path: root/arch/x86/cpu
2016-10-19Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2016-10-19 Highlights this time around: - Add run time service (power control) support for PSCI (fixed in v3) - Add efi gop pointer exposure - SMBIOS support for EFI (on ARM) - efi pool memory unmap support (needed for 4.8) - initial x86 efi payload support (fixed up in v2) - various bug fixes Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: include/tables_csum.h
2016-10-19x86: efi: Add EFI loader support for x86Simon Glass
Add the required pieces to support the EFI loader on x86. Since U-Boot only builds for 32-bit on x86, only a 32-bit EFI application is supported. If a 64-bit kernel must be booted, U-Boot supports this directly using FIT (see doc/uImage.FIT/kernel.its). U-Boot can act as a payload for both 32-bit and 64-bit EFI. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-10-19cpu: Add get_vendor callbackAlexander Graf
The CPU udevice already has a few callbacks to retreive information about the currently running CPUs. This patch adds a new get_vendor() call that returns the vendor of the main CPUs. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-19cpu: Add DMTF id and family fieldsAlexander Graf
For SMBIOS tables we need to know the CPU family as well as CPU IDs. This patches allocates some space for them in the cpu device and populates it on x86. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-18x86: Add implementations of setjmp() and longjmp()Simon Glass
Bring in these functions from Linux v4.4. They will be needed for EFI loader support. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-10-12x86: coreboot: Convert to use DM coreboot video driverBin Meng
This converts coreboot to use DM framebuffer driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-11x86: ivybridge: Tidy up enable_clock_gating() for 64-bitSimon Glass
Fix the hex case and remove unused brackets. Use ~0U instead of ~0UL to allow compilation on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11x86: ivybridge: Fix PCH power setupSimon Glass
At present pch_power_options() has the arguments to writel() around the wrong way. Fix this and update it to compile on 64-bit machines. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11x86: Correct address casts in interrupt codeSimon Glass
We should cast an address to unsigned long, not u32. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11x86: Correct address casts in cpu codeSimon Glass
2016-10-11x86: Allow interrupts to be disabled in 64-bit modeSimon Glass
Update the code to support both 32-bit and 64-bit modes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11dm: x86: Move link to use driver model for videoSimon Glass
Update the configuration to use the new driver. Drop the existing plumbing code and unused header files. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11dm: x86: Move samus to use new driver model supportSimon Glass
Update the samus driver to avoid the direct call to the video BIOS setup. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-10-11x86: baytrail: Add 2nd eMMC controller to the PCI probe listStefan Roese
With this addition, the eMMC device available on the congatec and DFI BayTrail SoM is detected correctly. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-09-23x86: squash lines for immediate returnMasahiro Yamada
arch_cpu_init() can be simpler by this refactoring. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-30x86: Add debugging when cpu_common_init() failsSimon Glass
Add a debug() at this point to help figure out what is wrong. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-30x86: ivybridge: Allow microcode to be collatedSimon Glass
Generally the microcode is combined into a single block only (and removed from the device tree) when there are multiple blocks. But this is not a requirement. Adjust the ivybridge code to avoid assuming this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-30x86: Add debugging when a microcode update failsSimon Glass
Add a debug() at this point to help figure out what is wrong. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Heiko Schocher<hs@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-08-16x86: baytrail: Add SIO HS-UART clock setupStefan Roese
To support the BayTrail internal SIO HS UART, the internal UART clock needs to get configured. This patch adds support for this clock configuration which will be done, if the PCI device(s) are found. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-12Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2016-07-12x86: link: Correct a failure in DRAM initSimon Glass
With the change to set up pinctrl after relocation, link fails to boot. Add a special case in the link code to handle this. Fixes: d8906c1f (x86: Probe pinctrl driver in cpu_init_r()) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-07-12x86: quark: Introduce ACPI global NVSBin Meng
This introduces quark-specific ACPI global NVS structure, defined in both C header file and ASL file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-12x86: baytrail: Introduce ACPI global NVSBin Meng
This introduces baytrail-specific ACPI global NVS structure, defined in both C header file and ASL file. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-12x86: baytrail: Introduce a Kconfig option for the internal UARTBin Meng
There are quite a number of BayTrail boards that uses an external SuperIO chipset to provide the legacy UART. For such cases, it's better to have a Kconfig option to enable the internal UART. So far BayleyBay and MinnowMax boards are using internal UART as the U-Boot console, enable this on these two boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-11x86: fdt: Drop the unused compatible strings in fdtdecSimon Glass
We have drivers for several more devices now, so drop the strings which are no-longer used. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-06-29x86: coreboot: Remove the dummy pch driverBin Meng
There is a dummy pch driver in the coreboot directory. This causes drivers of its children fail to function due to empty ops. Remove the whole file since it is no longer needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-06-12x86: Probe pinctrl driver in cpu_init_r()Bin Meng
At present pinctrl driver gets probed in ich6_gpio driver's probe routine, which has two issues: - Pin's PADs only gets configured when GPIO driver is probed, which is not done by default. This leaves the board in a partially functional state as we must initialize PADs correctly to get perepherals fully working. - The probe routine of pinctrl driver is called multiple times, as normally there are multiple GPIO controllers. It should really be called just once. Move the call to syscon_get_by_driver_data() from ich6_gpio driver to cpu_init_r(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2016-05-30x86: baytrail: acpi: Fix I/O APIC ID in the MADT tableBin Meng
So far this is hardcoded to 2, but it should really be read from the I/O APIC register. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-30x86: quark: Generate ACPI FADT/MADT tablesBin Meng
Generate quark platform-specific FADT/MADT tables. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: broadwell: Correct I/O APIC IDBin Meng
Currently ID 2 is assgined to broadwell I/O APIC, however per chromebook_samus.dts 2 is the core#2 LAPIC ID. Now we change I/O APIC ID to 4 to avoid conflict. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: quark: Assign a unique I/O APIC IDBin Meng
After power-on, both LAPIC and I/O APIC appear with the same APIC ID zero, which creates an ID conflict. When generating MP table, U-Boot reports zero as the LAPIC ID in the processor entry, and zero as the I/O APIC ID in the I/O APIC as well as the I/O interrupt assignment entries. Such MP table confuses Linux kernel and finally a kernel panic is seen during boot: BUG: unable to handle kernel paging request at ffff9000 IP: [<c101d462>] native_io_apic_write+0x22/0x30 *pdpt = 00000000014fb001 *pde = 00000000014ff067 *pte = 0000000000000000 Oops: 0002 [#1] Modules linked in: Pid: 1, comm: swapper Tainted: G W 3.8.7 #3 intel galileo/galileo EIP: 0060:[<c101d462>] EFLAGS: 00010086 CPU: 0 EIP is at native_io_apic_write+0x22/0x30 ... Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009 Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Call lapic_setup() in interrupt_init()Bin Meng
Let's configure LAPIC in a common place - interrupt_init(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Remove SMP limitation in lapic_setup()Bin Meng
At present LAPIC is enabled and configured as virtual wire mode in lapic_setup() only when CONFIG_SMP is on. This limitation is however not necessary as for uniprocessor this is still needed. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Don't touch IA32_APIC_BASE MSR on Intel QuarkBin Meng
Intel Quark processor core provides an integrated Local APIC but does not support the IA32_APIC_BASE MSR. As a result, the Local APIC is always globally enabled and the Local APIC base address is fixed at 0xfee00000. Attempting to access the IA32_APIC_BASE MSR causes a general protection fault. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Reserve configuration tables in high memoryBin Meng
When SeaBIOS is on, reserve configuration tables in reserve_arch(). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Unify reserve_arch() for all x86 boardsBin Meng
Instead of asking each platform to provide reserve_arch(), supply it in arch/x86/cpu/cpu.c in a unified way. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Fix up PIRQ routing table checksum earlierBin Meng
PIRQ routing table checksum is fixed up in copy_pirq_routing_table(), which is fine if we only write the configuration table once. But with the SeaBIOS case, when we write the table for the second time, the checksum will be fixed up to zero per the checksum algorithm, which is caused by the checksum field not being zero before fix up, since the checksum has already been calculated in the first run. To fix this, move the checksum fixup to create_pirq_routing_table(), so that copy_pirq_routing_table() only does what its function name suggests: copy the table to somewhere else. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: Call board_final_cleanup() in last_stage_init()Bin Meng
At present board_final_cleanup() is called before booting a Linux kernel. This actually needs to be done before booting anything, like SeaBIOS, VxWorks or Windows. Move the call to last_stage_init() instead. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: qemu: rename qemu/acpi_table.cMiao Yan
Rename qemu/acpi_table.c to qemu/e820.c, because ACPI stuff is moved to qfw core, this file only contains code for installing e820 table. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23cmd: qfw: bring ACPI generation code into qfw coreMiao Yan
Loading ACPI table from QEMU's fw_cfg interface is not x86 specific (ARM64 may also make use of it). So move the code to common place. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23cmd: qfw: rename qemu_fw_cfg.[c|h] to qfw.[c|h]Miao Yan
Make file names consistent with CONFIG_QFW and CONFIG_CMD_QFW Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: add comment about qfw register endiannessMiao Yan
This patch adds some comments about qfw register endianness for clarity. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: move x86 specific operations out of qfw coreMiao Yan
The original implementation of qfw includes several x86 specific operations, like directly calling outb/inb and using some inline assembly code which prevents it being ported to other architectures. This patch adds callback functions and moves those to arch/x86/ Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: split qfw command interface and qfw coreMiao Yan
This patch splits qfw command interface and qfw core function into two files, and introduces a new Kconfig option (CONFIG_QFW) for qfw core. Now when qfw command interface is enabled, it will automatically select qfw core. This patch also makes the ACPI table generation select CONFIG_QFW. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23cmd: qfw: remove qemu_fwcfg_free_files()Miao Yan
This patch is part of the qfw refactor work. The qemu_fwcfg_free_files() function is only used in error handling in ACPI table generation, let's not make this a core function and move it to the right place. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: fix ACPI Kconfig optionsMiao Yan
CONFIG_GENENRATE_ACPI_TABLE controls the generation of ACPI table which uses U-Boot's built-in methods and CONFIG_QEMU_ACPI_TABLE controls whether to load ACPI table from QEMU's fw_cfg interface. But with commit "697ec431469ce0a4c2fc2c02d8685d907491af84 x86: qemu: Drop our own ACPI implementation", there is only one way to support ACPI table for QEMU targets which is the fw_cfg interface. Having two Kconfig options for this purpose is not necessary any more, so this patch consolidates the two. Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: Move qfw command over to cmd and add Kconfig entryTom Rini
- Move the command portion of arch/x86/cpu/qemu/fw_cfg.c into cmd/qemu_fw_cfg.c - Move arch/x86/include/asm/fw_cfg.h to include/qemu_fw_cfg.h - Rename ACPI table portion to arch/x86/cpu/qemu/acpi_table.c Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: baytrail: Generate ACPI FADT/MADT tablesBin Meng
FADT/MADT tables are platform specific. Generate them for BayTrail. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23x86: irq: Enable SCI on IRQ9Bin Meng
By default SCI is disabled after power on. ACTL is the register to enable SCI and route it to PIC/APIC. To support both ACPI in PIC mode and APIC mode, configure SCI to use IRQ9. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
