path: root/arch/x86/cpu/ivybridge/Kconfig
2019-02-20sound: x86: link: Add sound supportSimon Glass
Add sound support for link, using the HDA codec implementation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-06-13x86: Conditionally build the pinctrl_ich6 driverBin Meng
The pinctrl_ich6 driver is currently unconditionally built for all x86 boards. Let's use a Kconfig option to control the build. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-06-13x86: ivybridge: Imply USB_XHCI_HCDBin Meng
The Panther Point chipset connected to Ivybridge has xHC integrated, imply it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-01x86: Switch all boards to use DM SCSIBin Meng
After MMC is converted to DM, convert to use DM SCSI as well for all x86 boards and imply BLK for both MMC and SCSI drivers. CONFIG_SCSI_DEV_LIST is no longer used. Clean them up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: Convert INTEL_ICH6_GPIO to KconfigBin Meng
This converts Intel ICH6 GPIO driver to Kconfig, and add it to the imply list of platform drivers. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Move USB to platform KconfigBin Meng
Like other peripheral drivers, move USB related drivers to platform Kconfig as well. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: ivybridge: kconfig: Imply platform specific driversBin Meng
Imply drivers that are working with Ivybridge platform in the platform Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply ENABLE_MRC_CACHE in the platform KconfigBin Meng
Platform knows whether MRC cache is implemented, but using it can be a choice of a specific board. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-01x86: kconfig: Imply HAVE_INTEL_ME in the platform KconfigBin Meng
Intel Management Engine is required by the platform, however it's not a must have when building a U-Boot image. For example, during development normally programming ME firmware is a one-time effort. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-17x86: Move common MRC Kconfig options to the common fileSimon Glass
At present the MRC options are private to ivybridge. Other Intel CPUs also use these settings. Move them to a common place. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-21x86: Add Intel Cougar Canyon 2 boardBin Meng
This adds basic support to Intel Cougar Canyon 2 board, a board based on Chief River platform with an Ivy Bridge processor and a Panther Point chipset. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-21x86: ivybridge: Add FSP supportBin Meng
IvyBridge FSP package is built with a base address at 0xfff80000, and does not use UPD data region. This adds basic FSP support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested on link (ivybridge non-FSP) Tested-by: Simon Glass <sjg@chromium.org>
2016-01-13x86: ivybridge: Do not require HAVE_INTEL_MEBin Meng
Do not set HAVE_INTEL_ME by default as for some cases Intel ME firmware even does not reside on the same SPI flash as U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-12-09x86: Remove CPU_INTEL_SOCKET_RPGA989Bin Meng
This Kconfig option name indicates it has something to do with cpu socket, however it is actually not the case. Remove it and move options inside it to NORTHBRIDGE_INTEL_IVYBRIDGE. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-12-09x86: Clean up ivybridge/chrome Kconfig optionsBin Meng
There are some options which are never used, and also some options which are selected by others but have never been a Kconfg option. Clean these up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-12-09x86: ivybridge: Remove NORTHBRIDGE_INTEL_SANDYBRIDGEBin Meng
NORTHBRIDGE_INTEL_SANDYBRIDGE is for sandybridge, not ivybridge. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-07-14x86: ivybridge: Remove SMP from CPU_SPECIFIC_OPTIONSBin Meng
Ivybridge is not ready for U-Boot MP initialization yet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-01-24x86: ivybridge: Drop the Kconfig MRC cache informationSimon Glass
This is now stored in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: ivybridge: Implement SDRAM initSimon Glass
Implement SDRAM init using the Memory Reference Code (mrc.bin) provided in the board directory and the SDRAM SPD information in the device tree. This also needs the Intel Management Engine (me.bin) to work. Binary blobs everywhere: so far we have MRC, ME and microcode. SDRAM init works by setting up various parameters and calling the MRC. This in turn does some sort of magic to work out how much memory there is and the timing parameters to use. It also sets up the DRAM controllers. When the MRC returns, we use the information it provides to map out the available memory in U-Boot. U-Boot normally moves itself to the top of RAM. On x86 the RAM is not generally contiguous, and anyway some RAM may be above 4GB which doesn't work in 32-bit mode. So we relocate to the top of the largest block of RAM we can find below 4GB. Memory above 4GB is accessible with special functions (see physmem). It would be possible to build U-Boot in 64-bit mode but this wouldn't necessarily provide any more memory, since the largest block is often below 4GB. Anyway U-Boot doesn't need huge amounts of memory - even a very large ramdisk seldom exceeds 100-200MB. U-Boot has support for booting 64-bit kernels directly so this does not pose a limitation in that area. Also there are probably parts of U-Boot that will not work correctly in 64-bit mode. The MRC is one. There is some work remaining in this area. Since memory init is very slow (over 500ms) it is possible to save the parameters in SPI flash to speed it up next time. Suspend/resume support is not fully implemented, or at least it is not efficient. With this patch, link boots to a prompt. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Add chromebook_link boardSimon Glass
This board is a 'bare' version of the existing 'link 'board. It does not require coreboot to run, but is intended to start directly from the reset vector. This initial commit has place holders for a wide range of features. These will be added in follow-on patches and series. So far it cannot be booted as there is no ROM image produced, but it does build without errors. Signed-off-by: Simon Glass <sjg@chromium.org>
