ford <aford173@gmail.com> #da850evm & omap3_logic_somlv Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-01-18x86: Kconfig: spelling fixesChris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-12-10efi: payload: only init usb if necessaryBin Meng
Up until now the call to initialize the USB subsystem was hardcoded for U-Boot running as an EFI payload. This was used to enable the use of a USB keyboard in the U-Boot shell. However not all boards might need this functionality. As initializing the USB subsystem can take a considerable amount of time (several seconds on some boards), we now initialize the USB subsystem only if U-Boot is configured to use USB keyboards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-12-10coreboot: only init usb if necessaryThomas RIENOESSL
Up until now the call to initialize the USB subsystem was hardcoded for U-Boot running as a coreboot payload. This was used to enable the use of a USB keyboard in the U-Boot shell. However not all boards might need this functionality. As initializing the USB subsystem can take a considerable amount of time (several seconds on some boards), we now initialize the USB subsystem only if U-Boot is configured to use USB keyboards. Signed-off-by: Thomas RIENOESSL <thomas.rienoessl@bachmann.info> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-12-10x86: make the LAPIC / IOAPIC construct switchable with KconfigHannes Schmelzer
There are still systems running which do not have any LAPIC or even IOAPIC. Responsible MSRs for those do not exist and the systems are crashing on trying to setup LAPIC. This commit makes the APIC stuff able to switch off for those boards which dont' have an LAPIC / IOAPIC. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-11-14cpu: Add DM_FLAG_PRE_RELOC flag to various cpu driversBin Meng
It turns out commit c0434407b595 broke some boards which have DM CPU driver with CONFIG_DISPLAY_CPUINFO option on. These boards just fail to boot when print_cpuinfo() is called during boot. Fixes: c0434407b595 ("board_f: Use static print_cpuinfo if CONFIG_CPU is active") Reported-by: Stefan Roese <sr@denx.de> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2018-11-14sysreset: Remove DM_FLAG_PRE_RELOC flag in various driversBin Meng
When a driver declares DM_FLAG_PRE_RELOC flag, it wishes to be bound before relocation. However due to a bug in the DM core, the flag only takes effect when devices are statically declared via U_BOOT_DEVICE(). This bug has been fixed recently by commit "dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt()", but with the fix, it has a side effect that all existing drivers that declared DM_FLAG_PRE_RELOC flag will be bound before relocation now. This may expose potential boot failure on some boards due to insufficient memory during the pre-relocation stage. To mitigate this potential impact, the following changes are implemented: - Remove DM_FLAG_PRE_RELOC flag in the driver, if the driver only supports configuration from device tree (OF_CONTROL) - Keep DM_FLAG_PRE_RELOC flag in the driver only if the device is statically declared via U_BOOT_DEVICE() - Surround DM_FLAG_PRE_RELOC flag with OF_CONTROL check, for drivers that support both statically declared devices and configuration from device tree Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-28x86: Fix car_uninit weak symbol definitionBin Meng
Since commit 80df194f0165 ("x86: detect unsupported relocation types"), an error message is seen on QEMU x86 target during boot: do_elf_reloc_fixups32: unsupported relocation type 0x1 at fff841f0, offset = 0xfff00087 do_elf_reloc_fixups32: unsupported relocation type 0x2 at fff841f8, offset = 0xfff00091 Check offset 0xfff00087 and 0xfff00091 in the u-boot ELF image, fff00087 000df401 R_386_32 00000000 car_uninit fff00091 000df402 R_386_PC32 00000000 car_uninit we see R_386_32 and R_386_PC32 relocation type is generated for symbol car_uninit, which is declared as a weak symbol in start.S. However the actual weak symbol implementation ends up nowhere. As we can see below, it's *UND*. $ objdump -t u-boot | grep car_uninit 00000000 w *UND* 00000000 car_uninit With this fix, it is normal now. $ objdump -t u-boot | grep car_uninit fff00094 w F .text.start 00000001 car_uninit Reported-by: Hannes Schmelzer <hannes@schmelzer.or.at> Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2018-10-22x86: quark: Specify X86_TSC_TIMER_EARLY_FREQBin Meng
Specify X86_TSC_TIMER_EARLY_FREQ for Quark SoC so that TSC as the early timer can be supported. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-22x86: Fix the mystery of printch() during 64-bit bootBin Meng
At present in arch_setup_gd() it calls printch(' ') at the end which has been a mystery for a long time as without such call the 64-bit U-Boot just does not boot at all. In fact this is due to the bug that board_init_f() was called with boot_flags not being set. Hence whatever value being there in the rdi register becomes the boot_flags if without such magic call. With a printch(' ') call the rdi register is initialized as 0x20 and this value seems to be sane enough for the whole boot process. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2018-10-22x86: put global data pointer into the .data sectionHeinrich Schuchardt
On x86_64 the field global_data_ptr is assigned before relocation. As sections for uninitialized global data (.bss) overlap with the relocation sections (.rela) this destroys the relocation table and leads to spurious errors. Initialization forces the global_data_ptr into a section for initialized global data (.data) which cannot overlap any .rela section. Fixes: a160092a610f ("x86: Support global_data on x86_64") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-09x86: Update mtrr functions to allow leaving cache aloneSimon Glass
At present the mtrr functions disable the cache before making changes and enable it again afterwards. This is fine in U-Boot, but does not work if running in CAR (such as we are in SPL). Update the functions so that the caller can request that caches be left alone. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-09-17x86: tangier: pinmux: add API to configure protected pinsGeorgii Staroselskii
This API is going to be used to configure some pins that are protected for simple modification. It's not a comprehensive pinctrl driver but can be turned into one when we need this in the future. Now it is planned to be used only in one place. So that's why I decided not to pollute the codebase with a full-blown pinctrl-merrifield nobody will use. This driver reads corresponding fields in DT and configures pins accordingly. The "protected" flag is used to distinguish configuration of SCU-owned pins from the ordinary ones. The code has been adapted from Linux work done by Andy Shevchenko in pinctrl-merrfifield.c Signed-off-by: Georgii Staroselskii <georgii.staroselskii@emlid.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> [bmeng: fix build warning] Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2018-08-30x86: zimage: Support booting Linux kernel from an EFI payloadBin Meng
At present Linux kernel loaded from U-Boot as an EFI payload does not boot. This fills in kernel's boot params structure with the required critical EFI information like system table address and memory map stuff so that kernel can obtain essential data like runtime services and ACPI table to boot. With this patch, now U-Boot as an EFI payload becomes much more practical: it is another option of kernel bootloader, ie, can be a replacement for grub. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-30x86: efi: payload: Install E820 map from EFI memory mapBin Meng
This implements payload-specific install_e820_map() to get E820 map from the EFI memory map descriptors. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-21Merge tag 'signed-efi-2018.09' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-08-21 A few fixes for 2018.09. Most noticable are: - unbreak x86 target (-fdata-section fallout) - fix undefined behavior in a few corner cases - make Jetson TX1 boot again - RTS fixes - implement reset for simple output
2018-08-20x86: Include bss subsections in linker scriptAlexander Graf
When we build with -fdata-sections we may end up with bss subsections. Our linker script explicitly lists only a single consecutive bss section though. Adapt the statement to also include subsections. This fixes booting efi-x86_app_defconfig. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-08-20x86: coreboot: Add generic coreboot payload supportBin Meng
Currently building U-Boot as the coreboot payload requires user to change the build configuration for a specific board during menuconfig process. This uses the board's native device tree to configure the hardware. For example, the device tree provides PCI address range for the PCI host controller and U-Boot will re-program all PCI devices' BAR to be within this range. In order to make sure we don't mess up the hardware, we should guarantee the range matches what coreboot programs the chipset. But we really should make the coreboot payload support easier. Just like EFI payload, we can create a generic coreboot payload for all x86 boards as well. The payload is configured to include as many generic drivers as possible. All stuff that touches low level initialization are not allowed as such is the coreboot's responsibility. Platform specific drivers (like gpio, spi, etc) are not included. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2018-07-25x86: Add efi_loader bits to x86_64 linker scriptAlexander Graf
The x86_64 linker script was missing efi runtime information. Add it. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-25efi_loader: Rename sections to allow for implicit dataAlexander Graf
Some times gcc may generate data that is then used within code that may be part of an efi runtime section. That data could be jump tables, constants or strings. In order to make sure we catch these, we need to ensure that gcc emits them into a section that we can relocate together with all the other efi runtime bits. This only works if the -ffunction-sections and -fdata-sections flags are passed and the efi runtime functions are in a section that starts with ".text". Up to now we had all efi runtime bits in sections that did not interfere with the normal section naming scheme, but this forces us to do so. Hence we need to move the efi_loader text/data/rodata sections before the global *(.text*) catch-all section. With this patch in place, we should hopefully have an easier time to extend the efi runtime functionality in the future. Signed-off-by: Alexander Graf <agraf@suse.de> [agraf: Fix x86_64 breakage]
2018-07-20x86: acpi: Don't touch ACPI hardware in write_acpi_tables()Bin Meng
write_acpi_tables() currently touches ACPI hardware to switch to ACPI mode at the end. Move such operation out of this function, so that it only does what the function name tells us. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
